layout 发表于 2022-2-23 14:18
川土微chipanalog CA-RF1625X 射频 PCB
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMED1WHITE-GREEN_0603_LED0603_LTST-CLTST-C190KRKTLED0603H1TESTPIN_3_TH158D80_TESTPINTESTPINTH158D80H2TESTPIN_3_TH158D80_TESTPINTESTPINTH158D80H3TESTPIN_3_TH158D80_TESTPINTESTPINTH158D80H4TESTPIN_3_TH158D80_TESTPINTESTPINTH158D80J1SMA_SMAPIANJIAO_SMA_SMDSMA_SMDSMAPIANJIAOJ3SMA_SMAPIANJIAO_SMA_SMDSMA_SMDSMAPIANJIAOJ5SMA_SMAPIANJIAO_SMA_SMDSMA_SMDSMAPIANJIAOJ6SMA_SMAPIANJIAO_SMA_SMDSMA_SMDSMAPIANJIAOJ7SMA_SMAPIANJIAO_SMA_SMDSMA_SMDSMAPIANJIAOJ9DIP_2_2.54MM_H1X2_7D62MM_DIP_2_DIP_2_10MMH1X2_7D62MMJ10SMA_SMAPIANJIAO_SMA_SMDSMA_SMDSMAPIANJIAOK16*6KEY_6X6_KEY_6*66*66X6_KEYL1CERAMIC_SMD_IND0402_L0402_1.5NH1.5nHL0402L2CERAMIC_SMD_IND0402_L0402_15NH15nHL0402L3CERAMIC_SMD_IND0402_L0402_82NH82nHL0402L8CERAMIC_SMD_IND0402_L0402_180NH180nHL0402L9CERAMIC_SMD_IND0402_L0402_180NH180nHL0402LB9COMM_SMD_BEAD0402_L0805_330R330RL0805PL12.2UH-30%-4A_IND3X3_1D1_2.2UH2.2uHIND3X3_1D1S1SPI_CON10NEW_SPISpiCON10NEWT1TCXO_0_X4S32X25_TCXO_10MHZTCXO_10MHzX4S32X25T2CON2_CON2_CON2CON2CON2T3CON2_CON2_CON2CON2CON2T4CON2_CON2_CON2CON2CON2T6CON3_CON3_CON3CON3CON3U2LP38690SD-3_0.3_PWR6_0D95_3G_LPLP38690SD-3_3PWR6_0D95_3GU4LT3042_2_SO8_0D65_3_LT1762LT1762SO8_0D65_3U5SAW_3X3_QFNS6_1D1_1D25_NDF9200NDF9200QFNS6_1D1_1D25U6TPS62240DRVT_1_QFNS6_0D65_0D75GTPS62240DRVTQFNS6_0D65_0D75GBU7SAW_3X3_QFNS6_1D1_1D25_NDF9219NDF9219QFNS6_1D1_1D25U8CARF1625X_CA_RF1625X_CARF1625XCARF1625XCA_RF1625X
layout 发表于 2022-2-23 14:19
PCB文件。回复可见
**** Hidden Message *****
罗塘阮经天 发表于 2022-2-23 21:36
a6682100 发表于 2022-2-23 21:37
bidezhi7777 发表于 2022-2-24 00:54
aokema124 发表于 2022-2-24 14:50
804890538 发表于 2022-2-24 15:15
清心如水 发表于 2022-3-6 08:12
ilovepcb 发表于 2022-3-6 08:23
i_333333 发表于 2022-3-6 08:29
非常感谢楼主大神分享
页: [1] 2 3 4 5 6
查看完整版本: 川土微chipanalog CA-RF1625X 射频 PCB
