yfchen1003 发表于 2022-3-10 08:20
S905Y4/W2_DDR4X4 BOX
S905Y4/W2_DDR4X4 BOX芯片A35
Item
IndexValueDecalQTYNameChips11S905Y4_20201210BGA315_0P65_S41U1Diodes62IR_LED_5MM_GREENLED/5_90B6LED1,LED7,LED8,LED9,LED11,LED13Connectors1936.5X0.8X1.28MMPAD_JACK_(6.5X0.8X1.28)18J6,J8,J10,J11,J14,J16,J17,J19,J20,J21,J22,J23,J24,J26,J27,J29,J32,J344NCJACK_SHIELD_56.5X36MM1J36Switchs15NC/SW_SLIDESK-12D07G51SW1Unkowns68860.1UFC040223C50,8C3970.1UF_16VC0402131C12,1C14,1C15,1C17,1C20,1C23,1C24,1C28,1C32,1C35,1C38,1C39,1C4480.1UF_6.3VC020192C8,2C12,2C24,3C10,3C27,4C46,5C17,7C35,9C190.1UF_6.3VC0402661C30,1C45,1C46,1C47,2C5,3C11,3C18,3C20,3C21,3C22,3C23,3C24,3C26,3C28,3C29,3C33,3C34,3C36,3C37,3C45,3C46,3C47,3C48,3C49,3C52,3C53,3C55,3C58,3C59,3C60,3C61,3C62,3C63,3C65,3C66,3C67,3C70,3C71,3C73,4C37,4C38,4C39,4C40,5C1,5C3,5C4,5C5,6C2,6C7,6C13,6C15,6C17,6C22,6C31,6C33,6C34,6C37,6C38,6C40,7C28,7C33,8C19,8C40,9C5,9C6,9C10100RR0402232R29,3R19,4R1,4R5,4R49,4R59,6R23,6R32,6R44,6R46,6R47,7R2,7R3,7R10,7R11,7R21,7R31,7R32,7R33,7R34,8R17,8R18,9R8110RR060317R16121.2PFC040217C2131.3K_1%R040219R4141.8UHL060318L4151000R_200MAL040219FB116100KR040232R36,9R1,9R2117100K_1%R040231R18,1R19,1R2518100PFC040242C18,2C39,8C43,8C4419100RR040272R6,6R43,7R13,8R6,9R3,9R12,9R1420100R_300MAFB040219FB22110KR0402171R20,1R29,2R8,2R9,2R12,4R30,5R3,5R5,5R6,6R4,6R20,6R39,6R55,7R14,7R18,8R53,9R22210K_1%R040221R17,6R272310NFC040211C82410PFC040237C3,7C12,7C272510UF_16VC0805101C3,1C5,1C33,1C34,1C36,1C37,1C40,6C12,6C14,6C262610UF_6.3VC0603131C27,3C25,3C30,3C31,3C32,3C39,3C54,3C56,6C23,7C5,7C34,8C41,9C1127120K_1%R040221R5,9R2028137K_1%R040211R232915.8K_1%R040228R56,8R5930160K_1%R040211R13116K_1%R040211R43218.2K_1%R040211R123318PFC040222C3,2C9341KR040251R13,2R4,2R28,6R52,8R62351MR060316R54361NFC0402171C1,1C4,1C43,1C49,1C50,1C51,1C52,2C21,2C25,2C28,3C72,6C5,6C16,6C41,8C49,8C50,9C8371NF_2KVC120616C11381UF_6.3VC020162C2,2C11,2C20,2C23,3C2,3C6391UF_6.3VC0402213C1,3C3,3C12,3C17,3C41,3C51,3C57,3C64,3C68,3C69,3C74,4C3,6C1,6C4,6C18,6C24,6C25,8C48,8C54,9C3,9C16402.2PFC040213C147412.2RR040226R19,6R69422.2UF_6.3VC040228C46,8C52432.2UH_3A_DCR<=30MOHML505021L1,1L54420K_1%R040211R164522.1K_1%R040211R2446220UF_10VSMD_DL6.3X7.716C354722RR040272R10,6R26,6R28,6R30,6R49,6R50,8R504822UF_6.3VC080531C13,1C22,1C2649240R_1%R020113R150240R_1%R040282R1,2R16,3R2,3R7,3R9,3R14,6R62,6R635124MHZ_CL12PF_20PPMXT-SMD4P322512Y25227K_1%R040219R75327PFC040261C9,1C16,1C21,1C29,1C42,8C42542KR040246R65,6R66,9R6,9R13552K_1%R040283R3,3R4,3R5,3R8,3R10,3R11,3R12,3R1356300K_1%R040211R355730K_1%R040211R105833K_1%R040212R27594.7KR040251R3,4R18,6R6,6R51,8R52604.7K_1%R040252R20,2R21,2R24,2R30,2R31614.7UF_6.3VC040252C6,2C7,2C13,2C16,3C19624.7UF_6.3VC0603111C2,1C6,1C7,1C11,2C40,3C4,3C7,4C42,5C2,9C12,9C13634.7UH_3A_DCR<=70MOHML505031L2,1L3,1L46447KR040234R7,5R2,6R41654X0RRN040217RN1664X3.3RRN040229RN2,9RN3675.1RR040292R25,6R2,6R3,6R15,6R16,6R17,6R18,6R48,6R70685.6K_1%R040216R3369510RR040258R3,8R4,8R8,8R55,8R607051K_1%R040211R227156KR040211R27256RR060332R13,2R17,2R497366.5K_1%R040228R54,8R617475RR080546R21,6R22,6R60,6R617575R_1%R040219R32768.2KR040212R157791KR040212R378A2501WV-4PCON_4P_2.0MM_V112CON179AZ1043-04FDFN2510P10E29D1,9D280AZ5325-01FESD040286D7,6D8,6D9,6D10,6D11,6D12,6D13,6D1481AZ5725-01FESD0402136D1,6D2,6D3,6D4,6D5,6D6,8D3,8D5,8D6,9D3,9D4,9D5,9D782AZC199-04SSOT23-616U283CON_2X18P_2.0CON_2.0MM_2X18P15CON184DC044DCJACK_5.5MM_SEN511J585DIO2133CT14TSSOP-14-PT06518U786FT232RLSSOP28P_GL852G16U487GREENLED060318D188H1601CGTS8121C16T189HDA31-F1F1-1000-AJACK_HDMI_19P_SEN519J290IRM-3638N3IR_3PIN_SEN512U191IR_GQ_015_TOPTICAL170618J492JACK_IPEXJACK_IPEX_4P27J1,7J493KEYSW-4P-90_H(7.5MM)12K594KEYSW-TACH-CHIPIND14K195KLMAG1JETD-B041BGA169-INAND14U796MARKMARK41M5,1M6,1M7,1M897MICRO_USB_PORTMICRO_USB_5P/4DIP16J298NCACM2012-2P26L1,6L299NCC040284C225,6C32,7C4,7C11,7C13,7C22,7C30,8C20100NCR040252R35,4R3,7R4,7R6,7R19101NCTEST_R29R9,9R80102NC/0.05RR080513RT1,RT2,RT3,RT6,RT7,RT8,RT9,RT10,RT11,RT12,RT13,RT14,RT15103NC/0.1UFC040218C2104NC/0.1UF_16VC040238C8,8C12,8C37105NC/0.1UF_6.3VC0402112C15,4C7,4C12,4C15,4C17,4C18,7C7,8C4,8C22,8C25,8C31106NC/0.47UF_25VC060328C15,8C16107NC/0RR0402164R26,4R27,4R28,6R45,6R53,7R1,7R27,7R28,7R29,7R30,7R54,7R59,7R60,8R10,8R12,8R13108NC/0RR060335R1,6R40,6R56109NC/0RR080512R7110NC/100KR040242R14,6R12,6R31,8R74111NC/100PFC040223C43,3C44112NC/100UF_25VSMD_DL6.3X7.728C10,8C56113NC/10KR0402331R6,1R7,1R11,2R2,4R8,4R12,4R32,6R24,6R25,6R29,6R37,6R42,6R64,6R67,7R5,7R12,7R17,7R20,7R22,7R39,7R47,8R1,8R9,8R26,8R29,8R31,8R39,8R40,8R57,8R58,8R66,8R72,8R75114NC/10PFC040293C5,3C42,6C6,6C8,6C10,6C39,7C19,8C26,8C27115NC/10RR040218R71116NC/10UF_16VC080511C41117NC/10UF_6.3VC060328C1,8C21118NC/12PFC040227C23,7C24119NC/137K_1%R040219R16120NC/150PFC040228C47,8C51121NC/15UH_2A_DCR<=70MOHML505028L2,8L3122NC/1KR040262R11,8R2,8R30,8R33,8R49,8R67123NC/1NFC040214C1124NC/1UFC040218C3125NC/1UF_16VC040248C7,8C11,8C17,8C29126NC/1UF_6.3VC040287C1,8C5,8C6,8C13,8C14,8C32,9C7,9C9127NC/2.26K_1%R040216R11128NC/2.2UF_25VC060328C9,8C28129NC/2.2UH_1.2A_DCR110MOHML303017L2130NC/2.2UH_1.7AL303017L1131NC/220UF_25VSMD_DL6.3X7.711EC1132NC/22RR040297R15,8R5,8R7,8R24,8R25,8R28,8R32,8R34,8R45133NC/22UF_6.3VC080541C10,1C18,1C19,1C25134NC/32.768KHZ_CL15PF_10PPMXTAL_322517Y1135NC/330PFC040213C40136NC/37.4MHZY-SMD4P322517Y2137NC/4.7KR040261R8,2R26,4R2,4R4,4R6,8R63138NC/4.7K_1%R040219R18139NC/4.7UF_6.3VC060344C16,7C6,7C16,7C29140NC/470KR040222R5,7R55141NC/47KR040224R31,8R65142NC/47PFC040237C8,8C45,8C53143NC/56R_1%R060346R7,6R8,6R9,6R10144NC/6.8PFC040217C25145NC/60R_2AL080518FB1146NC/AZ5725-01FESD040222D1,2D2147NC/B5819WSOD-12319D6148NC/CON_FPC_0.5MMCON_FPC_REAR_0.5MM_14P18J1149NC/PMBT3904SOT-2318Q4150NC/RS809R/MAX809RDSOT-2312U2151NC/SDCMA21-4-900-M1TEMI-TF2010A4X29L1,9L2152NC/SGM2032-ADJSOT23-519U1153NC/SGM3157SC-7028U3,8U5154NC/SLC_NANDTSOP-4814U1155NC/SPKCON-2/2.54MM18J2156NC/TLC59116IRHBRQFN32_0P5_5X5MM18U2157NC/TPA3112D1HTSSOP_2818U1158NC/WL2803E18-5SOT23-517U2159NC/WNM2020SOT-2346Q2,6Q6,6Q7,6Q8160NC/WPM3401SOT-2318Q3161NC/XR_1204RGBLED_RGB_90_3.2X1MM58LED1,8LED2,8LED3,8LED4,8LED9162NT5AD256M16D4-HRBGA96-0P8MM_DDR443U1,3U3,3U4,3U5163PJ-320AJACK_PHONE_3.5MM_5P_SEN518J3164PMBT3904SOT-2372Q3,2Q4,2Q5,2Q6,2Q7,2Q8,6Q1165QCA6174A-3(8274B-SR)AP_WIFI2X2_13X15_L17U1166REDLED060328D2,8D4167RJ45_USB3.0_COMBINERJ45+USB3.0_SMT-27P16J4168RT9701GBSOT23-526U1,6U5169SY8113BADCSOT23-611U4170SY8120B1ABCSOT23-641U1,1U3,1U5,1U6171TDITP1253T5,3T10,5T1,5T2,5T16172TEST12TEST1294T1,4T3,4T4,4T5,4T7,4T8,4T12,4T23,4T24173TEST12TP12MIL76T2,6T3,6T4,6T5,6T6,6T7,6T8174TEST12TP_0P871TP1,1TP2,1TP3,1TP4,1TP5,1TP6,1TP7175TFWF1-EBF1-1X0XJACK_TF_CARD16J1176TUSB320RWBRX2QFN1216U3177T_POINT_R_1PAD_1X4MM1P10178T_POINT_R_1PAD_2X3.5MM5P3,P4,P5,P6,P9179USB_TYPE-CTYPE-C_USB_24P_SMD_V1.016J3180WL2803E18-5SOT23-521U2,1U7181WL2803E25-5SOT23-513U2182WNM6001SOT-2319Q2183WPM3401SOT-2315Q1
zycman 发表于 2022-3-10 08:33
谢谢分享,学习一下。
sekisan 发表于 2022-3-10 08:41
阿幸 发表于 2022-3-10 08:50
cat 发表于 2022-3-10 08:54
wangyitu 发表于 2022-3-10 08:54
学习一下ddr4的板子~
leslie_aqiang 发表于 2022-3-10 08:54
kualong05 发表于 2022-3-10 08:57
研究一下DDR4的板子
chery 发表于 2022-3-10 08:58
感谢分享
xiaoxiao 发表于 2022-3-10 08:59
页: [1] 2 3 4
查看完整版本: S905Y4/W2_DDR4X4 BOX
