老吴 发表于 2022-3-16 18:03
最新Intel 12代CPU LGA1700插槽 电脑主板PCB文件挂两条DDR4&nbs
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEATXPWR1DIP_CNTR-ATX-NOPOST_2X12ATXPWR_24PINATX-WB4202A-212S-4_2-2X12PAU1RT8800_0_QFN7_60L_0-4_RT3628AERT3628AEQFN7_60L_0-4BU1BUZZER_BUZZER1205_SAT-1205HE45SAT-1205HE45BUZZER1205CE1CE_EC6P3X11-100_220UF_16V220uF_16VEC6P3X11-100CE48CE_EC6P3X11-100_220UF_16V220uF_16VEC6P3X11-100CE49CE_EC8X12-140_470UF_16V470uF_16VEC8X12-140CON3USB2_2.0&PS2_USB2X2-14-2_00_USBUSB2.0&PS2USB2X2-14-2_00CON4BUTTONCONNECTOR_0_02002A10F5ERHW05100-2402002A10F5ER_USB_2X10_CON-20CR1DIO_ESD_1_BS3500N-C-F_2P_PESDNCPESDNC2FD5VBSBS3500N-C-F_2PD1DIODE_SOD523_RB520SM-30RB520SM-30SOD523D5IC_ESD_AZ1045_LCC10_NS_2P5X1P0_AZ1045-04FLCC10_NS_2P5X1P0_P65HD10IC_ESD_AZ1045_LCC10_NS_2P5X1P0_AZ1045-04FLCC10_NS_2P5X1P0_P65HD11IC_ESD_AZ1045_LCC10_NS_2P5X1P0_AZ1045-04FLCC10_NS_2P5X1P0_P65HD12ESDSPE6V8UD DFN-10_0_LCC10_NS_PESDALC10N5VULCC10_NS_2P5X1P0_P65HD13ESDSPE6V8UD DFN-10_0_LCC10_NS_PESDALC10N5VULCC10_NS_2P5X1P0_P65HD14DIODE_SOD523_RB520SU-30RB520SU-30SOD523D22IC_ESD_AZ1045_LCC10_NS_2P5X1P0_AZ1045-04FLCC10_NS_2P5X1P0_P65HD23DIO_ESD_TVS0402_PPES0402V06B_PPES0402V06BTVS0402D25IC_ESD_AZ1045_LCC10_NS_2P5X1P0_AZ1045-04FLCC10_NS_2P5X1P0_P65HD26DIO_ESD_1_TVS0402_AZ5725-01F_AZ5725-01FTVS0402D28DIODE_SOD523_RB520SM-30T2RRB520SM-30T2RSOD523D29DIODE_SOD523_RB520SM-30T2RRB520SM-30T2RSOD523D60DIODE_SOD523_RB520SU-30RB520SU-30SOD523D80DIO_ESD_TVS0402_PESDNC2FD5VBS_PESDNC2FD5VBSTVS0402D81DIO_ESD_TVS0402_PESDNC2FD5VBS_PESDNC2FD5VBSTVS0402D82DIO_ESD_TVS0402_PESDNC2FD5VBS_PESDNC2FD5VBSTVS0402D83DIO_ESD_TVS0402_PESDNC2FD5VBS_PESDNC2FD5VBSTVS0402D84DIO_ESD_TVS0402_PESDNC2FD5VBS_PESDNC2FD5VBSTVS0402D85DIO_ESD_TVS0402_PESDNC2FD5VBS_PESDNC2FD5VBSTVS0402D86DIO_ESD_TVS0402_PESDNC2FD5VBS_PESDNC2FD5VBSTVS0402D87DIO_ESD_TVS0402_PESDNC2FD5VBS_PESDNC2FD5VBSTVS0402D88DIO_ESD_TVS0402_PESDNC2FD5VBS_PESDNC2FD5VBSTVS0402D89DIO_ESD_TVS0402_PESDNC2FD5VBS_PESDNC2FD5VBSTVS0402D96DIODE_SOD523_RB520SM-30T2RRB520SM-30T2RSOD523D142DIODE_SOD523_RB520SM-30RB520SM-30SOD523D143DIODE_SOD523_RB520SM-30RB520SM-30SOD523D144DIO_ESD_TVS0402_PPES0402V06B_PPES0402V06BTVS0402D145DIODE_SOD523_RB520SM-30T2RRB520SM-30T2RSOD523D1707IC_ESD_AZ1045_LCC10_NS_2P5X1P0_AZ1045-04FLCC10_NS_2P5X1P0_P65HD1708DIODE_SOD523_RB520SM-30T2RRB520SM-30T2RSOD523D1709DIODE_SOD523_RB520SM-30T2RRB520SM-30T2RSOD523D1710DIODE_SOD523_RB520SM-30T2RRB520SM-30T2RSOD523D1711DIODE_SOD523_RB520SM-30T2RRB520SM-30T2RSOD523D1712DIODE_SOD523_RB520SM-30T2RRB520SM-30T2RSOD523D1713DIODE_SOD523_RB520SM-30T2RRB520SM-30T2RSOD523D1726DIODE_SOD523_RB520SM-30T2RRB520SM-30T2RSOD523D1727DIODE_SOD523_RB520SM-30T2RRB520SM-30T2RSOD523D1728DIODE_SOD523_RB520SM-30T2RRB520SM-30T2RSOD523D1729DIODE_SOD523_RB520SM-30T2RRB520SM-30T2RSOD523D1730DIODE_SOD523_RB520SM-30T2RRB520SM-30T2RSOD523D1731DIODE_SOD523_RB520SM-30T2RRB520SM-30T2RSOD523DIMA1DDR4_DIMM_288P_CON_DDR4_288_FOXDDR4-DIMM_SLOT_BLACKCON_DDR4_288_FOXCONN_AH08813DIMB1DDR4_DIMM_288P_CON_DDR4_288_FOXDDR4-DIMM_SLOT_BLACKCON_DDR4_288_FOXCONN_AH08813FB1BEAD_L0402_BLM15PX600SN1DBLM15PX600SN1DL0402H3ME_TONGZHU_C6_00D4_70_SSD_NUT_MSSD_NUT_MIDC6_00D4_70J1CON6_5_HW05100-10_CON-10P_CON_DCON_DEBUGHW05100-10_CON-10PJ2HDMI-DP_EAST-DPHD01X2101-HDMI-DHDMI_TypeAEAST-DPHD01X2101-HDMI-DPJ3PCIE_X16_164PIN_DIP_SLOT-PCI-EXPCIE4.0_x16DIP_SLOT-PCI-EXPRESS-X16_164J4PCI_EXPRESS_X1_DIP_SLOT-PCI-EXPPCIEX1DIP_SLOT-PCI-EXPRESS-X1_36J10SATAHOST CONN_0_SATA-7P-MALE-SSATAHOST CONNSATA-7P-MALE-SOKETJ12SATAHOST CONN_0_SATA-7P-MALE-SSATAHOST CONNSATA-7P-MALE-SOKETJ14CON-ATP12040-F0D8H_ATX-WB4202A-ATP12040-F0D8HATX-WB4202A-212S-4_2-2X4PJ16AUDIO-JA33331-4112_0_AUDIO_JACKAUDIO-JA33331-4112_0AUDIO_JACK-EAST-359S-11PJ17HEADER_3_HEADER5X2-2P54-D1P02-8HEADER_2.54X9_8LHEADER5X2-2P54-D1P02-8J19HEADER_3_HEADER5X2-2P54-D1P02-9HEADER_5*2HEADER5X2-2P54-D1P02-9J20HEADER_0_HEADER5X2-2P54-D1P02-1HEADER_2.54X9_10LHEADER5X2-2P54-D1P02-10J21HEADER_2PIN_HEADER2X1-2P54-D1P0Header_2PINHEADER2X1-2P54-D1P02J25PINHEADER_1_WB2543A-004S-BAND-WB2543A-004R-BAND-DWWB2543A-004S-BAND-DW_CON-4PJ26PINHEADER_1_WB2543A-004S-BAND-WB2543A-004R-BAND-DWWB2543A-004S-BAND-DW_CON-4PJ27HEADER_0_HEADER5X2-2P54-D1P02-1HEADER_2.54X9_10LHEADER5X2-2P54-D1P02-10J33RJ45-USB20X2_EAST-317XO-RJ45-USRJ45-USB20X2EAST-317XO-RJ45-USBX2-LEDJ34SATAHOST CONN_0_SATA-7P-MALE-SSATAHOST CONNSATA-7P-MALE-SOKETJ35SATAHOST CONN_0_SATA-7P-MALE-SSATAHOST CONNSATA-7P-MALE-SOKETJ36PCI_EXPRESS_X1_DIP_SLOT-PCI-EXPPCIEX1DIP_SLOT-PCI-EXPRESS-X1_36J37CON_2P_1_BS-02-A1B0J001_CON-2P_RTC_CONBS-02-A1B0J001_CON-2PJ71HDMI-TYPE-A_11-110131X20_HDMI-1HDMI_TypeA11-110131X20_HDMI-19PJ79CON-USB,STD-USB3_0.0_USB30_18P_KY-U3A-F206USB30_18P__KY_U3A_F206J104PINHEADER_1_WB2543A-004S-BAND-WB2543A-004R-BAND-DWWB2543A-004S-BAND-DW_CON-4PJ123HEADER_2_HEADER6X2-2P54-D1P02_HHEADER_6*2HEADER6X2-2P54-D1P02JSSD1NGFF_M_SSD_1_NGFF_TOPMOUNT_KEY_NGFFNGFF_TOPMOUNT_KEY_M_H3P2MM_2280L1L_CHOKE_4P2C_CHOKE-DLP11SN900HL90Ohm_100mACHOKE-DLP11SN900HL2L-4P-1L2CHOKE_4PIN_ALT_CHOKE-DLP11SN900MCF1210NF2-900T01CHOKE-DLP11SN900HL2L-4P-1L3CHOKE_4PIN_ALT_CHOKE-DLP11SN900MCF1210NF2-900T01CHOKE-DLP11SN900HL2L-4P-1L4CHOKE_4PIN_ALT_CHOKE-DLP11SN900MCF1210NF2-900T01CHOKE-DLP11SN900HL2L-4P-1L5CHOKE_4PIN_ALT_CHOKE-DLP11SN900MCF1210NF2-900T01CHOKE-DLP11SN900HL2L-4P-1L6L_CHOKE_4P2C_SML_4P_125X100_CM_MCF1201NF2-900T01SML_4P_125X100_CM_P50HL7L_CHOKE_4P2C_SML_4P_125X100_CM_MCF1201NF2-900T01SML_4P_125X100_CM_P50HL8L_CHOKE_4P2C_SML_4P_125X100_CM_MCF1201NF2-900T01SML_4P_125X100_CM_P50HL9L_CHOKE_4P2C_SML_4P_125X100_CM_MCF1201NF2-900T01SML_4P_125X100_CM_P50HL14INDUCTOR_PL2520_H1P2_4.7UH_1.2A4.7uH_1.2APL2520_H1P2L16L_CHOKE_4P2C_CHOKE-DLP11SN900HL90Ohm_100mACHOKE-DLP11SN900HL2L-4P-1L17L_CHOKE_4P2C_CHOKE-DLP11SN900HL90Ohm_100mACHOKE-DLP11SN900HL2L-4P-1L18L_CHOKE_4P2C_CHOKE-DLP11SN900HL90Ohm_100mACHOKE-DLP11SN900HL2L-4P-1L19L_CHOKE_4P2C_CHOKE-DLP11SN900HL90Ohm_100mACHOKE-DLP11SN900HL2L-4P-1L23L_CHOKE_4P2C_CHOKE-DLP11SN900HL90Ohm_100mACHOKE-DLP11SN900HL2L-4P-1L24L_CHOKE_4P2C_CHOKE-DLP11SN900HL90Ohm_100mACHOKE-DLP11SN900HL2L-4P-1L25L_CHOKE_4P2C_CHOKE-DLP11SN900HL90Ohm_100mACHOKE-DLP11SN900HL2L-4P-1L27L_CHOKE_4P2C_CHOKE-DLP11SN900HL90Ohm_100mACHOKE-DLP11SN900HL2L-4P-1L28L_CHOKE_4P2C_CHOKE-DLP11SN900HL90Ohm_100mACHOKE-DLP11SN900HL2L-4P-1L29L_CHOKE_4P2C_CHOKE-DLP11SN900HL90Ohm_100mACHOKE-DLP11SN900HL2L-4P-1L30L_CHOKE_4P2C_CHOKE-DLP11SN900HL90Ohm_100mACHOKE-DLP11SN900HL2L-4P-1L31L_CHOKE_4P2C_CHOKE-DLP11SN900HL90Ohm_100mACHOKE-DLP11SN900HL2L-4P-1L32BEAD_L0402_BLM15PX600SN1DBLM15PX600SN1DL0402L33BEAD_L0402_BLM15PX600SN1DBLM15PX600SN1DL0402L36L_CHOKE_4P2C_CHOKE-DLP11SN900HL90Ohm_100mACHOKE-DLP11SN900HL2L-4P-1L37L3752_STAND_1_L2_P7R9_11R0X11R01UH/30AL2_P7R9_11R0X11R0_H10L38L_SML_5P7X5P4_1P5H_2.2UH_6A2.2uH_6ASML_5P7X5P4_1P5HL39L_SML_7P0X6P6_1P3H_2.2UH_6A2.2uH_6ASML_7P0X6P6_1P3HL40L_SML_5P7X5P4_1P5H_4.7UH_116.6M4.7uH_116.6mohmSML_5P7X5P4_1P5HL41L_PL4040_H1P8_LVS404018-1R0M-NLVS404018-1R0M-NPL4040_H1P8L42L_ENVELOP_0_L2_P7R58_8R5X11R5_H0.22uH_45AL2_P7R58_8R5X11R5_H8R9L47L_SML2520_BRICK_1MM_UHP252012NFUHP252012NF-2R2MSML2520_BRICK_1MML48L_SML2520_BRICK_1MM_UHP252012NFUHP252012NF-2R2MSML2520_BRICK_1MML49INDUCTORPOL_0_PL7066_H2P4_1.5U1.5UH_12APL7066_H2P4L51L_ENVELOP_0_L2_P7R58_8R5X11R5_H0.22uH_45AL2_P7R58_8R5X11R5_H8R9L52L_ENVELOP_0_L2_P7R58_8R5X11R5_H0.22uH_45AL2_P7R58_8R5X11R5_H8R9L53L_ENVELOP_0_L2_P7R58_8R5X11R5_H0.22uH_45AL2_P7R58_8R5X11R5_H8R9L54L_ENVELOP_0_L2_P7R58_8R5X11R5_H0.22uH_45AL2_P7R58_8R5X11R5_H8R9L55L_ENVELOP_0_L2_P7R58_8R5X11R5_H0.22uH_45AL2_P7R58_8R5X11R5_H8R9L56L_ENVELOP_0_L2_P7R58_8R5X11R5_H0.22uH_45AL2_P7R58_8R5X11R5_H8R9L57L_ENVELOP_0_L2_P7R58_8R5X11R5_H0.22uH_45AL2_P7R58_8R5X11R5_H8R9L58L_CHOKE_4P2C_CHOKE-DLP11SN900HL90Ohm_100mACHOKE-DLP11SN900HL2L-4P-1L59L_CHOKE_4P2C_CHOKE-DLP11SN900HL90Ohm_100mACHOKE-DLP11SN900HL2L-4P-1L60L_CHOKE_4P2C_CHOKE-DLP11SN900HL90Ohm_100mACHOKE-DLP11SN900HL2L-4P-1L61BEAD_L0402_BLM15PX600SN1DBLM15PX600SN1DL0402L62BEAD_L0402_BLM15PX600SN1DBLM15PX600SN1DL0402L63BEAD_L0402_BLM15PX600SN1DBLM15PX600SN1DL0402L64L_CHOKE_4P2C_CHOKE-DLP11SN900HL90Ohm_100mACHOKE-DLP11SN900HL2L-4P-1L65L_SML2520_BRICK_1MM_UHP252012NFUHP252012NF-2R2MSML2520_BRICK_1MML66L_CHOKE_4P2C_CHOKE-DLP11SN900HL90Ohm_100mACHOKE-DLP11SN900HL2L-4P-1L67BEAD_L0402_BLM15PX600SN1DBLM15PX600SN1DL0402L68BEAD_L0402_BLM15PX600SN1DBLM15PX600SN1DL0402L69L_CHOKE_4P2C_CHOKE-DLP11SN900HL90Ohm_100mACHOKE-DLP11SN900HL2L-4P-1L70L_CHOKE_4P2C_CHOKE-DLP11SN900HL90Ohm_100mACHOKE-DLP11SN900HL2L-4P-1L71L_CHOKE_4P2C_CHOKE-DLP11SN900HL90Ohm_100mACHOKE-DLP11SN900HL2L-4P-1L72BEAD_L0402_BLM15PX600SN1DBLM15PX600SN1DL0402L9558BEAD_L0402_ACMS160808A6001AACMS160808A6001AL0402LED1LED,SMT,GREEN,0603,AOT_0_XNT-16GREEN_REDLEDXNT-1615_LED-4PMTH1HOLE,MOUNTINGHOLE 120_63_H_C8DScrewholeH_C8D4MTH2HOLE,MOUNTINGHOLE 120_63_H_C8DScrewholeH_C8D4MTH3HOLE,MOUNTINGHOLE 120_63_NUT_C02AP1049NUT_C8B8P4D4MTH4HOLE,MOUNTINGHOLE 120_63_NUT_C02AP1049NUT_C8B8P4D4MTH5HOLE,MOUNTINGHOLE 120_63_H_C8DScrewholeH_C8D4MTH6HOLE,MOUNTINGHOLE 120_63_H_C8DScrewholeH_C8D4MTH7HOLE,MOUNTINGHOLE 120_63_NUT_C02AP1049NUT_C8B8P4D4MTH8HOLE,MOUNTINGHOLE 120_63_NUT_C02AP1049NUT_C8B8P4D4MTH12HOLE,MOUNTINGHOLE 120_63_H_C8DScrewholeH_C8D4MTH13HOLE,MOUNTINGHOLE 120_63_H_C8DScrewholeH_C8D4PC4CAPE8X12_EC6P3X9-100_560UF_2.5V560uF_2.5VEC6P3X9-100PC5CAPE8X12_EC6P3X9-100_560UF_2.5V560uF_2.5VEC6P3X9-100PC7CAPE8X12_EC6P3X9-100_560UF_2.5V560uF_2.5VEC6P3X9-100PC8CAPE8X12_EC6P3X9-100_560UF_2.5V560uF_2.5VEC6P3X9-100PC14CE_EC6P3X11-100_100UF_25V100uF_25VEC6P3X11-100PC15CE_EC6P3X11-100_100UF_25V100uF_25VEC6P3X11-100PC41CE_EC6P3X9-100_470UF_2.5V470uF_2.5VEC6P3X9-100PC42CAPE8X12_EC6P3X9-100_560UF_2.5V560uF_2.5VEC6P3X9-100PC43CE_EC6P3X11-100_100UF_25V100uF_25VEC6P3X11-100PC49CAPE8X12_EC6P3X9-100_560UF_2.5V560uF_2.5VEC6P3X9-100PC50CAPE8X12_EC6P3X9-100_560UF_2.5V560uF_2.5VEC6P3X9-100PC51CE_EC6P3X11-100_100UF_25V100uF_25VEC6P3X11-100PC52CAPE8X12_EC6P3X9-100_560UF_2.5V560uF_2.5VEC6P3X9-100PC53CE_EC6P3X11-100_100UF_25V100uF_25VEC6P3X11-100PC54CAPE8X12_EC6P3X9-100_560UF_2.5V560uF_2.5VEC6P3X9-100PC55CAPE8X12_EC6P3X9-100_560UF_2.5V560uF_2.5VEC6P3X9-100PC56CAPE8X12_EC6P3X9-100_560UF_2.5V560uF_2.5VEC6P3X9-100PC57CAPE8X12_EC6P3X9-100_560UF_2.5V560uF_2.5VEC6P3X9-100PC58CE_EC6P3X11-100_100UF_25V100uF_25VEC6P3X11-100PC59CAPE8X12_EC6P3X9-100_560UF_2.5V560uF_2.5VEC6P3X9-100PC60CE_EC6P3X11-100_100UF_25V100uF_25VEC6P3X11-100PC61CAPE8X12_EC6P3X9-100_560UF_2.5V560uF_2.5VEC6P3X9-100PC62CAPE8X12_EC6P3X9-100_560UF_2.5V560uF_2.5VEC6P3X9-100PC63CE_EC6P3X11-100_100UF_25V100uF_25VEC6P3X11-100PC64CAPE8X12_EC6P3X9-100_560UF_2.5V560uF_2.5VEC6P3X9-100PC65CAPE8X12_EC6P3X9-100_560UF_2.5V560uF_2.5VEC6P3X9-100PC66CE_EC6P3X11-100_100UF_25V100uF_25VEC6P3X11-100PC67CAPE8X12_EC6P3X9-100_560UF_2.5V560uF_2.5VEC6P3X9-100PC68CE_EC6P3X11-100_100UF_25V100uF_25VEC6P3X11-100PC69CAPE8X12_EC6P3X9-100_560UF_2.5V560uF_2.5VEC6P3X9-100PC70CAPE8X12_EC6P3X9-100_560UF_2.5V560uF_2.5VEC6P3X9-100PC71CAPE8X12_EC6P3X9-100_560UF_2.5V560uF_2.5VEC6P3X9-100PQ1SI7392ADP_0_PRPAK5X6MM_8P_3098_AON6414APRPAK5X6MM_8P_3098PQ2SI7392ADP_0_PRPAK5X6MM_8P_309_1AON6354PRPAK5X6MM_8P_3098PQ3MOSFET-N-AON7380_PK664BA-PDFN_1PK8B0BAPK664BA-PDFN5X6-5PPQ4MOSFET-N-AON7380_PK664BA-PDFN5XPK664BAPK664BA-PDFN5X6-5PPQ38MOSFET-N-AON7380_PK664BA-PDFN_1PK8B0BAPK664BA-PDFN5X6-5PPS1MINI-FUSE_SMD1812_FUSE_2AFUSE_2ASMD1812Q8MOSFET_SN_3P_SOT723_PNM723T30V0PNM723T30V01SOT723Q9MOSFET_SN_3P_SOT723_PNM723T30V0PNM723T30V01SOT723Q10MOSFET_SN_3P_SOT523_RUE002N02RUE002N02SOT523Q11MOSFET_SN_3P_SOT523_RUE002N02RUE002N02SOT523Q12MOSFET_SN_3P_SOT523_RUE002N02RUE002N02SOT523Q16PMOS3P_SOT23_SSC8033GS6SSC8033GS6SOT23Q17MOSFET_N_SOT723_PNM723T30V01PNM723T30V01SOT723Q19MMBT3904_4_SOT723_MMBT3904MMMBT3904MSOT723Q23MOS-N_3_SOT23_BSS138NBSS138NSOT23Q24FETP SO-8_1_DFN3_3_QM3005M3QM3005M3DFN3_3Q25MOSFET_SN_3P_SOT723_PNM723T30V0PNM723T30V01SOT723Q26MOSFET_SN_3P_SOT723_PNM723T30V0PNM723T30V01SOT723Q272N7002_4_SOT723_PNM723T30V01PNM723T30V01SOT723Q282N7002_4_SOT723_PNM723T30V01PNM723T30V01SOT723Q31SI7392ADP_0_PRPAK5X6MM_8P_3098_AON6414APRPAK5X6MM_8P_3098Q32FETP SO-8_1_DFN3_3_QM3005M3QM3005M3DFN3_3Q33MOSFET_SN_3P_SOT723_PNM723T30V0PNM723T30V01SOT723Q34MOSFET_SN_3P_SOT723_PNM723T30V0PNM723T30V01SOT723Q35MOSFET_SN_3P_SOT723_PNM723T30V0PNM723T30V01SOT723Q36MOSFET_SN_3P_SOT723_PNM723T30V0PNM723T30V01SOT723Q37MOSFET_SN_3P_SOT523_RUE002N02RUE002N02SOT523Q38MOSFET_SN_3P_SOT523_RUE002N02RUE002N02SOT523Q73MOSFET_SN_3P_SOT723_PNM723T30V0PNM723T30V01SOT723Q74MOSFET_SN_3P_SOT723_PNM723T30V0PNM723T30V01SOT723Q133MOSFET_SN_3P_SOT723_PNM723T30V0PNM723T30V01SOT723Q134MOSFET_SN_3P_SOT523_RUE002N02RUE002N02SOT523Q136MOSFET_SN_3P_SOT523_RUE002N02RUE002N02SOT523Q137MOSFET_SN_3P_SOT523_RUE002N02RUE002N02SOT523Q138MOSFET_SN_3P_SOT523_2SK30192SK3019SOT523Q139MOSFET_SN_3P_SOT523_2SK30192SK3019SOT523Q140MOSFET_SN_3P_SOT523_2SK30192SK3019SOT523RT1THERMISTOR_SMRT0402_10K_NTC_?10K_NTCSMRT0402RT2THERMISTOR_SMRT0402_10K_NTC_10K_NTCSMRT0402RT8THERMISTOR_SMRT0402_100K_NTC_100K_NTCSMRT0402RT11THERMISTOR_SMRT0402_100K_NTC_100K_NTCSMRT0402RT13THERMISTOR_SMRT0402_10K_NTC_?10K_NTCSMRT0402RT15THERMISTOR_SMRT0402_100K_NTC_100K_NTCSMRT0402RT16THERMISTOR_SMRT0402_10K_NTC_?10K_NTCSMRT0402SH1SHORT_PAD_2_SHUNT_0402_SHORT_PAShort_PadSHUNT_0402SH3SHORT_PAD_2_SHUNT_0805_LOCAL_SHLOCAL_SHUNTSHUNT_0805SH14SHORT_PAD_2_SHUNT_L4_3X6_LOCAL_LOCAL_SHUNTSHUNT_L4_3X6SH15SHORT_PAD_2_SHUNT_0402_SHORT_PAShort_PadSHUNT_0402SH16SHORT_PAD_2_SHUNT_0603_LOCAL_SHLOCAL_SHUNTSHUNT_0603SH17SHUNT_LOCAL_SHUNT_0402_SHORT_04SHORTSHUNT_0402SH18SHORT_PAD_2_SHUNT_0402_SHUNT_RESHUNT_RESSHUNT_0402U3D1C_ADL_S_CPU_EXT_1P0_CLPDB_XLGA1C_ADL_S_CPU_EXT_1P0CLPDB_XLGA1700_ADL_S_LP7215_MAU1ADL_S_PCH_EXT_1P5_CLPDB_BGA1045ADL_S_PCH_EXT_1P5CLPDB_BGA1045_ADL_S_LP7190_MAU2SGM4552YN6G_SOT23-6_SGM4552YN6GSGM4552YN6GSOT23-6U3FLASH_17P_SOP8L_150_200_W25Q256W25Q256JVSIQSOP8L_150_200U8TTL1G08_SOT353_SGM7SZ08YC5G/TR_SGM7SZ08YC5G/TR_ANDSOT353U9IC,RJ45,INTEL_I219,QFN49_QFN48-I219QFN48-040-0606-S118U1124LC02_0_SOT_23_5_AP1621AHKTBERAP1621AHKTBERSOT_23_5U1224LC02_0_SOT_23_5_AP1621AHKTBERAP1621AHKTBERSOT_23_5U1524LC02_0_SOT_23_5_AP1621AHKTBERAP1621AHKTBERSOT_23_5U1824LC02_0_SOT_23_5_AP1621AHKTBERAP1621AHKTBERSOT_23_5U19IT8625E_0_LQFP128-15P7_IT8625E/IT8625E/LXLQFP128-15P7U26HIP6501_2_QFN_10_3X3_H0P8_RT823RT8237AZQWQFN_10_3X3_H0P8U27IC_POWER_SY8003A_LCC8_P5MM_2P1SSY8003LCC8_P5MM_2P1SQ_HP65U28IC_POWER_NB685_LCC16_P5MM_SQ3_NNB685LCC16_P5MM_SQ3_NSU29CODEC_CX20632_LCC48_S60_40DFS44Codec_CX20632LCC48_S60_40DFS44MAU30IC_POWER_RT9059_SOP8-1_27-5_0X4RT9059GSPSOP8-1_27-5_0X4_0H-H1_753U31NB671L_1_MP2384_QFN11_0P5_2X2MMMPS_MP2384MP2384_QFN11_0P5_2X2MMU32APL5325A_SOT23-5_APL5325AAPL5325ASOT23-5U33ANPEC_APL5327_SOT23-5_ETA5050V0ETA5050V0S2FSOT23-5U34JW5223SOTA_SOT_23_5_JW5223SOTAJW5223SOTASOT_23_5U35RT6543AGQW_1_WQFN20_PT04_W3X3_RRT6543AGQWWQFN20_PT04_W3X3U41TTL1G08_SOT353_SGM7SZ08YC5G/TR_SGM7SZ08YC5G/TR_ANDSOT353U42SGM7SZ00_NAND_0_SOT353_SGM7SZ04SGM7SZ04YC5G/TR_FSOT353U43SGM7SZ00_NAND_0_SOT353_SGM7SZ04SGM7SZ04YC5G/TR_FSOT353U44TTL1G08_SOT353_SGM7SZ08YC5G/TR_SGM7SZ08YC5G/TR_ANDSOT353U6924LC02_0_SOT_23_5_AP1621AHKTBERAP1621AHKTBERSOT_23_5U10475C185_SOP20-0_65-0705_GD75232GD75232SOP20-0_65-0705U106ALC882-LQFP48_0_LQFP48_P5_ALC89ALC897LQFP48_P5U107UP7501AMA8_SOT23-8-25P6_UPI_UP7uP7501M8SOT23-8-25P6_UPIU109NB690_NB690-QFN12-2X2_5X1_NB690NB690NB690-QFN12-2X2_5X1U11024LC02_0_SOT_23_5_AP1621AHKTBERAP1621AHKTBERSOT_23_5U11124LC02_0_SOT_23_5_AP1621AHKTBERAP1621AHKTBERSOT_23_5U162RT9610C_4_DS9610C-WDFN8-2X2-P0_RT9610CDS9610C-WDFN8-2X2-P0_5U163RT9610C_4_DS9610C-WDFN8-2X2-P0_RT9610CDS9610C-WDFN8-2X2-P0_5U164RT9610C_4_DS9610C-WDFN8-2X2-P0_RT9610CDS9610C-WDFN8-2X2-P0_5U165RT9610C_4_DS9610C-WDFN8-2X2-P0_RT9610CDS9610C-WDFN8-2X2-P0_5U166RT9610C_4_DS9610C-WDFN8-2X2-P0_RT9610CDS9610C-WDFN8-2X2-P0_5U167RT9610C_4_DS9610C-WDFN8-2X2-P0_RT9610CDS9610C-WDFN8-2X2-P0_5U168RT9610C_4_DS9610C-WDFN8-2X2-P0_RT9610CDS9610C-WDFN8-2X2-P0_5U170TTL1G08_SOT353_SGM7SZ08YC5G/TR_SGM7SZ08YC5G/TR_ANDSOT353U171TTL1G08_SOT353_SGM7SZ08YC5G/TR_SGM7SZ08YC5G/TR_ANDSOT353U172TTL1G08_SOT353_SGM7SZ08YC5G/TR_SGM7SZ08YC5G/TR_ANDSOT353U173TTL1G08_SOT353_SGM7SZ08YC5G/TR_SGM7SZ08YC5G/TR_ANDSOT353U174APL5934KAI_0_NCT3103S_SOP8-50-1APL5934KAITRGNCT3103S_SOP8-50-154U175IC_74AUP1G07GW_SC70_5_74AUP1G0774AUP1G07GWSC70_5ULAN1TRANSFORMER_TBDB_GST5009LFGST5009LFTBDBV1HD1VARISTOR_TVS0402_PPES0402V06BPPES0402V06BTVS0402V1DIODE_TVS_TVS0402_WE05DLVF-BWE05DLVF-BTVS0402V31DIODE_TVS_TVS0402_PESDNC2FD5VBSPESDNC2FD5VBSTVS0402V32DIODE_TVS_TVS0402_WE05DLVF-BWE05DLVF-BTVS0402V33IC_ESD_AZ1045-04F.R7G_LCC10_NS_PESDALC10N5VULCC10_NS_2P5X1P0_P65HV34DIO_ESD_TVS0402_PPES0402V06B_?PPES0402V06BTVS0402V36DIODE_TVS_TVS0402_WE05DLVF-B_WE05DLVF-BTVS0402V37DIODE_TVS_TVS0402_WE05DLVF-B_WE05DLVF-BTVS0402V38DIODE_TVS_TVS0402_WE05DLVF-B_WE05DLVF-BTVS0402V39DIODE_TVS_TVS0402_WE05DLVF-B_WE05DLVF-BTVS0402V42DIODE_TVS_TVS0402_WE05DLVF-B_WE05DLVF-BTVS0402V43DIODE_TVS_TVS0402_WE05DLVF-B_WE05DLVF-BTVS0402V46DIODE_TVS_TVS0402_PESDNC2FD5VBSPESDNC2FD5VBSTVS0402V47DIODE_TVS_TVS0402_PESDNC2FD5VBSPESDNC2FD5VBSTVS0402V48DIODE_TVS_TVS0402_PESDNC2FD5VBSPESDNC2FD5VBSTVS0402V49DIODE_TVS_TVS0402_PESDNC2FD5VBSPESDNC2FD5VBSTVS0402V50DIO_ESD_TVS0402_WE05DLVF-B_?WE05DLVF-BTVS0402V51DIO_ESD_TVS0402_WE05DLVF-B_?WE05DLVF-BTVS0402V52DIODE_TVS_TVS0402_WE05DLVF-B_WE05DLVF-BTVS0402V55DIODE_TVS_TVS0402_WE05DLVF-BWE05DLVF-BTVS0402V56DIODE_TVS_TVS0402_WE05DLVF-BWE05DLVF-BTVS0402V57DIODE_TVS_TVS0402_CESD1006NC24VCESD1006NC24VBTVS0402V58DIODE_TVS_TVS0402_CESD1006NC24VCESD1006NC24VBTVS0402V59DIODE_TVS_TVS0402_CESD1006NC24VCESD1006NC24VBTVS0402V60DIODE_TVS_TVS0402_WE05DLVF-B_WE05DLVF-BTVS0402V61DIODE_TVS_TVS0402_WE05DLVF-B_WE05DLVF-BTVS0402V62DIODE_TVS_TVS0402_CESD1006NC24VCESD1006NC24VBTVS0402V63DIODE_TVS_TVS0402_CESD1006NC24VCESD1006NC24VBTVS0402V64DIODE_TVS_TVS0402_CESD1006NC24VCESD1006NC24VBTVS0402V80DIODE_TVS_TVS0402_WE05DLVF-B_WE05DLVF-BTVS0402V89DIODE_TVS_TVS0402_WE05DLVF-BWE05DLVF-BTVS0402V90IC_ESD_AZ1045-04F.R7G_LCC10_NS_PESDALC10N5VULCC10_NS_2P5X1P0_P65HV91IC_ESD_AZ1045-04F.R7G_LCC10_NS_PESDALC10N5VULCC10_NS_2P5X1P0_P65HV92DIODE_TVS_TVS0402_PPES0402V06B_PPES0402V06BTVS0402V93IC_ESD_AZ1045-04F.R7G_LCC10_NS_PESDALC10N5VULCC10_NS_2P5X1P0_P65HV94DIODE_TVS_TVS0402_PPES0402V06B_PPES0402V06BTVS0402V95DIO_ESD_TVS0402_PPES0402V06B_?PPES0402V06BTVS0402V96DIODE_TVS_TVS0402_WE05DLVF-BWE05DLVF-BTVS0402V97DIODE_TVS_TVS0402_WE05DLVF-BWE05DLVF-BTVS0402V98DIODE_TVS_TVS0402_CESD1006NC24VCESD1006NC24VBTVS0402V99DIODE_TVS_TVS0402_CESD1006NC24VCESD1006NC24VBTVS0402X1XTAL_16.369M_3PT5X6MM_TCXO_322525MHzTCXO_3225X520MHZ_XTAL-3225-H1_2-4P_24MHZ24MHZXTAL-3225-H1_2-4PY7D1XTAL_4P_C_SMY4_32X25MB_38.4MHZ_38.4MHZSMY4_32X25MBY1XTAL_CRYSTAL_2P_X2-3216_H0P8_3232.768KX2-3216_H0P8
PCB文件来了。 文件收集于网络。如有侵权请联系我删除。
文件分加锁和没加锁版本。 加锁版本只能打开查看。不能修改保存。没加锁版本就没限制。 一般欣赏下载加锁版本即可。
没加锁版本
加锁版本。
szhj14e 发表于 2022-3-16 18:44
e高手
bidinghong 发表于 2022-3-16 19:24
zspdeyc 发表于 2022-3-16 20:16
罗塘阮经天 发表于 2022-3-16 22:16
kanxue_nmg 发表于 2022-3-17 05:35
shuszhao 发表于 2022-3-17 08:28
有图纸吗?
kxz564978637 发表于 2022-3-17 08:29
lf2k2022 发表于 2022-3-17 08:32
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: 最新Intel 12代CPU LGA1700插槽 电脑主板PCB文件挂两条DDR4 &n
