layout 发表于 2022-4-7 09:08
D2PAK-7 +UCC28740DR 做的电源板PCB文件共享
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEC22LEC007_0805_50V_C0805W_1U1uC0805WC23LEC007_0805_50V_C0805W_1U1uC0805WC67LEC007_0805_50V_R0805_1000PF1000pFR0805C73LEC007_0805_50V_R0805_4.7U4.7uR0805C94LEC006_0603_50V_R0603_33N33nR0603C95LEC006_0603_50V_R0603_33N33nR0603C96LEC039_Y_1000PF_10MM_CRAD-13X4X1000pFCRAD-13X4X9P5MMC109CAPPOL_0_ECAP_10MM_DIA_5MM_PIT15uFECAP_10MM_DIA_5MM_PITCHC110CAPPOL_0_ECAP_10MM_DIA_5MM_PIT15uFECAP_10MM_DIA_5MM_PITCHC111LEC052_1206_0.033UF_630V_C1206_0.033uC1206C112LEC017_1206_500V_C1206_100P100pC1206C113LEC231_AL_470UF_25V_10ODX16_CRA470uFCRAD-10ODX16LC114LEC231_AL_470UF_25V_10ODX16_CRA470uFCRAD-10ODX16LC115CAPPOL_0_ECAP_10MM_DIA_5MM_PIT15uFECAP_10MM_DIA_5MM_PITCHC116LEC043_0603_25V_C0603_0.1U0.1uC0603C117CAPPOL_0_ECAP_10MM_DIA_5MM_PIT15uFECAP_10MM_DIA_5MM_PITCHC118LEC003_0603_16V_C0603_100P100pC0603C119LEC043_0603_25V_C0603_0.1U0.1uC0603D1LED144_1000V_1A_SMA_DIO-SMA_S1MS1M-13-FDIO-SMAD10LED051_BAS21HT1_SOD323_SOD323_BBAS21HT1SOD323D25LED005_1000V_1A_DO214AC_DIO-SMAES1MDIO-SMAD26LED005_1000V_1A_DO214AC_DIO-S_1ES1M-TPDIO-SMAD28LED144_1000V_1A_SMA_DIO-SMA_S1MS1M-13-FDIO-SMAD30LED277_SCHOTTKY_40V_3A_SMB_0_SMLED277_SCHOTTKY_40V_3A_SMBSMB_FLATD31LED277_SCHOTTKY_40V_3A_SMB_SMB_STPS3150UFSMB_FLATD32LED188_TVS_350V_600W_SMB_DIO-SMP6SMB350ADIO-SMBD35LED002_1N4148_SOD323_SOD323_1N41N4148SOD323F2LEF037_22OHM_2W_RAX-40D_RES600_27OHM 2WRES600J22HEADER2X2_0_CON_2MM54_2X2_RA_44P Header ConnectorCON_2MM54_2X2_RAJ23HEADER2X2_0_CON_2MM54_2X2_RA_44P Header ConnectorCON_2MM54_2X2_RAJ24HEADER3X2_1_CON_2MM54_3X2_RA_66P Header ConnectorCON_2MM54_3X2_RAL1CHOKE_DM_CHOKE_RAD_7P8MM_8200UH8200uHDM_CHOKE_RAD_7P8MML2CHOKE_DM_CHOKE_RAD_7P8MM_8200UH8200uHDM_CHOKE_RAD_7P8MML3LET0186_IND_33UH_1.5A_CHOKE-PS03.3uHCHOKE-PS064TL7LET0011_FERRITE_0603_200MA_FB06HZ0603B751R-10FB0603Q2D2PAK-7_1_D2PAK7L_D2PAK-7D2PAK-7D2PAK7LT1LEX0340_8MH_PQ2020_LEX0340_PQ203mHLEX0340_PQ2020TP1TESTPOINT SMD 60 RND_TPS-60RD_TESTPOINT SMD 60 RNDTPS-60RDTP2TESTPOINT SMD 60 RND_TPS-60RD_TESTPOINT SMD 60 RNDTPS-60RDU1LEU577_UCC28740DR_SOIC7_UCC2874UCC28740DRSOIC7U9LEU094_ZTL431AFTA_SOT23_SOT23_1TL431AQDBZRSOT23_1-32U11LEU169_TCLT1003_SOP-4L_OPTO-SOPTCLT1003OPTO-SOP-4L
bidezhi7777 发表于 2022-4-7 09:34
丁响820425 发表于 2022-4-7 09:39
好东西啊
dianguai14 发表于 2022-4-7 10:57
lf2k2022 发表于 2022-4-7 11:25
wangchangsheng 发表于 2022-4-8 08:55
chery 发表于 2022-4-8 08:58
感谢分享
罗塘阮经天 发表于 2022-4-10 22:12
谢谢分享
cityhu 发表于 2022-4-11 00:26
清心如水 发表于 2022-5-26 08:21
查看完整版本: D2PAK-7 +UCC28740DR 做的电源板PCB文件共享
