君正T31 QFN88 +GC4653+DP83825I 做的一个AI 摄像头PCB 原理图
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMECE1CAPPOL_SC0402_4.7UF4.7uFSC0402CE2CAPPOL_SC0402_1UF1uFSC0402D1DIODE_3_SOD-123_1N5819/NC1N5819/NCSOD-123D2SMBJ54A_6_SMA_SMAJ15CASMAJ15CASMAD3DIODE_0_SOD-523_RB521S30T1/NCrb521s30t1/NCSOD-523D6DIODEBI-DIR TRIG_0_SMB_P0080SCP0080SCSMBFB1BEAD_SL0402_1000OHM/250MA1000ohm/250mASL0402FB11SMD_BEAD_FB0603_SL0402_FB120RFB120RSL0402HS1HEATSINK_1_YT1037_LENSlensYT1037ID1ID-BOARD_ID-BOARD_ID-BOARDID-BOARDID-BOARDID2ID-BOARD_ID-BOARD_ID-BOARDID-BOARDID-BOARDJ1CON10_0_A1251AWR-8-F2MA_A1251AWa1251awr-8-f2maA1251AWR-8-F2MAJ2CON24_1_FPC24_0D5_CON24CON24FPC24_0D5J3WAFER2X1-1.25_WAFER2X1-1_25_A12a1251awr-2-f2maWAFER2X1-1_25J4WAFER2X1-1_3.25_CON2X1-1D25MM_CCON2-1/NCCON2X1-1D25MMJ7CON20_1_FPC20-0D5_CON-FPC20CON-FPC20FPC20-0D5J8CON14_1_A125X4-SMD_A1251AWR-4-Fa1251awr-4-f2maA125X4-SMDJ12CON14_3_A125X4-SMD_A1251AWR-4-Fa1251awr-4-f2maA125X4-SMDJ13CON14_1_A125X4-SMD_A1251AWR-4-Fa1251awr-4-f2maA125X4-SMDL5CHOKE_MPIH2520_MPIA252010-2R2M-MPIA252010-2R2M-LFMPIH2520L6CHOKE_MPIT3015_MPIT3015-4R7M-LFMPIT3015-4R7M-LFMPIT3015L7CHOKE_MPIH2520_MPIA252010-2R2M-MPIA252010-2R2M-LFMPIH2520L8L_MPIH2520_MPIT2520-4R7M-LFMPIT2520-4R7M-LFMPIH2520MH1MH_3MM_MH_IPC-FSAN_MH_3MMMH_3MMMH_IPC-FSANMH2MH_3MM_MH_IPC-FSAN_MH_3MMMH_3MMMH_IPC-FSANMH3MH_3MM_MH_IPC-FSAN_MH_3MMMH_3MMMH_IPC-FSANMH4MH_3MM_MH_IPC-FSAN_MH_3MMMH_3MMMH_IPC-FSANN2MMBT3904_SOT-23_MMBT3904MMBT3904SOT-23N3MMBT3904_SOT-23_MMBT3904MMBT3904SOT-23Q2MMBT3904_SOT-23_MMBT3904MMBT3904SOT-23Q3P_MOSFET_SOT23_SOT-23_APM2301AAAPM2301AASOT-23Q4MMBT3904_SOT-23_MMBT3904MMBT3904SOT-23TVS1DIODEBI-DIR TRIG_0_SOD2614X116LC03ISOD2614X116TVS2DIODEBI-DIR TRIG_0_SOD2614X116LC03ISOD2614X116TVS3DIODEBI-DIR TRIG_0_SR0402_ESD-ESD-PESD0402AS05SR0402TVS4DIODEBI-DIR TRIG_0_SR0402_ESD-ESD-PESD0402AS05SR0402U1BL9193-25_1_SOT-23-6_AP1511AAP1511ASOT-23-6U3GC4653_GC4653_GC4653GC4653GC4653U5T31_QFN88_QFN88_0D35_T31_T31QFT31QFN88QFN88_0D35_T31U6S25FL064K0SMFI001_SOP8-208_MX25MX25L12835ZNSOP8-208U13MP2162_2_SOT-563_MP1605CGTFMP1605CGTFSOT-563U14MP1657_SOT-563_MP1657MP1657SOT-563U15MP2162_2_SOT-563_MP1605CGTFMP1605CGTFSOT-563U16MP1657_SOT-563_MP1657MP1657SOT-563U18BL9193-25_0_SOT-23-5_TLV70228TLV70228SOT-23-5U19BL9193-25_0_SOT-23-5_TLV70212TLV70212SOT-23-5U21MS41929_1_QFN32_0505_MS41929MS41929QFN32_0505U22H1102_1_H1102NL_H1102NLH1102NLH1102NLU23RTL8201F-VB-CG_0_WQFN-24_DP8382DP83825IWQFN-24X1X_B_HSX4-0302_24MHZ24MHZHSX4-0302Y2XL/SM_HSX4-0302_27MHZ27MHZHSX4-0302 PCB 原理图。回复可见下载
**** Hidden Message ***** 谢谢分享
