小小欧 发表于 2022-4-14 21:26
iso15118 欧标协议程序全套开源
展示部分代码,全部代码将整理后补充到网站,敬请留意!!!
// describe:
// param-in:
// param-re:
int main(int argc, const char * argv[])
    EVSE_SYSTEM("###########################################################\n");
    EVSE_SYSTEM("[%s %s by %s at %s]\n",PROJECT_NAME,VERSION,AUTHOR,TIME);
    EVSE_SYSTEM("@ %s/bin/main edited at: %s %s \n", MODULE_NAME,__DATE__, __TIME__);
    SystemExecute.mission_manage();
    pause();
    exit(0);
static void interface_receive(uint8_t *data, uint16_t len)
    int error = 0;
    if (SystemExecute.get_sys_state() != SYS_CHARGING || SystemExecute.get_v2g_state() == V2G_READY)
      return;
    if (Handshake.is_evcc_online() == false && SystemExecute.get_v2g_state() == V2G_HANDSHAKE) {
      if ((error = Handshake.decode(data, len, DECODE_HANDSHAKE_REQ)) != 0) {
            error = Handshake.encode(false, ENCODE_HANDSHAKE_RES);
      } else {
            error = Handshake.encode(true, ENCODE_HANDSHAKE_RES);
            Handshake.set_evcc_online(true);
            SystemExecute.set_v2g_state(V2G_INITIALIZE);
    } else {
      switch (Handshake.get_matched_protocol()) {
            case MATCHED_PROTOCOL_ISO15118_2014:
                error = MessageManageOne.decode_document(data, len);
            break;
            case MATCHED_PROTOCOL_DIN70121_2012:
                error = MessageManageTwo.decode_document(data, len);
            break;
            case MATCHED_PROTOCOL_ISO15118_2020:
                error = MessageManageThree.decode_document(data, len);
            break;
    if (error != 0) {
      EVSE_EVCC("decode or encode tcp stream failed # %d \n", error);
chen 发表于 2022-4-15 08:38
weiziushi 发表于 2022-4-15 08:56
in.f 发表于 2023-4-24 14:00
66666666
查看完整版本: iso15118 欧标协议程序全套开源
