老吴 发表于 2022-10-31 11:11
星宸SigmaStar (SSD222)SSD222D DEMO板PCB文件共享
NamePart TypePCB DecalValueCON1JACK\DCJACK\DCDC-JACKCON2B2.0V-L4PB2.0V-L4PWAFER/2.0MM/1*4P/180D/MALECON3HCON4-DIP-1.25HCON4-DIP-1.25HCON4-DIP-1.25CON5USB-4P-AUSB-4P-AUSB-A/90DCON6FPC_6PINBFPC_6PINBFPC_6PINB_UP_TYPECON7DIP1X02PM-80-VDIP1X02PM-80-VCON2-DIP-2.0MMCON10FPC40PIN-0.5MMAFPC40PIN-0.5MMAFPC40PM-0.5MM-BCON16USB-5P-MINIUSB-5P-MINICON21JACK-12P-RJ45JACK-12P-RJ45RJ45_1X1-90DD2SOD-323HESOD-323HEWSB5543W-2/TRD3SOT-23SOT-23BAT54S/WSB5522F-3/TRD4SOD-323HESOD-323HEWSB5543W-2/TRD5SOD123SOD123DC52C7V5(7.5V)D7SOT-23SOT-23BAT54S/WSB5522F-3/TRD8SOD123SOD123DC52C18(18V)D9SOD-523SOD-523AZ5123D10SOD-523SOD-523AZ5123D11SOD-523SOD-523AZ5123D12SOD-523SOD-523AZ5123D13SOD-523SOD-523AZ5123D16SMBSMBP0640SCD24SOD_323SOD_323DCLLC03C-05CD25SOT23-3LSOT23-3LAZ5125D26SOD_323SOD_323DCLLC03C-05CEC1CE-3.5X8CE-3.5X8470UF/50VEC2CE-3.5X8CE-3.5X8FB1L0402L0402FB_60R_300MAFB2R0603R0603FBMA-11-160808-601A10TJ1IL-FHR-50SIL-FHR-50SFPC-CON50_DOWN_TYPEJ11FPC10-0.5-2FPC10-0.5-2CON10-0D5J12HBS36-05-VHBS36-05-VHBS36-05-VJ13HBS36-05-VHBS36-05-VHBS36-05-VJP1JP-1X2JP-1X22.54MM_1*2PJP3JP-1X2JP-1X22.54MM_1*2PJP4JP-2X10JP-2X10HEADER/2.54MM/2*10P/180D/MALEJP5JP-1X3JP-1X3HEADER/2.54MM/1*3P/180D/MALEJP6JP-1X2JP-1X22.54MM_1*2P_180D_MALEJP8JP-1X3JP-1X3HEADER/2.54MM/1*3P/180D/MALEJP9JP-1X2JP-1X22.54MM_1*2P_180D_MALEJP21JP-1X3JP-1X3HEADER/2.54MMJP87JP-1X2JP-1X2JP118JP-1X4JP-1X4HEADER/2.54MMJP121JP-1X4JP-1X4HEADER/2.54MMJP125JP-1X6JP-1X6HEADER/2.54MMJP126JP-1X4JP-1X4HEADER/2.54MMJP127JP-1X6JP-1X6NC/HEADERJP128JP-1X2JP-1X2L2L-MLPS-3015L-MLPS-3015ATNR3015M2R2MTH/1.8AL3L-MLPS-3015L-MLPS-3015ATNR3015M2R2MTH/1.8AL5L-MLPS-4018L-MLPS-4018ATNR4018M4R7MT/2.3AL6L-MLPS-4018L-MLPS-4018ATNR4018M4R7MT/2.3AL35L-MLPS-4018L-MLPS-4018ATNR4018M4R7MT/2.3ALED4LED-0603LED-0603LED_RED-0603LED12LED-0603LED-0603LED_RED-0603LOGOSIGMASTAR-LOGOSIGMASTAR-LOGONCMIC0DIP1X02PM-80-VDIP1X02PM-80-VMIC_1MIC1DIP1X02PM-80-VDIP1X02PM-80-VMIC_1MIC2DIP1X02PM-80-VDIP1X02PM-80-VMIC_1Q4SOT-23SOT-23AO3401A/WPM3020-3/TRQ5SOT_23SOT_23AO3401A/WPM3020-3/TRQ6SOT_23SOT_232N7002/WNM7002-3/TRQ7SOT23-3SOT23-32N7002/WNM7002-3/TRQ24SOT_23SOT_23AO3401A/WPM3020-3/TRQ25SOT_23SOT_23AO3401A/WPM3020-3/TRS4H8D4H8D4NC/H8D4SD1SK10056619_WGQSK10056619_WGQSK10056619SW1SW-2P-MRA1KKAT0BSW-2P-MRA1KKAT0BROCKER-SWITCHSW2JP-1X3JP-1X3HEADER/2.54MM/1*3P/180D/MALESW3JP-1X3JP-1X3HEADER/2.54MM/1*3P/180D/MALET1IC-16P-10_100BASEIC-16P-10_100BASEHST-0041SARTP29TP-0_8MMTP-0_8MMRESTP30TP-0_8MMTP-0_8MMU1SOT-23-6LSOT-23-6LFR9205S6U2SOT23-5PSOT23-5PFP6397S5U3SOT23-5PSOT23-5PTMI3408/FP6396S5U7SOT23-6SOT23-6AZC199-04SU8SOT23-6SOT23-6AZC199-04SU9SOT23-6SOT23-6AZC199-04SU10IC-6P-TSOT23IC-6P-TSOT23FP6755S6CTRU11SOT23-6SOT23-6AZC199-04SU12SOT23-5PSOT23-5PFP6736S5GTRU13MSOP8MSOP8SGM4890U14SOP8-150+208SOP8-150+208W25Q128FVSIQ/128MBU15SOP8-150+208A9SOP8-150+208A9W25NO1GVZE1GU16MQFN128\0.35-12.3X12.3MQFN128\0.35-12.3X12.3QFN128 SSD222DU17SO8SO8NC/A24C512M8RU18SOT-23-5SOT-23-5FP6185-1V8/TMI6030-1V8U20AP6181_13P-BAP6181_13P-BNC/SSW102B_MU21SOT-23-5SOT-23-5FP6185-1V8/TMI6030-1V8U22BL-M8188FU3-BBL-M8188FU3-BNC/BL-M8188FU3-BVCOM1TP-0_6MMTP-0_6MMTPVR1VR-3296WVR-3296W50KY1XTALS-2_5X3_2MMXTALS-2_5X3_2MMCRYSTAL/24MHZ/3.2X2.5MM
老吴 发表于 2022-10-31 11:12
PCB文件来了。回复可见下载
**** Hidden Message *****
13131 发表于 2022-10-31 11:18
renjiawu 发表于 2022-10-31 11:51
谢谢
kof2000 发表于 2022-10-31 14:24
bidezhi7777 发表于 2022-10-31 14:25
cl422541179 发表于 2022-10-31 14:26
zxy20099 发表于 2022-10-31 16:02
00000845 发表于 2022-10-31 17:19
roezw 发表于 2022-10-31 19:00
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: 星宸SigmaStar (SSD222)SSD222D DEMO板PCB文件共享
