| Name | Part Type | PCB Decal | Value |
| ANT802 | ANT_P07-AB001F085 | ANT_P07-AB001F085_2013 | P07-AB001F085 |
| ANT803 | ANT_P07-AB001F085 | ANT_P07-AB001F085_2013 | P07-AB001F085 |
| ANT901 | ANT_P07-AB001F085 | ANT_P07-AB001F085_2013 | P07-AB001F085 |
| ANT903 | ANT_P07-AB001F085 | ANT_P07-AB001F085_2013 | P07-AB001F085 |
| D301 | DIODE_PSBD3D40V1H | DIODE_SOD-323 | PSBD3D40V1H |
| D302 | DIO_PZ3D4V2H | DIODE_UDZ5V6B_2011 | PZ3D4V2H |
| F801 | FILTER_TPRX_TPX205950MT-7110A1 | FILTER_SMD_TPX205950MT-7110A1 | TRPX / TPX205950MT-7110A1 |
| J401 | BATT_B50-AB04F221 | BATT_B50-AB04F22A_1407_0818_M5B | B50-AB04F221 |
| J410 | CON_FPC_2PIN_LED_0.5X2.3 | CON2-2.3X0.5-P1.0 | 2PIN 1.0p 0.5*2.3 |
| J501 | CON_FPC_2PIN_LED_0.5X2.3 | CON2-2.3X0.5-P1.0 | 2PIN 1.0p 0.5*2.3 |
| J503 | CON_SIM_S80-0B12F16A | S80-0B12F16A | S80-0B12F16A |
| J504 | CON_TF_T08-BB08F230 | T08-BB08F230 | T08-BB08F230 |
| J507 | CON_FPC_8PIN_0.8P_0.4X2.3 | CON_FPC_8PIN_0.8P_0.4X2.3 | 8PIN 0.8p 0.4x2..3 |
| J601 | CON_AXT524124_24PIN | AXT524124 | AXT524124 |
| J602 | CON_FPC_21PIN_0.4X2.3 | CON_FPC_21PIN_0.4X2.3 | 21PIN 0.4X2.5 |
| J603 | CON_6PIN_046298706000883 | CONN_6PIN_(046298004000883)_2011 | 04 6298 706 000 883+ |
| J604 | CON_PF030-O25B-C10-H | PF030-O25B-C10-H | PF030-O25B-C10-H |
| J701 | CON_FPC_6PIN_0.8P_0.4X2.2 | CON_FPC_6PIN_0.8P_0.4X2.2 | 6PIN 0.8p 0.4x2.2 |
| J702 | CON_FPC_4PIN_0.8P_0.4X2.5 | CON_FPC_4PIN_0.8P_0.4X2.5 | 4PIN 0.8p 0.4x2.5 |
| J703 | CON_AUDJACK_PH10-2B05F35A | PH10-2B05F35A | PH10-2B05F35A |
| J704 | CON_FPC_21PIN_0.4X2.5 | CON_FPC_21PIN_0.4X2.5 | 21PIN 0.4X2.5 |
| J901 | CON_RF_C90P106-00004AH | RF_C90P106-00004AH | C90P106-00004AH |
| J1001 | CON_ANT_70369-001E | COAXLAL-818000157 | 70369-001E |
| J1005 | CON_RF_C90P106-00004AH | RF_C90P106-00004AH | C90P106-00004AH |
| L304 | IND3X3_10UH_1.2MM | IND3X3 | 10uH 1.2MM |
| L333 | IND-BLM15HD102SN1D | BLM15B | 1000@100M_HD |
| L335 | IND-BLM15AX102SN1 | BLM15B | 1000@100M_AX |
| L402 | IND_WPN252012HR33MT | L_LQM2HPN2R2MG0_2011 | 0.33uH |
| L404 | IND_WPN201610UR47MT | L/IND/SMD/VLS201610E_1406 | 0.47uH 2016 |
| L405 | IND_WPN201610UR47MT | L/IND/SMD/VLS201610E_1406 | 0.47uH 2016 |
| L407 | IND_WPN201610UR47MT | L/IND/SMD/VLS201610E_1406 | 0.47uH 2016 |
| L410 | IND_SPH252010L2R2MT | L_LQM2HPN2R2MG0_2011 | 2.2uH 2520 |
| L501 | RES0402_0R_5% | RES0402 | 0 |
| L601 | RES0402_0R_5% | RES0402 | 0 |
| L612 | RES0201_33R_5% | RES0201 | 33 |
| L613 | RES0201_33R_5% | RES0201 | 33 |
| L701 | IND-BLM15AX102SN1 | BLM15B | 1000@100M_AX |
| L702 | IND-BLM15AX102SN1 | BLM15B | 1000@100M_AX |
| L705 | IND-UPZ1005D221-R90TF | BLM15B | 220@100M_AX |
| L706 | IND-UPZ1005D221-R90TF | BLM15B | 220@100M_AX |
| L707 | IND-BLM15BD182SN1D | BLM15B | 1800@100M_BD |
| L708 | IND-BLM15BD182SN1D | BLM15B | 1800@100M_BD |
| L709 | IND-BLM15BD182SN1D | BLM15B | 1800@100M_BD |
| L710 | IND-BLM15BD182SN1D | BLM15B | 1800@100M_BD |
| L800 | IND-BLM15AX102SN1 | BLM15B | 1000@100M_AX |
| L801 | IND0201_NC | IND0201 | IND0201 NC |
| L1159 | IND0201P_2.7NH | IND0201 | 2.7nH |
| M901 | RES0201_0R_5% | RES0201 | 0 |
| M903 | RES0201_0R_5% | RES0201 | NC |
| M904 | RES0201_0R_5% | RES0201 | NC |
| MARK1 | MARK_TB | MARK_TB | |
| MARK2 | MARK_TB | MARK_TB | |
| MOTOR | FPC_2PIN_1.1X2.0_P2.1 | FPC_2PIN_1.1X2.0_P2.1 | 2PIN 1.1X2.0 P2.1 |
| Q401 | MOS-SSM3K35MFV | 2-1L1B/SMD/SSM3K35MFV | SSM3K35MFV |
| REC1 | FPC_2PIN_1.1X2.0_P2.1 | FPC_2PIN_1.1X2.0_P2.1 | 2PIN 1.1X2.0 P2.1 |
| REC2 | FPC_2PIN_1.1X2.0_P2.1 | FPC_2PIN_1.1X2.0_P2.1 | 2PIN 1.1X2.0 P2.1 |
| T514 | ESD9L5.0ST5G_SOD-923 | ESD_SOD-923 | SOD923 ESD9L5.0ST5G |
| T515 | ESD9L5.0ST5G_SOD-923 | ESD_SOD-923 | SOD923 ESD9L5.0ST5G |
| T517 | SDV1005E090C800NPTF | VR0402 | 9V 80pf |
| T610 | TVS-ESD9M5.0ST5G_ESD_SOD-923 | ESD_SOD-923 | ESD9M5.0ST5G |
| T611 | TVS-ESD9M5.0ST5G_ESD_SOD-923 | ESD_SOD-923 | ESD9M5.0ST5G |
| T612 | TVS-ESD9M5.0ST5G_ESD_SOD-923 | ESD_SOD-923 | ESD9M5.0ST5G |
| T613 | TVS-ESD9M5.0ST5G_ESD_SOD-923 | ESD_SOD-923 | ESD9M5.0ST5G |
| T614 | TVS-ESD9M5.0ST5G_ESD_SOD-923 | ESD_SOD-923 | ESD9M5.0ST5G |
| T701 | ESD_ESDBVD5V0Y1 | ESD_0402 | 1.5pF 5V |
| T702 | ESD_ESDBVD5V0Y1 | ESD_0402 | 1.5pF 5V |
| T703 | TVS-ESD9M5.0ST5G_ESD_SOD-923 | ESD_SOD-923 | ESD9M5.0ST5G |
| T704 | TVS-ESD9M5.0ST5G_ESD_SOD-923 | ESD_SOD-923 | ESD9M5.0ST5G |
| T705 | TVS-ESD9M5.0ST5G_ESD_SOD-923 | ESD_SOD-923 | ESD9M5.0ST5G |
| T706 | TVS-ESD9M5.0ST5G_ESD_SOD-923 | ESD_SOD-923 | ESD9M5.0ST5G |
| T707 | TVS-ESD9M5.0ST5G_ESD_SOD-923 | ESD_SOD-923 | ESD9M5.0ST5G |
| T708 | TVS-ESD9M5.0ST5G_ESD_SOD-923 | ESD_SOD-923 | ESD9M5.0ST5G |
| T709 | ESD_ESDBVD5V0Y1 | ESD_0402 | 1.5pF 5V |
| T710 | ESD_ESDBVD5V0Y1 | ESD_0402 | 1.5pF 5V |
| T711 | ESD_ESDBVD5V0Y1 | ESD_0402 | 1.5pF 5V |
| T712 | ESD_ESDBVD5V0Y1 | ESD_0402 | 1.5pF 5V |
| T713 | ESD_ESDBVD5V0Y1 | ESD_0402 | 1.5pF 5V |
| T714 | ESD_ESDBVD5V0Y1 | ESD_0402 | 1.5pF 5V |
| T715 | TVS-ESD9M5.0ST5G_ESD_SOD-923 | ESD_SOD-923 | ESD9M5.0ST5G |
| T716 | ESD9L5.0ST5G_SOD-923 | ESD_SOD-923 | SOD923 ESD9L5.0ST5G |
| T717 | ESD9L5.0ST5G_SOD-923 | ESD_SOD-923 | SOD923 ESD9L5.0ST5G |
| T719 | ESD9L5.0ST5G_SOD-923 | ESD_SOD-923 | SOD923 ESD9L5.0ST5G |
| T720 | ESD_ESDBVD5V0Y1 | ESD_0402 | 1.5pF 5V |
| T721 | ESD_ESDBVD5V0Y1 | ESD_0402 | 1.5pF 5V |
| T728 | ESD_ESDBVD5V0Y1 | ESD_0402 | 1.5pF 5V |
| T800 | ESD_ESDPSA0402V05 | ESD_0402 | NC |
| TVS515 | TVS-ESD9M5.0ST5G_ESD_SOD-923 | ESD_SOD-923 | ESD9M5.0ST5G |
| TVS518 | TVS-ESD9M5.0ST5G_ESD_SOD-923 | ESD_SOD-923 | ESD9M5.0ST5G |
| U101 | IC-MT6735-LP3-E1-SBS_MAP0827A | MT6735/VFBGA641/P0.4/B0.25/12.6X12.6 | MT6735 |
| U300 | IC/MT6328-E1/XXXMM_41_205BALL_1503 | MT6328/VFBGA205/P0.4/B0.25/6.6X6.6_1503 | MT6328E1 |
| U405 | SGM3726YTD16G/TR_TDFN-2X2-6L | SGM3726YTD16G/TR_TDFN-2X2-6L | SGM3726 |
| U406 | CAP0805_47UF | CAP0805 | 47uF |
| U407 | STT818B_SOT23-6L | SOT23-6L(PT236T30E2/STT818B)_2011 | STT818B |
| U410 | TDFN10_SMD_P0.5_SGM3141B | TDFN10_SMD_P0.5_SGM3141B | SGM3141B |
| U501 | KXTJ2_1009 | KXTJ2_1.0_2013 | KXTJ2-1009 |
| U502 | ET4003YD18_2013 | ET4003YD_0.9MM_20140123 | ET4003YD18 |
| U503 | LDO_SGM2030_2.5V | SGM2030 | SGM2030-2.5YUDG4G/TR |
| U600 | EXC14CE900U | EXC14CE900U | EXC14CE900U |
| U601 | EXC14CE900U | EXC14CE900U | EXC14CE900U |
| U602 | EXC14CE900U | EXC14CE900U | EXC14CE900U |
| U603 | EXC14CE900U | EXC14CE900U | EXC14CE900U |
| U604 | EXC14CE900U | EXC14CE900U | EXC14CE900U |
| U605 | LDO_SGM2030 | SGM2030 | NC |
| U606 | EXC14CE900U | EXC14CE900U | EXC14CE900U |
| U608 | EXC14CE900U | EXC14CE900U | EXC14CE900U |
| U610 | EXC14CE900U | EXC14CE900U | EXC14CE900U |
| U611 | EXC14CE900U | EXC14CE900U | EXC14CE900U |
| U612 | LP_DDR3_FBGA221_P0.5/B0.27/11.5X13 | FBGA221_P0.5/B0.27/11.5X13/SAMSUNG | LPDDR3+eMMC |
| U613 | EXC14CE900U | EXC14CE900U | EXC14CE900U |
| U614 | EXC14CE900U | EXC14CE900U | EXC14CE900U |
| U615 | EXC14CE900U | EXC14CE900U | EXC14CE900U |
| U616 | EXC14CE900U | EXC14CE900U | EXC14CE900U |
| U701 | AW8736FCR | AW8736FCR | AW8736FCR |
| U801 | SAW_SAFEA2G45MC0F0A | SAW1411_2015 | SAFEA2G45MC0F0A |
| U802 | MT6625L_QFN40 | MT6625_SQFN40/SMD/P0.4/5X5 | QFN40/MT6625L |
| U803 | SAW_SF14-1575F5UUA1_2011 | SAW1411_2015 | SF14-1575F5UUA1 |
| U804 | BGU7005 | DALLAS/MAX2659_2011 | BGU7005 |
| U901 | SAW-SAFFB2G35AA0F0A | SAW1109/B1/2/3/5/7/17/39/2GEGSM_DRX_1404 | SAFFB2G35AA0F0A |
| U902 | LDM152G4910QC032TEMP | BALUN/LDM152G4910QC032TEMP_1404 | LDM152G4910QC032TEMP |
| U903 | LDM152G4910QC032TEMP | BALUN/LDM152G4910QC032TEMP_1404 | LDM152G4910QC032TEMP |
| U904 | SAW-SAFFB2G60AA1F0A | SAW1109/B1/2/3/5/7/17/39/2GEGSM_DRX_1404 | SAFFB2G60AA1F0A |
| U906 | MT6169/VFBGA175/P0.4/B0.25/6.2X5.4 | MT6169/VFBGA175/P0.4/B0.25/6.2X5.4 | MT6169 |
| U908 | KT2520F26000DCW28QAK | TCXO/SMD/2.5X2.0/KT2520F | KT2520F26000DCW28QAK |
| U909 | SPDT_/_SKYWORKS_/_SKY13373 | SKY13373 | SKY13373 |
| U910 | SAW-SAFFB1G90FB0F0A | SAW1109/B1/2/3/5/7/17/39/2GEGSM_DRX_1404 | SAFFB1G90FB0F0A |
| U1000 | PA_/_SKY77824-11 | SKY77824 | SKY77824-11 |
| U1001 | SAW_SAFEA2G60MA0F0A | SAW1411_2015 | SAFEA2G60MA0F0A |
| U1002 | SAW_SAFEA2G35MF0F0A | SAW1411_2015 | SAFEA2G35MF0F0A |
| U1004 | LF1608-B2R5KCB | RF_LPF_DEA162690LT_1404 | LF1608-B2R5KCB |
| U1011 | SAW_SAWEN1G84CW0F00R14 | SAW/SMD/SAWEN881MCY0F00R14 | SAWEN1G84CW0F00R14 |
| U1102 | SAW-SAWEN881MCY0F00R14 | SAW-SAWEN881MCY0F00R14 | SAWEN881MCY0F00R14 |
| U1103 | SAW-SAWFD1G90BK0F0A | SAW-SAWFD1G90BK0F0A | SAWFD1G90BK0F0A |
| U1104 | LDM152G4910QC032TEMP | BALUN/LDM152G4910QC032TEMP_1404 | LDM152G4910QC032TEMP |
| U1107 | SKY77910-11 | SKY77910 | SKY77910-11 |
| X401 | CRYSTAL_FC135_32.768_2011 | CRYSTAL_FC135_32.768_2011 | 32.768K |
| Y801 | KT2520P26000ACW28TAA_6620_2011 | KT2520P26000ACW28TAA_6620_2011 | KT2520P26000ACW28TAA |
