wallys 发表于 2022-11-8 13:49
Three networking methods of wireless mesh network/Wallys
MT7915/IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/IPQ5018/IPQ8072/IPQ8072A/IPQ8074/IPQ8074A/QCN6024/QCN9074/QCN9072/QCN9024/IPQ4018/IPQ4028/AR9223/QCA9880/QCA9882/AR9582/AR9531/AR9344 /AR9342/AX200NGW/QCA9531
The principle of the mesh router is that the Mesh client accesses the wireless Mesh router through a wireless connection. The wireless Mesh router forms a relatively stable forwarding network in the form of multi-hop interconnection.
Wireless mesh networks consist of meshrouters and meshclients, with meshrouters constituting backbone networks
Network and connect to wired internet network, responsible for providing mesh clients with multi-hop wireless internet connection, wireless Mesh network
Network, also known as "multi-hop" network, is a new wireless network technology that is completely different from the traditional wireless network. In the traditional wireless LAN
In WLAN, each client accesses the network through a wireless link connected to an Access Point (AP), forming a local BSS(Basic)
The Service Set). In order to communicate with each other, users must first access a fixed access point (AP), which is called a single-hop network.
https://www.imgeek.org/uploads/article/20221108/ebe6a4b54b7a8bb3aa442f909741693b.gif
In the wireless Mesh network, any wireless device node can serve as an AP and router at the same time, and each node in the network can send and receive signals.
Each node can communicate directly with one or more peer nodes.
In today's broadband speed, most people are not worried about high bandwidth, everyone is mainly concerned about whether the router signal can cover every corner of the home. Therefore, it is very important to choose a router, especially for large households or multi-storey buildings. The first thing to choose is a dual-band router. At the same time, a router is usually not enough.
Before the emergence and popularization of Mesh technology, we usually use wireless relay or wired second level router to extend the signal coverage of WIFI. Compared with previous extensions, Mesh is the most ideal solution.
A Mesh router, also known as a distributed router or a parent router, is usually composed of two routers. If you have a large home area, it can cover a very large area of WIFI if it is placed in a certain distance from your home.
The generated Mesh routers is a Mesh network, different devices in the network access points can to star, tree, series and bus way to hybrid networking, the advantage is able to make your equipment within the scope of automatic search for the best equipment and intelligent switch.
If the wifi coverage of one router in your home is not enough, the mesh network can connect several routers to change the wifi coverage to the range of these routers superplaced together, and then your mobile phone will always automatically connect to the router with the best signal, achieving seamless wifi roaming.
https://www.imgeek.org/uploads/article/20221108/cd02030bbb6c5e7b19774ac8cfc56c1f.png
What is the case with mesh networking?
To put it simply, the WiFi in your home can't cover some dead corners, but I can cover those dead corners by placing a router in the place where there is a signal. The router acts as the Mesh node of the relay, and then the relay router can cover those dead corners.
Features of wireless mesh network:
1. Simple and convenient networking construction
2. Configure dynamic synchronization
3. Support wired and wireless hybrid networking
4, contact me to repair
5. Seam roaming
Wireless mesh network is a stable and effective WiFi networking method for your home. If your house is too large and wifi coverage is not seamless, remember to switch to the mesh router.
Wallys has been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We're a supplier to Facebook.
Skype/EMAIL/Teams:sales@wallystech.com
WEB:https://www.wallystech.com/
查看完整版本: Three networking methods of wireless mesh network/Wallys
