wallys 发表于 2022-11-23 09:37
Wallys wifi5 router/DR40X9 QSDK IPQ4029/IPQ4019 and test MT7915 support openw
Today, I will introduce the wifi5 router DR40x9 of wallys. QSDK IPQ4029/IPQ4019 and test MT7915 support openwrt
In fact, this product is the best-selling product, because many places have not touched wifi6, so wifi5 products are very popular.
DR40x9 is based on Qualcomm IPQ4019 and IPQ4029 chips. Appropriate chips can be selected according to the project requirements. Normally, IPQ4019 is enough to meet the requirements.
The difference between the two chips is that the IPQ4029 is 5M,10M more than the IPQ4019, and everything else is the same.
2 x2 2.4 G & 5 G
Support HTTPS Support all the modules of Quectel
support mini pcie card
Support openwrt21.02.
If the version does not meet your project requirements, wallys can customize the product according to the customer's requirements. Of course, if there are major changes in hardware and software involved, NRE will be charged. I think we all know this.
Let's take a look at the test results of DR40x9 and DR7915 mini pcie cards. It can support 2.4G and 5G at the same time, which is a breakthrough for card design, because some projects require dual-frequency support instead of single-frequency support.
Let's have a look at the screenshots by using Wallys #DR4019 router board plus
DR7915 DBDC Wlan module combo.
When the DR7915 is inserted into the DR40X9 board, there are 4 radios that can
work at the same time, and it can be used as a soft router
https://www.wch.cn/uploads/image/20221122/1669099795349057.png
https://www.wch.cn/uploads/image/20221122/1669099795125859.png
As we can see, by using this combo,there will be 4 radios working at the same
time,and you can configure each radio into AP or STA mode as you wish.
DR7915 can work on OpenWrt 21.02 version OS directly, no need to install the driver
to support this MTK chipset.
We guess it would be a smart option as well to select #DR7915 for applications which
require Multi-radios,soft router, Mesh,bonding etc...
andyzhou666 发表于 2022-11-23 09:55
cy30404 发表于 2022-11-23 14:50
闪耀的空白 发表于 2022-11-24 08:13
多谢分享
清心如水 发表于 2022-11-24 08:47
jackychen456 发表于 2022-11-24 08:59
loveut2ran 发表于 2022-11-24 09:02
千叶999888 发表于 2022-11-24 09:14
查看完整版本: Wallys wifi5 router/DR40X9 QSDK IPQ4029/IPQ4019 and test MT7915 support openw
