wallys 发表于 2022-12-19 16:28
QSDK/wifi6 IPQ8072A-IPQ8074A/4T4R OpenWRT 10GE port 10G-SFP 2.4G and 5G
QSDK/industrial wifi6 routerboard/ IPQ8072A-IPQ8074A/4T4R OpenWRT 10GE port 10G-SFP 2.4G and 5G
As SoC is only one of the components of router, wireless network chip, switch chip, FEM, antenna gain, design and work materials will affect the overall performance.
The ipq8074/8072 are both quad-core A53 2.2GHz, 14nm manufacturing process, with dual-core NPU (network processor).
IPQ8074 is Qualcomm's first WiFi6 networking solution designed to meet the growing demands of an increasingly crowded and dense Wi-Fi environment. It offers the best configuration to bring unprecedented capacity and coverage to Wi-Fi networks, and supports several unique features to ensure the best Wi-Fi performance for all types of applications. Q8074A compared to IPQ8074, IPQ8074A adds MU-MIMO Uplink, OFDMA -- UL, MU-RTS (Multi-User Request To Send), Preamble Puncture, Spatial Reuse (OBSS PD) and other functions. Maximize payload data rate by increasing efficiency, reduce contention between STAs and improve channel utilization. This shows that IPQ8074A can have more stable and higher wireless data rate, anti-interference ability is also better.
DR8074A(HK01)
■ Qualcomm Atheros IPQ8074A AR Quad Core CPU■ On-board 5GHz radio, up to 4804Mbps physical data rate 32MB NOR Flash, 256MB NAND Flash
■ On-board 2.4GHz radio, up to 1147Mbps physical data rate■ Support 11ax TX Beamforming
■ Support 11ac/ax MU-MIMO DL and UL■ Support OFDMA DL and UL
■ Tri-band support with 5G SBS (4x4/5GHz + 4x4/5GHz) + 4x4/2.4GHz■ Supports Dynamic Frequency Selection (DFS)
Hardware Specifications
Symbol
Parameter
CPU
Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8074A 2.2GHz CPU
CPU Frequency
Derived from Qualcomm Atheros AP.HK01
System Memory
1GB (2x 512MB) DDR3L 32-bit interface
Frequency Range
2.412GHz to 2.472GHz, 5.150GHz to 5.825GHz
Modulation Techniques
OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
NGFF Slot for 5G Module
M.2 (NGFF) “B Key” Socket with PCIe 3.0 interface
Optional Onboard Modules
Supports 1x BT module,1x ZigBee module,1x Touch pad connector,1x Audio header,1x LCD display header
Flash
NOR Flash: 32MB NAND Flash: 256MB
eMMC: 8GB
Wireless
On-board 4x4 2.4GHz MU-MIMO 802.11b/g/n/ax, max TBDdBm per chain
On-board 2x(4x4) or 8x8 5GHz MU-MIMO 802.11a/802.11n/802.11ac/802.11ax, max TBDdBm per chain
12x U.FL connectors
Reset Buttons
2x Hardware reset button, 1x WPS reset button
DC Jack Input
1x DC Jack Connector: 12V, 5A
Interface
5x Gigabit Ethernet (1GbE) LAN/WAN RJ45 Port (Auto MDI-X) 1x 10Gigabit Ethernet (10GbE) LAN/WAN RJ45 Port (Auto MDI-X) 1x SFP+ Port
2x USB 3.0 Port
1x Serial Port 12 Pin Connector 1x JTAG 20 Pin Connector
1x micro SD Card Socket
1x M.2 Slot
LED
13x LED indicators, 2 additional LED on Ethernet port
Power Consumption
TBD
DR8072 V01
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU■ On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ 8 MB NOR Flash, 256MB NAND Flash(NAND Flash can be up to 1GB as optional)■ Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL
■ Supports Dynamic Frequency Selection (DFS)■ DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional)
■ M.2 connector can support QCN9074 production
Symbol
Parameter
CPU
Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8072A 2.2GHz CPU
CPU Frequency
Derived from Qualcomm Atheros AP.HK09
System Memory
1x 512MB, DDR4 2400MHz 16-bit interface(RAM can be up to 2GB as optional)
Frequency Range
2.412~2.472GHz, 5.150~5.825GHz
M.2 Slot
1x M.2 Slot with PCIe 3.0
Environmental Temperature
Operating: -20ºC to 70ºC, Storage: -40ºC to 90ºC
Flash
NOR Flash: 8 MB NAND Flash: 256MB(1GB optional)
Wireless
On-board 4x4 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 17dBm per chain On-board 4x4 5GHz MU-MIMO OFDMA 802.11a/802.11n/80.211ac/802.11ax, max 17dBm per chain
8x U.FL Connectors
Reset Buttons
1x S/W Reset Button
DC Jack Input
Interface
4x 1Gbps Ethernet Port, 1x 10Gbps Ethernet Port
1x 10Gbps SFP2x USB 3.0 Port
1x JTAG 20 Pin Connector 1x Serial Port 4 Pin Connector
LED
2x RGB LED Indicators
Power Consumption
TBD
https://www.wallystech.com/ueditor/php/upload/image/20211217/1639706058929218.jpgCommercial processes and communications are all managed utilising wireless technologies, and the number of users, devices and apps are only going to increase.Therefore, it is essential to have a robust, secure and high performing WiFi solution that is future-proofed, mobile, and scalable.Not only is business WiFi vital for your workforce and organisation, it is now imperative for visitors to be able to access a secure guest wireless network.
Wallys has been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We're a supplier to Facebook.Skype/EMAIL/Teams:sales@wallystech.com
WEB:https://www.wallystech.com/
love欣 发表于 2022-12-19 16:41
bidinghong 发表于 2022-12-19 17:05
hellotxdpj 发表于 2022-12-19 17:10
chinachen 发表于 2022-12-19 19:05
罗塘阮经天 发表于 2022-12-19 22:00
魏伟 发表于 2022-12-19 22:42
317 发表于 2022-12-20 00:02
Re:read_h1
谢谢分享!
nj20044 发表于 2022-12-20 00:10
·风来了 发表于 2022-12-20 08:07
页: [1] 2 3 4 5 6
查看完整版本: QSDK/wifi6 IPQ8072A-IPQ8074A/4T4R OpenWRT 10GE port 10G-SFP 2.4G and 5G
