Industrial wifi6 router/wifi6-Qualcomm-IPQ6010/IPQ6018-Wallys
MT7915/IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/IPQ5018/IPQ8072/IPQ8072A/IPQ8074/IPQ8074A/QCN6024/QCN9074/QCN9072/QCN9024/IPQ4018/IPQ4028/AR9223/QCA9880/QCA9882/AR9582/AR9531/AR9344 /AR9342/AX200NGW/QCA9531.Wallys' products It is also constantly upgraded, from WIFI5 to WIFI6, the chipset is also from IPQ4019 to IPQ8074 and so on, Wallys is always the most cutting-edge wireless technology of the times!
EMAIL:sales2@wallystech.com
WEB:https://www.wallystech.com/
This section describes three Wallys RouterBoards based on Qualcomm IPQ6010/IPQ6018 chips. DR6018, DR6018C, V01, DR6018S.
Let's talk a little bit about the parameters.
DR6018 and DR6018C V01, support :QUECTEL RM500Q-GL&Support: QCN9074 WiFi 6 e card, 802.11ax, IPQ6010, support 2.4g&5g OpenWRT 2×2.
The difference is that DR6018 does not have SFP and DR6018C V01 has SFP.
Compared with the previous two Routerboards, DR6018S has fewer network ports and no SFP. Therefore, DR6018S cannot be used with a moudle.
DR6018
https://www.wallystech.com/Routerboard/DR6018V4-wifi6-Qualcomm-IPQ6010-IPQ6018-FAMILY-2T2R-2.5G-ETH-port-supporting-5G-celluar-Modem-802-11AX-MU-MIMO-OFDMA.html
QCN9074 WiFi 6E Card OpenWRT, IPQ6010,802.11ax,
2×2 2.4G&5G 2.5Gbps Ethernet Port Support OpenWRT Support:QUECTEL RM500Q-GL&Support:
Qualcomm-Atheros IPQ6010
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
32MB NOR Flash, 256MB NAND Flash
Supports Dynamic Frequency Selection (DFS)
2×2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate
2×2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
Support:QUECTEL RM500Q-GL&Support:QCN9074 WiFi 6E Card,802.11ax,IPQ6010
DR6018C V01
https://www.wallystech.com/Routerboard/DR6018CV01-wifi6-Qualcomm-IPQ6010-IPQ6018-FAMILY-2T2R-2.5G-ETH-port-supporting-5G-celluar-Modem-802-11AX-MU-MIMO-OFDMA-SFP.html
Support OpenWRT 2×2 2.4G&5G 2.5Gbps Ethernet Port SFP
DR6018-S
https://www.wallystech.com/Routerboard/DR6018-S-V02-wifi6-Qualcomm-IPQ6010-2T2R-2-GE-port-supporting-QCN9074-wifi-card-802.11AX-MU-MIMO-OFDMA.html
DR6018-S V02 IPQ6010/IPQ6018/IPQ6000
8MB NOR Flash, 256MB NAND Flash
QCN9074/QCN9024/QCN6024 series moudle
Support 2.4G/5G/6G, single frequency. 支持 加油
