老吴 发表于 2023-4-3 11:40
MC6630+4个FH6210 16路DVR  PCB文件共享 挂2个DDR4
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEB1BEEP_RB12_8_BEEPBEEPRB12_8BT1BATTERY_CR1220-2_DISCRETE_CR122CR1220CR1220-2D1TSOP4838_1_A3638ASEN3-100-0606D3SBD_SOT_23_LBAT54CLT1GLBAT54CLT1GSOT_23D4PESD5V0X1BLPESD5V0X1BLHSOD882D5PESD5V0X1BLPESD5V0X1BLHSOD882D6PESD5V0X1BLPESD5V0X1BLHSOD882D7PESD5V0X1BLPESD5V0X1BLHSOD882D8PESD5V0X1BLPESD5V0X1BLHSOD882D10PESDALC10N5VURCLAMP0524PMLF10-050-0301LD11PESD5V0X1BLPESD5V0X1BLHSOD882D12PESD5V0X1BLPESD5V0X1BLHSOD882D13PESD5V0X1BLPESD5V0X1BLHSOD882D14PESD5V0X1BLPESD5V0X1BLHSOD882D15BAT60BE6327BAT60BE6327HSOD323AD16PESD5V0X1BLPESD5V0X1BLHSOD882D181SMA13CAT3G1SMA13CAT3GSD1710AD24TVS_DO-214AA_SPD4200BSPD4200BDO-214AAD30PESD5V0X1BLPESD5V0X1BLHSOD882D31PESD5V0X1BLPESD5V0X1BLHSOD882D32P3100_ESD0603_NC/PUSI1608S170_1NC/PUSI1608S170ESD0603D33P3100_ESD0603_NC/PUSI1608S170_1NC/PUSI1608S170ESD0603D34TVS_DO-214AA_SPD4200BSPD4200BDO-214AAD35TVS_DO-214AA_SPD4200BSPD4200BDO-214AAD36TVS_DO-214AA_SPD4200BSPD4200BDO-214AAD39TVS_DO-214AA_SPD4200BSPD4200BDO-214AAD40TVS_DO-214AA_SPD4200BSPD4200BDO-214AAD41TVS_DO-214AA_SPD4200BSPD4200BDO-214AAD42TVS_DO-214AA_SPD4200BSPD4200BDO-214AAD43PESDALC10N5VURCLAMP0524PMLF10-050-0301LD44TVS_DO-214AA_SPD4200BSPD4200BDO-214AAE28ESD_PCB_ESD_PCB_NC_ESD_PCBNC_ESD_PCBESD_PCBF10451005MRL0451005MRLSF6127ID1PCB_MARKPOINTID-BOARDID-BOARDID2PCB_MARKPOINTID-BOARDID-BOARDID3PCB_MARKPOINTID-BOARDID-BOARDID4PCB_MARKPOINTID-BOARDID-BOARDID5PCB_MARKPOINTID-BOARDID-BOARDID6PCB_MARKPOINTID-BOARDID-BOARDJ8DC2026_00PWC3_APWC0103-M-CJ10SATA_7_SATA7-M-A_SATASOCKETSATASOCKETSATA7-M-AJ11ZH1.5-4PWBC1X41FPC4-1_5-9_2X3_8-H5_1J12DB15-3M2_DB15-3RF-A_DB15-3M2DB15-3M2DB15-3RF-AJ14CON-RJ45&USBX2_RJC5_RJ45&USBX2RJ45&USBx2RJC5J16HDMIHDMISOCKETRUSB19-050-1512J23SATA_POWER_SIP-4P-200_SATA_POWESATA_POWERSIP-4P-200J26ZH1.5-4PWBC1X41FPC4-1_5-9_2X3_8-H5_1J102RCA1X2_RCA1X2_RCA1X2RCA1X2RCA1X2J105BNC4_0_BNC4_BNC4X1BNC4X1BNC4J106BNC4_0_BNC4_BNC4X1BNC4X1BNC4J107BNC4_0_BNC4_BNC4X1BNC4X1BNC4J109BNC4_0_BNC4_BNC4X1BNC4X1BNC4J110SATA_7_SATA7-M-A_SATASOCKETSATASOCKETSATA7-M-AL1INDUCTORFERRITE_L5X5H4_4.7UH4.7uHL5X5H4L2INDUCTORFERRITE_L2X2H2_2.2UH2.2uHL2X2H2L3INDUCTORFERRITE_L4X4H3_1.0UH1.0uHL4X4H3L4INDUCTORFERRITE_L5X5H4_4.7UH4.7uHL5X5H4L5INDUCTORFERRITE_0_SL0603_150NH150nHSL0603L6INDUCTORFERRITE_0_SL0603_150NH150nHSL0603L7INDUCTORFERRITE_0_SL0603_150NH150nHSL0603L9INDUCTORFERRITE_L2X2H2_2.2UH2.2uHL2X2H2L10INDUCTORFERRITE_L2X2H2_2.2UH2.2uHL2X2H2L11BEAD_SR0603_30OHM/100MHZ30ohm/100MHzSR0603LB10BEAD_SL0402_1000OHM/100MHZ1000ohm/100MHzSL0402LB11BEAD_SL0402_1000OHM/100MHZ1000ohm/100MHzSL0402LB12BEAD_SL0402_1000OHM/100MHZ1000ohm/100MHzSL0402LB13BEAD_SL0603_30OHM/100MHZ30ohm/100MHzSL0603LB18BEAD_SL0402_1000OHM/100MHZ1000ohm/100MHzSL0402LB19BEAD_SL1210_600OHM/100MHZ600ohm/100MHzSL1210LB20BEAD_SL1210_600OHM/100MHZ600ohm/100MHzSL1210LB83BEAD_SL0402_1000OHM/100MHZ1000ohm/100MHzSL0402LB94BEAD_SL0402_1000OHM/100MHZ1000ohm/100MHzSL0402LB96BEAD_SL0402_1000OHM/100MHZ1000ohm/100MHzSL0402LB97BEAD_SL0402_1000OHM/100MHZ1000ohm/100MHzSL0402LB99BEAD_SL0402_1000OHM/100MHZ1000ohm/100MHzSL0402LB100BEAD_SL1210_600OHM/100MHZ600ohm/100MHzSL1210LB101BEAD_SL0603_30OHM/100MHZ30ohm/100MHzSL0603LB102BEAD_SL0603_30OHM/100MHZ30ohm/100MHzSL0603LB103BEAD_SL0603_30OHM/100MHZ30ohm/100MHzSL0603LB104BEAD_SL0603_30OHM/100MHZ30ohm/100MHzSL0603LB105BEAD_SL0603_30OHM/100MHZ30ohm/100MHzSL0603LB106BEAD_SL0603_30OHM/100MHZ30ohm/100MHzSL0603LB107BEAD_SL0603_30OHM/100MHZ30ohm/100MHzSL0603LB108BEAD_SL0603_30OHM/100MHZ30ohm/100MHzSL0603LB109BEAD_SL0603_30OHM/100MHZ30ohm/100MHzSL0603LB110BEAD_SL0402_1000OHM/100MHZ1000ohm/100MHzSL0402LB121BEAD_SL0402_1000OHM/100MHZ1000ohm/100MHzSL0402LB122BEAD_SL0402_1000OHM/100MHZ1000ohm/100MHzSL0402LB123BEAD_SL0603_30OHM/100MHZ30ohm/100MHzSL0603LB124BEAD_SL0603_30OHM/100MHZ30ohm/100MHzSL0603LB125BEAD_SL0603_30OHM/100MHZ30ohm/100MHzSL0603LB126BEAD_SL0603_30OHM/100MHZ30ohm/100MHzSL0603LB127BEAD_SL0603_30OHM/100MHZ30ohm/100MHzSL0603LB128BEAD_SL0603_30OHM/100MHZ30ohm/100MHzSL0603LB129BEAD_SL0603_30OHM/100MHZ30ohm/100MHzSL0603LB130BEAD_SL0603_30OHM/100MHZ30ohm/100MHzSL0603LB131BEAD_SL0603_30OHM/100MHZ30ohm/100MHzSL0603LB132BEAD_SL0603_30OHM/100MHZ30ohm/100MHzSL0603LB133BEAD_SL0402_1000OHM/100MHZ1000ohm/100MHzSL0402LB134BEAD_SL0402_1000OHM/100MHZ1000ohm/100MHzSL0402LED3LED_LED0603_YELLOWYELLOWLED0603LED4LED_LED0603_BLUEBLUELED0603LED5LED_LED0603_REDREDLED0603LED6LED_SD0805-LED_REDREDSD0805-LEDM1138MIL_STAR_HOLE_TO_M3_ANCHOLE160-8STARM2138MIL_STAR_HOLE_TO_M3_ANCHOLE160-8STARM3138MIL_STAR_HOLE_TO_M3_ANCHOLE160-8STARQ42N835_SOT-23_S8050S8050SOT-23RN26R8P4R_0_SRN8-0804_3333SRN8-0804SW2PUSH_BUTTON_KEY_2PIN_RESETResetKEY_2PINT5PAD1-SQ_PAD_SMD_001_S005_NC-PANC-PAD-0.5X0.5PAD_SMD_001_S005U1MP1605_3_HSOT-563_MP1605MP1605HSOT-563U4GD25Q127CSIG_WSON8-MX25L12835ZNGD25Q127CSIGWSON8-MX25L12835ZNU5GD25Q127CSIG_WSON8-MX25L12835ZNGD25Q127CSIGWSON8-MX25L12835ZNU8MP1605_3_HSOT-563_MP1605MP1605HSOT-563U10K4A4G165WF-BCTDK4A4G165WF-BCTDBGA96-32-1609MU12MP1495S_TSOT23-8_MP1495SMP1495STSOT23-8U14ESD5305F-6/TR_0_SOT23-6L_ESD530ESD5305F-6/TRSOT23-6LU15MP1495S_TSOT23-8_MP1495SMP1495STSOT23-8U17MP1653_HSOT-563_MP1653MP1653HSOT-563U21MP1652_HSOT-563_MP1652MP1652HSOT-563U35YJ_QFN88_DVP_QFN88_YJ_FH6210FH6210QFN88_YJU37H1601CG_SOP16_270_50_H1601CGH1601CGSOP16_270_50U38YJ_QFN88_DVP_QFN88_YJ_FH6210FH6210QFN88_YJU44TPS51200TPS51200UQFN-10PINU189TPS79301DBVR_SOT23_6_TPS79301DBTPS79301DBVRSOT23_6U195CAT811CAT811SOT-143U196MC6650_0_BGA462-32-2323_(S1+S2+MC6650BGA462-32-2323U197K4A4G165WF-BCTDK4A4G165WF-BCTDBGA96-32-1609MU198ESD5305F-6/TR_0_SOT23-6L_ESD530ESD5305F-6/TRSOT23-6LU199YJ_QFN88_DVP_QFN88_YJ_FH6210FH6210QFN88_YJU200YJ_QFN88_DVP_QFN88_YJ_FH6210FH6210QFN88_YJU202SN74LVC2G34DBVRSN74LVC2G34DBVRSOT23-6-P095-H1_45U203SN74LVC2G34DBVRSN74LVC2G34DBVRSOT23-6-P095-H1_45X1M24000E02724MHzHSX4-0302X2CRY_HSX2-0302_32.768KHZ32.768KHZHSX2-0302Y1OSC4P_HSX4-0302B_27MHZ27MHZHSX4-0302BY2OSC4P_HSX4-0302B_27MHZ27MHZHSX4-0302B
老吴 发表于 2023-4-3 11:41
1、产品特点
6合1 DVR产品解决方案(6合1),支持高清模拟视频编码,高清模拟+高清 IP输入,纯高清IP输入支持VGA、HDMI输出;
支持多种云技术,实现摄像头网络穿透 与DVR对接,支持报警信息推送功能手机支持远程访问,DDNS实现一键远程监控;
具有UTC功能,可通过UTC功能调整摄像机菜单参数;
支持H.264/H.265(HEVC) IP摄像机 支持IP摄像机地址批量修改,远程添加摄像机设备;
支持AHD/TVI/CVI/CVBS/IP 五合一及自识别
可对接市场主流IP摄像机品牌(私有协议或 Onvif);
支持其他基于ONVIF2.4(IP模式)的第三方产品;
支持VGA、HDMI同时显示,最大分辨率高达HDMI 1080P。
录像回放可按时间显示,录像类型以颜色显示,可搜索 检索方便、高效;
可按时间、时长安排记录备份,准确无误 秒;
预览画面可以随机交换。图片位置没有改变 物理地址变更,方便施工
支持多国语言
提供配套的Web、CMS SDK服务;
支持多种播放模式:快进、慢放、快退等。 最大16倍快进或快退
支持WEB、VMS,支持android/IOS移动系统支持P2P,二维码扫描,APP播放
支持TVI同轴音频输入,也支持AHD同轴音频输入。
2、产品参数
System
Main processor
MC6650
Operation system
Embedded LINUX operation system
System resources
Multichannel real time record
Multichannel real time playback
multichannel multi-user on network operation
Interface
Operation system
graphic menu operation interface, support mouse to operate
Image display
1/4/6/9/16 screen
Language
English, traditional Chinese, simplified Chinese, Japanese, Russian, German, Italian, Turkish,
polish, Spanish, Korean, Indonesian, Thai, Arabic, Persian, Vietnamese, French, Portuguese,
Greek, Czech
Video
Image coding
H.264/H.265
Surveillance quality
VGA(Max 1080P);HDMI(Max 1080P), CVBS optional
Preview
16*5MN@12fps/16*4MN@15fps/16*1080P@30fps
Code capacity
16*5MN@5fps/16*4MN@8fps/16*1080N@15fps
Decode capacity
4*5MN@5fps/16*D1@12fps
Various mode input
Coaxial: 16*5MP-N
Mixed: 4MP-N(coaxial)+1080P (IP) Arbitrary combination for coaxial and IP hybrid mode
IP: 8*5MP, 16*5MP for all IP mode
Recognize method
Automatic Identification 、All AHD、All TVI、All CVI、Customized
Motion detection
192 (16*12) testing areas can be set for each image;
can set multi-sensitivity (only for local channel and P6S IP camera)
Audio
Audio compression
G.711U
Audio output
HDMI, support extended audio output.
Audio Input
Can extend to 4ch audio In.
intercom
Support extend audio in and out intercom
coaxial audio
Support 16ch coaxial audio
Record &
Playback
Video mode
manual>alarm>dynamic testing>timing
Local playback
16CH (5MP-N coaxial input)
16CH (Coaxial or Hybrid mode);
16ch IP mode
Playback mode
Fast playback, Playback by Time, Smart playback
Record retrieval
Time retrieval, event retrieval, Timeline retrieval, channel retrieval 、Intelligent playback(Motion
detection playback)
Storage&
Backup
Occupation
1080P 10-15G/day*channel; 720P 10G/day*channel; 960H 6-10G/day*channel; Audio:691.2M/day*channel
Record storage
Local hard disk; network
Backup mode
Network backup 、USB , SATA record
VMS
Type
IE/mobile/VMS
P2P
Support(IOS, Android, PC)
APP
Multi-screen surveillance; audio surveillance; mobile record; snap; pan-tile control; remote record playback
UTC
Camera OSD control
Support
Pan-tilt control
Don’t support
3D-NR
Support auto/manual setting for noise reduction parameters
Port
Video input
16ch BNC; support coaxial audio in
Video output
1ch VGA ,1ch HDMI; 1ch TV output(Optional)
Audio output
HDMI output/Extended 1ch RCA audio output
Network port
RJ45 10M/100M Self-adapt to Ethernet interface
USB port
2 USB 2.0 port
HDD port
2 SATA Port (Can support 8T HDD)
Wifi port
NO
Remote control
Optional
Others
Power
12V/2A(Sufficient amperes)
Consumption
< 15W (exclusive hard disk)
Temperature
-5 °C~ +55 °C
Working humidity
10%~90%
老吴 发表于 2023-4-3 11:44
PCB文件来了。 回复可见下载。没有原理图
**** Hidden Message *****
bidezhi7777 发表于 2023-4-3 12:13
魏伟 发表于 2023-4-3 13:52
jielove2003 发表于 2023-4-3 14:39
shuszhao 发表于 2023-4-3 14:50
lf2k2022 发表于 2023-4-4 08:29
mirage 发表于 2023-4-4 09:29
roezw 发表于 2023-4-4 11:03
页: [1] 2 3 4
查看完整版本: MC6630+4个FH6210 16路DVR  PCB文件共享 挂2个DDR4
