查看: 2350|回复: 13
allegro17.4转PADS9.5,遇到的报错,请问怎么解决
发表于 2023-4-26 09:09:28 | 显示全部楼层 |阅读模式
ERROR: Techfile conversion failed!
WARNING: layer BOTTOM not found in layer table.  Check the Allegro cross-section!
WARNING: layer TOP not found in layer table.  Check the Allegro cross-section!
WARNING:  No route border found, bounding box used!
ERROR: no data issued for clearance DEFAULT
WARNING: layer SOLDERMASK_TOP not found in layer table.  Check the Allegro cross-section!
WARNING: layer SOLDERMASK_BOTTOM not found in layer table.  Check the Allegro cross-section!
WARNING: layer PASTEMASK_TOP not found in layer table.  Check the Allegro cross-section!
WARNING: layer PASTEMASK_BOTTOM not found in layer table.  Check the Allegro cross-section!
WARNING: layer FILMMASKTOP not found in layer table.  Check the Allegro cross-section!
WARNING: layer FILMMASKBOTTOM not found in layer table.  Check the Allegro cross-section!
ERROR: Unable to issue shapes for padstack PAD19 - layer problems
ERROR: Unable to issue shapes for padstack PAD20 - layer problems
ERROR: Unable to issue shapes for padstack PAD45 - layer problems
ERROR: Unable to issue shapes for padstack PAD14 - layer problems
ERROR: Unable to issue shapes for padstack PAD32 - layer problems
ERROR: Unable to issue shapes for padstack PAD34 - layer problems
ERROR: Unable to issue shapes for padstack PAD4 - layer problems
ERROR: Unable to issue shapes for padstack PAD5 - layer problems
ERROR: Unable to issue shapes for padstack PAD24 - layer problems
ERROR: Unable to issue shapes for padstack PAD1 - layer problems
ERROR: Unable to issue shapes for padstack PAD33 - layer problems
ERROR: Unable to issue shapes for padstack PAD27 - layer problems
ERROR: Unable to issue shapes for padstack PAD28 - layer problems
ERROR: Unable to issue shapes for padstack PAD26 - layer problems
ERROR: Unable to issue shapes for padstack PAD30 - layer problems
ERROR: Unable to issue shapes for padstack PAD29 - layer problems
ERROR: Unable to issue shapes for padstack PAD31 - layer problems
ERROR: Unable to issue shapes for padstack PAD21 - layer problems
ERROR: Unable to issue shapes for padstack PAD43 - layer problems
ERROR: Unable to issue shapes for padstack PAD44 - layer problems
ERROR: Unable to issue shapes for padstack PAD22 - layer problems
ERROR: Unable to issue shapes for padstack PAD16 - layer problems
ERROR: Unable to issue shapes for padstack PAD35 - layer problems
ERROR: Unable to issue shapes for padstack PAD36 - layer problems
ERROR: Unable to issue shapes for padstack PAD6 - layer problems
ERROR: Unable to issue shapes for padstack PAD7 - layer problems
ERROR: Unable to issue shapes for padstack PAD23 - layer problems
ERROR: Unable to issue shapes for padstack PAD3 - layer problems
ERROR: Unable to issue shapes for padstack PAD38 - layer problems
ERROR: Unable to issue shapes for padstack PAD39 - layer problems
ERROR: Unable to issue shapes for padstack PAD40 - layer problems
ERROR: Unable to issue shapes for padstack PAD25 - layer problems
ERROR: Unable to issue shapes for padstack PAD8 - layer problems
ERROR: Unable to issue shapes for padstack PAD37 - layer problems
ERROR: Unable to issue shapes for padstack PAD46 - layer problems
ERROR: Unable to issue shapes for padstack PAD48 - layer problems
ERROR: Unable to issue shapes for padstack PAD47 - layer problems
ERROR: Unable to issue shapes for padstack PAD41 - layer problems
ERROR: Unable to issue shapes for padstack PAD42 - layer problems
ERROR: Unable to issue shapes for padstack STANDARDVIA - layer problems
WARNING: layer internal_pad_def not found in layer table.  Check the Allegro cross-section!
WARNING: layer ~TSM not found in layer table.  Check the Allegro cross-section!
WARNING: layer ~BSM not found in layer table.  Check the Allegro cross-section!
WARNING: layer ~TPM not found in layer table.  Check the Allegro cross-section!
WARNING: layer ~BPM not found in layer table.  Check the Allegro cross-section!
WARNING: layer ~TFM not found in layer table.  Check the Allegro cross-section!
WARNING: layer ~BFM not found in layer table.  Check the Allegro cross-section!
WARNING: layer ~ALV not found in layer table.  Check the Allegro cross-section!
    1元学习Allegro(1期)
    发表于 2023-4-26 13:50:20 | 显示全部楼层
    你这个直接Allegro转的?
     楼主| 发表于 2023-4-26 13:56:14 | 显示全部楼层
  • 签到天数: 7 天
    发表于 2023-5-15 09:03:08 | 显示全部楼层
    发表于 2023-6-30 23:38:20 | 显示全部楼层
    昨天 15:43
  • 签到天数: 58 天
    发表于 2023-11-13 08:30:35 | 显示全部楼层
    昨天 15:43
  • 签到天数: 58 天
    发表于 2023-11-15 08:24:31 | 显示全部楼层
    昨天 15:43
  • 签到天数: 58 天
    发表于 2023-12-2 09:36:08 | 显示全部楼层
    发表于 2023-12-12 10:17:42 | 显示全部楼层
    终身成就奖原创先锋奖
    发表于 2023-12-13 08:49:42 | 显示全部楼层
