armclub 发表于 2023-4-26 09:57
台湾联詠NT96670+TP9950+NV255H 做的高清行车记录仪PCB文件共享
NamePart TypePCB DecalValueBAT1CAP-5.8MAHMS621FE_FL11EML414H/1mAhCON1LTT-020ESLNFPC40-0.5-A-T1LTT-150ESLNCON2CON4FPC4P-H1.54*0.5*1.5D11N5818SOD123DSK34_3AD2LED0603D-0603REDD31N5818SOD323IN5819D4LED0603D-0603BLUED61N5818SOD123DSK34_3AD7DIODE_SCHOTTKYSOD5231N4148WTD91N5818SOD123DSK34D101N5818SOD123DSK34J2CON2_1.0CON2P-1.0-SMD-CCON1.0*2立贴J3CON25-0.3FPC_0.3MM_25PIN_BJ4CON25-0.3FPC_0.3MM_25PIN_BJ5CONCON-FPC05-26-T-11J7CON2_1.0CON2P-1.0-SMD-CCON1.0*2立贴L1L2520L25202.2uHL2RESISTOR_2R04020RL3INDUCTOR_2L0603100M/600RL4RESISTOR_2R04020RL15INDUCTORCD302.2uHL16INDUCTORCD302.2uHL17INDUCTORCD302.2uHMIC1MICROPHONEMIC-4013-SMTMICROPHONEQ1FDN338P_0SOT23AO3401Q2MOSFET_P_SGD_1SOT23AO2302Q3FDN338P_0SOT23AO3401Q4MOSFET-N_2SOT-23SI2302Q5FDN338P_0SOT23AO2301Q6DDTCEMT3DDTC124EEQ7DDTCEMT3DDTC124EEQ8MOSFET_P_SGD_1SOT23SI2302Q9DDTCEMT3DDTC124EERP1RESISTOR_4PACKR0402S422RRP3RESISTOR_4PACKR0402S422RRP4RESISTOR_4PACKR0402S4220RRP5RESISTOR_4PACKR0402S4220RRP6RESISTOR_4PACKR0402S410kS8SMT6-SHIELDSMT6_SHIELDTestPointSD1MINI_CARDMINI_CARD_NEWMicro_SDSW1SW_PUSHBUTTON_0TS1188MENUSW2SW_PUSHBUTTON_0TS1188MODEU1GSENSOR/BMA250E_1LGA12/2X2-GSC7A20U2NT96510_12BGA96670-288P-0.65MM_12X12NT96670U3FS8807-APV_1FS8807-APVWS3202EU4DDRIII_DRAM_3BGA96_DDR3_X16NT5CB2GM16APU5RT9166_0SOT-23PCX6209A-33U6RT9266PE_3SOT26SY7208U7RT-DS8097B-SOT-23-6_1SOT23-6RT-DS8097U8SERIAL_FLASH_0DIP8-SOP1KH25L3206EU9RT9193-33_2SOT-23-5RT9078-18U10AMP/PAM8302A_2LM4990LM4890U11RT9193-33_2SOT-23-5RT9078-30U12RT9167-NNCB_5SOT23_5PCX4055U13RT9020SOT-23-5RT9078-12/NCU14CM2830A_2SOT-23-5RT8059U15RT9193-33_2SOT-23-5RT9078-30U16CM2830A_8SOT-23-5RT8059U17RT9193-33_2SOT-23-5PCX6209B-25U18RT9020SOT-23-5RT9078-12U19RT9193-33_2SOT-23-5ME6209B-33U20TP2850_HD-TVI_DEC_MIPI_2-LANE_0E-QFN40TP9950U21TCM809SSOT23CL7809SS(2.93V)U22NV255H_2NV255NV255HWIFI_ANTRT9166_1WIFICONAANTY3XM/SM_4XTAL-MC14632.768KHz_AT1405-032768-12-20-NAY4SMD3225SMD322512M-20ppm
armclub 发表于 2023-4-26 09:59
PCB文件。10RMB 需要的下载
i_333333 发表于 2023-4-26 10:01
非常感谢楼主大神的分享
bidezhi7777 发表于 2023-4-26 10:44
mirage 发表于 2023-4-26 13:01
妍晔爱pcb 发表于 2023-4-26 13:43
wangxinyue 发表于 2023-4-26 14:13
果 发表于 2023-4-26 22:52
zspdeyc 发表于 2023-4-26 22:58
cat 发表于 2023-4-26 23:48
页: [1] 2 3 4 5 6 7 8
查看完整版本: 台湾联詠NT96670+TP9950+NV255H 做的高清行车记录仪PCB文件共享
