老吴 发表于 2023-5-19 10:31
CZ001BBCZ  RF ANT SWITCH  PCB文件
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEC1C_CAPC2013X140N_47UF47uFCAPC2013X140NC2C_CAPC1005X55N_0.1UF0.1uFCAPC1005X55NC3C_CAPC2013X140N_47UF47uFCAPC2013X140NC4C_CAPC1005X55N_0.1UF0.1uFCAPC1005X55NC5C_CAPC1005X55N_0.1UF0.1uFCAPC1005X55NC6C_CAPC2013X140N_47UF47uFCAPC2013X140NC7C_CAPC2013X140N_47UF47uFCAPC2013X140NC8C_CAPC1005X55N_1UF1uFCAPC1005X55NC10C_CAPC1608X90N_10UF10uFCAPC1608X90NC21C_CAPC1005X55N_0.1UF0.1uFCAPC1005X55NC42C_CAPC1005X55N_15PF15pFCAPC1005X55NC43C_CAPC1005X55N_15PF15pFCAPC1005X55NC44C_CAPC1005X55N_0.1UF0.1uFCAPC1005X55NC45C_CAPC1005X55N_0.1UF0.1uFCAPC1005X55NC48C_MC0201_0.1UF0.1uFMC0201C49C_MC0201_0.1UF0.1uFMC0201C80C_CAPC1005X55N_0.1UF0.1uFCAPC1005X55NC81C_CAPC1005X55N_33PF33pFCAPC1005X55NC82C_CAPC1005X55N_33PF33pFCAPC1005X55NC83C_CAPC1005X55N_33PF33pFCAPC1005X55NC84C_CAPC1005X55N_33PF33pFCAPC1005X55NC85C_0402_100PF100pF402C86C_0402_100PF100pF402C87C_0402_NCNC402C88C_0402_NCNC402C89C_0402_NCNC402C90C_0402_NCNC402C91C_CAPC1005X55N_33PF33pFCAPC1005X55NC92C_CAPC1005X55N_33PF33pFCAPC1005X55NC93C_CAPC1005X55N_33PF33pFCAPC1005X55NC94C_CAPC1005X55N_33PF33pFCAPC1005X55NC95C_0402_100PF100pF402C96C_0402_NCNC402C97C_0402_NCNC402C98C_0402_100PF100pF402C99C_0402_NCNC402C100C_0402_NCNC402C111C_0402_10UF10uF402C112C_0402_10UF10uF402C113C_MC0201_100PF100pFMC0201C114C_MC0201_100PF100pFMC0201C115C_0402_82PF82pF402C116C_0402_82PF82pF402C117C_0402_10UF10uF402C118C_0402_10UF10uF402C119C_MC0201_100PF100pFMC0201C120C_MC0201_100PF100pFMC0201C121C_0402_1000PF1000pF402C122C_0402_100PF100pF402C123C_0402_NCNC402C124C_0402_NCNC402C125C_0402_NCNC402C126C_0402_NCNC402C127C_CAPC1005X55N_0.1UF0.1uFCAPC1005X55NC128C_CAPC1608X90N_10UF10uFCAPC1608X90NC130C_CAPC1005X55N_0.01UF0.01uFCAPC1005X55NC131C_0402C_10UF10uF0402CC132C_0402C_0.01UF0.01uF0402CC133C_0402C_1UF1uF0402CC134C_0402C_10UF10uF0402CC135C_0402C_0.01UF0.01uF0402CC136C_0402C_10UF10uF0402CC137C_0402C_0.01UF0.01uF0402CC139C_0402C_10UF10uF0402CC140C_0402C_0.01UF0.01uF0402CC141C_0402C_10UF10uF0402CC142C_0402C_0.1UF0.1uF0402CC143C_CAPC1608X90N_10UF10uFCAPC1608X90NC144C_CAPC1005X55N_0.1UF0.1uFCAPC1005X55NC147C_0402C_10UF10uF0402CC148C_0402C_0.01UF0.01uF0402CC150C_0402C_10UF10uF0402CC152C_0402C_0.01UF0.01uF0402CC153C_0402C_10UF10uF0402CC154C_0402C_0.01UF0.01uF0402CC155C_0402C_10UF10uF0402CC156C_0402C_0.01UF0.01uF0402CC157C_CAPC1005X55N_10UF10uFCAPC1005X55NC158C_0402C_0.01UF0.01uF0402CC159C_0402C_10UF10uF0402CC160C_0402C_0.01UF0.01uF0402CC697CAP_0402_1UF_6.3V1uF_6.3V402C2016CAP_0402_0.1UF_16V0.1uF_16V402C2018CAP_0402_100PF_50V100pF_50V402C2019CAP_0603_10UF_6.3V10uF_6.3V603C2023CAP_0402_0.1UF_16V0.1uF_16V402C2024CAP_0603_10UF_6.3V10uF_6.3V603C2025CAP_0402_4700PF_50V4700pF_50V402C2231C_0402C_1UF_NC1uF_NC0402CC2232C_CAPC1608X90N_10UF10uFCAPC1608X90NC2233C_CAPC2013X140N_47UF47uFCAPC2013X140NC2234C_CAPC1005X55N_0.1UF0.1uFCAPC1005X55NC2235C_CAPC2013X140N_47UF47uFCAPC2013X140NC2236C_CAPC1005X55N_0.1UF0.1uFCAPC1005X55NC2237C_CAPC1005X55N_0.1UF0.1uFCAPC1005X55NC2238C_MC0201_0.01UF0.01uFMC0201C9225C_CAPC1608X90N_10UF10uFCAPC1608X90NC9226C_CAPC2013X140N_47UF47uFCAPC2013X140NC9227C_CAPC1005X55N_0.1UF0.1uFCAPC1005X55NC9228C_CAPC2013X140N_47UF47uFCAPC2013X140NC9229C_CAPC1005X55N_0.1UF0.1uFCAPC1005X55NC9230C_CAPC1005X55N_0.1UF0.1uFCAPC1005X55NC9231C_MC0201_0.01UF0.01uFMC0201C9245C_MC0201_100PF100pFMC0201C9246C_MC0201_100PF100pFMC0201C9247CAP_0402_0.1UF_16V0.1uF_16V402C9248CAP_0603_10UF_6.3V10uF_6.3V603C9249CAP_0603_10UF_6.3V10uF_6.3V603C9250CAP_0402_0.1UF_16V0.1uF_16V402C9251CAP_0603_10UF_6.3V10uF_6.3V603C9252CAP_0402_0.1UF_16V0.1uF_16V402C9253C_CAPC2013X140N_47UF47uFCAPC2013X140NC9254C_0402C_0.01UF_NC0.01uF_NC0402CC9255C_0402C_0.01UF_NC0.01uF_NC0402CC9256C_0402C_0.01UF_NC0.01uF_NC0402CC9259C_CAPC1005X55N_33PF33pFCAPC1005X55NC9260C_CAPC1005X55N_33PF33pFCAPC1005X55NC9261CAP_0402_10UF_6.3V10uF_6.3V402C9262CAP_0402_10UF_6.3V10uF_6.3V402D1LED_LEDC1608X60N_LED_GREENLED_GREENLEDC1608X60ND2LED_LEDC1608X60N_LED_GREENLED_GREENLEDC1608X60NF301FERRITE_BEAD_0603_11_3A_NC11_3A_NC603FB4BEAD_0805_22R@100MHZ6A22R@100MHz6A805FB5BEAD_0805_22R@100MHZ6A22R@100MHz6A805FB6BEAD_0805_70R@100MHZ2.5A70R@100MHz2.5A805FB7BEAD_0603_220R@100MHZ1A220R@100MHz1A603FB8BEAD_0402_120R@100MHZ0.45A120R@100MHz0.45A402FB9BEAD_0402_120R@100MHZ0.45A120R@100MHz0.45A402FB10BEAD_0402_120R@100MHZ0.45A120R@100MHz0.45A402FB11BEAD_0402_120R@100MHZ0.45A120R@100MHz0.45A402FB12BEAD_0402_120R@100MHZ0.45A120R@100MHz0.45A402FB13BEAD_0402_120R@100MHZ0.45A120R@100MHz0.45A402FB14BEAD_0402_120R@100MHZ0.45A120R@100MHz0.45A402FB15BEAD_0402_120R@100MHZ0.45A120R@100MHz0.45A402FB16BEAD_0402_120R@100MHZ0.45A120R@100MHz0.45A402FB20BEAD_0805_70R@100MHZ2.5A_NC70R@100MHz2.5A_NC805FB21BEAD_0603_220R@100MHZ1A_NC220R@100MHz1A_NC603FB22BEAD_BEADC1005X55N_600R@100MHZ_600R@100MHz_0.5ABEADC1005X55NFB23BEAD_BEADC1005X55N_600R@100MHZ_600R@100MHz_0.5ABEADC1005X55NJ1FMC_LPC_ASP-134604-01_(S1+S2+S3ASP-134604-01ASP-134604-01J2CON2_4_CON20VP2R54-1X2TM_CON2_NCON2_NCCON20VP2R54-1X2TMJ21CON2_4_CON20VP2R54-1X2TM_CON2_NCON2_NCCON20VP2R54-1X2TMJ25CON2_4_CON20VP2R54-1X2TM_CON2CON2CON20VP2R54-1X2TMJ43SMA_SMA_6565_D05_S17_SMASMASMA_6565_D05_S17J44SMA_SMA_6565_D05_S17_SMASMASMA_6565_D05_S17J46SMA_SMA_6565_D05_S17_SMASMASMA_6565_D05_S17J47SMA_SMA_6565_D05_S17_SMASMASMA_6565_D05_S17J62RFC_SMA_SMA_6464_W13_SMASMASMA_6464_W13L1INDUCTOR_XFL4020-222MEB_2.2UH2.2uHXFL4020-222MEBR1R_RESC1005X40N_100R_NC100R_NCRESC1005X40NR2R_RESC1005X40N_100R_NC100R_NCRESC1005X40NR3R_RESC1005X40N_100R_NC100R_NCRESC1005X40NR4R_RESC1005X40N_0R0RRESC1005X40NR5R_RESC1005X40N_0R0RRESC1005X40NR6R_RESC1005X40N_0R0RRESC1005X40NR7R_RESC1005X40N_0R0RRESC1005X40NR8R_RESC1005X40N_0R0RRESC1005X40NR9R_RESC1005X40N_0R0RRESC1005X40NR10R_RESC1005X40N_0R0RRESC1005X40NR11R_RESC1005X40N_0R0RRESC1005X40NR12R_RESC1005X40N_100R_NC100R_NCRESC1005X40NR13R_RESC1005X40N_0R0RRESC1005X40NR14R_0402R_100R_NC100R_NC0402RR15R_RESC1005X40N_0R0RRESC1005X40NR16R_RESC1005X40N_0R0RRESC1005X40NR17R_RESC1005X40N_0R0RRESC1005X40NR18R_RESC1005X40N_100R_NC100R_NCRESC1005X40NR19R_0402R_100R_NC100R_NC0402RR20R_RESC1005X40N_0R0RRESC1005X40NR21R_RESC1005X40N_0R0RRESC1005X40NR22R_RESC1005X40N_0R0RRESC1005X40NR23R_RESC1005X40N_0R0RRESC1005X40NR24R_RESC1005X40N_0R0RRESC1005X40NR25R_RESC1005X40N_0R0RRESC1005X40NR26R_0402R_100R_NC100R_NC0402RR27R_RESC1005X40N_0R0RRESC1005X40NR28R_0402R_100R_NC100R_NC0402RR29R_RESC1005X40N_0R0RRESC1005X40NR30R_RESC1005X40N_0R0RRESC1005X40NR31R_RESC1005X40N_0R0RRESC1005X40NR33R_RESC1005X40N_0R0RRESC1005X40NR39R_RESC1005X40N_0R0RRESC1005X40NR40R_RESC1005X40N_0R0RRESC1005X40NR41R_RESC1005X40N_0R0RRESC1005X40NR42R_RESC1005X40N_0R0RRESC1005X40NR43R_RESC1005X40N_0R0RRESC1005X40NR44R_RESC1005X40N_0R0RRESC1005X40NR45R_RESC1005X40N_0R0RRESC1005X40NR49R_RESC1005X40N_0R0RRESC1005X40NR50R_RESC1005X40N_0R0RRESC1005X40NR51R_RESC1005X40N_0R0RRESC1005X40NR52R_RESC1005X40N_0R0RRESC1005X40NR53R_RESC1005X40N_0R0RRESC1005X40NR54R_RESC1005X40N_0R0RRESC1005X40NR56R_RESC1005X40N_0R0RRESC1005X40NR57R_RESC1005X40N_100R*100R*RESC1005X40NR58R_RESC1005X40N_0R0RRESC1005X40NR59R_RESC1005X40N_100R*100R*RESC1005X40NR60R_RESC1005X40N_0R0RRESC1005X40NR61R_RESC1005X40N_100R*100R*RESC1005X40NR62R_RESC1005X40N_0R0RRESC1005X40NR63R_RESC1005X40N_0R0RRESC1005X40NR64R_RESC1005X40N_0R0RRESC1005X40NR65R_0402R_100R*100R*0402RR66R_RESC1005X40N_0R0RRESC1005X40NR67R_RESC1005X40N_0R0RRESC1005X40NR68R_0402R_100R*100R*0402RR69R_RESC1005X40N_0R0RRESC1005X40NR70R_RESC1005X40N_0R0RRESC1005X40NR71R_RESC1005X40N_0R0RRESC1005X40NR72R_RESC1005X40N_0R0RRESC1005X40NR73R_0402R_100R*100R*0402RR74R_RESC1005X40N_0R0RRESC1005X40NR75R_RESC1005X40N_0R0RRESC1005X40NR76R_0402R_100R*100R*0402RR77R_RESC1005X40N_0R0RRESC1005X40NR78R_RESC1005X40N_0R0RRESC1005X40NR80R_RESC1005X40N_0R0RRESC1005X40NR81R_RESC1005X40N_0R0RRESC1005X40NR82R_RESC1005X40N_0R0RRESC1005X40NR83R_RESC1005X40N_0R0RRESC1005X40NR84R_RESC1005X40N_0R0RRESC1005X40NR85R_RESC1005X40N_0R0RRESC1005X40NR86R_RESC1005X40N_330R330RRESC1005X40NR87R_RESC1005X40N_10R10RRESC1005X40NR88R_RESC1005X40N_4.7K4.7KRESC1005X40NR89R_RESC1005X40N_10K_1%10K_1%RESC1005X40NR90R_RESC1005X40N_20K_1%20K_1%RESC1005X40NR91R_R1206_0R0RR1206R92R_R1206_0R0RR1206R97R_RESC1005X40N_0R0RRESC1005X40NR98R_RESC1005X40N_0R0RRESC1005X40NR99R_RESC1005X40N_0R*0R*RESC1005X40NR100R_RESC1005X40N_0R*0R*RESC1005X40NR103R_RESC1005X40N_0R0RRESC1005X40NR104R_RESC1005X40N_49.9R49.9RRESC1005X40NR106R_RESC1005X40N_NCNCRESC1005X40NR113R_RESC1005X40N_4.7K4.7KRESC1005X40NR114R_0402R_0R0R0402RR115R_RESC1005X40N_0R_NC0R_NCRESC1005X40NR116R_RESC1005X40N_0R_NC0R_NCRESC1005X40NR117R_RESC1005X40N_0R_NC0R_NCRESC1005X40NR119R_RESC1005X40N_0R0RRESC1005X40NR120R_RESC1005X40N_100K_1%100K_1%RESC1005X40NR121R_RESC1005X40N_0R_NC0R_NCRESC1005X40NR122R_RESC1005X40N_4.7K4.7KRESC1005X40NR123R_RESC1005X40N_4.7K4.7KRESC1005X40NR124R_RESC1005X40N_4.7K4.7KRESC1005X40NR125R_RESC1005X40N_4.7K4.7KRESC1005X40NR126R_RESC1005X40N_330R330RRESC1005X40NR135R_0402_NCNC402R136R_0402_NCNC402R137R_0402_NCNC402R138R_0402_NCNC402R161R_RESC1005X40N_33R33RRESC1005X40NR162R_RESC1005X40N_33R33RRESC1005X40NR163R_RESC1005X40N_33R33RRESC1005X40NR164R_RESC1005X40N_33R33RRESC1005X40NR261RES_0603_3.74K_F3.74k_F603R315RES_0603_2.37K_F2.37k_F603R1648RES_0402_NC/15K*NC/15k*402R1649R_RESC1005X40N_10K_1%10K_1%RESC1005X40NR1650R_RESC1005X40N_14K_1%14K_1%RESC1005X40NR1651R_RESC1005X40N_10K_1%10K_1%RESC1005X40NR1655R_R0805_0R0RR0805R7221R_RESC1005X40N_0R0RRESC1005X40NR7222R_RESC1005X40N_10K_1%10K_1%RESC1005X40NR7223R_RESC1005X40N_14K_1%14K_1%RESC1005X40NR7224R_RESC1005X40N_10K_1%10K_1%RESC1005X40NR7225R_R0805_0R0RR0805R7226RES_0402_00402R7227RES_0402_00402R7231RES_0402_00402R7232RES_0402_00402R7233RES_0402_00402R7234RES_0402_00402R7237RES_0402_00402R7238RES_0402_00402R7239R_R0805_0R0RR0805R7240RES_0402_00402R7246RES_0402_00402R7247R_R0805_0R0RR0805R7248R_RESC1005X40N_0R0RRESC1005X40NR7249RES_0402_0_NC0_NC402R7250R_R0805_0R0RR0805R7251R_R0805_0R0RR0805R7252R_R0805_0R0RR0805R7253R_R0805_0R0RR0805R7254R_RESC1005X40N_0R_NC0R_NCRESC1005X40NR7255R_RESC1005X40N_0R0RRESC1005X40NR7256R_RESC1005X40N_0R0RRESC1005X40NR7257R_RESC1005X40N_0R_NC0R_NCRESC1005X40NR7258R_RESC1005X40N_0R0RRESC1005X40NR7259R_RESC1005X40N_0R0RRESC1005X40NR7260R_RESC1005X40N_0R0RRESC1005X40NR7261R_RESC1005X40N_0R0RRESC1005X40NR7262R_R0805_0R0RR0805SW1SENS59025-SPST_RES400_SENS59025SENS59025-SPSTRES400T1BL17J50100_TRAN6SM_0R65_2R15X1RHHM1564A4TRAN6SM_0R65_2R15X1R4T2BL_BD1722J50100A00_TRAN6SM_0R_1BD0810J50100AHFTRAN6SM_0R65_2R15X1R4T3BL_BD1722J50100A00_TRAN6SM_0R_23700BL15B050TRAN6SM_0R65_2R15X1R4T4BL_BD1722J50100A00_TRAN6SM_0R_35400BL15B100TRAN6SM_0R65_2R15X1R4T7BL_BD1722J50100A00_TRAN6SM_0R_23700BL15B050TRAN6SM_0R65_2R15X1R4T8BL_BD1722J50100A00_TRAN6SM_0R_4HHM1533TRAN6SM_0R65_2R15X1R4T9BL_BD1722J50100A00_TRAN6SM_0R_50900BL15C050ETRAN6SM_0R65_2R15X1R4T10BL_BD1722J50100A00_TRAN6SM_0R652500BL14M050TRAN6SM_0R65_2R15X1R4TP39TP_TP0R80_NCNCTP0R80TP40TP_TP0R80_NCNCTP0R80TPV1CON1_PAD_NCNCPADTPV9CON1_VIA_D32_NCNCVIA_D32TPV14CON1_VIA_D32_NCNCVIA_D32TPV15CON1_TPV0R40_NCNCTPV0R40TPV16CON1_TPV0R40_NCNCTPV0R40TPV17CON1_TPV0R40_NCNCTPV0R40TPV18CON1_TPV0R40_NCNCTPV0R40TPV19CON1_TPV0R40_NCNCTPV0R40U1ADP2164ACPZ_2_ADP2164ACPZ_ADP21ADP2164ACPZADP2164ACPZU5CZ001BBCZ_2_BGA144_0R80_10X10_CCZ001BBCZBGA144_0R80_10X10U8SPDT_BGS12P2L6_BGS12SN6BGS12SN6BGS12P2L6U9SPDT_BGS12P2L6_BGS12SN6BGS12SN6BGS12P2L6U112NCP59744_QFN20EP_0R65_5X5_TPS74TPS74401RGWRQFN20EP_0R65_5X5U113ADP1755ACPZ-R7_QFN16_4X4_PAD2_1ADP1741ACPZ-R7QFN16_4X4_PAD2_1X2_1U116ADP1755ACPZ-R7_QFN16_4X4_PAD2_1ADP1741ACPZ-R7QFN16_4X4_PAD2_1X2_1X8SMA_132134-15_132134-15132134-15132134-15X9SMA_SMA_6565_D05_S17_SMASMASMA_6565_D05_S17Y1XTAL3225_0_CO4-2R5X3R2-S_XTAL32XTAL3225CO4-2R5X3R2-S
老吴 发表于 2023-5-19 10:33
PCB文件。回复可见
**** Hidden Message *****
i_333333 发表于 2023-5-19 10:33
非常感谢楼主大神的分享
wangxinyue 发表于 2023-5-19 11:02
ize 发表于 2023-5-19 11:25
bidezhi7777 发表于 2023-5-19 13:49
巴霍巴利 发表于 2023-5-19 14:06
amwqqw5200 发表于 2023-5-19 14:22
止损 发表于 2023-5-19 14:23
6666666666666666666
kamenrider 发表于 2023-5-19 16:32
页: [1] 2 3 4
查看完整版本: CZ001BBCZ  RF ANT SWITCH  PCB文件
