重要提示:PCB作品文件展下载说明
本板块需要二级以上才能下载(100积分自动升级),没二级以上不要购买下载附件,购买也下载不了--->>>>点这里可以充值快速升级
下载板块默认-5金币,如果会员有销售附件需要扣销售金币+板块5金币,最少要保证你的积分>=100+5+附件销售金额,否则下载不了。
| Comment | Pattern | Quantity | Components | | | | | | | | 0Ω DNP | 0603_R | 1 | R52 | 0603WAF0000T5E | | 0Ω | 0603_R | 3 | R4, R12, R51 | 0603WAF0000T5E | | 1.5KΩ | 0603_R | 1 | R27 | 0603WAF1501T5E
C22843 | | 100nF | 0603_C | 16 | C3, C6, C11, C24, C35, C38, C40, C41, C43, C44, C47, C58, C78,C83, C85, C87 | CL10B104KO8NFNC | | 100uF | CAP_AL_SMT_100uF | 2 | C1, C26 | EEEHA1V101P
JLC C336419 | | 100Ω | 0603_R | 1 | R2 | 0603WAF1000T5E
JLC C22775 | | 10KΩ | 0603_R | 8 | R6, R15, R24, R33, R35, R44, R45, R57 | 0603WAF1002T5E
JLC C25804 | | 10nF | 0402_C | 2 | C19, C88 | GRM155R71H103KA88D | | 10nF | 0603_C | 1 | C68 | GRM155R71H103KA88D | | 10pF | 0603_C | 5 | C63, C64, C65, C66, C67 | CL10C100JB8NNNC | | 10uF | 0603_C | 10 | C2, C36, C37, C39, C42, C46, C54, C56, C59, C77 | CL10A106KP8NNNC | | 10uF | CAP_SMT_AL_10uF_DC | 2 | C29, C30 | EMVE160ADA100MD55G | | 10uH | INDUCTOR 4.7_10 TOGETHER | 4 | L1, L2, L3, L4 | 1274AS-H-100M=P3, Murate | | 110pF | 0603_C | 2 | C21, C22 | CC0603JRNPO9BN111 | | 16.2KΩ | 0603_R | 2 | R13, R14 | AC0603FR-0716K2L | | 1KΩ | 0603_R | 2 | R11, R42 | 0603WAF1001T5E
C21190 | | 1nF | 0603_C | 4 | C31, C32, C33, C34 | CL10B102KB8NNNC
JLC C1588 | | 1uF | 0603_C | 5 | C7, C18, C55, C79, C86 | CL10A105KB8NNNC | | 2.2KΩ | 0603_R | 4 | R7, R8, R53, R54 | 0603WAF2201T5E | | 2.2uF | 0603_C | 2 | C81, C82 | CL10A225KO8NNNC
JLC C23630 | | 2.2uH | INDUCTOR_SLO0630H2R2MTT | 1 | L6 | SLO0630H2R2MTT | | 200KΩ | 0603_R | 2 | R25, R26 | 0603WAF2003T5E
JLC C25811 | | 200Ω | 0603_R | 1 | R41 | 0603WAF2000T5E
JLC C8218 | | 20pF | 0402_C | 2 | C51, C53 | GRM1555C1H200JA01D | | 210KΩ | 0603_R | 1 | R32 | 0603WAF2103T5E
JLC C22952 | | 220nF | 0603_C | 1 | C50 | CL10B224KB8NNNC
JLC C64705 | | 22pF | 0603_C | 1 | C52 | CL10C220JB8NNNC
JLC C1653 | | 22uF | 0805_C | 12 | C4, C23, C45, C62, C69, C70, C71, C72, C73, C74, C75, C76 | C2012X5R1V226M125AC
JLC C2179409 | | 23.2KΩ ±1% | 0603_R | 1 | R9 | RC0603FR-0723K2L | | 27pF | 0603_C | 2 | C60, C61 | CL10C270JB8NNNC
JLC C1656 | | 2KΩ | 0603_R | 1 | R5 | AC0603FR-072KL | | 2N7002-7-F | MOSFET, N-CH, 2N7002-7-F | 1 | Q1 | 2N7002-7-F
JLC C85049 | | 33Ω | 0603_R | 3 | R20, R21, R22 | 0603WAF330JT5E
JLC C23140 | | 4.7KΩ | 0603_R | 7 | R1, R3, R10, R47, R48, R50, R55 | 0603WAF4701T5E
JLC C23162 | | 4.7nF | 0603_C | 1 | C27 | 0603B472K500NT
JLC C53987 | | 4.7uF | 0603_C | 7 | C5, C8, C15, C25, C48, C49, C84 | GRM188R6YA475KE15D | | 4.7uH | INDUCTOR_SWPA60 series | 1 | L5 | SWPA6045S4R7NT | | 470KΩ | 0603_R | 1 | R29 | 0603WAF4703T5E
JLC C23178 | | 470nF | 0603_C | 4 | C10, C13, C14, C16 | CL10B474KA8NNNC
JLC C1623 | | 49.9Ω | 0603_R | 6 | R30, R36, R37, R38, R39, R40 | 0603WAF499JT5E | | 5.1KΩ | 0603_R | 1 | R28 | RC0603JR-075K1L | | 51KΩ | 0603_R | 1 | R46 | 0603WAF5102T5E
JLC C23196 | | 5A, 4.5-30V Sync BuckConverter | SO8E | 1 | U14 | SY8205FCC, 5A, 4.5-30V Sync Buck Converter | | 5V_EXT | testpoint_SMD | 1 | TP5 | Testpoint SMT | | 5V_LDO | Tie_point | 1 | T12 | | | 680nF | 1206_C | 4 | C9, C12, C17, C20 | CL31B684KBHNNNE
JLC C307578 | | 680Ω | 0603_R | 1 | R23 | 0603WAF6800T5E
JLC C23228 | | 68KΩ | 0603_R | 1 | R43 | 0603WAF6802T5E
JLC C23231 | | 68nF | 0603_C | 1 | C28 | CL10B683KB8NNNC
C31658 | | 68Ω | 0603_R | 4 | R16, R17, R18, R19 | 0603WAF680JT5E
JLC C27592 | | 73.2K | 0603_R | 1 | R31 | AC0603FR-0773K2L | | 8K2 ±1% | 0603_R | 1 | R56 | AC0603FR-078K2L | | ACM8625 | TSSOP28PP ACM3128 BIG LF | 1 | U1 | ACM8625; TSSOP 28 | | ADR/GPIO2 | Header, 100mil, 2pins | 1 | J3 | PZ254V-11-02P | | Analog Input | 3.5mm_Audio_Jack_35RASMT4BHNTRX | 1 | J7 | 35RASMT4BHNTRX | | BAT | Terminal_R2.3 | 1 | T9 | | | BCLK_TP | testpoint_SMD | 1 | TP7 | Testpoint SMT | | BCLK | Header, 100MIL, 3PINS | 1 | J4 | PZ254V-11-03P | | CH341T | CH341 | 1 | U11 | CH341T | | CLASSH | Header, 100mil, 2pins | 1 | J8 | PZ254V-11-02P | | ClassH | testpoint_SMD | 1 | TP17 | Testpoint SMT | | CP2112 F03 GMR | CP2112 | 1 | U13 | CP2112-F03-GM, QFN24
C2678020 JLC | | DVDD | Header, 100MIL, 3PINS | 1 | J13 | PZ254V-11-03P | | ETA1188 | QFN3X3FC_20P | 1 | U12 | ETA1188 | | Fault | 0603_R | 1 | D1 | XL-1608SURC-04 | | FSYNC_TP | testpoint_SMD | 1 | TP8 | Testpoint SMT | | FSYNC | Header, 100MIL, 3PINS | 1 | J5 | PZ254V-11-03P | | GND | Terminal_R2.3 | 1 | T6 | | | GND | testpoint_SMD | 3 | TP10, TP11, TP18 | Testpoint SMT | | GPIO1/SDOUT | Header, 100mil, 2pins | 1 | J12 | PZ254V-11-02P | | heatsink_bottom | Heatsink_bottom | 1 | H1 | | | Keystone 5102 | Jumper Link surface | 1 | J2 | Keystone 5102 | | LDO, 1A, DFN3x3-6, VIN1.6-5.5V | DFN3x3-6 | 2 | U9, U10 | | | NA | 0603_C | 1 | C80 | 0603CG220G500NT | | NA | 0603_R | 1 | R49 | | | OUT_L- | Terminal_R2.3 | 1 | T2 | | | OUT_L+ | Terminal_R2.3 | 1 | T1 | | | OUT_R- | Terminal_R2.3 | 1 | T3 | | | OUT_R+ | Terminal_R2.3 | 1 | T4 | | | OUTA-_PWM | testpoint_SMD | 1 | TP2 | Testpoint SMT | | OUTA+_PWM | testpoint_SMD | 1 | TP1 | Testpoint SMT | | OUTB-_PWM | testpoint_SMD | 1 | TP3 | Testpoint SMT | | OUTB+_PWM | testpoint_SMD | 1 | TP4 | Testpoint SMT | | PCM9211PTR | LQFP48_PCM9211 | 1 | U5 | digikey part number:296-27688-2-ND
PCM9211PTR
JLC C181660 | | PDNz | Switch Button - Small | 1 | S1 | TL3365AF180QG, E-Switch | | Power ON | 0603_R | 1 | D4 | BL-HGE36G-AV-TRB | | PVDD_BST | Tie_point | 1 | T8 | | | PVDD_EXT | Tie_point | 1 | T7 | | | PVDD | Terminal_R2.3 | 1 | T5 | | | SCL | Header, 100MIL, 3PINS | 1 | J9 | PZ254V-11-03P | | SCL | testpoint_SMD | 1 | TP12 | Testpoint SMT | | SDA | Header, 100MIL, 3PINS | 1 | J10 | PZ254V-11-03P | | SDA | testpoint_SMD | 1 | TP13 | Testpoint SMT | | SDIN_TP | testpoint_SMD | 1 | TP6 | Testpoint SMT | | SDIN | Header, 100MIL, 3PINS | 1 | J6 | PZ254V-11-03P | | SN74AVC4T774RSV | SN74AVC4T774RSV (UQFN16) | 1 | U3 | SN74AVC4T774RSV | | SN74LVC1G14DCKR | SN74LVC1G14DCKT | 1 | U6 | JLC C35740 | | SP0503BAHTG | SP0503BAHTG-SOT143-4_V | 1 | D3 | JLC C7074
TVS Diode Array, 30 pF, 30 KV, -40 to 85 degC, 4-Pin SOT143, RoHS, Tape andReel | | SPDIF-IN | PLR135_T10 | 1 | U4 | PLR135/T10 | | SPDIF-LOCK | 0603_R | 1 | D2 | XL-1608BGWC-06 | | SPDIF-OUT | EAPLTAA4 | 1 | U7 | EAPLTAA4 | | TCA9406DCUR | TCA9406DCUR (DCR R-PDS0-G8) | 1 | U2 | Voltage Level TranslatorBidirectional 1 Circuit 2 Channel 24Mbps 8-VSSOP
A 1.65V~3.6V; B 2.3V~5.5V | | TYPEC | type c_type2 | 1 | J11 | KH-TYPE-C-16P | | VR_DIG | testpoint_SMD | 1 | TP9 | Testpoint SMT | | VREG_AVDD | testpoint_SMD | 1 | TP16 | Testpoint SMT | | XTAL | XTAL-5x3.2 | 1 | Y2 | TXM12.000M2503LDCE-O00T | | XTAL | XTAL-ABM10 | 1 | Y1 | ABM10-24.576MHZ-E20-T |
重要提示:PCB作品文件展下载说明
