老吴 发表于 2023-7-12 17:50
首发-国产飞腾腾 云S5000C 服务器主板14层PCB文件 挂16条DDR5
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMED11DIODE_SOD_323_M_LBAT40HT1GLBAT40HT1GSOD_323_MD26DIODE_SOD_323_M_LBAT40HT1GLBAT40HT1GSOD_323_MD27MLVS0603M04_ESDPAD_R0402_LESD9DLESD9D5.0CT5GESDPAD_R0402D28MLVS0603M04_ESDPAD_R0402_LESD9DLESD9D5.0CT5GESDPAD_R0402D29MLVS0603M04_ESDPAD_R0402_LESD9DLESD9D5.0CT5GESDPAD_R0402D30MLVS0603M04_ESDPAD_R0402_LESD9DLESD9D5.0CT5GESDPAD_R0402D31LBAT54ALT1G_SOT_23_M_LBAT54ALT1LBAT54ALT1GSOT_23_MD41DIODE_SOD_323_M_LBAT40HT1GLBAT40HT1GSOD_323_MD42DIODE_SOD_323_M_LBAT40HT1GLBAT40HT1GSOD_323_MD43LBAT54CLT1G_SOT23_3N00X1N40-3N_LBAT54CLT1GSOT23_3N00X1N40-3ND44DIODE_SOD_323_M_LBAT40HT1GLBAT40HT1GSOD_323_MD45DIODE_SOD_323_M_LBAT40HT1GLBAT40HT1GSOD_323_MD46DIODE_SOD_323_M_LBAT40HT1GLBAT40HT1GSOD_323_MD47DIODE_SOD_323_M_LBAT40HT1GLBAT40HT1GSOD_323_MD48DIODE_SOD_323_M_LBAT40HT1GLBAT40HT1GSOD_323_MD49DIODE_SOD_323_M_LBAT40HT1GLBAT40HT1GSOD_323_MD50DIODE_SOD_323_M_LBAT40HT1GLBAT40HT1GSOD_323_MD52LBAT40HT1G_SOD_323_M_LBAT40HT1GLBAT40HT1GSOD_323_MD53LBAT40HT1G_SOD_323_M_LBAT40HT1GLBAT40HT1GSOD_323_MD54LBAT40HT1G_SOD_323_M_LBAT40HT1GLBAT40HT1GSOD_323_MD55LBAT40HT1G_SOD_323_M_LBAT40HT1GLBAT40HT1GSOD_323_MD56DIODE_SOD_323_M_LBAT40HT1GLBAT40HT1GSOD_323_MD57DIODE_SOD_323_M_LBAT40HT1GLBAT40HT1GSOD_323_MESD1MLVS0603M04_ESDPAD_R0402_LESD9DLESD9D5.0CT5GESDPAD_R0402ESD2MLVS0603M04_ESDPAD_R0402_LESD9DLESD9D5.0CT5GESDPAD_R0402ESD3MLVS0603M04_ESDPAD_R0402_LESD9DLESD9D5.0CT5GESDPAD_R0402ESD4MLVS0603M04_ESDPAD_R0402_LESD9DLESD9D5.0CT5GESDPAD_R0402F3FUSE_SMD1812_TLC-MSMD260-8TLC-MSMD260-8SMD1812F4FUSE_FUSE610X260_2N_TAB25ATAB25AFUSE610X260_2NF5FUSE_FUSE610X260_2N_TAB25ATAB25AFUSE610X260_2NF6FUSE_FUSE610X260_2N_TAB25ATAB25AFUSE610X260_2NF7FUSE_FUSE610X260_2N_TAB25ATAB25AFUSE610X260_2NFB1FERRITEBEAD_FB0805_M_11R_100M_11R_100M_6AFB0805_MJ1DDR5_FEMALE_SCONN288_DDR5_(S1+SDDR5_femaleSCONN288_DDR5J2DDR5_FEMALE_SCONN288_DDR5_(S1+SDDR5_femaleSCONN288_DDR5J3DDR5_FEMALE_SCONN288_DDR5_(S1+SDDR5_femaleSCONN288_DDR5J4DDR5_FEMALE_SCONN288_DDR5_(S1+SDDR5_femaleSCONN288_DDR5J5DDR5_FEMALE_SCONN288_DDR5_(S1+SDDR5_femaleSCONN288_DDR5J6DDR5_FEMALE_SCONN288_DDR5_(S1+SDDR5_femaleSCONN288_DDR5J7DDR5_FEMALE_SCONN288_DDR5_(S1+SDDR5_femaleSCONN288_DDR5J8DDR5_FEMALE_SCONN288_DDR5_(S1+SDDR5_femaleSCONN288_DDR5J9DDR5_FEMALE_SCONN288_DDR5_(S1+SDDR5_femaleSCONN288_DDR5J10DDR5_FEMALE_SCONN288_DDR5_(S1+SDDR5_femaleSCONN288_DDR5J11DDR5_FEMALE_SCONN288_DDR5_(S1+SDDR5_femaleSCONN288_DDR5J12DDR5_FEMALE_SCONN288_DDR5_(S1+SDDR5_femaleSCONN288_DDR5J13DDR5_FEMALE_SCONN288_DDR5_(S1+SDDR5_femaleSCONN288_DDR5J14DDR5_FEMALE_SCONN288_DDR5_(S1+SDDR5_femaleSCONN288_DDR5J15DDR5_FEMALE_SCONN288_DDR5_(S1+SDDR5_femaleSCONN288_DDR5J16DDR5_FEMALE_SCONN288_DDR5_(S1+SDDR5_femaleSCONN288_DDR5J17BATTERY_CONN_J-BAT-2-20-LOTES-BCR2032-D1-00J-BAT-2-20-LOTES-BAT029K01J18CONN_1X4_HDR1X4-2R50-V_HK01_CONcon1x4_2mm54HDR1X4-2R50-V_HK01J21CONN_2X10_HEADERV2X10_2MM54_CONcon2x10_2mm54HEADERV2X10_2MM54J23CONN_2X5_CON2X5-12_7X5_1M-IP_111125-1205G0S116C001CON2X5-12_7X5_1M-IPJ24CONN_1X3_HEADERV1X3_2MM54_CON1Xcon1x3_2mm54HEADERV1X3_2MM54J25CONN_SATA3.0_SATA3-7P-V-TH_SATASATA3.0SATA3-7P-V-THJ26CONN_SATA3.0_SATA3-7P-V-TH_SATASATA3.0SATA3-7P-V-THJ29CONN_SATA3.0_SATA3-7P-V-TH_SATASATA3.0SATA3-7P-V-THJ30CONN_SATA3.0_SATA3-7P-V-TH_SATASATA3.0SATA3-7P-V-THJ31CONN_SATA3.0_SATA3-7P-V-TH_SATASATA3.0SATA3-7P-V-THJ32CONN_SATA3.0_SATA3-7P-V-TH_SATASATA3.0SATA3-7P-V-THJ35HAP-ABA-USB-152_HAP-ABA-USB-152HLL2107-CBC2G-4HHAP-ABA-USB-152J36M.2_M2_MKEY_4R2_0R5_22110_KEYMKEYMM2_MKEY_4R2_0R5_22110J37M.2_M2_MKEY_4R2_0R5_22110_KEYMKEYMM2_MKEY_4R2_0R5_22110J38CONNGENZ_4C_NON-FULL_PIN_GENZ_GenZ_4C_Non-Full_PINGENZ_4C_FAMALEJ39CONNGENZ_4C_NON-FULL_PIN_GENZ_GenZ_4C_Non-Full_PINGENZ_4C_FAMALEJ40MCIO_X8_PCIE5_MCIO_X8_FAMALE_MCMCIO_X8PCIE5_MCIO_X8_FAMALEJ41MCIO_X8_PCIE5_MCIO_X8_FAMALE_MCMCIO_X8PCIE5_MCIO_X8_FAMALEJ42MCIO_X8_PCIE5_MCIO_X8_FAMALE_MCMCIO_X8PCIE5_MCIO_X8_FAMALEJ43MCIO_X8_PCIE5_MCIO_X8_FAMALE_MCMCIO_X8PCIE5_MCIO_X8_FAMALEJ44MCIO_X8_PCIE5_MCIO_X8_FAMALE_MCMCIO_X8PCIE5_MCIO_X8_FAMALEJ45MCIO_X8_PCIE5_MCIO_X8_FAMALE_MCMCIO_X8PCIE5_MCIO_X8_FAMALEJ46MCIO_X8_PCIE5_MCIO_X8_FAMALE_MCMCIO_X8PCIE5_MCIO_X8_FAMALEJ47MCIO_X8_PCIE5_MCIO_X8_FAMALE_MCMCIO_X8PCIE5_MCIO_X8_FAMALEJ48CONNGENZ_OCP_NIC3.0-168P_PCIE-CONNGenZ_OCP_NIC3.0-168PPCIE-2X84-0N6-GENZ-4C-HPJ49CONN_2X10_SMD_HDR2X10-1R25-V-DFCONN_2X10_SMDHDR2X10-1R25-V-DF13EA-20DPJ50BMC_V2_1.1_SLOT_BMC_V2_CONN_4MMBMC_V2.1_SLOTBMC_V2_CONN_4MMJ53FP_VGA_TH-HEAD-254P-18N_A_FP_VGFP_VGATH-HEAD-254P-18N_AJ54CONN_1X3_HEADERV1X3_2MM54_CON1Xcon1x3_2mm54HEADERV1X3_2MM54J55CONN_1X4_HDR1X4-2R50-V_HK01_CONcon1x4_2mm54HDR1X4-2R50-V_HK01J56CONN_1X3_HEADERV1X3_2MM54_CON1Xcon1x3_2mm54HEADERV1X3_2MM54J58CONN_1X4_HDR1X4-2R50-V_HK01_CONcon1x4_2mm54HDR1X4-2R50-V_HK01J59CONN_1X2_HEADERV1X2_2MM54_CON1Xcon1x2_2mm54HEADERV1X2_2MM54J60CONNFAN_HL4403E_CON6-HL44003E_HL4403ECON6-HL44003EJ61CONNFAN_HL4403E_CON6-HL44003E_HL4403ECON6-HL44003EJ64CONN_FAN_1X4_J-CON-4-2_54-INTELCNN-HF0804E-M2J-CON-4-2_54-INTEL-FAN-AJ66CONNFAN_HL4403E_CON6-HL44003E_HL4403ECON6-HL44003EJ70CONN_FAN_1X4_J-CON-4-2_54-INTELCNN-HF0804E-M2J-CON-4-2_54-INTEL-FAN-AJ72CONNFAN_HL4403E_CON6-HL44003E_HL4403ECON6-HL44003EJ77CONN_1X3_HEADERV1X3_2MM54_CON1Xcon1x3_2mm54HEADERV1X3_2MM54J78CONN_1X3_HEADERV1X3_2MM54_CON1Xcon1x3_2mm54HEADERV1X3_2MM54J79SOCKET_BIOS_SOP8_1D27_SOCKET_ACACA-SPI-004-K01SOP8_1D27_SOCKETJ80SOCKET_BIOS_SOP8_1D27_SOCKET_ACACA-SPI-004-K01SOP8_1D27_SOCKETJ81HAEDER-2X8PIN_HEADER2X8-1P27_HAHAEDER-2X8pinHEADER2X8-1P27J83CRPS_CONN_10035388-106_GOLDFINGGOLDFINGER5010035388-106J84CRPS_CONN_10035388-106_GOLDFINGGOLDFINGER5010035388-106J87SATA_PWR_WF3001-2WM03BR2_WF3001PWR_WF3001-2WM03BR2WF3001-2WM03BR2J91LGA_BP_S5000C_64_BGA_SOCKET_LGALGA_BPS5000C_64_BGA_SOCKETJ92LGA_BP_S5000C_64_BGA_SOCKET_LGALGA_BPS5000C_64_BGA_SOCKETJ93CONN_2X3_HEADERV2X3_2MM54_CON2XCON2X3HEADERV2X3_2MM54J95CN2-S_THERMALPICE_NP3N2_109N5X7CN2-STHERMALPICE_NP3N2_109N5X7MMJ97CONN-5PIN_HDR1X5_2N54_5N08X15N2con1x5_2mm54HDR1X5_2N54_5N08X15N24MM_VJ99CN2-S_THERMALPICE_NP3N2_109N5X7CN2-STHERMALPICE_NP3N2_109N5X7MMJ101ATX2X4_CPU_ATXPOWER2X4P420_TYCOATX2X4_PowersocketATXPOWER2X4P420_TYCO1586495J102ATX2X4_CPU_ATXPOWER2X4P420_TYCOATX2X4_PowersocketATXPOWER2X4P420_TYCO1586495J103CONN_1X2_HEADERV1X2_2MM54_CON1Xcon1x2_2mm54HEADERV1X2_2MM54J104CONN_1X2_HEADERV1X2_2MM54_CON1Xcon1x2_2mm54HEADERV1X2_2MM54J105CONN_1X2_HEADERV1X2_2MM54_CON1Xcon1x2_2mm54HEADERV1X2_2MM54J106CONN_1X2_HEADERV1X2_2MM54_CON1Xcon1x2_2mm54HEADERV1X2_2MM54J107ATX2X3_CPU_POWER2X3P420_POWER_2POWER_2X3POWER2X3P420J108ATX2X4_GPU_ATX_PCIE_8P_VERT_PCIPCIE_6+2P_VERTATX_PCIE_8P_VERTJ109ATX2X4_GPU_ATX_PCIE_8P_VERT_PCIPCIE_6+2P_VERTATX_PCIE_8P_VERTJ110ATX2X3_CPU_POWER2X3P420_POWER_2POWER_2X3POWER2X3P420J113CONN_2X3_HEADERV2X3_2MM54_CON2XCON2X3HEADERV2X3_2MM54J114CONN_1X4_HDR1X4-2R50-V_HK01_CONcon1x4_2mm54HDR1X4-2R50-V_HK01J116CONN_1X3_HEADERV1X3_2MM54_CON1Xcon1x3_2mm54HEADERV1X3_2MM54J118CONN_1X3_HEADERV1X3_2MM54_CON1Xcon1x3_2mm54HEADERV1X3_2MM54J121SLIMSAS_X8_SLIMSAS_X8_V_SLIMSASSLIMSAS_X8SLIMSAS_X8_VJ122CONN_2X10_4PIN_NULL_TH-HEAD-254CONN_2X10_4PIN_NULLTH-HEAD-254P-20ANJ123SATA_PWR_WF3001-2WM03BR2_WF3001PWR_WF3001-2WM03BR2WF3001-2WM03BR2J124SATA_PWR_WF3001-2WM03BR2_WF3001PWR_WF3001-2WM03BR2WF3001-2WM03BR2J125MCIO_X8_PCIE5_MCIO_X8_FAMALE_MCMCIO_X8PCIE5_MCIO_X8_FAMALEJ126MCIO_X8_PCIE5_MCIO_X8_FAMALE_MCMCIO_X8PCIE5_MCIO_X8_FAMALEJ127CONN_2X10_TH-HEAD-254P-20N_HC11HC11101TH-HEAD-254P-20NJ129CONN_1X2_HEADERV1X2_2MM54_CON1Xcon1x2_2mm54HEADERV1X2_2MM54J130ATX2X4_GPU_ATX_PCIE_8P_VERT_PCIPCIE_6+2P_VERTATX_PCIE_8P_VERTJ131CONN_1X2_HEADERV1X2_2MM54_CON1Xcon1x2_2mm54HEADERV1X2_2MM54J132CONN_1X2_HEADERV1X2_2MM54_CON1Xcon1x2_2mm54HEADERV1X2_2MM54J133CONN_1X2_HEADERV1X2_2MM54_CON1Xcon1x2_2mm54HEADERV1X2_2MM54J134ATX2X4_GPU_ATX_PCIE_8P_VERT_PCIPCIE_6+2P_VERTATX_PCIE_8P_VERTJ135CONN_2X8_HEADERV2X8_2MM54_CON2Xcon2x8_2mm54HEADERV2X8_2MM54J139CONN_1X3_HEADERV1X3_2MM54_CON1Xcon1x3_2mm54HEADERV1X3_2MM54J140CONN_1X3_HEADERV1X3_2MM54_CON1Xcon1x3_2mm54HEADERV1X3_2MM54J141CONN_1X2_HEADERV1X2_2MM54_CON1Xcon1x2_2mm54HEADERV1X2_2MM54J142CONN_1X2_HEADERV1X2_2MM54_CON1Xcon1x2_2mm54HEADERV1X2_2MM54J143CONN_1X4_HDR1X4-2R50-V_HK01_CONcon1x4_2mm54HDR1X4-2R50-V_HK01J144ATX2X3_CPU_POWER2X3P420_POWER_2POWER_2X3POWER2X3P420J145ATX2X3_CPU_POWER2X3P420_POWER_2POWER_2X3POWER2X3P420J146TCM_SPI_HEADERV2X5_2MM54_CUT10_TCM_SPIHEADERV2X5_2MM54_CUT10J147CONN_1X2_HEADERV1X2_2MM54_CON1Xcon1x2_2mm54HEADERV1X2_2MM54L1COMMONMODE CHOKE_L_4P_110_126X90R-100MHZ_0R35L_4P_110_126X63L2COMMONMODE CHOKE_L_4P_110_126X90R-100MHZ_0R35L_4P_110_126X63L3COMMONMODE CHOKE_L_4P_110_126X90R-100MHZ_0R35L_4P_110_126X63L4COMMONMODE CHOKE_L_4P_110_126X90R-100MHZ_0R35L_4P_110_126X63L5COMMONMODE CHOKE_L_4P_110_126X90R-100MHZ_0R35L_4P_110_126X63L6COMMONMODE CHOKE_L_4P_110_126X90R-100MHZ_0R35L_4P_110_126X63L7COMMONMODE CHOKE_L_4P_110_126X90R-100MHZ_0R35L_4P_110_126X63L8COMMONMODE CHOKE_L_4P_110_126X90R-100MHZ_0R35L_4P_110_126X63L9COMMONMODE CHOKE_L_4P_110_126X90R-100MHZ_0R35L_4P_110_126X63L10COMMONMODE CHOKE_L_4P_110_126X90R-100MHZ_0R35L_4P_110_126X63L11COMMONMODE CHOKE_L_4P_110_126X90R-100MHZ_0R35L_4P_110_126X63L12COMMONMODE CHOKE_L_4P_110_126X90R-100MHZ_0R35L_4P_110_126X63L13INDUCTOR_SPL2_1150X1060_0.47UH_0.47uH_30A_1.7mRSPL2_1150X1060L14INDUCTOR_SPL2_449X406-MCSM42Z_11uH_5A_30mR_4.5x4.1SPL2_449X406-MCSM42ZL16INDUCTOR_INDSM2-10R5X10R3_1UH_31uH_3mR23AINDSM2-10R5X10R3L17INDUCTOR_INDSM2-10R5X10R3_1UH_31uH_3mR23AINDSM2-10R5X10R3L18INDUCTOR_SPL2_449X406-MCSM42Z_11uH_5A_30mR_4.5x4.1SPL2_449X406-MCSM42ZL19INDUCTOR_SPL2_490X450_0.68UH_7A0.68uH_7A_18mR_4.9x4.5SPL2_490X450L20INDUCTOR_SML700X660_0.1UH_32.5A0.1uH_32.5ASML700X660L21INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L22INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L23INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L24INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L25INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L26INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L27INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L28INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L29INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L30INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L31INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L32INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L33INDUCTOR_L-2-7_87-PULSE-PA2607_0.23uH_40A_0.47mRL-2-7_87-PULSE-PA2607L34INDUCTOR_L-2-7_87-PULSE-PA2607_0.23uH_40A_0.47mRL-2-7_87-PULSE-PA2607L35INDUCTOR_L-2-7_87-PULSE-PA2607_0.23uH_40A_0.47mRL-2-7_87-PULSE-PA2607L36INDUCTOR_L-2-7_87-PULSE-PA2607_0.23uH_40A_0.47mRL-2-7_87-PULSE-PA2607L37INDUCTOR_SPL2_449X406-MCSM42Z_11uH_5A_30mR_4.5x4.1SPL2_449X406-MCSM42ZL40INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L41INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L42INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L43INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L44INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L45INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L46INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L47INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L48INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L49INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L50INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L51INDUCTOR_SMD8D0X6D4X12D15_0.15U0.15uH_55A_0.29mRSMD8D0X6D4X12D15L52INDUCTOR_L-2-7_87-PULSE-PA2607_0.23uH_40A_0.47mRL-2-7_87-PULSE-PA2607L53INDUCTOR_L-2-7_87-PULSE-PA2607_0.23uH_40A_0.47mRL-2-7_87-PULSE-PA2607L54INDUCTOR_L-2-7_87-PULSE-PA2607_0.23uH_40A_0.47mRL-2-7_87-PULSE-PA2607L55INDUCTOR_L-2-7_87-PULSE-PA2607_0.23uH_40A_0.47mRL-2-7_87-PULSE-PA2607L56INDUCTOR_SPL2_449X406-MCSM42Z_11uH_5A_30mR_4.5x4.1SPL2_449X406-MCSM42ZL61INDUCTOR_SPL2_490X450_0.68UH_7A0.68uH_7A_18mR_4.9x4.5SPL2_490X450L62INDUCTOR_SML700X660_0.1UH_32.5A0.1uH_32.5ASML700X660L63INDUCTOR_SML700X660_0.1UH_32.5A0.1uH_32.5ASML700X660L64INDUCTOR_SML700X660_0.1UH_32.5A0.1uH_32.5ASML700X660L65COMMONMODE CHOKE_L_4P_110_126X90R-100MHZ_0R35L_4P_110_126X63L66COMMONMODE CHOKE_L_4P_110_126X90R-100MHZ_0R35L_4P_110_126X63L67COMMONMODE CHOKE_L_4P_110_126X90R-100MHZ_0R35L_4P_110_126X63LED1LED_LED0603_LED_BLUELED_BLUELED0603LED2LED_LED0603_LED_BLUELED_BLUELED0603LED3LED_LED0603_LED_BLUELED_BLUELED0603LED4LED_LED0603_LED_BLUELED_BLUELED0603LED5LED_LED0603_LED_BLUELED_BLUELED0603LED6LED_LED0603_LED_BLUELED_BLUELED0603LED7LED_LED0603_LED_BLUELED_BLUELED0603LED8LED_LED0603_LED_BLUELED_BLUELED0603LS1DIP_BUZZER-12PD05_D120-P75-H95TMB12A05BZ_D12M.2_MH1HOLE_MTG340SQ580_M.2_HOLEM.2_HOLEMTG340SQ580M.2_MH2HOLE_MTG340SQ580_M.2_HOLEM.2_HOLEMTG340SQ580M.2_MH3HOLE_MTG340SQ580_M.2_HOLEM.2_HOLEMTG340SQ580M.2_MH4HOLE_MTG340SQ580_M.2_HOLEM.2_HOLEMTG340SQ580MARK1MARK_POINT_MARK100_MARKMARKMARK100MARK2MARK_POINT_MARK100_MARKMARKMARK100MARK3MARK_POINT_MARK100_MARKMARKMARK100MARK4MARK_POINT_MARK100_MARKMARKMARK100MARK5MARK_POINT_MARK100_MARKMARKMARK100MARK6MARK_POINT_MARK100_MARKMARKMARK100MARK7MARK_POINT_MARK100_MARKMARKMARK100MARK8MARK_POINT_MARK100_MARKMARKMARK100MARK9MARK_POINT_MARK100_MARKMARKMARK100MARK10MARK_POINT_MARK100_MARKMARKMARK100MARK11MARK_POINT_MARK100_MARKMARKMARK100MARK12MARK_POINT_MARK100_MARKMARKMARK100MH1MOUNTING_HOLE_PAD8R5CIR4R0D_HOLHOLEPAD8R5CIR4R0DMH2MOUNTING_HOLE_A_PAD8R5CIR4R0D-NHOLEPAD8R5CIR4R0D-NMH3MOUNTING_HOLE_A_PAD8R5CIR4R0D-NHOLEPAD8R5CIR4R0D-NMH4MOUNTING_HOLE_A_PAD8R5CIR4R0D-NHOLEPAD8R5CIR4R0D-NMH5MOUNTING_HOLE_A_PAD8R5CIR4R0D-NHOLEPAD8R5CIR4R0D-NMH6MOUNTING_HOLE_PAD8R5CIR4R0D_HOLHOLEPAD8R5CIR4R0DMH7MOUNTING_HOLE_A_PAD8R5CIR4R0D-NHOLEPAD8R5CIR4R0D-NMH8MOUNTING_HOLE_A_PAD8R5CIR4R0D-NHOLEPAD8R5CIR4R0D-NMH9MOUNTING_HOLE_A_PAD8R5CIR4R0D-NHOLEPAD8R5CIR4R0D-NMH10MOUNTING_HOLE_PAD8R5CIR4R0D_HOLHOLEPAD8R5CIR4R0DMH11MOUNTING_HOLE_A_PAD8R5CIR4R0D-NHOLEPAD8R5CIR4R0D-NMH12MOUNTING_HOLE_PAD8R5CIR4R0D_HOLHOLEPAD8R5CIR4R0DMH13MOUNTING_HOLE_A_PAD8R5CIR4R0D-NHOLEPAD8R5CIR4R0D-NMH14MOUNTING_HOLE_A_PAD8R5CIR4R0D-NHOLEPAD8R5CIR4R0D-NMH15MOUNTING_HOLE_PAD10R2CIR6R4D_HOHOLEPAD10R2CIR6R4DMH16MOUNTING_HOLE_PAD10R2CIR6R4D_HOHOLEPAD10R2CIR6R4DMH17HOLE_PAD6R0CIR3R5D_HOLEHOLEPAD6R0CIR3R5DMH18HOLE_PAD6R0CIR3R5D_HOLEHOLEPAD6R0CIR3R5DMH19HOLE_PAD6R0CIR3R5D_HOLEHOLEPAD6R0CIR3R5DMH20HOLE_PAD6R0CIR3R5D_HOLEHOLEPAD6R0CIR3R5DMH21HOLE_PAD8CIR8U_HOLEHOLEPAD8CIR8UMH22HOLE_PAD8CIR8U_HOLEHOLEPAD8CIR8UMH23HOLE_PAD8CIR8U_HOLEHOLEPAD8CIR8UMH24HOLE_PAD6R0CIR3R5D_HOLEHOLEPAD6R0CIR3R5DMH25HOLE_PAD6R0CIR3R5D_HOLEHOLEPAD6R0CIR3R5DMH26HOLE_PAD6R0CIR3R5D_HOLEHOLEPAD6R0CIR3R5DMH27HOLE_PAD6R0CIR3R5D_HOLEHOLEPAD6R0CIR3R5DQ1PMOS_SOT_23_M_LP2305ALT1GLP2305ALT1GSOT_23_MQ2PMOS_SOT_23_M_LP2305ALT1GLP2305ALT1GSOT_23_MQ3PMOS_SOT_23_M_LP2305ALT1GLP2305ALT1GSOT_23_MQ4PMOS_SOT_23_M_LP2305ALT1GLP2305ALT1GSOT_23_MQ5PMOS_SOT_23_M_LP2305ALT1GLP2305ALT1GSOT_23_MQ6PMOS_SOT_23_M_LP2305ALT1GLP2305ALT1GSOT_23_MQ7PMOS_SOT_23_M_LP2305ALT1GLP2305ALT1GSOT_23_MQ8PMOS_SOT_23_M_LP2305ALT1GLP2305ALT1GSOT_23_MQ13PESD5V0X1BT_SOT23-3L_PESD5V0X1BPESD5V0X1BTSOT23-3LQ14PESD5V0X1BT_SOT23-3L_PESD5V0X1BPESD5V0X1BTSOT23-3LQ15LRC099-04DT1G_DFN2510P10E_LRC09LRC099-04DT1GDFN2510P10EQ16LRC099-04DT1G_DFN2510P10E_LRC09LRC099-04DT1GDFN2510P10EQ20LBAV99LT1G_SOT23A_LBAV99LT1GLBAV99LT1GSOT23AQ21LBAV99LT1G_SOT23A_LBAV99LT1GLBAV99LT1GSOT23AQ22LBAV99LT1G_SOT23A_LBAV99LT1GLBAV99LT1GSOT23AQ24LBAV99LT1G_SOT23A_LBAV99LT1GLBAV99LT1GSOT23AQ26LBAV99LT1G_SOT23A_LBAV99LT1GLBAV99LT1GSOT23AQ29LBAV99LT1G_SOT23A_LBAV99LT1GLBAV99LT1GSOT23AQ30LBAV99LT1G_SOT23A_LBAV99LT1GLBAV99LT1GSOT23AQ31FET_NMOS_SOT_23_M_LBSS138LT1GLBSS138LT1GSOT_23_MQ62FET_NMOS_SOT_23_M_LBSS138LT1GLBSS138LT1GSOT_23_MQ63FET_NMOS_SOT_23_M_LBSS138LT1GLBSS138LT1GSOT_23_MQ71NMOSFET_LN8320DT1AG_DFN8_0D65_3LN8320DT1AGDFN8_0D65_3X3Q72NMOSFET_LN8320DT1AG_DFN8_0D65_3LN8320DT1AGDFN8_0D65_3X3Q74NMOSFET_LN8320DT1AG_DFN8_0D65_3LN8320DT1AGDFN8_0D65_3X3Q75NMOSFET_LN8320DT1AG_DFN8_0D65_3LN8320DT1AGDFN8_0D65_3X3Q76FET_NMOS_SOT_23_M_LBSS138LT1GLBSS138LT1GSOT_23_MQ77FET_NMOS_SOT_23_M_LBSS138LT1GLBSS138LT1GSOT_23_MQ78FET_NMOS_SOT_23_M_LBSS138LT1GLBSS138LT1GSOT_23_MQ79FET_NMOS_SOT_23_M_LBSS138LT1GLBSS138LT1GSOT_23_MQ80FET_NMOS_SOT_23_M_LBSS138LT1GLBSS138LT1GSOT_23_MSW1SWITCH_SWS4_600X600-PTS-06104A_SW-1102WSWS4_600X600-PTS-06104ASW2SWITCH_SWS4_600X600-PTS-06104A_SW-1102WSWS4_600X600-PTS-06104ATPCM_MH0HOLE_PAD4R0CIR2R2D_TPCM_HOLETPCM_HOLEPAD4R0CIR2R2DU1S5000C_64C_V1.3_DDR5_LGA5796P94S5000C_64C_DDR5_1130_LGALGA5796P94_7040X8800U2S5000C_64C_V1.3_DDR5_LGA5796P94S5000C_64C_DDR5_1130_LGALGA5796P94_7040X8800U3SGM5018_TSSOP_16_SGM5018SGM5018TSSOP_16U4SGM5018_TSSOP_16_SGM5018SGM5018TSSOP_16U5TCA39306_VSSOP8P50_200X310X75_TTCA39306DCURVSSOP8P50_200X310X75U6TCA39306_VSSOP8P50_200X310X75_TTCA39306DCURVSSOP8P50_200X310X75U7SGM5018_TSSOP_16_SGM5018SGM5018TSSOP_16U8SGM5018_TSSOP_16_SGM5018SGM5018TSSOP_16U9TCA39306_VSSOP8P50_200X310X75_TTCA39306DCURVSSOP8P50_200X310X75U10TCA39306_VSSOP8P50_200X310X75_TTCA39306DCURVSSOP8P50_200X310X75U11TMP468_VFQN16P50_300X300X100_CTCT7428VFQN16P50_300X300X100U12TMP468_VFQN16P50_300X300X100_CTCT7428VFQN16P50_300X300X100U13SGM4553_SOT23-8-0_65-3_02X1_7-HSGM4553SOT23-8-0_65-3_02X1_7-H1_25U21SGM4553_SOT23-8-0_65-3_02X1_7-HSGM4553SOT23-8-0_65-3_02X1_7-H1_25U2274LVC2G3157_VSSOP10P50_310X310X74LVC2G3157VSSOP10P50_310X310X110U23DS1339U_SOP8-3_1X3_1-P0_65M_AT8AT8339ASSOP8-3_1X3_1-P0_65MU24FM24C1024A_SOP8_127-620X500_FM2FM24C1024ASOP8_127-620X500U25TCA9548A_TSSOP24P65_660X790X120CA9548MTRTSSOP24P65_660X790X120U27TCA9548A_TSSOP24P65_660X790X120CA9548MTRTSSOP24P65_660X790X120U28PCA9555_TSSOP24P65_450X790X120_NCA9555TSSOP24P65_450X790X120U29PCA9555_TSSOP24P65_450X790X120_NCA9555TSSOP24P65_450X790X120U30PCA9555_TSSOP24P65_450X790X120_NCA9555TSSOP24P65_450X790X120U31EF3L90CG400_BGA400C80P20X20_(S1EF3L90CG400BGA400C80P20X20U36CLK_AU5329_QFN-64_AU5329Au5329QFN-64U37CLK_AU5411_QFN48-7X7-AU5411_AU5AU5411QFN48-7X7-AU5411U38CLK_AU5411_QFN48-7X7-AU5411_AU5AU5411QFN48-7X7-AU5411U39CLK_AU5411_QFN48-7X7-AU5411_AU5AU5411QFN48-7X7-AU5411U40CLK_AU5411_QFN48-7X7-AU5411_AU5AU5411QFN48-7X7-AU5411U41CLK_AU5411_QFN48-7X7-AU5411_AU5AU5411QFN48-7X7-AU5411U42CLK_AU5411_QFN48-7X7-AU5411_AU5AU5411QFN48-7X7-AU5411U43CLK_AU5410_QFN-32_AU5410Au5410QFN-32U44SN74LVC1G125DCKR_SC70-5P-D65_7474LVC1G125GWSC70-5P-D65U4588SE9230_QFN76_D4_9X9X1_88SE92388SE9230QFN76_D4_9X9X1U46W25Q16BVSSIG_SOP8-150_W25X40CLSW25X40CLSNIGSOP8-150U47SN74LVC1G125DCKR_SC70-5P-D65_7474LVC1G125GWSC70-5P-D65U4888SE9230_QFN76_D4_9X9X1_88SE92388SE9230QFN76_D4_9X9X1U49W25Q16BVSSIG_SOP8-150_W25X40CLSW25X40CLSNIGSOP8-150U50UPD720201_QFN68_UPD720201uPD720201QFN68U51W25Q16BVSSIG_SOP8-208_FM25Q08B-FM25Q08B-SO-T-GSOP8-208U52UPD720201_QFN68_UPD720201uPD720201QFN68U53W25Q16BVSSIG_SOP8-208_FM25Q08B-FM25Q08B-SO-T-GSOP8-208U54SGM58031_MSOP10_3X5_0N5MM_SGM58SGM58031XMS10G/TRMSOP10_3X5_0N5MMU55SGM58031_MSOP10_3X5_0N5MM_SGM58SGM58031XMS10G/TRMSOP10_3X5_0N5MMU58CT75MMR_SOP8-3X3X1_1-P0_65M_CT7CT75MMRSOP8-3X3X1_1-P0_65MU59CT75MMR_SOP8-3X3X1_1-P0_65M_CT7CT75MMRSOP8-3X3X1_1-P0_65MU60CT75MMR_SOP8-3X3X1_1-P0_65M_CT7CT75MMRSOP8-3X3X1_1-P0_65MU61CT75MMR_SOP8-3X3X1_1-P0_65M_CT7CT75MMRSOP8-3X3X1_1-P0_65MU62CT75MMR_SOP8-3X3X1_1-P0_65M_CT7CT75MMRSOP8-3X3X1_1-P0_65MU63CT75MMR_SOP8-3X3X1_1-P0_65M_CT7CT75MMRSOP8-3X3X1_1-P0_65MU64CT75MMR_SOP8-3X3X1_1-P0_65M_CT7CT75MMRSOP8-3X3X1_1-P0_65MU65CT75MMR_SOP8-3X3X1_1-P0_65M_CT7CT75MMRSOP8-3X3X1_1-P0_65MU66ISL59833IAZ_QSOP16LD_ISL59833IAISL59833IAZQSOP16LDU67ISL59833IAZ_QSOP16LD_ISL59833IAISL59833IAZQSOP16LDU69SN74LS125ANSR_SOP127P780-14N_SNSN74LS125ANSRSOP127P780-14NU70SP3243EA_SSOP28_0N65_7N9X10N3_UUM3243SSOP28_0N65_7N9X10N3U71SGM4568YTS20G_TSSOP20P65_650X44SGM4568YTS20G/TRTSSOP20P65_650X440U72SGMA6505_TSSOP24_SGM6505SGM6505TSSOP24U73IS6608A_IS6608A_IS6608AIS6608AIS6608AU74IS6605A_QFN-14_IS6605IS6605QFN-14U77IS6607A_QFN-21_IS6607IS6607QFN-21U78IS6607A_QFN-21_IS6607IS6607QFN-21U79IS6605A_QFN-14_IS6605IS6605QFN-14U82RAA229126_QFN45P600X600-48N_RAARAA229126GNP#HA0QFN45P600X600-48NU84ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU85ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU86ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU87ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU88ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU89ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU90ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU91ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU92ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU93ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU94ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU95ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU96SGM2037_SOT-23-6_SGM2037SGM2037SOT-23-6U97IS6608A_IS6608A_IS6608AIS6608AIS6608AU99IS6608A_IS6608A_IS6608AIS6608AIS6608AU100IS6608A_IS6608A_IS6608AIS6608AIS6608AU101SGM2037_SOT-23-6_SGM2037SGM2037SOT-23-6U102IS6605A_QFN-14_IS6605IS6605QFN-14U104ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU105ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU106ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU107ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU108ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU109ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU110ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU111ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU112ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU113ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU114ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU115ISL99390R5935_PQFN45P500X600N-4ISL99390FRZ-TR5935PQFN45P500X600N-41NU116SGM2037_SOT-23-6_SGM2037SGM2037SOT-23-6U117IS6608A_IS6608A_IS6608AIS6608AIS6608AU119IS6608A_IS6608A_IS6608AIS6608AIS6608AU120IS6608A_IS6608A_IS6608AIS6608AIS6608AU122IS6605A_QFN-14_IS6605IS6605QFN-14U129IS6605A_QFN-14_IS6605IS6605QFN-14U130SGM2037_SOT-23-6_SGM2037SGM2037SOT-23-6U132SGM4553_SOT23-8-0_65-3_02X1_7-HSGM4553SOT23-8-0_65-3_02X1_7-H1_25U137SGM4568YTS20G_TSSOP20P65_650X44SGM4568YTS20G/TRTSSOP20P65_650X440U138SGM4568YTS20G_TSSOP20P65_650X44SGM4568YTS20G/TRTSSOP20P65_650X440U139SGM4568YTS20G_TSSOP20P65_650X44SGM4568YTS20G/TRTSSOP20P65_650X440U140SGM4568YTS20G_TSSOP20P65_650X44SGM4568YTS20G/TRTSSOP20P65_650X440U141SGMA6505_TSSOP24_SGM6505SGM6505TSSOP24U143SGM25711B_LTC4370IDE_MSOP16_SGMSGM25711BLTC4370IDE_MSOP16U144SGM25711B_LTC4370IDE_MSOP16_SGMSGM25711BLTC4370IDE_MSOP16U145SGM25711B_LTC4370IDE_MSOP16_SGMSGM25711BLTC4370IDE_MSOP16U146SGM25711B_LTC4370IDE_MSOP16_SGMSGM25711BLTC4370IDE_MSOP16U147RAA229126_QFN45P600X600-48N_RAARAA229126GNP#HA0QFN45P600X600-48NU148SGM2037_SOT-23-6_SGM2037SGM2037SOT-23-6U149IS6605A_QFN-14_IS6605IS6605QFN-14U151IS6608A_IS6608A_IS6608AIS6608AIS6608AU152IS6608A_IS6608A_IS6608AIS6608AIS6608AU153FM24C1024A_SOP8_127-620X500_FM2FM24C1024ASOP8_127-620X500U154TCA39306_VSSOP8P50_200X310X75_TTCA39306DCURVSSOP8P50_200X310X75U155TCA39306_VSSOP8P50_200X310X75_TTCA39306DCURVSSOP8P50_200X310X75U156TCA39306_VSSOP8P50_200X310X75_TTCA39306DCURVSSOP8P50_200X310X75U157TCA39306_VSSOP8P50_200X310X75_TTCA39306DCURVSSOP8P50_200X310X75U158TCA39306_VSSOP8P50_200X310X75_TTCA39306DCURVSSOP8P50_200X310X75U159TCA39306_VSSOP8P50_200X310X75_TTCA39306DCURVSSOP8P50_200X310X75U160TCA39306_VSSOP8P50_200X310X75_TTCA39306DCURVSSOP8P50_200X310X75U161TCA39306_VSSOP8P50_200X310X75_TTCA39306DCURVSSOP8P50_200X310X75U163W25Q16BVSSIG_SOP8-208_FM25Q08B-FM25Q08B-SO-T-GSOP8-208U164W25Q16BVSSIG_SOP8-208_FM25Q08B-FM25Q08B-SO-T-GSOP8-208U165SGM4553_SOT23-8-0_65-3_02X1_7-HSGM4553SOT23-8-0_65-3_02X1_7-H1_25U166SGM4553_SOT23-8-0_65-3_02X1_7-HSGM4553SOT23-8-0_65-3_02X1_7-H1_25U167ICS553MILF_SOP8-4_9X3_9X2-P1_27ICS553MILFSOP8-4_9X3_9X2-P1_27MU168SGM4553_SOT23-8-0_65-3_02X1_7-HSGM4553SOT23-8-0_65-3_02X1_7-H1_25U169SGMA6505_TSSOP24_SGM6505SGM6505TSSOP24U17274LVC1G08GW_SOT65P190-5N_74LVC174LVC1G08GW,125SOT65P190-5NX1CRYSTAL_XTAL_2P_OSC_3_2X1_5_1_332.768KHZ12.5p_S-HF-2OSC_3_2X1_5_1Y1OSCILLATOR_OSC170P320X250-4N_5050MHz,3.3V,3225OSC170P320X250-4NY2CRYSTAL_XTAL_OSC170P320X250-4N_54MHZ_3225_8pFOSC170P320X250-4NY3OSCILLATOR_OSC170P320X250-4N_4848MHz,1.8V,3225OSC170P320X250-4NY4CRYSTAL_XTAL_OSC170P320X250-4_125MHZ_8P_30ppm_3225OSC170P320X250-4NY5CRYSTAL_XTAL_OSC170P320X250-4_125MHZ_8P_30ppm_3225OSC170P320X250-4NY6CRYSTAL_XTAL_OSC170P320X250-4_224MHz_12p_30ppmOSC170P320X250-4NY7CRYSTAL_XTAL_OSC170P320X250-4_224MHz_12p_30ppmOSC170P320X250-4N
老吴 发表于 2023-7-12 17:57
PCB文件,没原理图。收10RMB 。不需要的不要下载。
文件非常大,解压后差不多300m 。
敏行 发表于 2023-7-12 18:07
学习一下。好文件
roezw 发表于 2023-7-12 18:16
cgddz 发表于 2023-7-12 18:39
好文件,学习学习!
yangyida137324 发表于 2023-7-12 18:52
leslie_aqiang 发表于 2023-7-12 19:48
zspdeyc 发表于 2023-7-12 19:55
junkyoung 发表于 2023-7-12 20:28
好好学习,谢谢分享。
csuxl 发表于 2023-7-12 20:40
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: 首发-国产飞腾腾 云S5000C 服务器主板14层PCB文件 挂16条DDR5
