armclub 发表于 2023-9-15 09:19
RK3128 挂两个DDR3 高清电视盒PCB和原理图
NamePart TypePCB DecalValueANT1CRYSTAL-4_2ANT_JACKNC/ANTANT2ANT_IIFA_CC2420_32MIL_MIRANT2G4_BN/ACE1CD5.0/2.5CD5.0/2.5100uF/16VCE2CD5.0/2.5CD5.0/2.5100uF/16VCN1CON5_2.0MM_DIPCON5_2.54MMCON5_2.54MM_DIPCN2CON4_2.5MM_DIPCON4_2.54CON4_2.54MM_DIPCN3CON4_2.5MM_DIPCON4_2.54CON4_2.54MM_DIPD1DIODE_1SOT23NC/BAT54CD2DIODESOD123NC/1N4148D3DIODESOD123NC/1N5819D4DIODESOD1231N5819D5BAT54S/SOT_2SOT23BAT54SED1DIODE_BI-DIR_TRIGE0402NNC/ESD9B5VED2ESD_1SOT23NC/ESDA6V8UL/AZC199-02SED3ESD_1SOT23NC/ESDA6V8UL/AZC199-02SED28TVSE0402NNC/ESD9B5VF1FUSER0805NCFB1INDUCTOR-COML0603DNC/SDCW2012-2-900FB2INDUCTOR-COML0603DNC/SDCW2012-2-900H1H0502H3.8MMH3.8MMH2H0502H3.8MMH3.8MMIR1IR_RECEIVETO92ECBIRM-3638J1DC_1DC36-DDC-208J9HDMI_A_1HDMI_DIPHDMI_AJ10AV_CONNECTOR_0AV3-DAV_connectorJ11XH-2-2_54XH-2-2_54NC/XH-2-2_54J12SW4P_1CON4_2.54NC/CON4_2.54J13LED_1LED-DIPLEDJ14CON_10PIN_1.25CON_10PIN_1.25CON_10PIN_1.25JP1RJ45_CON8_1RJ45-DRJ45SL1INDUCTOR_1IND-3X32.2uH/1AL2INDUCTOR_1IND-4X41.0uH/2AL3INDUCTOR_1IND-4X41.0uH/2AL4INDUCTOR_1IND-3X32.2uH/1AL5INDUCTOR_2L0603BLM18PG181SN1L6INDUCTOR_2L0603BLM18PG181SN1L7INDUCTORL0603NC/1.8uHL9INDUCTOR_3R0402NCL10INDUCTOR_3R0402NCL11INDUCTOR_2L0603BLM18PG181SN1L12INDUCTORL06031.0uHL52INDUCTOR_2L0603NCL53INDUCTOR_2L0603BLM18PG181SN1Q140852_1SOT238050Q240852_1SOT238050Q3MOSFET_PSOT23WPM2015/TCS1015Q540852_1SOT23NC/8050RP1RESISTOR_4PACKR0402S4NC/10KRP2RESISTOR_4PACKR0402S4NC/10KSW1SW4P_1TS-019NC/RESETSW2SW4P_1SW4-SKQG-5_2X5_2H1_5BRECOVER1SW3SW4P_1IT-1185SRECOVER2T1TESTMARKMARKT2TESTMARKMARKT3TESTMARKMARKT4TESTMARKMARKT5TESTMARKMARKT6TESTMARKMARKT7TEST_2T-0.7eFUSET8TEST_2T-0.7GNDT9TEST_2T-0.7FLASH_CLET10TEST_2T-0.7FALSH_DQS/EMMC_CLKOU1RK3128_3BGA316-14X14_0.65RK3128U5DDRII_3FBGA96-10X14DDR3-128X16bitU6DDRII_3FBGA96-10X14DDR3-128X16bitU7EM78P153_0SOP8NC/ZQ2996U9DS8008_6SOT25ETA3486/SY8088AACU10DS8008_6SOT25ETA3409A/TCS4201/SY8089AAACU11DS8008_6SOT25ETA3409A/TCS4201/SY8089AAACU12DS8008_6SOT25ETA3486/SY8088AACU13DS8008_4SOT25PT5108E23E-12/WL2801E-12U14DS8008_4SOT25PT5108E23E-33/WL2801E-33U15MAX809SD_3SOT23CE8809C263MAU17DS8008_0SOT25SY6280AAC/WS4603U18TSD_0TSOP1-48tSD_FlashU19NANDFLASH_0TSOP1-48NAND_FLASHU20INAND_2INAND_169_AeMMCU21DS8008_3SLP2510P8NC/RClamp0524J/ESDA6V8UDU22DS8008_3SLP2510P8NC/RClamp0524J/ESDA6V8UDU23U_DRV602TSSOP14-0.65MMTPF632/DRV632PW/Dio2112HU24DP83848JQFN40_58DP83848JU25LAN1102SOIC16HR601680U26DS8008_4SOT25NC/PT5108E23E-33U28AP6493_0QFN-44PRTL8189ETVUSB1JP_USB2_2.0USB_BUSBDIP90CEUSB2JP_USB2_2.0USB_BUSBDIP90CEY1CRYSTAL-4_0CRY-D322524M-20ppm
PCB 原图。回复可见下载
**** Hidden Message *****
地球很危险 发表于 2023-9-15 09:39
宝贝儿 发表于 2023-9-15 09:41
elecc 发表于 2023-9-15 09:51
135270 发表于 2023-9-15 11:16
谢谢分享
bidezhi7777 发表于 2023-9-15 13:14
fairy0212 发表于 2023-9-15 18:46
牛牛
zspdeyc 发表于 2023-9-15 21:25
逆天pads 发表于 2023-9-15 22:24
页: [1] 2 3 4 5 6 7
查看完整版本: RK3128 挂两个DDR3 高清电视盒PCB和原理图
