MPC948和IBS 6层电脑主板PCB文件共享
REFDESCOMP_DEVICE_TYPESYM_NAMEB1A_BAT3_BAT3-BAT3,6026A0018401A_BTY-10MMCR1A_LED_LED-BLUE,6011A0025601A_LED2-934ECR2A_DIODE_A_DIODE-5V,6011A0019601A_DIODE-0603CR3A_DIODE_A_DIODE-5V,6011A0019601A_DIODE-0603CR4A_DIODE_A_DIODE-5V,6011A0019601A_DIODE-0603CR5A_DIODE_A_DIODE-5V,6011A0019601A_DIODE-0603CR6A_LED_LED-GRN,60110GA0654TA_LED-0603CR7A_LED_LED-GRN,60110GA0654TA_LED-0603CR8A_LED_LED-GRN,60110GA0654TA_LED-0603CR9A_LED_LED-RED,6011A0001301A_LED-0603CR10A_LED_LED-GRN,60110GA0654TA_LED-0603CR11A_LED_LED-GRN,60110GA0654TA_LED-0603CR12A_LED_LED-GRN,60110GA0654TA_LED-0603CR13A_DIODE_A_DIODE-5V,6011A0019601A_DIODE-0603CR14A_LED_LED-GRN,60110GA0654TA_LED-0603CR15A_DIODE_A_DIODE-5V,6011A0019601A_DIODE-0603CR16A_DIODE_A_DIODE-5V,6011A0019601A_DIODE-0603CR17A_DIODE_A_DIODE-5V,6011A0019601A_DIODE-0603CR18A_LED_LED-GRN,60110GA0654TA_LED-0603CR19A_LED_LED-GRN,60110GA0654TA_LED-0603CR20A_LED_LED-GRN,60110GA0654TA_LED-0603CR21A_LED_LED-GRN,60110GA0654TA_LED-0603CR22A_LED_LED-GRN,60110GA0654TA_LED-0603CR23A_LED_LED-GRN,60110GA0654TA_LED-0603CR24A_LED_LED-RED,6011A0001301A_LED-0603CR25A_LED_LED-GRN,6011A0015101A_LED-71CR26A_LED_LED-RED,6011A0001301A_LED-0603CR27A_LED_LED-RED,6011A0001301A_LED-0603CR28A_LED_LED-RED,6011A0001301A_LED-0603D1A_DSOT23A_SOT23-BAV99,6011A000AA_SOT23FTD2A_DSOT23A_SOT23-BAV99,6011A000AA_SOT23FTD3A_DSOT23A_SOT23-BAV99,6011A000AA_SOT23FTD4A_DSOT23A_SOT23-BAV99,6011A000AA_SOT23FTD5A_DSOT23A_SOT23-BAV99,6011A000AA_SOT23FTD6A_DSOT23A_SOT23-BAV99,6011A000AA_SOT23FTD7A_DE4PAK_SOIC8-DE4PAK,60110GA0AA_SOIC8-50X208D8A_DSOT23A_SOT23-BAV99,6011A000AA_SOT23FTD9A_DSOT23A_SOT23-BAV99,6011A000AA_SOT23FTD11A_DIODE_DO-136-LS4148,6011A001AA_DO-136D13A_DIODE3_C_DIODE-6V,6011A00224AA_SOT23FTD14A_DIODE_SDO95A-40V,60110GA0632TA_DIODE-SDO95AD15A_DIODE_SDO95A-40V,60110GA0632TA_DIODE-SDO95AD16A_DIODE3_A_DIODE-100V,6011A001AA_SOT23FTD18A_DIODE_DO-136-LS4148,6011A001AA_DO-136D20A_DSHTKY_SM-20V,6011A0001901A_DO270-MBRS340D21A_DE4PAK_SOIC8-DE4PAK,60110GA0AA_SOIC8-50X208D22A_DIODE_DIODE-157-30V,6011B001AA_DIODE-157D23A_DIODE_DIODE-157-30V,6011B001AA_DIODE-157D24A_DIODE3_A_DIODE-100V,6011A001AA_SOT23FTD25A_DSOT23A_SOT23-BAV99,6011A000AA_SOT23FTD26A_DSOT23A_SOT23-BAV99,6011A000AA_SOT23FTD27A_DIODE_DO-136-LS4148,6011A001AA_DO-136D50A_DIODE_DO-136-LS4148,6011A001AA_DO-136D51A_DIODE_DO-136-LS4148,6011A001AA_DO-136J1A_COM_CN9-6012A0061401A_CN9-SERIALJ2A_VGACONN_VGA-6012A0060401A_CN15-DZ11AA2J3A_USBCONN_USBCONN-60120IA19150A_CN8-UB1112CJ4A_2X6_5MP_CN12-2X6_5MP,6026A00AA_CN12-KM_AJ5A_1X4_HD4-6012B0031801A_HD4-2P54MMJ6A_1X25_3MP_CN25-6012A0061101A_CN25-PARALLEL_BJ7A_RJ45LEDC_CN28-RJ45LEDC,6026AAA_CN28-RJ45LED2_CJ8A_1X4_HD4-6012B0031801A_HD4-2P54MMJ9A_PCIE8X_PCIE8X-6012A0100101A_CN98-2MM_FLJ10A_TOOL1X1_1X1-ID-BATTP0-00A_BATTPJ11A_PCI5V32B_A_CN124-6012A0046601A_CN124-PCIJ12A_PCI5V32B_A_CN124-6012A0046601A_CN124-PCIJ13A_PCI5V32B_A_CN124-6012A0046601A_CN124-PCIJ14A_2X4_A_TH-6012B0037001A_CN8-165X217_AJ15A_PCIE16X_PCIE16X-6012A0108002A_CN164-2MM_FLJ16A_TEJAS_A_PGA775-TEJAS_A,6026AAA_SKTPGA775-1P17MMJ17A_2X30_CN60-6012A0109001A_CN60-0P5MM_FLJ18A_1X2_HD2-100-60120IA16990A_HD2-100J19A_2X7_B_CN14-6012B0037901A_CN14-100X100_DJ20A_2X5_A_CN10-6012A0061301A_CN10-100X100_AJ21A_2X5K10_A_CN10-6012A0061305A_CN10-100X100K10_AJ22A_1X2_CN2-6012A0038902A_CN2-5P08MMJ23A_DIMM240_DIMM240-DIMM240,6026AA_DIMM240J24A_DIMM240_DIMM240-DIMM240,6026AA_DIMM240J25A_DIMM240_DIMM240-DIMM240,6026AA_DIMM240J26A_DIMM240_DIMM240-DIMM240,6026AA_DIMM240J27A_2X5K9_TH-6012B0037301A_CN10_100X100_O9J28A_1X2_CN2-6012A0038902A_CN2-5P08MMJ29A_1X2_HD2-79-6012A0074701A_HD2-79J30A_2X20_O20_CN40-6012A0037601A_CN40-100X100_O20J31A_2X17_CN34-6012A0045201A_CN34-2362705J34A_SATACONN_CN9-6012B0037601A_CN9-1P27MMJ35A_SATACONN_CN9-6012B0037601A_CN9-1P27MMJ36A_SATACONN_CN9-6012B0037601A_CN9-1P27MMJ37A_SATACONN_CN9-6012B0037601A_CN9-1P27MMJ38A_1X4_HD4-6012B0031801A_HD4-2P54MMJ39A_2X5_A_CN10-6012A0061301A_CN10-100X100_AJ40A_2X12_CN24-6012B0036501A_CN24-4P2MMJ41A_2X15_K3K25K26_CN30-6012B0017AA_CN30-2P54MM_K3K25K26L1A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L2A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L3A_BEAD_BEAD-0603-600,6014B0009BA_BEAD-0603L4A_BEAD_BEAD-2012-60,6014B00098AA_BEAD-0603L5A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L6A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L7A_BEAD_BEAD-2012-60,6014B00098AA_BEAD-0603L8A_BEAD4_SM-90,6014A0018501A_BEAD4-1P5MML9A_BEAD4_SM-90,6014A0018501A_BEAD4-1P5MML10A_BEAD_BEAD-0603-600,6014B0009BA_BEAD-0603L11A_BEAD_BEAD-0603-600,6014B0009BA_BEAD-0603L12A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L13A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L14A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L15A_BEAD_BEAD-2012-60,6014B00098AA_BEAD-0603L16A_BEAD_BEAD-0603-600,6014B0009BA_BEAD-0603L17A_BEAD_BEAD-2012-60,6014B00098AA_BEAD-0603L18A_BEAD_BEAD-2012-60,6014B00098AA_BEAD-0603L19A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L20A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L21A_BEAD_BEAD-0805-2K,6014B00099AA_BEAD-0805L22A_BEAD_BEAD-0603-600,6014B0009BA_BEAD-0603L23A_BEAD_BEAD-0603-600,6014B0009BA_BEAD-0603L24A_BEAD_BEAD-0805-2K,6014B00099AA_BEAD-0805L25A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L26A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L27A_BEAD_BEAD-0805-2K,6014B00099AA_BEAD-0805L28A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L29A_INDUCT_INDUCT-0.5UH,6014B001AA_INDUCT_7P62MM_AL30A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L31A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L32A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L33A_INDUCT_INDUCT-0.5UH,6014B001AA_INDUCT_7P62MM_AL34A_INDUCT_INDUCT-2.2UH,6014A003AA_INDUCT_5P54MML35A_INDUCT_INDUCT-1UH,6014B00104AA_INDUCT_6P5MML36A_INDUCT_INDUCT-0.5UH,6014B001AA_INDUCT_7P62MM_AL37A_INDUCT_INDUCT-0.5UH,6014B001AA_INDUCT_7P62MM_AL38A_BEAD_BEAD-0603-600,6014B0009BA_BEAD-0603L39A_BEAD_BEAD-0603-600,6014B0009BA_BEAD-0603L40A_BEAD_BEAD-0603-600,6014B0009BA_BEAD-0603L41A_BEAD_BEAD-60,6014B0012301A_BEAD-0603L42A_BEAD_BEAD-1206-300,6014B0010AA_BEAD-1206L43A_BEAD_BEAD-0805-100,6014A0030AA_BEAD-0805L44A_BEAD_BEAD-1206-300,6014B0010AA_BEAD-1206L45A_BEAD_BEAD-0805-100,6014A0030AA_BEAD-0805L46A_BEAD4_SM-90,6014A0018501A_BEAD4-1P5MML47A_BEAD4_SM-90,6014A0018501A_BEAD4-1P5MML48A_BEAD_BEAD-0805-100,6014A0030AA_BEAD-0805L49A_INDUCT_INDUCT-0.5UH,6014B001AA_INDUCT_7P62MM_AL50A_BEAD_BEAD-0603-600,6014B0009BA_BEAD-0603L51A_INDUCT_INDUCT-1.0UH,6014B000AA_INDUCT-2P2MM_AL52A_INDUCT_INDUCT-1.0UH,6014B000AA_INDUCT-2P2MM_AL53A_BEAD_BEAD-0603-600,6014B0009BA_BEAD-0603L54A_BEAD_BEAD-60,6014B0012301A_BEAD-0603L55A_BEAD_BEAD-0805-100,6014A0030AA_BEAD-0805L56A_INDUCT_INDUCT-1UH,6014A00272AA_INDUCT_5P54MML57A_INDUCT_INDUCT-1UH,6014A00272AA_INDUCT_5P54MML58A_INDUCT_INDUCT-2.5UH,6014B001AA_INDUCT_5P5MM_AL59A_INDUCT_INDUCT-1UH,6014B00105AA_INDUCT_6P5MML60A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L61A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L62A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L63A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L64A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L65A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L66A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L67A_BEAD_BEAD-2012-60,6014B00098AA_BEAD-0603L68A_BEAD_BEAD-2012-60,6014B00098AA_BEAD-0603L69A_BEAD_BEAD-2012-60,60140NE013AA_BEAD-2012L70A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L71A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L72A_BEAD_BEAD-0805-100,6014A0030AA_BEAD-0805L73A_INDUCT_INDUCT-10UH,6014A0037AA_INDUCT-130L74A_INDUCT_INDUCT-10UH,6014A0037AA_INDUCT-130L75A_BEAD_BEAD-0805-100,6014A0030AA_BEAD-0805L76A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L77A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L78A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L79A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L80A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L81A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L82A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L83A_BEAD_BEAD-0603-600,6014B0009AA_BEAD-0603L84A_BEAD_BEAD-0805-100,6014A0030AA_BEAD-0805LS1A_BUZZER_TH-40OHM,60390K004808A_BUZZER-256X480Q1A_PNP4_A_SM-40V,6015A0058201A_SOT223-90X248Q3A_NMFET_TO252-30V,6015B0003201A_TO252Q4A_NMFET_TO252-30V,6015B0003101A_TO252Q5A_NMFET_TO252-30V,6015B0003101A_TO252Q6A_NMFET_TO252-30V,6015B0003201A_TO252Q7A_NMFET_TO252-30V,6015B0003101A_TO252Q8A_NMFET_TO252-30V,6015B0003101A_TO252Q9A_NMFET_TO252-30V,6015B0003201A_TO252Q10A_NMFET_TO252-30V,6015B0003101A_TO252Q11A_NMFET_TO252-30V,6015B0003101A_TO252Q12A_NPN_SM-PMBT3904,6015B0007101A_SOT23FTQ13A_NMFET_TO252-30V,6015B0003201A_TO252Q14A_NMFET_TO252-30V,6015B0003101A_TO252Q15A_NMFET_TO252-30V,6015B0003101A_TO252Q16A_NPN_SM-PMBT3904,6015B0007101A_SOT23FTQ17A_NPN_SM-PMBT3904,6015B0007101A_SOT23FTQ18A_NPN_SM-PMBT3904,6015B0007101A_SOT23FTQ19A_NPN_SM-PMBT3904,6015B0007101A_SOT23FTQ20A_NPN_SM-PMBT3904,6015B0007101A_SOT23FTQ21A_NPN_SM-PMBT3904,6015B0007101A_SOT23FTQ22A_NPN_SM-PMBT3904,6015B0007101A_SOT23FTQ23A_NPN_SM-PMBT3904,6015B0007101A_SOT23FTQ24A_NPN_SM-PMBT3904,6015B0007101A_SOT23FTQ25A_NPN_SM-PMBT3904,6015B0007101A_SOT23FTQ26A_NPN_SM-PMBT3904,6015B0007101A_SOT23FTQ27A_NPN_SM-PMBT3904,6015B0007101A_SOT23FTQ28A_NPN_SM-PMBT3904,6015B0007101A_SOT23FTQ29A_NPN_SM-PMBT3904,6015B0007101A_SOT23FTQ30A_NMFET_A_SOT23FT-2N7002,6015BAA_SOT23FTQ31A_NPN_SM-PMBT3904,6015B0007101A_SOT23FTQ32A_NPN_SM-PMBT3904,6015B0007101A_SOT23FTQ33A_NPN_SM-PMBT3904,6015B0007101A_SOT23FTQ35A_NMFET_TO252-30V,6015B0003101A_TO252Q36A_NMFET_TO252-30V,6015B0003101A_TO252Q37A_NFET_SOT23FT-15V,6015B0008001A_SOT23FTQ38A_NMFET_TO252-30V,6015B0003101A_TO252Q39A_NFET_SOT23FT-15V,6015B0008001A_SOT23FTQ40A_NPN_SM-PMBT3904,6015B0007101A_SOT23FTQ41A_NMFET_TO252-30V,6015B0003101A_TO252Q42A_NMFET_TO252-FDD6690A,6015A00AA_TO252Q43A_NPN_SM-PMBT3904,6015B0007101A_SOT23FTQ44A_NPN_SM-PMBT3904,6015B0007101A_SOT23FTQ45A_NPN_SM-PMBT3904,6015B0007101A_SOT23FTQ46A_SI4501ADY_SO8-SI4542DY,6015AAA_SO8-50X208Q47A_PNP4_A_SM-40V,6015A0058201A_SOT223-90X248Q60A_NPN_SM-PMBT3904,6015A0065701A_SOT23FTQ61A_NPN_SM-PMBT3904,6015A0065701A_SOT23FTRP1A_SIP8_RS4N-1020-33,5%,1/16W,6AA_RS4N-1020RP24A_SIP8_RS4N-1020-2.7K,5%,1/16WAA_RS4N-1020RP25A_SIP8_RS4N-1020-2.7K,5%,1/16WAA_RS4N-1020SW1A_4SWPK_SWDIP8-4SWPK,60260IE03AA_SWDIP8-100X300TH1A_TO157_N1_TO159-ID-159TO-03A_159TOOL-SM2-CO-325TH2A_TO157_N1_TO159-ID-159TO-03A_159TOOL-SM2-CO-325TH3A_TO157_N1_TO159-ID-159TO-03A_159TOOL-SM2-CO-325TH4A_TO157_N1_TO157-ID-157TOOL-394A_157TOOL-SM2-394TH5A_TO157_N1_TO157-ID-157TOOL-394A_157TOOL-SM2-394TH6A_TO157_N1_TO157-ID-157TOOL-394A_157TOOL-SM2-394TH7A_TO157_N1_TO157-ID-157TOOL-394A_157TOOL-SM2-394TH8A_TO157_N1_TO159-ID-159TO-03A_159TOOL-SM2-CO-325TH9A_TO157_N1_TO159-ID-159TO-03A_159TOOL-SM2-CO-325TH10A_TO157_N1_TO159-ID-159TO-03A_159TOOL-SM2-CO-325TH11A_TO157_N1_TO159-ID-159TO-03A_159TOOL-SM2-CO-325TH12A_TO157_N1_TO159-ID-159TO-03A_159TOOL-SM2-CO-325TH13A_TO157_N1_TO159-ID-159TO-03A_159TOOL-SM2-CO-325U1A_AME1117_SOT223-AME1117,6019AAA_SOT223-90X248U4A_AT45DB011B_SOIC8-AT45DB011B,AA_SOIC8-50X284U7A_TSG08_SC70-NC7SZ08,6019B0048AA_SC70-0P65MMX1P9MMU8A_BCM5751_FPBGA100-BCM5751,601AA_FPBGA196_1MMU9A_RAGEXL_BGA272-RAGEXL,6019B00AA_BGA272U10A_24C256_SOIC8-24C256,6019A014AA_SOIC8-50X208U12A_DS75S_SOIC8-DS75S,6019A01094AA_SOIC8-50X208U13A_MAX211_SSOP28-MAX211,60190H1AA_SSOP28-25P6X275U14A_2MX32_TSOP86-2MX32,6019B0053AA_TSOP86-19P7X434U15A_TSG125_SC70-7SZ125,6019B0049AA_SC70-0P65MMX1P9MMU16A_PCA9511_TSSOP-PCA9511,6019A0AA_TSSOP8-25P6X166U17A_TSG125_SC70-7SZ125,6019B0049AA_SC70-0P65MMX1P9MMU19A_TSG08_SC70-NC7SZ08,6019B0048AA_SC70-0P65MMX1P9MMU20A_ISL6612_SO8-ISL6612,6019B007AA_SOIC8-50X208U21A_BCM5751_FPBGA100-BCM5751,601AA_FPBGA196_1MMU22A_AT45DB011B_SOIC8-AT45DB011B,AA_SOIC8-50X284U23A_ISL6612_SO8-ISL6612,6019B007AA_SOIC8-50X208U24A_ISL6561_MLFP-ISL6561,6019B00AMLFP40_6_50MAU25A_24C256_SOIC8-24C256,6019A014AA_SOIC8-50X208U26A_ISL6612_SO8-ISL6612,6019B007AA_SOIC8-50X208U27A_ISL6612_SO8-ISL6612,6019B007AA_SOIC8-50X208U28A_TPS54612_TSSOP-TPS54612,6019AA_SSOP28-25P6X224_TPU29A_MAX6640AEE_QSOP16-MAX6640AEEAA_QSOP16-25X208_CU30A_PCA9511_TSSOP-PCA9511,6019A0AA_TSSOP8-25P6X166U32A_TTL157_SOIC16-74VHC157,60190AA_SOIC16-50X208U33A_TTL07_TSSOP14-74LCX07,6019A0AA_TSSOP14-25P6X216U34A_24C256_SOIC8-24C256,6019A014AA_SOIC8-50X208U35A_L6910_SOIC16-L6910,6019A0175AA_SOIC16-50X208U36A_TTL00_SOIC14-74LCX00,60190H3AA_SOIC14-50X208U37A_TTL08_TSSOP14-74LCX08,6019A0AA_TSSOP14-25P6X216U38A_H8S2168_TQFP144-H8S2168,6019AA_TQFP144-0P4MMU39A_ICS954141_TSSOP56-ICS954141,BA_TSSOP56-197X284U40A_MAX211_SSOP28-MAX211,60190H1AA_SSOP28-25P6X275U42A_9DB104_SSOP28-9DB104,6019A01AA_SSOP28-25P6X275U43A_1587CM_19_TO-252-1587CM,6019AA_TO-252U44A_TSG08_SC70-NC7SZ08,6019A0251AA_SC70-0P65MMX1P9MMU45A_TSG08_SC70-NC7SZ08,6019A0251AA_SC70-0P65MMX1P9MMU46A_MMCH_DDR2_FCBGA1202-MMCH_DDRAA_FCBGA1202_TMPU47A_MIC5219_SOT23-MIC5255,6019B0AA_SOT23-5PU48A_DS75S_SOIC8-DS75S,6019A01094AA_SOIC8-50X208U49A_ICH7_BGA-ICH7,6019B0053401A_BGA961U50A_PCA9511_TSSOP-PCA9511,6019A0AA_TSSOP8-25P6X166U52A_SC1592_A_SOIC-SC1592,6019B00AA_SOICEDP8-50X208U53A_FWH_PLCC-FWH,6026A0011001A_PLCC32SK-50X520U54A_87366_PQFP128-87366,60190H40AA_PQFP128-197U55A_TPS54672_SSOP28-TPS54672,601AA_SSOP28-25P6X224_TU56A_L6910_SOIC16-L6910,6019A0175AA_SOIC16-50X208U57A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MMU58A_TSG14_SC70-SN74LVC,6019A0246AA_SC70-0P65MMX1P9MMU59A_TSG14_SC70-SN74LVC,6019A0246AA_SC70-0P65MMX1P9MMU60A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MMU61A_TSG14_SC70-SN74LVC,6019A0246AA_SC70-0P65MMX1P9MMU62A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MMU63A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MMU64A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MMU65A_EPM3128A_TQFP100P-EPM3128A,6AA_PQFP100-197U66A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MMU67A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MMU68A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MMU69A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MMU70A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MMU71A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MMU72A_TSG14_SC70-NC7SZ14,6019B0048AA_SC70-0P65MMX1P9MMU73A_ADM809_SOT23FT-ADM809,6019B0AA_SOT23FTU80A_TSG14_SC70-SN74LVC,6019A0246AA_SC70-0P65MMX1P9MMU81A_TSG14_SC70-SN74LVC,6019A0246AA_SC70-0P65MMX1P9MMU101A_BCM5721_PBGA-BCM5721,6019B00AA_PBGA196U243A_74CBT3257_TSSOP16-74CBT3257,AA_TSSOP16-25P6X224U244A_74CBT3257_TSSOP16-74CBT3257,AA_TSSOP16-25P6X224U248A_74CBT3257_TSSOP16-74CBT3257,AA_TSSOP16-25P6X224U249A_74CBT3257_TSSOP16-74CBT3257,AA_TSSOP16-25P6X224Y1A_XTAL_CRY-25M,6018A0015801A_XTAL-7MM_AY2A_XTAL_CRY-25M,6018A0015801A_XTAL-7MM_AY3A_XTAL_CRY-25MHZ,6018A0008401A_XTAL-7MMY4A_SM_XTAL_SM-14.318MHZ,6018A00AA_OSC-MA406HY5A_XTAL_CRY-32.768K,60180E03449TA_XTAL2-100 PCB文件共享。回复可见下载
**** Hidden Message *****
回 armclub 的帖子
armclub:PCB文件共享。回复可见下载[内容隐藏]
(2023-10-12 15:27) images/back.gif
谢谢分享!
