bitstream
发表于 2024-2-21 16:01
LCEDA画的7-100伏转5伏,3.3伏带电压检测Air001开发板
<div></div><div> </div><div> </div><div> </div><div></div><div> </div><div><table width="1600" bgcolor="#ffffff" border="0"><tbody><tr><td width="160">No.</td><td width="160">Quantity</td><td width="160">Comment</td><td width="160">Designator</td><td width="160">Footprint</td><td width="160">Value</td><td width="160">Manufacturer Part</td><td width="160">Manufacturer</td><td width="160">Supplier Part</td><td width="160">Supplier</td></tr><tr><td>1</td><td>1</td><td>4.7uF / 50V</td><td>C1</td><td>C1206</td><td>4.7uF / 50V</td><td>CL31B475KBHNNNE</td><td>SAMSUNG(三星)</td><td></td><td>LCSC</td></tr><tr><td>2</td><td>1</td><td>4.7uF / 16V</td><td>C2</td><td>C0603</td><td>4.7uF / 16V</td><td>CL10A475KO8NNNC</td><td>SAMSUNG(三星)</td><td></td><td>LCSC</td></tr><tr><td>3</td><td>1</td><td>1nF</td><td>C7</td><td>C0603</td><td>1nF</td><td>0603B102K500NT</td><td>FH(风华)</td><td>C44369</td><td>LCSC</td></tr><tr><td>4</td><td>2</td><td>100nF</td><td>C17,C19</td><td>C0603</td><td>100nF</td><td>0603B104K500NT</td><td>FH(风华)</td><td>C30926</td><td>LCSC</td></tr><tr><td>5</td><td>1</td><td>100uF / 25V 钽电容(CASE-D)</td><td>C18</td><td>CASE-D_7343</td><td>100uF / 25V 钽电容(CASE-D)</td><td>16TQC100MYF</td><td>PANASONIC(松下)</td><td></td><td>LCSC</td></tr><tr><td>6</td><td>3</td><td>HC-0.8-2PWT</td><td>CN4,CN5,CN6</td><td>CONN-SMD_2P-P0.80_HCTL_HC-0.8-2PWT</td><td></td><td>HC-0.8-2PWT</td><td>HCTL(华灿天禄)</td><td>C2845343</td><td>LCSC</td></tr><tr><td>7</td><td>3</td><td>SS3150</td><td>D1,D4,D5</td><td>SMA_L4.3-W2.6-LS5.2-RD</td><td></td><td>SS3150</td><td>MDD</td><td>C65000</td><td>LCSC</td></tr><tr><td>8</td><td>1</td><td>1N4148WS</td><td>D3</td><td>SOD-323_L1.8-W1.3-LS2.5-RD</td><td></td><td>1N4148WS</td><td>CJ(江苏长电/长晶)</td><td>C2128</td><td>LCSC</td></tr><tr><td>9</td><td>1</td><td>47uH</td><td>L1</td><td>IND-SMD_L5.8-W5.2</td><td>47uH</td><td>YP0502-470M</td><td>YJYCOIN(益嘉源)</td><td>C576585</td><td>LCSC</td></tr><tr><td>10</td><td>2</td><td>NCD0603B1</td><td>LED1,LED2</td><td>LED0603-RD</td><td></td><td>NCD0603B1</td><td>国星光电</td><td>C84266</td><td>LCSC</td></tr><tr><td>11</td><td>2</td><td>CON-4-0.8MM</td><td>P1,P2</td><td>CONN-SMD_4P-P0.80_A0800WR-S-04P</td><td></td><td>CON-4-0.8MM</td><td></td><td>C9900023700</td><td>LCSC</td></tr><tr><td>12</td><td>1</td><td>3kΩ</td><td>R7</td><td>R0603</td><td>3kΩ</td><td>0603WAF3001T5E</td><td>UNI-ROYAL(厚声)</td><td>C4211</td><td>LCSC</td></tr><tr><td>13</td><td>1</td><td>80mΩ</td><td>R8</td><td>R1206</td><td>80mΩ</td><td>HoYH1206-1W-80mR-1%</td><td>Milliohm(毫欧)</td><td>C601089</td><td>LCSC</td></tr><tr><td>14</td><td>3</td><td>10kΩ</td><td>R9,R10,R36</td><td>R0603</td><td>10kΩ</td><td>0603WAF1002T5E</td><td>UNI-ROYAL(厚声)</td><td>C25804</td><td>LCSC</td></tr><tr><td>15</td><td>2</td><td>309kΩ</td><td>R11,R12</td><td>R0603</td><td>309kΩ</td><td>RS-03K3093FT</td><td>FH(风华)</td><td>C321847</td><td>LCSC</td></tr><tr><td>16</td><td>3</td><td>10kΩ</td><td>R29,R30,R32</td><td>R0603</td><td>10kΩ</td><td>RC0603FR-0710KL</td><td>YAGEO(国巨)</td><td>C98220</td><td>LCSC</td></tr><tr><td>17</td><td>1</td><td>5.1kΩ</td><td>R31</td><td>R0603</td><td>5.1kΩ</td><td>0603WAF5101T5E</td><td>UNI-ROYAL(厚声)</td><td>C23186</td><td>LCSC</td></tr><tr><td>18</td><td>1</td><td>294kΩ</td><td>R33</td><td>R0805</td><td>294kΩ</td><td>RS-05K2943FT</td><td>FH(风华)</td><td>C322408</td><td>LCSC</td></tr><tr><td>19</td><td>1</td><td>82kΩ</td><td>R35</td><td>R0805</td><td>82kΩ</td><td>RS-05K8202FT</td><td>FH(风华)</td><td>C139838</td><td>LCSC</td></tr><tr><td>20</td><td>1</td><td>TS-1092S-B3D2-G</td><td>SW1</td><td>SW-SMD_L6.1-W3.6-LS7.9</td><td></td><td>TS-1092S-B3D2-G</td><td>Yuandi(元迪)</td><td>C520860</td><td>LCSC</td></tr><tr><td>21</td><td>1</td><td>oc2006</td><td>U1</td><td>ESOP-8_L4.9-W3.9-P1.27-LS6.0-TL-EP</td><td></td><td></td><td></td><td></td><td></td></tr><tr><td>22</td><td>1</td><td>10uF / 100V 电解电容</td><td>U2</td><td>CAP-TH_BD5.0-P2.00-D0.5-FD-1</td><td>10uF / 100V 电解电容</td><td>NLC50V10M5*11 2.5TP</td><td>SAMYOUNG(韩国三莹)</td><td></td><td>LCSC</td></tr><tr><td>23</td><td>1</td><td>78L05</td><td>U7</td><td>SOT-89-3_L4.5-W2.5-P1.50-LS4.2-BR</td><td></td><td>78L05</td><td>UMW(友台半导体)</td><td>C347258</td><td>LCSC</td></tr><tr><td>24</td><td>1</td><td>XC6210B332MR</td><td>U31</td><td>SOT-23-5_L2.9-W1.6-P0.95-LS2.8-BR</td><td></td><td>XC6210B332MR</td><td>TECH PUBLIC(台舟)</td><td>C3021084</td><td>LCSC</td></tr><tr><td>25</td><td>3</td><td>1uF</td><td>U32,U33,U35</td><td>C0603</td><td>1uF</td><td>CGA3E3X5R1V105M080AB</td><td>TDK</td><td>C3910162</td><td>LCSC</td></tr><tr><td>26</td><td>1</td><td>AIR001</td><td>U34</td><td>TSSOP-20_L6.5-W4.4-P0.65-LS6.4-BL</td><td></td><td>AIR001</td><td></td><td>C7461672</td><td>LCSC</td></tr><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr></tbody></table></div><div><br /></div>
bitstream
发表于 2024-2-21 16:06
新手作品,请多多指教
cityhu
发表于 2024-2-22 00:04
longxuekai
发表于 2024-2-22 06:13
学习学习学习下吧
wddz
发表于 2024-2-22 08:07
学习学习下吧
ilpuyi
发表于 2024-2-22 08:22
986720
发表于 2024-2-22 08:48
kingweison
发表于 2024-2-22 08:57
小跟班2014
发表于 2024-2-22 09:14
dongpassport
发表于 2024-2-22 09:25
