GD32F470ZIT6 PCB原理图 没画完的PCB SRS800Y3-ZB-V1-2
CommentPatternQuantityComponents1117 3.3VSOT2231U7120R/1206/±1%1206R1R7412K/0603/±1%6032R41, R631K/0603/±5%6033R2, R78, R1011M6031R871N4007W/SOD-123FL1206D1D161N4148WT4/12061206D1D1200K/0603/±1%6031R24220/50V/06036034C6, C7, C8, C9220K/0603/±1%6031R402510-2A条形弯座SIP21JP4300R/0603/±5%6031R23300R0603/±5%6031R3032.768KRAD0.11JK25PINSIP51JP37.3728MSMT_XTALFZ1JK19012SOT-231Q1AO3422SOT-231Q11AT070TN92+FH12A-50S-0.5SH(55)FH12A-50S-0.5SH1LCD1CJO04-250003320B3050321JK3CPFC74NP-CB10M4CMR_L1L4EE10-WX2EE10_4*41T1ESD03V32D-LCSOD-3236D2, D6, D8, D9, D14, D19GD32F470ZIT6/LQFP144LQFP144_M1U3GR08050805D1LED1HR911105AHR911105A1RJ1HT7550/SOT89SOT891U2IS42S16160G-7TLITSOP541U1LA1631SOT23-6L1U14LAN8720AQFN-241U4MCP2551SO-81U9NAN0SMDC050F-13.2-21206R1R83PGB1010603NRHF不焊接6031ESD1PGB1010603不焊接60311ESD8, PTX2222/SOT-89SOT891Q2PTZTE255.1B1210d1D10PTZTE256.8B1210D1D12SCF020-1206R1206R1R4Si8421AB-D-ISSO-81U10SMAJ33A/12101210D2D17, D18SMAJ36A1210D1D3SMAJ6.5A1210D1D4SMBJ33CA/1812D1812D1D15SMD43-4R7M/4.7uH/1.15APIO43_FZ1L1SS14/SMA1210D1D5SS141210d2D7, D13SS14不焊接1210D1D11WT1312sot23-61U5XT25F64BSOP-8M1U13电池座zl_cr12201BT1简易牛角插座 20P/2.54直座IDC201JP1简易牛角插座 26P/2.54直座IDC261JP2
