| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| A1 | ANTENNA_PCB_ANTENNA_DN024N_DISC | 868MHz/2440MHz | ANTENNA_DN024N |
| CR1 | LED_LEDC1707X65L_LPL296-J2L2-25 | LPL296-J2L2-25 | LEDC1707X65L |
| CR2 | LED_LEDC1708X67L_LS L296-P2Q2-1 | LS L296-P2Q2-1 | LEDC1708X67L |
| CR4 | LED_LEDC1708X67N_IC_LS L296-P2Q | LS L296-P2Q2-1 | LEDC1708X67L |
| CR5 | LED_LEDC1707X65N_IC_LPL296-J2L2 | LPL296-J2L2-25 | LEDC1707X65L |
| CR6 | DIODE_TPD4E004_SON6_SON50P100X1 | TPD4E004DRY | SON50P100X145X60-6N |
| CR7 | DIODE_TVS_TPD6E004_QFN8_V1_QFN5 | TPD6E004RSER | QFN50P150X150X60-8N |
| CR8 | DIODE_TVS_TPD6E004_QFN8_V1_QFN5 | TPD6E004RSER | QFN50P150X150X60-8N |
| CR14 | DIODE_ZENER_DIO_BZX84JN_IC_3.9V | 3.9V | DIO_BZX84JN |
| CR15 | DIODE_SCHOTTKY_SOD3716X135N_IC_ | MBR130T1 | SOD3716X135L |
| FIDU1 | FIDMARK_FID127X142_IO_FIDU_1.27 | FIDU_1.27mm | FID127X142 |
| FIDU2 | FIDMARK_FID127X142_IO_FIDU_1.27 | FIDU_1.27mm | FID127X142 |
| FIDU3 | FIDMARK_FID127X142_IO_FIDU_1.27 | FIDU_1.27mm | FID127X142 |
| FIDU4 | FIDMARK_FID127X142_IO_FIDU_1.27 | FIDU_1.27mm | FID127X142 |
| FIDU5 | FIDMARK_FID127X142_IO_FIDU_1.27 | FIDU_1.27mm | FID127X142 |
| FIDU6 | FIDMARK_FID127X142_IO_FIDU_1.27 | FIDU_1.27mm | FID127X142 |
| FL1 | FILTER_2PIN_FIL_BLM18HE152SN1DL | BLM18HE152SN1 | FIL_BLM18HE152SN1DL |
| FL2 | FILTER_2PIN_FIL_BLM18HE152SN1DN | BLM18HE152SN1 | FIL_BLM18HE152SN1DN |
| FL3 | FILTER_LFD21829_0_FIL_LFD21829M | LFD21829MDKED859 | FIL_LFD21829MDKED859_A2N |
| FL4 | FILTER_2PIN_FIL_BLM18HE152SN1DN | BLM18HE152SN1 | FIL_BLM18HE152SN1DL |
| FL5 | FILTER_2PIN_FIL_BLM18HE152SN1DN | BLM18HE152SN1 | FIL_BLM18HE152SN1DN |
| J1 | CONN_HEADER_2X10_J_S_V1_SAMTEC_ | SSQ-110-23-L-D | SAMTEC_SSQ11023LD_A2B |
| J2 | CONN_HEADER_2X10_J_S_V1_SAMTEC_ | SSQ-110-23-L-D | SAMTEC_SSQ11023LD_A2B |
| J6 | CONN_USB_MICRO_B_2MH_MOLEX_1051 | 105164-0001 | MOLEX_1051640001_B2N |
| J7 | CONN_COAX_1_4_HUSTSAN_SMA10V21T | SMA-10V21-TGG | HUSTSAN_SMA10V21TGGAN |
| L11 | INDUCTOR_HOR_1_2_INDC1005X60D2N | 15nH | INDC1005X60D2N |
| L12 | INDUCTOR_HOR_1_2_INDC1005X60D_1 | 2.4nH | INDC1005X60D2N |
| L13 | INDUCTOR_HOR_1_2_INDC1005X60D_2 | 2nH | INDC1005X60D2N |
| L14 | INDUCTOR_HOR_1_2_INDC1005X60D_2 | 2nH | INDC1005X60D2N |
| L21 | INDUCTOR_HOR_1_2_INDC1005X60D_1 | 2.4nH | INDC1005X60D2N |
| L31 | INDUCTOR_HOR_1_2_INDC1005X60C2N | 3.9nH | INDC1005X60C2N |
| L32 | INDUCTOR_HOR_1_2_INDC1005X60D_3 | 22nH | INDC1005X60D2N |
| L33 | INDUCTOR_HOR_1_2_INDC1005X60C_1 | 10nH | INDC1005X60C2N |
| L34 | INDUCTOR_HOR_1_2_INDC1005X60D_4 | 7.5nH | INDC1005X60D2N |
| L41 | INDUCTOR_HOR_1_2_INDC1005X60C2N | 3.9nH | INDC1005X60C2N |
| L42 | INDUCTOR_HOR_1_2_INDC1005X60C_1 | 10nH | INDC1005X60C2N |
| L331 | INDUCTOR_INDC2012X150A2N_DISCRE | 6.8uH | INDC2012X150A2N |
| L332 | INDUCTOR_FILC2012X110A2N_DISCRE | BLM21PG221SN1 | FILC2012X110A2N |
| L333 | INDUCTOR_FILC2012X110A2N_DISCRE | BLM21PG221SN1 | FILC2012X110A2N |
| L334 | INDUCTOR_FILC2012X110A2N_DISCRE | BLM21PG221SN1 | FILC2012X110A2N |
| LBL2 | TI_LOGO_V1_TI_LOGO_1_MECHANICAL | TI_LOGO | TI_LOGO_1 |
| LBL3 | CE_LABEL_V1_CE_MARKING_MECHANIC | CE_label | CE_MARKING |
| LBL4 | LABEL_FOR_EVALUATOIN_ONLY_LABEL | LABEL_FOR_EVALUATION_ONLY | LABEL_FOR_EVALUATION_ONLY |
| LBL5 | TRASH_V2_TRASH_7MM_MECHANICAL_T | TRASH_7mm | TRASH_7MM |
| LBL6 | ESD_LABEL_ESD_LABEL_5X5_MECHANI | ESD_LABEL_5x5mm | ESD_LABEL_5X5 |
| M1 | MECH_SHUNT_JUMPER_V1_SAMTEC_SNT | SNT-100-BK-G | SAMTEC_SNT100BKG |
| M2 | MECH_SHUNT_JUMPER_V1_SAMTEC_SNT | SNT-100-BK-G | SAMTEC_SNT100BKG |
| M3 | MECH_SHUNT_JUMPER_V1_SAMTEC_SNT | SNT-100-BK-G | SAMTEC_SNT100BKG |
| M4 | MECH_SHUNT_JUMPER_V1_SAMTEC_SNT | SNT-100-BK-G | SAMTEC_SNT100BKG |
| M5 | MECH_SHUNT_JUMPER_V1_SAMTEC_SNT | SNT-100-BK-G | SAMTEC_SNT100BKG |
| M6 | MECH_SHUNT_JUMPER_V1_SAMTEC_SNT | SNT-100-BK-G | SAMTEC_SNT100BKG |
| M7 | MECH_SHUNT_JUMPER_V1_SAMTEC_SNT | SNT-100-BK-G | SAMTEC_SNT100BKG |
| M8 | MECH_SHUNT_JUMPER_V1_SAMTEC_SNT | SNT-100-BK-G | SAMTEC_SNT100BKG |
| M9 | MECH_SHUNT_JUMPER_V1_SAMTEC_SNT | SNT-100-BK-G | SAMTEC_SNT100BKG |
| M10 | MECH_SHUNT_JUMPER_V1_SAMTEC_SNT | SNT-100-BK-G | SAMTEC_SNT100BKG |
| M11 | MECH_SHUNT_JUMPER_V1_SAMTEC_SNT | SNT-100-BK-G | SAMTEC_SNT100BKG |
| M12 | MECH_SHUNT_JUMPER_V1_SAMTEC_SNT | SNT-100-BK-G | SAMTEC_SNT100BKG |
| M13 | MECH_SHUNT_JUMPER_V1_SAMTEC_SNT | SNT-100-BK-G | SAMTEC_SNT100BKG |
| M14 | MECH_SHUNT_JUMPER_V1_SAMTEC_SNT | SNT-100-BK-G | SAMTEC_SNT100BKG |
| M15 | MECH_SPACERS_SUPPORT_V1_MECH_DC | DCB-10 | MECH_DCB10_A2B |
| M16 | MECH_SPACERS_SUPPORT_V1_MECH_DC | DCB-10 | MECH_DCB10_A2B |
| M17 | MECH_SPACERS_SUPPORT_V1_MECH_DC | DCB-10 | MECH_DCB10_A2B |
| M18 | MECH_SPACERS_SUPPORT_V1_MECH_DC | DCB-10 | MECH_DCB10_A2B |
| MH1 | HOLE_PTH_MTG320_380_IO_HOLE_3.2 | HOLE_3.2mm_PTH | MTG320_380 |
| MH2 | HOLE_PTH_MTG320_380_IO_HOLE_3.2 | HOLE_3.2mm_PTH | MTG320_380 |
| MH3 | HOLE_PTH_MTG320_380_IO_HOLE_3.2 | HOLE_3.2mm_PTH | MTG320_380 |
| MH4 | HOLE_PTH_MTG320_380_IO_HOLE_3.2 | HOLE_3.2mm_PTH | MTG320_380 |
| MH5 | HOLE_PTH_MTG110_170_IO_HOLE_1.1 | HOLE_1.1mm_PTH | MTG110_170 |
| P1 | CONN_HEADER_3_P_S_GRADCONN_BB02 | BB02-HC031-KB1-603000 | GRADCONN_BB02HC031KB1603000_A2B |
| P2 | CONN_HEADER_3_P_S_GRADCONN_BB02 | BB02-HC031-KB1-603000 | GRADCONN_BB02HC031KB1603000_A2B |
| P4 | CONN_HEADER_2X11_P_S_GRADCONN_B | BB02-HJ221-KB1-603000 | GRADCONN_BB02HJ221KB160300_A2B |
| P5 | CONN_HEADER_2X5_SAMTEC_FTSH-105 | FTSH-105-01-F-DV-K | SAMTEC_FTSH-105-01-F-DV-K-10L |
| P6 | CONN_HEADER_2X2_P_GRADCONN_BB02 | BB02-HJ041-KB1-603000 | GRADCONN_BB02HJ041KB1603000_A2B |
| P7 | CONN_HEADER_2X5_SAMTEC_FTSH-105 | FTSH-105-01-F-DV-K | SAMTEC_FTSH-105-01-F-DV-K-10L |
| P8 | CONN_IDC_TC2050-IDC-NL_TAGCONNE | TC2050-IDC-NL | TAGCONNECT_TC2050IDCNL_A2N |
| P10 | CONN_HEADER_3_P_S_GRADCONN_BB02 | BB02-HC031-KB1-603000 | GRADCONN_BB02HC031KB1603000_A2B |
| P11 | CONN_COAX_1_1_P_2MH_V1_MURATA_M | MM5829-2700 | MURATA_MM58292700RJ4_A2N |
| P12 | CONN_COAX_1_1_P_2MH_V1_MURATA_M | MM5829-2700 | MURATA_MM58292700RJ4_A2N |
| PCB1 | PCB_V2_TI_MCUXX_MECHANICAL_WCS0 | WCS038 | TI_MCUXX |
| SW1 | SWITCH_TACT_V2_SW_1188E1K2V_A2N | 1188E-1K2-V | SW_1188E1K2V_A2N |
| SW2 | SWITCH_TACT_V2_SW_1188E1K2V_A2N | 1188E-1K2-V | SW_1188E1K2V_A2N |
| SW3 | SWITCH_TACT_V2_SW_1188E1K2V_A_1 | 1188E-1K2 | SW_1188E1K2V_A2N |
| U1 | IC_RF_CC1352_QFN48_QFNFC50P700X | CC1352R1F3RGZ | QFNFC50P700X700X100-49A2N |
| U4 | IC_FLASH_MX25R8035F_USON8_SON50 | MX25R8035FZUIL0 | SON50P300X200X60-9B2L |
| U5 | IC_PROC_TM4C1294NCPDT_TQFP128_Q | TM4C1294NCPDTT3R | QFP40P1600X1600X120-128N |
| U6 | IC_REF_LM4040_SC70-5_SOT65P210X | LM4040B25IDCK | SOT65P210X110-5N |
| U7 | IC_PM_TPS79601_SON8_SON65P300X3 | TPS79601DR | SON65P300X300X100-9AL |
| U8 | IC_XCVR_SN74AVC4T245_UQFN16_2_Q | SN74AVC4T245RSV | QFNFC40P180X260X55-16A2L |
| U9 | IC_XCVR_SN74AVC4T245_UQFN16_2_Q | SN74AVC4T245RSV | QFNFC40P180X260X55-16A2L |
| U10 | IC_XCVR_SN74AVC4T245_UQFN16_2_Q | SN74AVC4T245RSV | QFNFC40P180X260X55-16A2L |
| U15 | IC_PROC_USB3300_QFN32_QFNWB50P5 | USB3300-EZK | QFNWB50P500X500X100-33N |
| U33 | IC_SWITCH_TS3A24159_SON10_SON50 | TS3A24159DRC | SON50P300X300X100-11A2N |
| U34 | IC_LOGIC_SN74LVC2G74_VSSOP8_SOP | SN74LVC2G74DCU | SOP50P310X90-8N |
| U35 | IC_ADC_ADS127L01_QFP32_0_QFP50P | ADS127L01IPBS | QFP50P700X700X120-32A2N |
| U36 | IC_OPAMP_INA118U_SO8_SOIC127P60 | INA118UB | SOIC127P600X175-8N |
| U37 | IC_OPAMP_THS4551_QFN10_QFNFCP50 | THS4551IRUN | QFNFCP50P200X200X80-10A2N |
| U38 | IC_SWITCH_TS3A24159_SON10_SON50 | TS3A24159DRC | SON50P300X300X100-11A2N |
| U39 | IC_SWITCH_TS3A4751_QFN14_QFNFC4 | TS3A4751RUCR | QFNFC40P200X200X40-14A2N |
| U40 | IC_REF_REF6025_VSSOP8_SOP65P490 | REF6025IDGK | SOP65P490X110-8A2N |
| U41 | IC_OPAMP_OPA320_SOT23-5_SOT95P2 | OPA320AIDBV | SOT95P280X145-5A2N |
| U42 | IC_PM_TPS79601_SON8_SON65P300X3 | TPS79601DR | SON65P300X300X100-9AL |
| U43 | IC_PM_LP5907-1_8_SOT23-5_SOT95P | LP5907MFX-1.8 | SOT95P280X145-5A2N |
| U44 | IC_PM_TPS73101_SOT23-5_SOT95P28 | TPS73101DBV | SOT95P280X145-5A2N |
| U45 | IC_OPAMP_OPA314_SC70-5_SOT65P21 | OPA314AIDCK | SOT65P210X110-5A2N |
| U46 | IC_PM_TPS79601_SON8_SON65P300X3 | TPS79601DR | SON65P300X300X100-9AN |
| U47 | IC_PM_TPS259530_WSON8_SON50P200 | TPS259530DSG | SON50P200X200X80-9A2N |
| Y1 | CRYSTAL_XTAL_FC-135N_32.768KHZ_ | 32.768kHz | XTAL_FC-135N |
| Y2 | XTAL_4PINS_1_3_OSCCC200X160X45- | 48MHz | OSCCC200X160X45-4A2N |
| Y3 | XTAL_4_OSCCC250X320X100-4BN_IC_ | 16MHz | OSCCC250X320X100-4BN |
| Y4 | XTAL_4_OSCCC250X320X70-4AN_IC_2 | 24MHz | OSCCC250X320X70-4AN |
| Y5 | XTAL_GEN_EN_V1_OSCSC254P320X500 | 16.384MHz | OSCSC254P320X500X130-4A2N |
| Z60 | INDUCTOR_INDC1005X60B2N_DISCRET | 3.3nH | INDC1005X60B2N |
| Z61 | CAPACITOR_CAPC1005X60B2N_DIS_12 | 5.6pF | CAPC1005X60B2N |
| Z62 | INDUCTOR_INDC1005X60B2N_DISCRET | 3.3nH | INDC1005X60B2N |
| Z63 | CAPACITOR_CAPC1005X60B2N_DIS_12 | 5.6pF | CAPC1005X60B2N |
