牛逼双面挂4个DDR4 国科微GK6780V100高清4K多功能商显一体机电视PCB文件
国科微GK6780V100 商显一体机电视
加密版,可以打开浏览欣赏。但是不能编辑修改保存。
可没加密版,可以修改保存。一般下载上面的加密版即可。
A1AHOLE_AHOLE157_AHOLE_4.0MMAHOLE_4.0MMAHOLE157
A2AHOLE_AHOLE157_AHOLE_4.0MMAHOLE_4.0MMAHOLE157
A3AHOLE_AHOLE157_AHOLE_4.0MMAHOLE_4.0MMAHOLE157
A4AHOLE_AHOLE157_AHOLE_4.0MMAHOLE_4.0MMAHOLE157
A5AHOLE_AHOLE157_AHOLE_4.0MMAHOLE_4.0MMAHOLE157
ANT1ANT-PLUG_IPEX3-3X3_1_NC/ANT_IF-NC/ANT_IF-0203IPEX3-3X3_1
BAT1BAT_BAT2-CR2032-2-1-DIP_BATBATBAT2-CR2032-2-1-DIP
CN1PH-3A_PH-3A_PH-3APH-3APH-3A
CN2XH-4A_XH-4A_XH-4AXH-4AXH-4A
CN3PH-2A_PH-2A_PH-2APH-2APH-2A
CN4PH-4A_DEBUG_PH-4A_PH-4A_BULEPH-4A_BULEPH-4A
CN5PH-4A_TOUCH_PH-4A_PH-4A_REDPH-4A_REDPH-4A
CN6PHB-2X5A_K_I2S_PHB-2X5A_PHB-2X5PHB-2X5A_K_I2SPHB-2X5A
CN7PH-4A_K_PH-4A_PH-4A_KPH-4A_KPH-4A
CN8PH-4A_UART_PH-4A_PH-4A_WHITEPH-4A_WHITEPH-4A
CNK1PHB-2X7A_K_KEY_PHB-2X7A_PHB-2X7PHB-2X7A_K_KEYPHB-2X7A
CNK2PH-3A_K_PH-3A_PH-3A_KPH-3A_KPH-3A
CNU1GH-12AB_1MM25T-12A-18_25X4_25-SNC/GH-12AB1MM25T-12A-18_25X4_25-SMD
CNU2GH-12AB_1MM25T-12A-18_25X4_25-SNC/GH-12AB1MM25T-12A-18_25X4_25-SMD
CNU3PH-4A_K_PH-4A_PH-4A_KPH-4A_KPH-4A
CNU4PH-4A_PH-4A_PH-4APH-4APH-4A
CNU5PH-4A_PH-4A_NC/PH-4ANC/PH-4APH-4A
CNU6PHB-2X4A_K_USB_PHB-2X4A_NC/PHB-NC/PHB-2X4A_K_USBPHB-2X4A
CO1CAP_0402_C0402_100NF/16V100nF/16VC0402
CW22CAP_0402_C0402_100NF/16V100nF/16VC0402
D1ESD_1_E0402_NC/ESD_6PFNC/ESD_6pFE0402
D2ESD_1_E0402_NC/ESD_6PFNC/ESD_6pFE0402
D3ESD_1_E0402_ESD_6PFESD_6pFE0402
D4ESD_1_E0402_ESD_6PFESD_6pFE0402
DA1DIODE_SOD-123_41484148SOD-123
DC1BAT54C_SOT-23_BAT54CBAT54CSOT-23
DD1DIODE_SMA-DO-214AC_SS34SS34SMA-DO-214AC
DD2DIODE_SMA-DO-214AC_SS34SS34SMA-DO-214AC
DE1ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DE2ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DE3ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DE4ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DE5ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DE6ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DF1ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DF2ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DF3ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DF4ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DF5ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DF6ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DF7ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DH1ESD-10P_ESD2710-10P_ESD_0.35PF_ESD_0.35pF_10PESD2710-10P
DH2ESD-10P_ESD2710-10P_ESD_0.35PF_ESD_0.35pF_10PESD2710-10P
DH3DIODE_SOD-123_41484148SOD-123
DH4ESD_1_E0402_ESD_6PFESD_6pFE0402
DH5ESD_1_E0402_ESD_6PFESD_6pFE0402
DH6ESD_1_E0402_ESD_6PFESD_6pFE0402
DH7ESD-10P_ESD2710-10P_ESD_0.35PF_ESD_0.35pF_10PESD2710-10P
DH8ESD-10P_ESD2710-10P_ESD_0.35PF_ESD_0.35pF_10PESD2710-10P
DH9DIODE_SMA-DO-214AC_SS34SS34SMA-DO-214AC
DH10ESD_1_E0402_ESD_6PFESD_6pFE0402
DH11ESD_1_E0402_ESD_6PFESD_6pFE0402
DH12ESD_1_E0402_ESD_6PFESD_6pFE0402
DH13ESD_1_E0402_ESD_6PFESD_6pFE0402
DH14ESD_1_E0402_ESD_6PFESD_6pFE0402
DH15ESD_1_E0402_ESD_6PFESD_6pFE0402
DH16ESD-10P_ESD2710-10P_ESD_0.35PF_ESD_0.35pF_10PESD2710-10P
DH17ESD-10P_ESD2710-10P_ESD_0.35PF_ESD_0.35pF_10PESD2710-10P
DH18DIODE_SOD-123_41484148SOD-123
DH19ESD_1_E0402_ESD_6PFESD_6pFE0402
DH20ESD_1_E0402_ESD_6PFESD_6pFE0402
DH21ESD_1_E0402_ESD_6PFESD_6pFE0402
DH22ESD_1_E0402_ESD_6PFESD_6pFE0402
DH23ESD_1_E0402_ESD_6PFESD_6pFE0402
DH24ESD_1_E0402_ESD_6PFESD_6pFE0402
DH25ESD_1_E0402_ESD_6PFESD_6pFE0402
DH26ESD_1_E0402_ESD_6PFESD_6pFE0402
DH27ESD_1_E0402_ESD_6PFESD_6pFE0402
DH28ESD-10P_ESD2710-10P_ESD_0.35PF_ESD_0.35pF_10PESD2710-10P
DH29ESD-10P_ESD2710-10P_ESD_0.35PF_ESD_0.35pF_10PESD2710-10P
DH30ESD_1_E0402_ESD_6PFESD_6pFE0402
DH31ESD_1_E0402_ESD_6PFESD_6pFE0402
DH32ESD_1_E0402_ESD_6PFESD_6pFE0402
DH33ESD_1_E0402_ESD_6PFESD_6pFE0402
DH34ESD_1_E0402_ESD_6PFESD_6pFE0402
DH35ESD_1_E0402_ESD_6PFESD_6pFE0402
DH36ESD_1_E0402_ESD_6PFESD_6pFE0402
DH38ESD_1_E0402_ESD_6PFESD_6pFE0402
DH39ESD_1_E0402_ESD_6PFESD_6pFE0402
DH40ESD_1_E0402_ESD_6PFESD_6pFE0402
DH41ESD_1_E0402_ESD_6PFESD_6pFE0402
DK1ESD_1_E0402_ESD_6PFESD_6pFE0402
DK2ESD_1_E0402_ESD_6PFESD_6pFE0402
DK3ESD_1_E0402_ESD_6PFESD_6pFE0402
DO1ESD_1_E0402_ESD_6PFESD_6pFE0402
DS1ESD_1_E0402_ESD_6PFESD_6pFE0402
DS2ESD_1_E0402_ESD_6PFESD_6pFE0402
DS3ESD_1_E0402_ESD_6PFESD_6pFE0402
DS4ESD_1_E0402_ESD_6PFESD_6pFE0402
DU1ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DU2ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DU3ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DU4ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DU5ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DU6ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DU7ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DU8ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DU9ESD_1_E0402_NC/ESD_0.05PFNC/ESD_0.05pFE0402
DU10ESD_1_E0402_NC/ESD_0.05PFNC/ESD_0.05pFE0402
DU11ESD_1_E0402_NC/ESD_0.05PFNC/ESD_0.05pFE0402
DU12ESD_1_E0402_NC/ESD_0.05PFNC/ESD_0.05pFE0402
DU13ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DU14ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DU15ESD_1_E0402_NC/ESD_0.05PFNC/ESD_0.05pFE0402
DU16ESD_1_E0402_NC/ESD_0.05PFNC/ESD_0.05pFE0402
DU17ESD_1_E0402_NC/ESD_0.05PFNC/ESD_0.05pFE0402
DU18ESD_1_E0402_NC/ESD_0.05PFNC/ESD_0.05pFE0402
DU19ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DU20ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DU21ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DU22ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DU23ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DU24ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DU25ESD-10P_ESD2710-10P_ESD_0.35PF_ESD_0.35pF_10PESD2710-10P
DU26ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DU27ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DU28ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DU29ESD_1_E0402_ESD_0.05PFESD_0.05pFE0402
DV1ESD_1_E0402_ESD_6PFESD_6pFE0402
DV2ESD_1_E0402_ESD_6PFESD_6pFE0402
DV3ESD_1_E0402_ESD_6PFESD_6pFE0402
DV4ESD_1_E0402_ESD_6PFESD_6pFE0402
DV5ESD_1_E0402_ESD_6PFESD_6pFE0402
DV6ESD_1_E0402_ESD_6PFESD_6pFE0402
DV7ESD_1_E0402_ESD_6PFESD_6pFE0402
DV8ESD_1_E0402_ESD_6PFESD_6pFE0402
DW1DIODE_SOD-123_NC/4148NC/4148SOD-123
HS1HEATSINK_100X85X7_8_HS_100X85XHS_100x85x7_8MMHS_100X85X7_8-4P
HS2HEATSINK_24X8X10_HS_8X24X10-2PNC/HS_24X8X10MMHS_8X24X10-2P
JA1XH-4AW_K_XH-4AWD_XHB-4AW_KXHB-4AW_KXH-4AWD
JA2GH-6AWB_1MM25T-6AW-10_75X4_2-SMGH-6AWB1MM25T-6AW-10_75X4_2-SMD
JA3PH-3A_K_PH-3A_PH-3A_KPH-3A_KPH-3A
JA4PJ-325_PJ-325_PJ-325CPJ-325CPJ-325
JD1PHB-2X10AW_DC_PHB-2X10AWD_PHB-2PHB-2X10AW_DCPHB-2X10AWD
JD2PH-4AW_K_PH-4AWD_PH-4A_K_DCPH-4A_K_DCPH-4AWD
JE1RJ45-L_Y-R_G_RJ45-12P-9BJ-NBJ-2RJ45RJ45-12P-9BJ-NBJ-260-R0
JH1HDMI_HDMI-19P-H_HDMIC-16101179HDMIC-161011792-00HDMI-19P-H
JH2HDMI_HDMI-19P-H_HDMIC-16101179HDMIC-161011792-00HDMI-19P-H
JI2C1PH-5A_K_I2C_PH-5A_PH-5A_K_I2CPH-5A_K_I2CPH-5A
JI2C2PH-5A_K_I2C_PH-5A_PH-5A_K_I2CPH-5A_K_I2CPH-5A
JO1COAX_AV1-8R4-38C_COAXCOAXAV1-8R4-38C
JO2OPTICAL_OPTICAL-DQT-026D_NC/OPTNC/OPTICALOPTICAL-DQT-026D
JS1RS232-DB9_DB9-H_RS232RS232DB9-H
JU1USB2.0_A_L_USB2_0-4P-LH_USB2.0-USB2.0-AUSB2_0-4P-LH
JU2USB3.0-B_H_USB3_0_TYPE_B-9P_USBUSB3.0-BUSB3_0_TYPE_B-9P
JU3USB2.0_A_L_USB2_0-4P-LH_USB2.0-USB2.0-AUSB2_0-4P-LH
JU4USB3.0-A_L_USB3_0-9P-LH_USB3.0-USB3.0-AUSB3_0-9P-LH
JU5USB2.0_A_L_USB2_0-4P-LH_USB2.0-USB2.0-AUSB2_0-4P-LH
JU7USB2.0-B-H_USB_TYPE_B-4P_USB2.0USB2.0-BUSB_TYPE_B-4P
JV1VGA-DB15_VGA15-F_VGAVGAVGA15-F
JV2PJ-325_PJ-325_PJ-325CPJ-325CPJ-325
JW1FPC_51P_FPC51-0MM5-35_35X4_2_FPFPC_51PFPC51-0MM5-35_35X4_2
JW2FPC_51P_FPC51-0MM5-35_35X4_2_FPFPC_51PFPC51-0MM5-35_35X4_2
JW3FPC_51P_FPC51-0MM5-35_35X4_2_FPFPC_51PFPC51-0MM5-35_35X4_2
L1BEAD_FB0402_FB120R/1.3AFB120R/1.3AFB0402
L2BEAD_FB0402_NC/FB120R/1.3ANC/FB120R/1.3AFB0402
L3BEAD_FB0402_FB120R/1.3AFB120R/1.3AFB0402
LA1BEAD_FB0402_FB120R/1.3AFB120R/1.3AFB0402
LA2INDUCTOR_PL7_4X6_8_15UH/3.2A15uH/3.2APL7_4X6_8
LA3INDUCTOR_PL7_4X6_8_15UH/3.2A15uH/3.2APL7_4X6_8
LA4INDUCTOR_PL7_4X6_8_15UH/3.2A15uH/3.2APL7_4X6_8
LA5INDUCTOR_PL7_4X6_8_15UH/3.2A15uH/3.2APL7_4X6_8
LD1INDUCTOR_SWPA4030S_2.2UH/2.95A2.2uH/2.95ASWPA4030S
LD2INDUCTOR_SWPA4030S_2.2UH/2.95A2.2uH/2.95ASWPA4030S
LD3INDUCTOR_PL5_2X5_4_1UH/9.85A1uH/9.85APL5_2X5_4
LD4INDUCTOR_SWPA4030S_2.2UH/2.95A2.2uH/2.95ASWPA4030S
LD5INDUCTOR_SWPA5040S_2.2UH/3.8A2.2uH/3.8ASWPA5040S
LD6INDUCTOR_SWPA5040S_4.7UH/3A4.7uH/3ASWPA5040S
LD7INDUCTOR_SWPA4030S_2.2UH/2.95A2.2uH/2.95ASWPA4030S
LU1BEAD_FB0402_FB120R/1.3AFB120R/1.3AFB0402
LU2BEAD_FB0402_FB120R/1.3AFB120R/1.3AFB0402
LU3BEAD_FB0402_FB120R/1.3AFB120R/1.3AFB0402
LU4BEAD_FB0402_FB120R/1.3AFB120R/1.3AFB0402
M1MARK_MARK_MARKMARKMARK
M2MARK_MARK_MARKMARKMARK
M3MARK_MARK_MARKMARKMARK
M4MARK_MARK_MARKMARKMARK
M5MARK_MARK_MARKMARKMARK
M6MARK_MARK_MARKMARKMARK
QA1NPN_3904_SOT-23_39043904SOT-23
QA2PNP_3906_SOT-23_39063906SOT-23
QD1NPN_3904_SOT-23_39043904SOT-23
QD2NPN_3904_SOT-23_39043904SOT-23
QD3NPN_3904_SOT-23_NC/3904NC/3904SOT-23
QD4NPN_3904_SOT-23_39043904SOT-23
QD5NPN_3904_SOT-23_39043904SOT-23
QD6NPN_3904_SOT-23_39043904SOT-23
QH1NPN_3904_SOT-23_39043904SOT-23
QH2NPN_3904_SOT-23_39043904SOT-23
QH3NPN_3904_SOT-23_39043904SOT-23
QH4NPN_3904_SOT-23_39043904SOT-23
QH5NPN_3904_SOT-23_39043904SOT-23
QH6NPN_3904_SOT-23_39043904SOT-23
QK2NPN_3904_SOT-23_39043904SOT-23
QK3NPN_3904_SOT-23_39043904SOT-23
QK4NPN_3904_SOT-23_NC/3904NC/3904SOT-23
QU1NPN_3904_SOT-23_39043904SOT-23
QU2NPN_3904_SOT-23_39043904SOT-23
QU3NPN_3904_SOT-23_39043904SOT-23
QU4NPN_3904_SOT-23_39043904SOT-23
QW1MOS_P_SOP8_SOP8-1MM27-5_2X6_5_MMOS_NCE4435SOP8-1MM27-5_2X6_5
QW2NPN_3904_SOT-23_39043904SOT-23
RM56YC124_JR_0733R10Rx4RESCA2010-8N
S1SCF_SCF-10X10_SCFSCFSCF-10X10
S2SCF_SCF-10X10_SCFSCFSCF-10X10
S3SCF_SCF-10X10_SCFSCFSCF-10X10
S4SCF_SCF-10X10_SCFSCFSCF-10X10
S5SCF_SCF-10X10_SCFSCFSCF-10X10
S6SCF_SCF-10X10_SCFSCFSCF-10X10
S7SCF_SCF-10X10_SCFSCFSCF-10X10
TF1TF-9P_TF_SOCKET_TF_CARDTF_CARDTF_SOCKET
TP1TESTPOINT_1_TEST1_5MM_3V3_WIFI3V3_WIFITEST1_5MM
TP2TESTPOINT_1_TEST1_5MM_2V5_DDR2V5_DDRTEST1_5MM
TP3TESTPOINT_1_TEST1_5MM_1V2_DDR1V2_DDRTEST1_5MM
TP4TESTPOINT_1_TEST1_5MM_1V8_NOR1V8_NORTEST1_5MM
TP5TESTPOINT_1_TEST1_5MM_5V_T5V_TTEST1_5MM
TP6TESTPOINT_1_TEST1_5MM_VDD_0V9VDD_0V9TEST1_5MM
TP7TESTPOINT_1_TEST1_5MM_VDDC_CPUVDDC_CPUTEST1_5MM
TP8TESTPOINT_1_TEST1_5MM_3V3_STB3V3_STBTEST1_5MM
TP9TESTPOINT_1_TEST1_5MM_3V3_NOR3V3_NORTEST1_5MM
TP10TESTPOINT_1_TEST1_5MM_5V_WIFI5V_WIFITEST1_5MM
TP11TESTPOINT_1_TEST1_5MM_PANEL_VCPANEL_VCCTEST1_5MM
TP12TESTPOINT_1_TEST1_5MM_SDASDATEST1_5MM
TP13TESTPOINT_1_TEST1_5MM_SCLSCLTEST1_5MM
U1GK6780V100GK6780V100BGA879-GK6780V100
UA1IC_ACM8625_28PIN_TSSOP28-0MM65-ACM8625STSSOP28-0MM65-10X6_4-EP6X3
UA2IC_AD22650_TSSOP14-0MM65-5X6_4_AD22650TSSOP14-0MM65-5X6_4
UC1IC_BM8563ESA_SOP8-1MM27-5_2X6_5BM8563ESASOP8-1MM27-5_2X6_5
UD1IC_ST13411A_SOT23-5_STI3411ASTI3411ASOT23-5
UD2IC_ST13411A_SOT23-5_STI3411ASTI3411ASOT23-5
UD3IC_TMI3252T_SOT23-6_TMI3252TTMI3252TSOT23-6
UD4IC_TMI3244T_SOT23-6_TMI3244TTMI3244TSOT23-6
UD5IC_SY8286ARAC_QFN20-0MM45-3X3-ESY8286ARACQFN20-0MM45-3X3-EP1_0X0_8
UD6IC_TMI3252T_SOT23-6_TMI3252TTMI3252TSOT23-6
UD7IC_ST13411A_SOT23-5_STI3411ASTI3411ASOT23-5
UD8IC_TMI6263BH_SOT23-5_NC/TMI6263NC/TMI6263SOT23-5
UE1NET_TRANSFORMER-100M_NET_TFM-10100M_TF1102NET_TFM-100M
UF1IC_EMMC5_0_BGA153-0MM5-11_5X13_BWCTARJ11X32GBGA153-0MM5-11_5X13
UF2IC_FLASH_SPI_SOP8-1MM27-5_3X7_9GD25Q80CSIGRSOP8-1MM27-5_3X7_9
UL1IC_LDO_SOT23-5_SOT23-5_RS3236-2RS3236-25SOT23-5
UL2IC_1117_SOT-223_TO-252-SHAPE_111117-18TO-252-SHAPE
UM1CXDQ3BFAM-CQ-ACXDQ3BFAM-CQ-ABGA96-0MM8-7_5X13_3-DDR4-1
UM2CXDQ3BFAM-CQ-ACXDQ3BFAM-CQ-ABGA96-0MM8-7_5X13_3-DDR4-1
UM3CXDQ3BFAM-CQ-ACXDQ3BFAM-CQ-ABGA96-0MM8-7_5X13_3-DDR4-1
UM4CXDQ3BFAM-CQ-ACXDQ3BFAM-CQ-ABGA96-0MM8-7_5X13_3-DDR4-1
US1IC_TJ232ED_SOIC16_UT3232UT3232SOIC16
UU1IC_PI3EQX7502M_QFN24-0MM5-4X4-EPI3EQX7502MZDEQFN24-0MM5-4X4-EPSQ2_5
UU2WIFI_RTL8188_M-WIFI-BL-R8188FU1NC/WIFI_BL-M8188FU1M-WIFI-BL-R8188FU1-6P
UU3WIFI_8822CU_ZLT_M-WIFI-CDT-6382WIFI_CDW-63822CU_RTL8822CUM-WIFI-CDT-63822CU-01HQ-32P
UU4IC_WAS4735Q_QFN16-0MM4-2_6X1_8_WAS4735QFN16-0MM4-2_6X1_8
UU5IC_GL850S-HHY60_SSOP28-0MM635-1GL850S-HHY60SSOP28-0MM635-10X6_2
UU6IC_AW7227S_QFN10-0MM4-1_3X1_6_AAW7227SQFN10-0MM4-1_3X1_6
UU7IC_TMI6263BH_SOT23-5_TMI6263TMI6263SOT23-5
UU8IC_GL850S-HHY60_SSOP28-0MM635_1NC/GL850S-HHY60SSOP28-0MM635-10X6_2
UU9IC_FE8.1-FSOP16A_SSOP16-0MM635-NC/FE8.1SSOP16-0MM635-5X6_2
UU10IC_TMI6263BH_SOT23-5_TMI6263TMI6263SOT23-5
UU11IC_TMI6263BH_SOT23-5_TMI6263TMI6263SOT23-5
X1CRYSTAL-3225_XTAL4-3225-SMD_24M24MHz/12pF/10PPMXTAL4-3225-SMD
XC1CRYSTAL_XTAL2-3068-SMD_32.768KH32.768KHz/12.5pF/2-PPMXTAL2-3068-SMD
XU1CRYSTAL-3225_XTAL4-3225-SMD_12M12MHz/20pF/10PPMXTAL4-3225-SMD
XU2CRYSTAL-3225_XTAL4-3225-SMD_NC/NC/12MHz/20pF/10PPMXTAL4-3225-SMD
XU3CRYSTAL-3225_XTAL4-3225-SMD_NC/NC/12MHz/20pF/10PPMXTAL4-3225-SMD
:):):):):):):):) :):):) 厉害 感谢分享!!!!!!!!!!!!!! ?两层板都能拉通 :):) 看完楼主的帖子,我的心情竟是久久不能平复,正如老子所云:大音希声,大象希形。我现在终于明白我缺乏的是什么了,正是楼主那种对真理的执着追求和楼主那种对理想的艰苦实践所产生的厚重感。面对楼主的帖子,我震惊得几乎不能动弹了,楼主那种裂纸欲出的大手笔,竟使我忍不住一次次的翻开楼主的帖子,每看一次,赞赏之情就激长数分,我总在想,是否有神灵活在它灵秀的外表下,以至能使人三月不知肉味,使人有余音穿梁,三日不绝的感受。楼主,你写得实在是太好了。我唯一能做的,就只有把这个帖子顶上去这件事了"# h1 g'
非常感谢楼主大神的分享
