mmdqtq 发表于 2024-7-30 16:13
ASM2364规格书USB转pcie(20Gbps)
ASM2364 is ASMedia second generation PCI Express to USB3.2 device controller, featuring PCI Express Gen3 x4 and one USB3.1 Gen2 device port, providing high bandwidth up to 20Gbps between PCI Express Gen3 x4 bus and USB 3.1 SuperSpeedPlus bus. It is used on external USB3.2 Gen2x2 NVM Express SSD application without additional driver, supporting PCI Express M.2 socket and SSD U.2 form factor, compliant with NVM Express revision 1.2.1, USB3.1 Revision 1.0 and PCI Express Base Spec Revision 3.1.ASM2364 is highly integrated with ASMedia USB3.2 Gen2x2 and PCI Express Gen3 self-designed PHYs. Target applications for USB3.2 Gen2x2 NVM Express SSDs for high performance external SSD or on board SSD on PC, laptop, servers, docking stations and embedded system.
ASM2364是 ASMedia 第二代 PCI Express 转 USB3.2 设备控制器,具有 PCI Express Gen3 x4 和一个 USB3.1 Gen2 设备端口,可在 PCI Express Gen3 x4 总线和 USB 3.1 SuperSpeedPlus 总线之间提供高达 20Gbps 的高带宽。它用于外部 USB3.2 Gen2x2 NVM Express SSD 应用,无需额外驱动程序,支持 PCI Express M.2 插槽和 SSD U.2 外形尺寸,符合 NVM Express 修订版 1.2.1、USB3.1 修订版 1.0 和 PCI Express 基本规范修订版 3.1。
查看完整版本: ASM2364规格书USB转pcie(20Gbps)
