老吴 发表于 2024-8-9 08:25:56
紫光展锐UMS9621(UMS9230)10层5G 手机主板PCB原理图 展锐T606 T616参考设计资料
   NamePart TypePCB DecalValue
ANT0800CON-SPRING-CM1406-180CON-SPRING-CM1406-180
ANT0801CON-SPRING-CM1406-180CON-SPRING-CM1406-180
ANT0802CON-SPRING-CM1406-180CON-SPRING-CM1406-180
ANT0803CON-SPRING-CM1406-180CON-SPRING-CM1406-180
ANT0804CON-SPRING-CM1406-180CON-SPRING-CM1406-180
ANT0805CON-SPRING-CM1406-180CON-SPRING-CM1406-180
ANT5201CON-SPRING-CM1406-180CON-SPRING-CM1406-180
ANT5202CON-SPRING-CM1406-180CON-SPRING-CM1406-180
D4100DIODE-SCHOTTKY-WSB5543W-2/TRSOD_FL_2412_H07040V/1A
D5200SENSOR-LIGHT+PROX-LTR-578ALS-034WASENSOR_LITEON_LTR-578ALS-034WA
D5201SENSOR_ACCEL+GYRO_LSM6DSMLGA_14_P050_300X250_H086_LSM6DSM
D5202SENSOR-MAG-AK09918CBGA_4_P040_076X076_H058_AK09918C
D6100TVS_PESDU4571D3SOD_2513_H110_N4.5V/530pF
D6300DIODE-LED-LTST-C19HE1WT-HDIODE-LED-LTST-C19HE1WT-H
FB4100BEAD-470-OHM-100MHZ-0.5A-0603SL0603-S470ohm@100MHz 500mA
FB4106BEAD-1K-OHM-100MHZ-300MA-0402SL04021000ohm@100MHz
FB4111BEAD-470-OHM-100MHZ-0.5A-0603SL0603-S470ohm@100MHz 500mA
FB6600RES-0-0402SR04020
FB6601RES-0-0402SR04020
FB7200RES-0-0402SR04020
FB7201RES-0-0402SR04020(NF)
FD6201FID-C100-M200-K200FID_C100_M200_K200(NF)
FD6202FID-C100-M200-K200FID_C100_M200_K200(NF)
FD6203FID-C100-M200-K200FID_C100_M200_K200(NF)
FD6204FID-C100-M200-K200FID_C100_M200_K200(NF)
J0700CON-RF-SWITCH-MM8030-2610RK0CON-RF-SWITCH-MM8030-2610RK0
J0701CON_RF_MM5829-2700RJ4CON_RF_MM5829-2700
J0702CON-RF-SWITCH-MM8030-2610RK0CON-RF-SWITCH-MM8030-2610RK0
J0703CON_RF_MM5829-2700RJ4CON_RF_MM5829-2700
J0800CON-RF-SWITCH-MM8030-2610RK0CON-RF-SWITCH-MM8030-2610RK0
J0801CON-RF-SWITCH-MM8030-2610RK0CON-RF-SWITCH-MM8030-2610RK0
J4102CON-BTB-F-WP27D-S038VA3_CWCON_BTB_F_WP27D-S038VA3_CWCW
J5100CON-BTB-F-WP27D-S030VA3_CWCON_BTB_F_WP27D-S030VA3_CWCW
J5101CON-BTB-F-WP27D-S030VA3_CWCON_BTB_F_WP27D-S030VA3_CWCW
J5102CON-BTB-F-WP27D-S030VA3_CWCON_BTB_F_WP27D-S030VA3_CWCW
J5103CON_POGO_PPA001-200-000CON_POGO_PPA001-200-0002A,WP=1.5mmm
J5104CON-BTB-F-WP27D-S030VA3_CWCON_BTB_F_WP27D-S030VA3_CWCW
J5105CON_POGO_PPA001-200-000CON_POGO_PPA001-200-0002A,WP=1.5mmm
J5106CON_POGO_PPA001-200-000CON_POGO_PPA001-200-0002A,WP=1.5mmm
J5200CON-BTB-F-WP27D-S010VA3_CWCON_BTB_F_WP27D-S010VA3_CWCW
J6100CON-BTB-F-WP10-S004VA10_UBCON_BTB_F_WP10-S004VA10_UBUB
J6101CON-BTB-F-WP10-S004VA10_UBCON_BTB_F_WP10-S004VA10_UBUB
J6200CON_BTB_F_AXF5D6012_UBCON_BTB_F_AXF5D6012_UBUB
J6201CON_BTB_F_AXT340224_UBCON_BTB_F_AXT340224_UBUB
J6202CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6203CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6204CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6205CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6206CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6207CON_SPRING_ECT_818003481CON_SPRING_ECT_818003481
J6208CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6209SHIELD_SHUNKAI_SK-UMS9230-1SHIELD_SHUNKAI_SK-UMS9230-1TOP RF TR
J6210CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6211CON_SPRING_ECT_818003481CON_SPRING_ECT_818003481
J6212CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6213CON_BTB_F_AXT340224_UBCON_BTB_F_AXT340224_UBUB
J6214SHIELD_SHUNKAI_SK-UMS9230-2SHIELD_SHUNKAI_SK-UMS9230-2TOP BB
J6215CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6216SHIELD_SHUNKAI_SK-UMS9230-3SHIELD_SHUNKAI_SK-UMS9230-3BOT RF PA
J6217CON-SPRING-TP-180-001CON_SPRING_TP-180-001
J6218CON-SPRING-TP-180-001CON_SPRING_TP-180-001
J6219SHIELD_SHUNKAI_SK-UMS9230-4SHIELD_SHUNKAI_SK-UMS9230-4BOT NFC
J6220CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6221CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6222CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6223CON_SPRING_ECT_818003481CON_SPRING_ECT_818003481
J6224CON-SPRING-TP-180-001CON_SPRING_TP-180-001
J6225CON_SPRING_ECT_818010682CON_SPRING_ECT_818010682
J6226CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6227SHIELD_SHUNKAI_SK-UMS9230-5SHIELD_SHUNKAI_SK-UMS9230-5BOT DC/DC
J6228CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6229SHIELD_SHUNKAI_SK-UMS9230-6SHIELD_SHUNKAI_SK-UMS9230-6BOT Charger
J6230CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6231SHIELD_SHUNKAI_SK-UMS9230-7SHIELD_SHUNKAI_SK-UMS9230-7BOT TCXO
J6232CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6233SHIELD_SHUNKAI_SK-UMS9230-8SHIELD_SHUNKAI_SK-UMS9230-8BOT WCN
J6262CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6264CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6265CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6266CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6267CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6269CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6270CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6271CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6272CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6274CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6275CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6276CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6277CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6278CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6279CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6282CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6283CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6284CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6288CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6290CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6291CON-CLIP-SHIELD-AC0200-268CON-CLIP-SHIELD-AC0200-268
J6300CON_BTB_F_AXG106144_CCWCON_BTB_F_AXG106144_CCWCCW
J6301CON-SPRING-TP-180-001CON_SPRING_TP-180-001
J6302CON-SPRING-TP-180-001CON_SPRING_TP-180-001
J6600PAD_2_P220_R120X160PAD_2_P220_R120X160
J7200CON_RF_MM5829-2700RJ4CON_RF_MM5829-2700
J7201CON_RF_MM5829-2700RJ4CON_RF_MM5829-2700
J7202CON-SPRING-TP-180-001CON_SPRING_TP-180-001
J7203CON-RF-SWITCH-MM8030-2610RK0CON-RF-SWITCH-MM8030-2610RK0
J7204CON-SPRING-TP-180-001CON_SPRING_TP-180-001
J7208CON-SPRING-CM1406-180CON-SPRING-CM1406-180
J7209CON-SPRING-CM1406-180CON-SPRING-CM1406-180
J7211CON-SPRING-CM1406-180CON-SPRING-CM1406-180
J7600CON_POGO_PPA001-200-000CON_POGO_PPA001-200-0002A,WP=1.5mmm
J7601CON_POGO_PPA001-200-000CON_POGO_PPA001-200-0002A,WP=1.5mmm
L0200IND-CER-100NH-5%-0201-SDCL0603Q-02B01SL0201100nH
L0300IND-POWER-0.33UH-WPN201610U-MIND_POW_WPN201610U0.33uH(Verifying)
L0301IND-POWER-0.33UH-WPN201610U-MIND_POW_WPN201610U0.33uH(Verifying)
L0302IND-POWER-1.0UH-WPN201610U-MIND_POW_WPN201610U1.0uH(Verifying)
L0303IND-POWER-1.0UH-WPN201610U-MIND_POW_WPN201610U1.0uH(Verifying)
L0304IND-POWER-1.0UH-WPN201610U-MIND_POW_WPN201610U1.0uH(Verifying)
L0305IND-POWER-0.33UH-WPN201610U-MIND_POW_WPN201610U0.33uH(Verifying)
L0306IND-POWER-1.0UH-WPN201610U-MIND_POW_WPN201610U1.0uH(Verifying)
L0307IND-POWER-0.33UH-WPN201610U-MIND_POW_WPN201610U0.33uH(Verifying)
L0308IND-POWER-1.0UH-WPN201610U-MIND_POW_WPN201610U1.0uH(Verifying)
L0309IND-POWER-0.33UH-WPN201610U-MIND_POW_WPN201610U0.33uH(Verifying)
L0310IND_POW_0.47UH_20%_WPN201610UIND_POW_WPN201610U0.47uH(Verifying)(NF)
L0600IND-NF-0201IND-NF-0201NF
L0601IND-CER-7.5NH-5%-0201-SDCL0603Q-02B01SL02017.5nH
L0602IND-NF-0201IND-NF-0201NF
L0603IND-CER-10NH-5%-0201-SDCL0603Q-02B01SL020110nH
L0604IND-NF-0201IND-NF-0201NF
L0605CAP-1PF-0.1-50V-0201-GRM0335C-A01SC02011pF/50V(NF)
L0606CAP-1.5PF-0.1-50V-0201-GRM0335C-A01SC02011.5pF/50V
L0607IND-NF-0201IND-NF-0201NF
L0608IND-NF-0201IND-NF-0201NF
L0609IND-NF-0201IND-NF-0201NF
L0610IND-NF-0201IND-NF-0201NF
L0611CAP-3.9PF-0201SC02013.9pF
L0612IND-NF-0201IND-NF-0201NF
L0613IND-NF-0201IND-NF-0201NF
L0614IND-CER-10NH-5%-0201-SDCL0603Q-02B01SL020110nH(NF)
L0615IND-NF-0201IND-NF-0201NF
L0616IND-CER-8.2NH-5%-0201-SDCL0603Q-02B01SL02018.2nH
L0617CAP-1.1PF-0.1-50V-0201-GRM0335C-A01SC02011.1pF
L0618IND-NF-0201IND-NF-0201NF
L0619IND-NF-0201IND-NF-0201NF
L0620IND-NF-0201IND-NF-0201NF
L0621IND-NF-0201IND-NF-0201NF
L0622IND-NF-0201IND-NF-0201NF
L0623CAP-1.5PF-0.1-50V-0201-GRM0335C-A01SC02011.5pF/50V
L0624IND-NF-0201IND-NF-0201NF
L0625IND-NF-0201IND-NF-0201NF
L0626CAP-0.5PF-0.1-50V-0201-GRM0335C-A01SC02010.5pF/50V
L0632IND-CER-1.8NH-0.3-0201-SDCL0603Q-02B01SL02011.8nH
L0700IND-NF-0201IND-NF-0201NF
L0701IND-CER-12NH-5%-0201-LQP03TN-02SL020112nH
L0702IND-CER-4.7NH-3%-0201-LQP03TN-00SL02014.7nH
L0703IND-CER-5.1NH-0.3-0201-SDCL0603Q-02B01SL02015.1nH(NF)
L0704IND-NF-0201IND-NF-0201NF
L0705IND-CER-4.7NH-3%-0201-LQP03TN-00SL02014.7nH
L0706IND-CER-5.1NH-0.3-0201-SDCL0603Q-02B01SL02015.1nH(NF)
L0707IND-NF-0201IND-NF-0201NF
L0708IND-CER-2.4NH-0.3-0201-SDCL0603Q-02B01SL02012.4nH
L0709IND-CER-2.7NH-0.3-0201-SDCL0603Q-02B01SL02012.7nH(NF)
L0710IND-CER-3.3NH-0.3-0201-SDCL0603Q-02B01SL02013.3nH
L0711IND-CER-8.2NH-5%-0201-SDCL0603Q-02B01SL02018.2nH
L0712CAP-1.2PF-0.1-50V-0201-GRM0335C-A01SC02011.2pF/50V
L0713CAP-1.5PF-0.1-50V-0201-GRM0335C-A01SC02011.5pF/50V
L0714IND-CER-22NH-5%-0201-SDCL0603Q-02B01SL020122nH(NF)
L0715CAP-1.5PF-0.1-50V-0201-GRM0335C-A01SC02011.5pF/50V
L0716CAP-NF-0201CAP-NF-0201NF
L0717CAP-1.5PF-0.1-50V-0201-GRM0335C-A01SC02011.5pF/50V
L0718IND-CER-8.2NH-5%-0201-SDCL0603Q-02B01SL02018.2nH
L0719IND-NF-0201IND-NF-0201NF
L0720IND-NF-0201IND-NF-0201NF
L0721IND-NF-0201IND-NF-0201NF
L0722CAP-2.2PF-0.25-50V-0201-GRM0335C-A01SC02012.2pF/50V
L0723IND-CER-33NH-5%-0201-SDCL0603Q-02B01SL020133nH
L0724IND-CER-15NH-5%-0201-LQP03TN-02SL020115nH(NF)
L0725IND-NF-0201IND-NF-0201NF
L0726IND-CER-10NH-5%-0201-LQP03TN-02SL020110nH
L0727IND-CER-18NH-5%-0201-SDCL0603Q-02B01SL020118nH(NF)
L0728IND-NF-0201IND-NF-0201NF
L0729IND-NF-0201IND-NF-0201NF
L0730IND-NF-0201IND-NF-0201NF
L0731IND-CER-7.5NH-5%-0201-SDCL0603Q-02B01SL02017.5nH
L0732IND-CER-2.7NH-0.3-0201-SDCL0603Q-02B01SL02012.7nH
L0733IND-NF-0201IND-NF-0201NF
L0734IND-CER-2.2NH-0.3-0201-SDCL0603Q-02B01SL02012.2nH
L0735IND-NF-0201IND-NF-0201NF
L0736CAP-0.5PF-0.1-50V-0201-GRM0335C-A01SC02010.5pF/50V(NF)
L0737CAP-0.5PF-0.1-50V-0201-GRM0335C-A01SC02010.5pF/50V(NF)
L0738IND-CER-4.3NH-0.3-0201-SDCL0603Q-02B01SL02014.3nH
L0739CAP-3.9PF-0201SC02013.9pF(NF)
L0740IND-NF-0201IND-NF-0201NF
L0741IND-CER-22NH-5%-0201-SDCL0603Q-02B01SL020122nH
L0742IND-CER-3.9NH-0.3-0201-SDCL0603Q-02B01SL02013.9nH
L0743IND-CER-12NH-5%-0201-SDCL0603Q-02B01SL020112nH
L0744IND-CER-12NH-5%-0201-SDCL0603Q-02B01SL020112nH
L0745IND-CER-2.4NH-0.3-0201-SDCL0603Q-02B01SL02012.4nH
L0746IND-CER-18NH-5%-0201-SDCL0603Q-02B01SL020118nH(NF)
L0747IND-CER-6.2NH-5%-0201-LQP03TN-02SL02016.2nH
L0748IND-CER-3.9NH-0.3-0201-SDCL0603Q-02B01SL02013.9nH
L0749IND-CER-2.7NH-0.3-0201-SDCL0603Q-02B01SL02012.7nH
L0750IND-NF-0201IND-NF-0201NF
L0751IND-NF-0201IND-NF-0201NF
L0752IND-CER-15NH-5%-0201-SDCL0603Q-02B01SL020115nH
L0753IND-CER-3.9NH-0.3-0201-SDCL0603Q-02B01SL02013.9nH
L0754IND-CER-9.1NH-5%-0201-SDCL0603Q-02B01SL02019.1nH
L0756IND-CER-6.2NH-0.3-0201-SDCL0603Q-02B01SL02016.2nH
L0757IND-CER-12NH-5%-0201-SDCL0603Q-02B01SL020112nH
L0760IND-NF-0201IND-NF-0201NF
L0763IND-CER-9.1NH-5%-0201-SDCL0603Q-02B01SL02019.1nH
L0764IND-CER-6.2NH-0.3-0201-SDCL0603Q-02B01SL02016.2nH
L0765IND-NF-0201IND-NF-0201NF
L0766IND-CER-9.1NH-5%-0201-SDCL0603Q-02B01SL02019.1nH
L0767IND-CER-15NH-5%-0201-SDCL0603Q-02B01SL020115nH
L0768IND-CER-1.8NH-0.3-0201-SDCL0603Q-02B01SL02011.8nH
L0769IND-CER-12NH-5%-0201-SDCL0603Q-02B01SL020112nH
L0770IND-NF-0201IND-NF-0201NF
L0771IND-NF-0201IND-NF-0201NF
L0772IND-NF-0201IND-NF-0201NF
L0800IND-CER-4.7NH-3%-0201-LQP03TN-00SL02014.7nH
L0801IND-CER-5.1NH-0.3-0201-SDCL0603Q-02B01SL02015.1nH(NF)
L0802IND-NF-0201IND-NF-0201NF
L0803IND-CER-15NH-5%-0201-SDCL0603Q-02B01SL020115nH(NF)
L0804IND-NF-0201IND-NF-0201NF
L0805IND-CER-3.9NH-0.3-0201-SDCL0603Q-02B01SL02013.9nH
L0806CAP-0.5PF-0.1-50V-0201-GRM0335C-A01SC02010.5pF/50V
L0807CAP-1.5PF-0.1-50V-0201-GRM0335C-A01SC02011.5pF/50V
L0809IND-NF-0201IND-NF-0201NF
L0810CAP-0.5PF-0.1-50V-0201-GRM0335C-A01SC02010.5pF/50V(NF)
L0811CAP-0.5PF-0.1-50V-0201-GRM0335C-A01SC02010.5pF/50V
L0812IND-NF-0201IND-NF-0201NF
L0813IND-CER-12NH-5%-0201-SDCL0603Q-02B01SL020112nH
L0814IND-CER-18NH-5%-0201-SDCL0603Q-02B01SL020118nH
L0815IND-NF-0201IND-NF-0201NF
L0816CAP-2.2PF-0.25-50V-0201-GRM0335C-A01SC02012.2pF/50V
L0817IND-CER-4.3NH-0.3-0201-SDCL0603Q-02B01SL02014.3nH
L0818IND-CER-4.3NH-0.3-0201-SDCL0603Q-02B01SL02014.3nH
L0819CAP-0.5PF-0.1-50V-0201-GRM0335C-A01SC02010.5pF/50V(NF)
L0820IND-NF-0201IND-NF-0201NF
L0821IND-CER-4.7NH-0.3-0201-SDCL0603Q-02B01SL02014.7nH
L0822CAP-2.7PF-0201SC02012.7pF(NF)
L0823IND-NF-0201IND-NF-0201NF
L0824CAP-2.2PF-0.25-50V-0201-GRM0335C-A01SC02012.2pF/50V
L0825IND-CER-7.5NH-5%-0201-SDCL0603Q-02B01SL02017.5nH
L0826IND-NF-0201IND-NF-0201NF
L0827CAP-1.2PF-0.1-50V-0201-GRM0335C-A01SC02011.2pF/50V
L0828IND-CER-18NH-5%-0201-LQP03TN-02SL020118nH
L0829IND-CER-12NH-5%-0201-LQP03TN-02SL020112nH
L0830CAP-2.7PF-0201SC02012.7pF(NF)
L0831CAP-NF-0201CAP-NF-0201NF
L0832IND-NF-0201IND-NF-0201NF
L0833IND-CER-4.7NH-0.3-0201-SDCL0603Q-02B01SL02014.7nH(NF)
L0834IND-CER-12NH-5%-0201-SDCL0603Q-02B01SL020112nH
L0835IND-CER-18NH-5%-0201-SDCL0603Q-02B01SL020118nH
L0837IND-CER-7.5NH-5%-0201-SDCL0603Q-02B01SL02017.5nH
L0838IND-NF-0201IND-NF-0201NF
L0841IND-CER-5.1NH-0.3-0201-SDCL0603Q-02B01SL02015.1nH(NF)
L3100IND-POWER-1.0UH-DFE252012F-P2IND_C_2520_H120_DFE2520121.0uH
L3101IND_WIRE_1.2MH_20%_LQH3NMN-03IND_WIRE_LQH3NMN1.2mH
L4100IND-POWER-10UH-SWPA3012S100MTIND-POWER-SWPA301210uH
L4101IND-POWER-4.7UH-WPN2520H-MIND_POWER_WPN2520104.7uH
L5100IND-POWER-1.0UH-WPN201610H-MIND_POW_WPN201610H1.0uH
L5200IND-CER-100NH-5%-0201-SDCL0603Q-02B01SL0201100nH
L6100IND-POWER-1.0UH-DFE252012F-P2IND_C_2520_H120_DFE2520121.0uH
L6101IND_POW_CER_0.33UH_20%_CIGT252010LM-NIND_POW_CIGT2520100.33uH
L7200IND-CER-4.3NH-0.3-0201-SDCL0603Q-02B01SL02014.3nH
L7201IND-CER-4.7NH-3%-0201-LQP03TN-00SL02014.7nH
L7202IND-CER-1.0NH-0.3-0201-SDCL0603Q-02B01SL02011.0nH
L7203IND-NF-0201IND-NF-0201NF
L7204IND-CER-2.0NH-0.2-0201-LQP03TN-02SL02012.0nH
L7205RES_0_5%_0201_RC-LSR02010
L7206RES_0_5%_0201_RC-LSR02010
L7207IND-CER-9.1NH-5%-0201-SDCL0603Q-02B01SL02019.1nH
L7209IND-CER-27NH-5%-0201-LQP03TN-02SL020127nH
L7210IND-CER-3.9NH-0.3-0201-SDCL0603Q-02B01SL02013.9nH
L7214RES_0_5%_0201_RC-LSR02010
L7217RES_0_5%_0201_RC-LSR02010
L7229IND-CER-3.3NH-0.2-0201-LQP03TN-02SL02013.3nH
L7600IND-WIRE-160NH-5%-0402-WL1005FS-M01SL0402160nH
L7601IND-WIRE-160NH-5%-0402-WL1005FS-M01SL0402160nH
MIC3101MIC_MEMS_BP-SPV0842LR5H-1MIC_MEMS_BP_SPV0842LR5H-1(Verifying)
MLV3100MLV-AVLC5S02050SMLV0402
MLV6412MLV-AVLC5S02050SMLV0402(NF)
REC3100REC_QR090820BL01REC_QR090820BL0130ohm,50mW(NF)
U0200PMIC_UMP510G_BGA_247_P040BGA_247_P040_770X770_H086_UMP510G
U0500MEM_EMMC51_EMMC32G-TA29BGA_153_P050_1150X1300_H080_L02732GB,HS400(Verifying)
U0502MEM_LPDDR4X_MT53E768M32D2NP-046WT-ABGA_200_P080X065_1000X1450_H100_L03024Gb(Verifying)
U0600RF-TRANSCEIVER-SR3595DBGAS_123_P035_450X450_H085_SR3595D
U0601RF_PAM_RPM6743-31PQFN_42_P044_680X400_T205X240X2_H090LTE Multi-Band
U0700RF_SW_RSW9106QFN_14_P040_200X200_T098_H060
U0701RF-SAW-SAFFB1G90KA0F0AFILTER_5_110X090_H0501900MHz
U0702RF-SAW-SAFFB2G01AA0F0AFILTER_5_110X090_H0502018MHz
U0703RF-SAW-SAFFB2G59AA1F0AFILTER_5_110X090_H0502593MHz(Verifying)
U0704RF-SAW-DUPLEX-SAYEY718MBC0F0AFILTER_8_180X140_H060TxRx:718/773MHz(NF)
U0705RF-FEM-RTM7916-51PQFN_38_P048_550X530_T390X370_H080
U0706RF_SAW_SAFRC2G59MC0F0AFILTER_5_140X110_H0602593MHz(Verifying)
U0707RF-SAW-SAFFB2G35AA0F0ARF-SAW-1.1X0.92350MHz
U0708RF-SAW-SAFFB2G35MA0F0AFILTER_5_110X090_H0502350MHz(Verifying)
U0709RF-SAW-DUPLEX-SAYEY2G53BA0F0AFILTER_8_180X140_H060TxRx:2535/2655MHz
U0710RF_SAW_QUADPLEX_SAHQV1G74BA0H0AFILTER_6_250X200_H070_MURATAB1/B3
U0711RF-SAW-DUPLEX-SAYEY1G88BA0B0AFILTER_8_180X140_H060TxRx:1880/1960MHz
U0712RF-SAW-DUPLEX-SAYEY897MBG0F0AFILTER_8_180X140_H060TxRx:897.5/942.5MHz
U0714RF-SAW-DUPLEX-SAYEY831MBA0B0AFILTER_8_180X140_H060TxRx:831.5/876.5MHz
U0715RF-SAW-DUPLEX-SAYEY806MBA0F0AFILTER_8_180X140_H060TxRx:847/806MHz
U0716RF-SW-RDASW293CPSON_6_P040_110X070_H055700-6000MHz(Verifying)
U0717RF-CPL-CP160825Q0822T/LFCPL_CAF_6_P050_160X080_H070698-2690MHz
U0718RF-SAW-DUPLEX-SAYEY733MBC0F0AFILTER_8_180X140_H060TxRx:733/788MHz(NF)
U0719RF-BPF-RFBPF16081G9DS8T60FILTER_4_160X080_H070_WALSIN1805-2025MHz
U0800RF-SW-RSW5103QFN_12_P050_200X200_T076_H060100-6000MHz
U0801RF-SAW-SAFFB2G01AA0F0AFILTER_5_110X090_H0502018MHz
U0802RF-SAW-SAWFD1G84AA0F0ARF-SAW-1.5X1.1-10PIN1842.5/2140MHz
U0803RF-SAW-SAFFB942MAN0F0ARF-SAW-1.1X0.9942.5MHz
U0804RF-SAW-SAFFB2G35AA0F0ARF-SAW-1.1X0.92350MHz
U0805RF-SAW-SAFFB1G90KA0F0AFILTER_5_110X090_H0501900MHz
U0806RF_SAW_SAFFB2G65AC0F0AFILTER_5_110X090_H0502655MHz(Verifying)
U0807RF-SAW-SAFFB806MAA0F0AFILTER_5_110X090_H050806MHz
U0808RF-SAW-SAFFB2G59AA1F0AFILTER_5_110X090_H0502593MHz(Verifying)
U0810RF-SAW-SAFFB876MAA0F0AFILTER_5_110X090_H050876.5MHz
U0811RF_SW_RST1245PQFN_10_P040_150X110_H057SP4T
U0812RF_SW_RSW9108QFN_14_P040_200X200_T098_H0600.7~3.8GHz
U0817RF-SAW-SAFFB1G96AB0F0ARF-SAW-1.1X0.91960MHz
U2100BB_UMS9230_BGAS_704_P040_RDBGAS_704_P040_1200X1080_H083_UMS9230
U2400RF_SW_RST1202QFN_12_P050_200X200_T095_H060
U2401RF_SW_RST1202QFN_12_P050_200X200_T095_H060
U3103AUDIO_AMP_UCP1301_BGA_23_P050BGA_23_P050_208X308_H057_UCP1301
U4100POWER-DC2DC-WD3139F-6/TRSOT_6_P095_280_H090-0.3-40V/1.2A
U4101POWER_DC2DC_NT50358ABGA_15_P040_136X226_H068_B0264~6V/200mA,-4~-6V/160mA
U5100SENSOR_TOF_VL53L0CBV0DH/1SENSOR_TOF_VL53L0CBV0DH(Verifying)(NF)
U5101POWER_LDO_NCP137AFCTADJT2GBGA_6_P040_080X120_H033_B0270.5-3V/700mA(Verifying)
U5102POWER-LDO-SGM2036-2.8YUDH4G/TRSON_4_P065_100X100_T048_H0602.8V/300mA
U5103POWER-LDO-SGM2036-2.8YUDH4G/TRSON_4_P065_100X100_T048_H0602.8V/300mA
U5104POWER_LDO_NCP137AFCTADJT2GBGA_6_P040_080X120_H033_B0270.5-3V/700mA(Verifying)
U5105SENSOR_XYZ+ALS_TCS34303SENSOR_XYZ_ALS_TCS34303(Verifying)
U5106POWER-LDO-SGM2036-2.8YUDH4G/TRSON_4_P065_100X100_T048_H0602.8V/300mA
U5107POWER-DC2DC-OCP8137WPADBGA_12_P040_128X166_H063_B0256V/2A
U5108POWER-LDO-SGM2036-2.8YUDH4G/TRSON_4_P065_100X100_T048_H0602.8V/300mA
U5200SENSOR_PROX_SX9338IULTRTSON_10_P040_210X180_H060_L022X075Capative,For SAR
U6100POWER_CHARGER_BQ25890RTWTQFN_24_P050_400X400_T270_H080_RTWFast Charger,5A,OTG2.4A
U6101POWER_LOADSW_NCP3902FCCTBGBGA_20_P040_226X166_H060_B0273A/5A(Verifying)
U6105POWER_CHARGER_BQ25910YFFTBGA_36_P040_244X241_H063_L023Fast Charger,Switch Mode,6A
U6400SKT-SIM-NANO-TF-ST19S020VCASKT_SIM_NANO_TF_ST19S020VCA
U7201RF-SAW-TRIPLEX-TPX205950MT-7104A2TPX_CAF_8_P065_200X125_H100_L1.5G/2.4G/5G(Verifying)
U7202RF-SAW-SAFFB1G56KB0F0AFILTER_5_110X090_H0501561.1/1575.42/1602MHz
U7203RF_LNA_RDALN1609PSON_6_P040_110X090_H050_RDAGPS/GNSS
U7204RF-SAW-SAFEA2G45MC0F0AFILTER_5_135X105_H0502441MHz
U7205WCN_UMW2631_BGAS_117_P035BGAS_117_P035_450X420_H100_UMW2631
U7208RF_FEM_KCT8553CQFN_16_P040_230X230_T140_H060_KCT5G WLAN,5.15~5.85GHz(Verifying)
U7600NFC_S3NSN4VXBGA_57_P035_234X402_H059_L020
X0200XTAL-CRYSTAL-32.768K-Q-SC32S0322070AAAFXTAL_CC_320X150_H08532.768KHz(NF)
X7200XTAL-TCXO-26MHZ-1XXB26000MABOSC_CC_250X200_H090_KDS26MHz(NF)
X7600XTAL-CRYSTAL-27M-E1AB27.1200F10E11XTAL_CC_200X160_H050_L085X07527.12MHz(NF)
Y0200XTAL-CRY+THM-26M-OZ26000012XTAL_CC_250X200_H10026MHz/9pF
老吴 发表于 2024-8-9 08:28:13
PCB 原理图一起打包。回复可见下载
**** Hidden Message *****
red_chen 发表于 2024-8-9 08:43:14
感谢老吴分享。10层还可以,看样子应该是官方的demo板
kingweison 发表于 2024-8-9 09:09:08
shuszhao 发表于 2024-8-9 09:34:38
这个不错,感谢分享
lf2k2022 发表于 2024-8-9 10:41:22
datdx 发表于 2024-8-9 10:53:09
rome2008ok 发表于 2024-8-9 11:32:19
学习学习
yfchen1003 发表于 2024-8-9 13:55:51
很帅!!
神话2013 发表于 2024-8-9 16:08:20
谢谢分享
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: 紫光展锐UMS9621(UMS9230)10层5G 手机主板PCB原理图 展锐T606 T616参考设计资料
