台湾高夫设计的新塘MA35D16F987C(MA35D16F787C) 方案PCB原理图 ORCAD层次设计
PCB原理图一起打包。回复可见下载
**** Hidden Message *****
NamePCB DecalPart TypeValue
CON2POWRJACK\3PPOWER_JACKDC-PLUG
CON3HEADER12X2_2.0MMCON24AHEADER 12x2 (2.0mm, male)
CON4HEADER20X2/2.54MM_MHEADER_20X2HEADER 20x2 (2.54mm, male)
CON5B8502A-13SB-HPAB8502A-13SB-HPA_(T-FLASH_CARD)B8502A-13SB-HPA (T-Flash Card)
CON6RJ45\8P\JA\LEDRJ45_SHLD_2RJ-45 8P8C_LED R/A
CON7RJ45\8P\JA\LEDRJ45_SHLD_2RJ-45 8P8C_LED R/A
CON8PHONE-PJK-634M_ASSJ-435107RS_92SJ3080-000111F SMD
CON9MICRO_USB_AB_LSUSB_TYPE_B_0micro USB 5pin
CON10MICRO_USB_AB_LSUSB_TYPE_B_0micro USB 5pin
CON11USB4PUSB_TYPE_A_CONNECTORUSB_TYPE-A_RECAP.
CON12HEADER10X2\BOXHEADER_2X20_0SWJ (JTAG/SWD)虏à
D1SOD-523ZENAR_0RB521S-30
D2DO-214ACZENAR_0SS24A
D3SOD-523ZENAR_0RB521S-30
D4SOD-523ZENAR_0RB521S-30
D5DO-214ACZENAR_0SS24A
D6DO-214ACZENAR_0SS24A
D7DFN1006DIODE_TAZ_BI-DIRES014005F4
H1H-3.4X6TEST_POINTH-3.4X6(NC)
H2H-3.4X6TEST_POINTH-3.4X6(NC)
H3H-3.4X6TEST_POINTH-3.4X6(NC)
H4H-3.4X6TEST_POINTH-3.4X6(NC)
H5H-3.4X6TEST_POINTH-3.4X6(NC)
H6H-3.4X6TEST_POINTH-3.4X6(NC)
H7H-3.4X6TEST_POINTH-3.4X6(NC)
H8H-3.4X6TEST_POINTH-3.4X6(NC)
J1HEADER2X1HEADER_2HEADER 2x1 (2.54mm, male)
J2HEADER2X1HEADER_2HEADER 2x1 (2.54mm, male)
J3HEADER2X1HEADER_2HEADER 2x1 (2.54mm, male)
J5HEADER5X1HEADER_5HEADER 5x1 (2.54mm, male)
J6HEADER2X1HEADER_2HEADER 2x1 (2.54mm, male)
J7HEADER2X1HEADER_2HEADER 2x1 (2.54mm, male)
J8HEADER2X1HEADER_2HEADER 2x1 (2.54mm, male)
J9HEADER5X1HEADER_5HEADER 5x1 (2.54mm, male)(NC)
J10HEADER2X1HEADER_2HEADER 2x1 (2.54mm, male)
L1L0603INDUCTORFB
L2L0603INDUCTORFB
L3L0603INDUCTORFB
L4SMTDR43INDUCTOR_IRON1uH
L6L0603INDUCTORFB
L7SMTDR43INDUCTOR_IRONNR3015-4R7M-4.7uH
L8SMTDR43INDUCTOR_IRONNR3015-4R7M-4.7uH
L9L0603INDUCTORFB
L10L0603INDUCTORFB
L11SMTDR43INDUCTOR_IRONNR3015-4R7M-4.7uH
L12SMTDR43INDUCTOR_IRONNR3015-4R7M-4.7uH
L13L0603INDUCTORFB
L14L0603INDUCTORFB
L15L0603INDUCTORFB
L16L0603INDUCTORFB
L17L0603INDUCTORFB
L18L0603INDUCTORFB
L19L0603INDUCTORFB
L20L0603INDUCTORFB(NC)
L21L0603INDUCTORFB
L22L0603INDUCTORFB
L23L0603INDUCTORFB
L24L0603INDUCTOR_2FB
L26L0603INDUCTORFB
L27L0603INDUCTORFB
L28SMTDR43INDUCTOR_IRON2.2uH/1A(NC)
L29L0603INDUCTORFB
L30L0603INDUCTORFB
L31L0603INDUCTORFB
L32L0603INDUCTORFB
L33L0603INDUCTORFB
L34L0603INDUCTORFB
L35L0603INDUCTORFB
L36603INDUCTOR_2FB
L37603INDUCTOR_2FB
L38L0603INDUCTORFB
L39L0603INDUCTORFB
L40L0603INDUCTORFB
LED1LED0805LED0805 LED G (厚) 炊
LED2LED0805LED0805 LED R () 蔼獹
LED3LED_0805LED0805 LED Y (独)蔼獹
LEDG1LED0805LED_00805 LED G (厚) 炊
LEDR1LED0805LED_00805 LED R () 蔼獹
LEDY1LED0805LED_00805 LED Y (独)蔼獹
M1DIP_LF-M6027FMICROPHONE_2MIC
NU1SIP-8PPOWER_CONNECT_0HEADER 2.54 8X1 female
NU2SIP-6PADC_CONNECT_0HEADER 2.54 6X1 female
NU3SIP-8PPWM0_CONNECT_0HEADER 2.54 8X1 female
NU4SIP-10PPWM1_CONNECT_1HEADER 2.54 10X1 female
PAD11PAD_1.25X1.25MM1PAD_1E_CKO(NC)
Q1SOT-23NPN2N3904 (NPN)
Q4SOT-23MOSFET_N_4SI2302 (NMOS)
Q5SOT-23MOSFET_N_4SI2302 (NMOS)
Q6SOT-23MOSFET_P_4SI2301 (PMOS)
Q7SOT-23BECNPN2N3904 (NPN)
Q8SOT23PNP_1S8550 (PNP)
Q9SOT-23MOSFET_N_4SI2302
Q10SOT-23MOSFET_P_4SI2301
Q11SOT-23MOSFET_N_4SI2302
Q12SOT-23EBCNPN2N3904
RP18P4RAR-PACK8_010K-8P4R
SW1STS-B5SW-SSMD 6X6X6H 厚
SW2STS-B5SW-SSMD 6X6X5H
SW3STS-B5SW-SSMD 6X6X5H 堵
SW4STS-B5SW-SSMD 6X6X5H 堵
SW5STS-B5SW-SSMD 6X6X5H 堵
SW6STS-B5SW-SSMD 6X6X5H 堵
SW7SWDIP-8/SMDSW_DIP-7_1SW DIP 8 (SMD)
T11PAD_1.25X1.25MM1PAD_1N_PRE(NC)
T21PAD_1.25X1.25MM1PAD_1N_RB2(NC)
T31PAD_1.25X1.25MM1PAD_1N_CE2(NC)
T41PAD_1.25X1.25MM1PAD_1N_PSL(NC)
T51PAD1.25X1.25MM1PAD_1VCOM_3V3(NC)
U1LQFP216MA35D1_LQFP216MA35D16F9(7)87C
U2TDFN2X2-8APW8827AQBIAPW8827AQBI
U3TSOT-25ZT7103S_0FP6381AS5CTR
U4TSOT-25ZT7103S_0FP6381AS5CTR
U5TSOT-25ZT7103S_0FP6381AS5CTR
U6TSOT-25ZT7103S_0FP6381AS5CTR
U7SOIC8TCAN332GD_0TLE9351VSJ
U8SOP16/150ADM232_0SN75C3232EDR
U9SO-8ADM232_1SN65HVD11DR
U10SOIC16_300W25Q128BV_4W25Q128BV(NC)
U11SOIC8_208_EPW55X10_3W25N04KWZEIR(SPI NAND)
U12TSOP48-0.5MMNAND_4-8G_4W29N08GVSIAA(NAND Flash)
U14QFN40_0_4RTL8211F(D)I-CGRTL8211F(D)I-CG
U15GST5009BMGST5009BMGST5009BM
U1632-PIN_QFNRTL8201FI-VCRTL8201FI-VC
U17ST6200TPE-68515_0TS8121CLF
U18QFN32L_5X5MM\0.5MM_PITCHNAU8501_0NAU88C22YG
U19QFN33_5X5NUC101_QFN_0NUC123ZD4AN0
U20TSOP-6PJ9293_0NSP4201MR6T1G
U21MSOP-8NCT3520W-H15_0AP2511M8-13
U22MSOP-8NCT3520W-H15_1AP2511M8-13
U23TDFN2X2-8APL3203A_1APL3211AQBI
U24SOT-223-1TO-247_REGULATOR_10AMS1117_3.3v
U25SOT-23-5APL5325BIAPL5325ABI
U39TSOP-6PJ9293_0NSP4201MR6T1G
U40TSOP-6PJ9293_0NSP4201MR6T1G
X1XTAL_2P/1.5MMMA306/SM_2TXC-9H T9 SMD 32.768KHz 30ppm
X2TXC7M-3.2X2.5MMCRYSTAL_SMD_2X3225B 24MHz SMD
X3TXC7M-3.2X2.5MMCRYSTAL_SMD_2X3225B 25MHz SMD
X4TXC7M-3.2X2.5MMCRYSTAL_SMD_2X3225B 25MHz SMD
X5TXC7M-3.2X2.5MMCRYSTAL_SMD_2X3225B 12MHz SMD
学习学习 学习学习:):) 学习学习
学习学习 台湾高夫设计可以呀 学习一下 谢谢 学习学习 谢谢老吴分享
