armclub 发表于 2024-8-30 16:09
S32K1XX FS32K148UJT0VLUT 开发板PCB文件 UJA1131HW+TJA1101+SGTL5000
PCB文件。回复可见
BH1MOUNT_HOLE_MH175-125P_IC_0MM_2MountingHoleMH175-125P
BH2MOUNT_HOLE_MH175-125P_IC_0MM_2MountingHoleMH175-125P
BH3MOUNT_HOLE_MH175-125P_IC_0MM_2MountingHoleMH175-125P
BH4MOUNT_HOLE_MH175-125P_IC_0MM_2MountingHoleMH175-125P
D1DIODE_SCHTKY_SOD-128_IC_1.1MM_PMEG3050EPSOD-128
D2DIODE_SCHTKY_SOD-128_IC_1.1MM_4PMEG6045ETPSOD-128
D3DIODE_SCHTKY_SOD-128_IC_1.1MM_4PMEG6045ETPSOD-128
D4LED_LED_0603_IC_0.67MM_370-7670LYL29K-H1K2-26-ZLED_0603
D7TRANZORB_BIDIR_AA_0805_IC_1.02MVC080505C150RP805
D8TRANZORB_BIDIR_AA_0805_IC_1.02MVC080505C150RP805
D9LED_TRI_COLOR_LED6_5X6MM_IC_2.6LEDRED/GRN/BLLED6_5X6MM
D10LED_LED_0603_11MIL_IC_0.28MM_37LED_ORANGELED_0603_11MIL
D11LED_LED_0603_IC_1.1MM_370-76709REDLED_0603
D12LED_LED_0603_IC_1.1MM_370-76709REDLED_0603
D13LED_LED_0603_11MIL_IC_0.28MM_37LED_ORANGELED_0603_11MIL
D14LED_LED_0603_11MIL_IC_0.28MM_37LED_ORANGELED_0603_11MIL
D15LED_LED_0603_IC_0.85MM_370-7654GREENLED_0603
D16LED_LED_0603_IC_1.1MM_370-75144LED_YELLOWLED_0603
D17ZDIODE_SOD323_IC_1.1MM_480-7859BZX384-C30SOD323
D18ZDIODE_SOD323_IC_1.1MM_480-7859BZX384-C30SOD323
D19ZDIODE_SOD323_IC_1.1MM_480-7859BZX384-C30SOD323
D22ZDIODE_SOD123_048X028_IC_1.45MMBZT52C3V3SOD123_048X028
D23ZDIODE_SOD123_048X028_IC_1.45MMBZT52C3V3SOD123_048X028
D24ZDIODE_SOD323_IC_1.1MM_480-7859BZX384-C30SOD323
D25DIODE_SCHTKY_SOD-128_IC_1.1MM_PMEG3050EPSOD-128
D26DIODE_SCHTKY_SOD-128_IC_1.1MM_PMEG3050EPSOD-128
D27LED_LED_0603_IC_1.1MM_370-76709REDLED_0603
FL1FILTER_4P_IND4_4P5X3P2_SMT_DISC200uH@ 100KHzIND4_4P5X3P2_SMT
FL2FILTER_4P_IND4_4P7X3P4_SMT_DISCACT45B-110-2P-TL003IND4_4P7X3P4_SMT
FL3FILTER_4P_IND4_4P7X3P4_SMT_DISCACT45B-110-2P-TL003IND4_4P7X3P4_SMT
FL4FILTER_4P_IND4_4P7X3P4_SMT_DISCACT45B-110-2P-TL003IND4_4P7X3P4_SMT
J2CONN_HDR_3X1_HDR103_IO_8.72MM_2HDRTH 1X3HDR103
J3CONN_HDR_6X2_HDR206_IO_8.58MM_2HDR2X6 THHDR206
J5CONN_HDR_4X1_CON_HDR_4M_100_TH_HDR1X4 RACON_HDR_4M_100_TH_RA
J8CONN_HDR_3X1_HDR103_IO_8.72MM_2HDRTH 1X3HDR103
J9CONN_HDR_3X1_HDR103_IO_8.72MM_2HDRTH 1X3HDR103
J11CONN_HDR_2X1_HDR102_IO_9.6MM_2HDR_1X2HDR102
J12CONN_HDR_10X2_HDR210_FTSH_SM_IOHDR_2X10HDR210_FTSH_SM
J14PHONOJACK_STEREO-15_4_4_PIN_TH_AUD44_4_PIN_TH
J15PHONOJACK_STEREO-15_4_4_PIN_TH_AUD44_4_PIN_TH
J16PHONOJACK_STEREO-15_4_4_PIN_TH_AUD44_4_PIN_TH
J17HDR-3X10_A_CON_3X10_100_TH_IO_1ESQ-110-33-T-TCON_3X10_100_TH
J18HDR-3X8_A_CON_3X8_100_TH_IO_16.ESQ-108-33-T-TCON_3X8_100_TH
J19HDR-3X10_A_CON_3X10_100_TH_IO_1ESQ-110-33-T-TCON_3X10_100_TH
J20HDR-3X8_A_CON_3X8_100_TH_IO_16.ESQ-108-33-T-TCON_3X8_100_TH
J21HDR-3X8_A_CON_3X8_100_TH_IO_16.ESQ-108-33-T-TCON_3X8_100_TH
J22CONN_HDR_10X2_HDR210_ESQ_SKT_IOCON2X10HDR210_ESQ_SKT
J25RCPT_1X12_CON_1X12_SKT_2P54_TH_SKT_1x12CON_1X12_SKT_2P54_TH
J26CONN_HDR_4X1_HDR_1X4_SSW_TH_RA_CON_1X4HDR_1X4_SSW_TH_RA
J27RCPT_1X12_CON_1X12_SKT_2P54_TH_SKT_1x12CON_1X12_SKT_2P54_TH
J28CONN_PLUG_1X5_M_CON1X5_2P54_RA_CON1X5CON1X5_2P54_RA_TH
J29CONN_HDR_3X1_HDR103_IO_8.72MM_2HDRTH 1X3HDR103
J31CON23_PLUG23_2MM_RA_TH_IO_32.4PLUG23 RAPLUG23_2MM_RA_TH
J32CONN_HDR_2X1_HDR1X2_5P48X2P69_IHDR1X2HDR1X2_5P48X2P69
J33CONN_HDR_2X1_HDR1X2_5P48X2P69_IHDR1X2HDR1X2_5P48X2P69
J34CONN_HDR_3X1_HDR103_IO_8.72MM_2HDRTH 1X3HDR103
JP1CONN_HDR_1X1_HDR101_045T_IO_8.5HDR1X1HDR101_045T
L1BEAD_IND_1608_DISCRETE_0.95MM_1330OHMIND_1608
L2INDUCTOR_IND_5P2X5P2_DISCRETE_24.7uHIND_5P2X5P2
L3INDUCTOR_IND2_6P5X6P2MM_SM_DISC22uHIND2_6P5X6P2MM_SM
L4INDUCTOR_FERRITE_IND_0402_DISCR30OHMIND_0402
L5INDUCTOR_FERRITE_IND_0402_DISCR30OHMIND_0402
L6BEAD_IND_0603_DISCRETE_0.95MM_1120OHMIND_0603
L7BEAD_IND_0603_DISCRETE_0.95MM_1120OHMIND_0603
L8BEAD_IND_0603_DISCRETE_0.95MM_1120OHMIND_0603
L9BEAD_IND_0603_DISCRETE_0.95MM_1120OHMIND_0603
L12INDUCTOR_FERRITE_IND_0402_DISCR30OHMIND_0402
L13INDUCTOR_FERRITE_IND_0402_DISCR30OHMIND_0402
L14BEAD_IND_0603_DISCRETE_0.95MM_1120OHMIND_0603
L15INDUCTOR_FERRITE_IND_0402_DISCR30OHMIND_0402
P1MIC_POM_MIC_WM-63PR_IC_2.4MM_51EM6022PMIC_WM-63PR
Q1NPN_SC_75_IC_0.9MM_480-75477_MMMBT3904TT1GSC_75
Q2NPN_SC_75_IC_0.9MM_480-75477_MMMBT3904TT1GSC_75
Q3NPN_SC_75_IC_0.9MM_480-75477_MMMBT3904TT1GSC_75
Q4NPN_SC_75_IC_0.9MM_480-75477_MMMBT3904TT1GSC_75
Q5NPN_SC_75_IC_0.9MM_480-75477_MMMBT3904TT1GSC_75
Q6NPN_SC_75_IC_0.9MM_480-75477_MMMBT3904TT1GSC_75
Q7NPN_SC_75_IC_0.9MM_480-75477_MMMBT3904TT1GSC_75
Q8NPN_SC_75_IC_0.9MM_480-75477_MMMBT3904TT1GSC_75
Q9NPN_SC_75_IC_0.9MM_480-75477_MMMBT3904TT1GSC_75
Q12NMOS_2N7002BKW_3P_SC70_3_IC_1.12N7002BKWSC70_3
Q13NMOS_2N7002BKW_3P_SC70_3_IC_1.12N7002BKWSC70_3
QZ1CRYSTAL_XTAL2-3P2X1P5-SM_IC_0.932.768KHZXTAL2-3P2X1P5-SM
SW1EDGE_MOUNT_PB_SW_2_SW4_SPST_4P8EVQ-P2402WSW4_SPST_4P8X3P6_2P5
SW2ELECTRODE_ELECTRODE_SQ_15MM_IC_ElectrodeELECTRODE_SQ_15MM
SW3ELECTRODE_ELECTRODE_SQ_15MM_IC_ElectrodeELECTRODE_SQ_15MM
SW4EDGE_MOUNT_PB_SW_2_SW4_SPST_4P8EVQ-P2402WSW4_SPST_4P8X3P6_2P5
SW5EDGE_MOUNT_PB_SW_2_SW4_SPST_4P8EVQ-P2402WSW4_SPST_4P8X3P6_2P5
SW6EDGE_MOUNT_PB_SW_2_SW4_SPST_4P8EVQ-P2402WSW4_SPST_4P8X3P6_2P5
TPH1CONN_HDR_1X1_HDR101_IO_8.59MM_2HDR_1X1HDR101
TPH2CONN_HDR_1X1_HDR101_IO_8.59MM_2HDR_1X1HDR101
U1AP1509_ADJ_SO8_1P27_4X5_IC_1.75AP1509-SG-13SO8_1P27_4X5
U2UJA1132HW_FD_HTQFP_48P_EP_HTQFPUJA1131HW/FD/5V/0HTQFP48_0P65_10X10_EP_5MM
U3NTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HXQFN8_1P45X1P25MM
U4NTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HXQFN8_1P45X1P25MM
U5NTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HXQFN8_1P45X1P25MM
U6NTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HXQFN8_1P45X1P25MM
U7NTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HXQFN8_1P45X1P25MM
U8NTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HXQFN8_1P45X1P25MM
U9NTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HXQFN8_1P45X1P25MM
U10S32K1XX_LQFP_144P_LQFP144_0P5_2FS32K148UJT0VLQTLQFP144_0P5_20X20MM
U11S32K1XX_LQFP_176P_TQFP176_IC_1.FS32K148UJT0VLUTTQFP176
U17PCA8565TS_TSSOP8_TSSOP8_A_IC_1.PCA85063ATTTSSOP8_A
U18MMA8452Q_16P_QFN5X3_0P5_3X3_IC_MMA8452QQFN5X3_0P5_3X3
U19NTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HXQFN8_1P45X1P25MM
U20NTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HXQFN8_1P45X1P25MM
U21TJA1101_QFN_36P_QFN36_0P5_6X6_ITJA1101QFN36_0P5_6X6
U23NTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HXQFN8_1P45X1P25MM
U24MX25L6433FM2R_SOP8_SO8_W_IC_2.1MX25L6433FM2R-08GSO8_W
U25SGTL5000_QFN32_0.9MM_315-77907_SGTL500032QFNQFN32
U29ESD_DIODE_2LINE_SOT23_A_IC_1.1MPESD2CANSOT23_A
U30TJA1043TK_14P_HVSON14_0P65_4P6XTJA1043TKYHVSON14_0P65_4P6X3P1_EP
U31ESD_DIODE_2LINE_SOT23_A_IC_1.1MPESD2CANSOT23_A
U32NTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HXQFN8_1P45X1P25MM
U33NTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HXQFN8_1P45X1P25MM
U34NTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HXQFN8_1P45X1P25MM
U35NTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HXQFN8_1P45X1P25MM
U36NTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HXQFN8_1P45X1P25MM
U37NTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HXQFN8_1P45X1P25MM
U38NTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HXQFN8_1P45X1P25MM
U39NTB0104BQ_DHVQFN14_3X2P5MM_IC_1NTB0104BQDHVQFN14_3X2P5MM
U40NTB0104BQ_DHVQFN14_3X2P5MM_IC_1NTB0104BQDHVQFN14_3X2P5MM
U41NTS0104BQ_14EP_DHVQFN14_3X2P5MMNTS0104BQDHVQFN14_3X2P5MM
U42NTB0104BQ_DHVQFN14_3X2P5MM_IC_1NTB0104BQDHVQFN14_3X2P5MM
U43NTB0104BQ_DHVQFN14_3X2P5MM_IC_1NTB0104BQDHVQFN14_3X2P5MM
U44NTS0104BQ_14EP_DHVQFN14_3X2P5MMNTS0104BQDHVQFN14_3X2P5MM
U45TJA1044GT/3_SO8_1P27_4X5_IC_1.7TJA1044GT/3SO8_1P27_4X5
U46OPAMP_DUAL_8P_D_SO8_1P27_4X5_ICMCP6022-I/SNSO8_1P27_4X5
U47AUIPS7091G_SOIC8_SO_8_1P27_4X5_AUIPS7091GSO_8_1P27_4X5
U48AUIPS7091G_SOIC8_SO_8_1P27_4X5_AUIPS7091GSO_8_1P27_4X5
U4974FCT38072S_DFN8_DFN_8_0P5_2X2_74FCT38072SDFN_8_0P5_2X2_A
Y1XTAL_XTAL2_3P3X2P6_IC_1MM_230-78MHZXTAL2_3P3X2P6
Y2XTAL_13Y_XTLOSC4_3P2X2P5MM_SM_I25MHzXTLOSC4_3P2X2P5MM_SM
Y3OSC3_XTLOSC4_CB3_SM_IC_1.8MM_2312.288MHzXTLOSC4_CB3_SM
Y4OSC_4P_XTLOSC4_3P3X1P6_SM_IC_1.32.7680KHZXTLOSC4_3P3X1P6_SM
lf2k2022 发表于 2024-8-30 16:20
小跟班2014 发表于 2024-8-31 09:53
感谢分享了,支持 一下
quan18503036960 发表于 2024-9-3 10:26
:lol:lol:lol:lol:lol:lol:lol:lol
beiniya 发表于 2025-5-12 14:05
1212132131312311
1368894698 发表于 2026-8-6 10:47
感谢感谢感谢分享
查看完整版本: S32K1XX FS32K148UJT0VLUT 开发板PCB文件 UJA1131HW+TJA1101+SGTL5000
