全志T113-S3 原厂DEMO板PCB文件共享 2层设计
ANT1SMA/RF_1_ANT3B300_310H125_WIFI-WIFI-ANTANT3B300_310H125
ANT2SMA/RF_1_ANT3B300_310H125_WIFI-WIFI-ANTANT3B300_310H125
B1FB-0603_L0603_600R-100M600R-100ML0603
B2FB-0603_L0603_600R-100M600R-100ML0603
B3FB-0603_L0603_600R-100M600R-100ML0603
B4FB-0603_L0603_600R-100M600R-100ML0603
B5FB-0603_L0603_600R-100M600R-100ML0603
BT1BATTERY_0_CR2B2000_2850H550_CR2CR2032-8CR2B2000_2850H550
CON10_0.8T-2PWB_CON-2P-0_8MM_NC/0_0NC/0_0.8T-2PWBCON-2P-0_8MM
CON20_0.8T-2PWB_CON-2P-0_8MM_NC/0_0NC/0_0.8T-2PWBCON-2P-0_8MM
CON3XH2.54MM-5P-M_HDR1_5P250B570_15CON5HDR1_5P250B570_1500H700
CON4XH2.54MM-5P-M_HDR1_5P250B570_15CON5HDR1_5P250B570_1500H700
CON7RT9266PE_3_HDR1_4P254B250_101_1CON4/2.54MM/DIP_ALHDR1_4P254B250_1016H254
CON8RT9266PE_3_HDR1_4P254B250_101_1CON4/2.54MM/DIP_ALHDR1_4P254B250_1016H254
CON10RT9266PE_3_HDR1_4P254B250_1016HCON_4P_2R54_PHHDR1_4P254B250_1016H254
D8DIO-SS24_SOD362_432H229_NC/SS24NC/SS24SOD362_432H229
D12DIO-M1_SOD269_426H222_1N40071N4007SOD269_426H222
D17ESD5451X_ESD0402_ESD5451X-2/TRESD5451X-2/TRESD0402
D18ESD5451X_ESD0402_ESD5451X-2/TRESD5451X-2/TRESD0402
D20ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
D21ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
D22ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
D23ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
D24ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
D26DIODE_SCHOTTKY_0_SOD155_270H118XBS104S14SOD155_270H118
D31DIODE_SCHOTTKY_0_SOD155_270H118XBS104S14SOD155_270H118
D32DIODE_SCHOTTKY_0_SOD155_270H118XBS104S14SOD155_270H118
D795KP22A_0_SOD1000_1350H485_SM8J2SM8J22ASOD1000_1350H485
D80ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
D81ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
D82ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
D83ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
D84ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
D85ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
D87DIODE_0_SOD591_686H234_6A106A10SOD591_686H234
D88ESD5451X_ESD0402_ESD5451X-2/TRESD5451X-2/TRESD0402
DC1ESD9B5VL_ESD0402_ESD9B5VL-2-TRESD9B5VL-2-TRESD0402
DC2ESD9B5VL_ESD0402_ESD9B5VL-2-TRESD9B5VL-2-TRESD0402
DC3ESD9B5VL_ESD0402_ESD9B5VL-2-TRESD9B5VL-2-TRESD0402
DC4ESD9B5VL_ESD0402_NC/ESD9B5VL-2-NC/ESD9B5VL-2-TRESD0402
DC5ESD9B5VL_ESD0402_ESD9B5VL-2-TRESD9B5VL-2-TRESD0402
DC6ESD9B5VL_ESD0402_ESD9B5VL-2-TRESD9B5VL-2-TRESD0402
DC7ESD9B5VL_ESD0402_ESD9B5VL-2-TRESD9B5VL-2-TRESD0402
DC8ESD9B5VL_ESD0402_ESD9B5VL-2-TRESD9B5VL-2-TRESD0402
DL2DIO-SS16F_SOD250_380H100_SS16FSS16FSOD250_380H100
ESD2ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
ESD3ESD5451X_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
ESD6TVS-FBP-02C_ESD0402_ESD9B5VL-2/ESD9B5VL-2/TRESD0402
ESD7TVS-WBFBP-02C_ESD0402_ESD9B5VL-ESD9B5VL-2/TRESD0402
ESD8TVS-WBFBP-02C_ESD0402_ESD9B5VL-ESD9B5VL-2/TRESD0402
ESD9TVS-FBP-02C_ESD0402_ESD9B5VL-2/ESD9B5VL-2/TRESD0402
ESD10TVS-WBFBP-02C_ESD0402_ESD9B5VL-ESD9B5VL-2/TRESD0402
ESD11TVS-WBFBP-02C_ESD0402_ESD9B5VL-ESD9B5VL-2/TRESD0402
ESD12TVS-FBP-02C_ESD0402_ESD5451X-2/ESD5451X-2/TRESD0402
ESD13TVS-FBP-02C_ESD0402_ESD5451X-2/ESD5451X-2/TRESD0402
ESD14TVS-FBP-02C_ESD0402_ESD5451X-2/ESD5451X-2/TRESD0402
ESD15ESD5451X_ESD0402_ESD5451X-2/TRESD5451X-2/TRESD0402
ESD20ESD5451X_ESD0402_ESD5451X-2/TRESD5451X-2/TRESD0402
ESD381_1.5KE100A_SOD130_175H101_ST5VST5VLBD322SOD130_175H101
ESD401_1.5KE100A_SOD130_175H101_ST5VST5VLBD322SOD130_175H101
ESD41ESD9B5VL_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
ESD42ESD9B5VL_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
ESD43ESD9B5VL_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
ESD44ESD9B5VL_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
ESD45ESD9B5VL_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
ESD46ESD9B5VL_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
ESD471_1.5KE100A_ESD0402_ESD5451X-2-ESD5451X-2-TRESD0402
ESD48ESD9B5VL_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
ESD49ESD9B5VL_ESD0402_ESD5451X-2-TRESD5451X-2-TRESD0402
ESD51TVS-FBP-02C_ESD0402_ESD9B5VL-2/ESD9B5VL-2/TRESD0402
ESD52TVS-FBP-02C_ESD0402_ESD9B5VL-2/ESD9B5VL-2/TRESD0402
ESD53TVS-FBP-02C_ESD0402_ESD9B5VL-2/ESD9B5VL-2/TRESD0402
ESD54TVS-FBP-02C_ESD0402_ESD9B5VL-2/ESD9B5VL-2/TRESD0402
ESD55TVS-WBFBP-02C_ESD0402_ESD9B5VL-ESD9B5VL-2/TRESD0402
ESD56TVS-WBFBP-02C_ESD0402_ESD9B5VL-ESD9B5VL-2/TRESD0402
ESD57ESD5451X_ESD0402_ESD5451X-2/TRESD5451X-2/TRESD0402
ESD58ESD5451X_ESD0402_ESD5451X-2/TRESD5451X-2/TRESD0402
FB4INDUCTOR_L0603_MH1608-600YMH1608-600YL0603
FB5INDUCTOR_L0603_MH1608-600YMH1608-600YL0603
FB6INDUCTOR_L0603_MH1608-600YMH1608-600YL0603
FB9INDUCTOR_L0603_MH1608-600YMH1608-600YL0603
FB10INDUCTOR_L0603_MH1608-600YMH1608-600YL0603
FB11INDUCTOR_L0603_MH1608-600YMH1608-600YL0603
FB12INDUCTOR_L0603_NC/MH1608-600YNC/MH1608-600YL0603
FB18FERRITEBEAD_0_L0603_120R@100M-120R@100M-1AL0603
FB21FERRITEBEAD_0_L0603_120R@100M-120R@100M-1AL0603
FB28INDUCTOR_3_R0805_90@100M90@100MR0805
FB29INDUCTOR_3_R0805_90@100M90@100MR0805
FBN1INDUCTOR_0805_L0603_600R@100M-1600R@100M-1AL0603
FBN2INDUCTOR_0805_L0603_600R@100M-1600R@100M-1AL0603
GND-0CON1X2-2.54-F-DIP_SKT1_2P254B25CON1X2-2.54-F-DIPSKT1_2P254B250_528H850
GND-1CON1X2-2.54-F-DIP_SKT1_2P254B25CON1X2-2.54-F-DIPSKT1_2P254B250_528H850
GND-2CON1X2-2.54-F-DIP_SKT1_2P254B25CON1X2-2.54-F-DIPSKT1_2P254B250_528H850
GND-3CON1X2-2.54-F-DIP_SKT1_2P254B25CON1X2-2.54-F-DIPSKT1_2P254B250_528H850
GND-4CON1X2-2.54-F-DIP_SKT1_2P254B25CON1X2-2.54-F-DIPSKT1_2P254B250_528H850
GND-5CON1X2-2.54-F-DIP_SKT1_2P254B25CON1X2-2.54-F-DIPSKT1_2P254B250_528H850
H1HOLE_MTH635D320_NC/HOLENC/HOLEMTH635D320
H2HOLE_MTH635D320_NC/HOLENC/HOLEMTH635D320
H3HOLE_MTH635D320_NC/HOLENC/HOLEMTH635D320
H4HOLE_MTH635D320_NC/HOLENC/HOLEMTH635D320
H5HOLE_TH300_NC/HOLENC/HOLETH300
H6HOLE_TH300_NC/HOLENC/HOLETH300
I2S2-CONCON1X6-2.54-F-DIP_SKT1_6P254B25NC/CON1X6-2.54-F-DIPSKT1_6P254B250_1544H850
J4FPC-40P-0.5MM-B_FPC42P50B450_24FPC-40P-0.5MM-BFPC42P50B450_2410H150
J5FPC-16P-0.5MM-B_FPC18P50B450_12FPC-16P-0.5MM-BFPC18P50B450_1210H150
J6DC3-2.0MM-44P-RGBLCD-20200618_ILCD_CNIDCN-44
J7FPC-4P-1MM-T_2_FPC6P100B550_110RTPFPC6P100B550_1100H250_T
J10PJ-327F_HP5B650_1400H500_PJ-327PJ-327FHP5B650_1400H500
J11TF-SLOT_SDC13B1450_1472H245_TF-TF-SLOTSDC13B1450_1472H245
J12USB2.0-MICRO-01F_USB9P65B500_69USB2.0-MICRO-01FUSB9P65B500_690H240
J13USB2.0-A-02F_USB8P200B512_1925HUSB-A-02FUSB8P200B512_1925H1250
J15DIP-4PIN-360_6_BMW8B600_1890H70DIPBMW8B600_1890H700
J17CON1X4-2.54-M_HDR1_4P254B250_10CON1X4-2.54-MHDR1_4P254B250_1016H254
J19ANT-F_ANT2_F_NC-ANT-FNC-ANT-FANT2_F
J25DC3-2.0MM-14P_HDR2_7P200B550_21DC3-2.0MM-14PHDR2_7P200B550_2130H560
J46DIP-4PIN-360_6_BMW8B600_1890H70DIPBMW8B600_1890H700
J49CON1X8-2.54-M_HDR1_8P254B250_20CON1X8-2.54-MHDR1_8P254B250_2032H254
J55MIPI_90_CON_FDF40HC(3.0)-90DS-0.4V(58)SEDSKT90P40B294_2060H290
J56XH2.54MM-2P-M_HDR1_2P250B570_75XH2.54MM-2P-MHDR1_2P250B570_750H700
J58CON2_0_SKT1_4P200B250_850H400_VNC-CON4/2.00MM/DIP_ALSKT1_4P200B250_850H400_V
J59CON2_0_SKT1_4P200B250_850H400_VNC-CON4/2.00MM/DIP_ALSKT1_4P200B250_850H400_V
J62CON1X2-2.54-F-DIP_SKT1_2P254B25CON1X2-2.54-F-DIPSKT1_2P254B250_528H850
J67CON1X2-2.54-F-DIP_SKT1_2P254B25CON1X2-2.54-F-DIPSKT1_2P254B250_528H850
J68CON1X2-2.54-F-DIP_SKT1_2P254B25CON1X2-2.54-F-DIPSKT1_2P254B250_528H850
J69CON1X8-2.54-M_HDR1_8P254B250_20CON1X8-2.54-MHDR1_8P254B250_2032H254
J72CON1X8-2.54-F-DIP_SKT1_8P254B25CON1X8-2.54-F-DIPSKT1_8P254B250_2052H850
J73CON1X6-2.54-F-DIP_SKT1_6P254B_1CON1X6-2.54-F-DIPSKT1_6P254B250_1544H850
JL2CTP_CN_2_FPC8P100B515_1090H340_CTP_CNFPC8P100B515_1090H340_B
JL5CTP_CN_3_FPC8P50B450_710H150_NCNC-CTP_CNFPC8P50B450_710H150
JL11DF40HC-90DS-0_3.4V_SKT2_35P50B4BTB2x35-0_5P6_5H-FemaleSKT2_35P50B400_2020H390_SMD
JN1LU1S041A_0_RJ-45B_RJ45ARJ45ARJ-45B
JS1DCIN-12V_PWR3B900_1400H1100_DCIDCIN-12VPWR3B900_1400H1100
K1SW-5P-DIP_SW5B830_1995H520_SW-5SW-5P-DIPSW5B830_1995H520
K2KEY-02P-SMD-01_KEY2B350_600H350KEY2B350_600H350_AKEY2B350_600H350_A
K3KEY-04P-SMD-01_KEY4B620_620H430VOL+KEY4B620_620H430
K4KEY-04P-SMD-01_KEY4B620_620H4_1VOL-KEY4B620_620H430
K5KEY-04P-SMD-01_KEY4B620_620H4_2MENUKEY4B620_620H430
K6KEY-04P-SMD-01_KEY4B620_620H4_3ENTERKEY4B620_620H430
K7KEY-04P-SMD-01_KEY4B620_620H4_4HOMEKEY4B620_620H430
K8KEY-02P-SMD-01_KEY2B350_600H3_1FELKEY2B350_600H350_A
L1UTC221408-842MAB_1_RD2B1150_24020uH-ACTA-01-200M-3ARD2B1150_2400H2400
L2L-L2520_LP500_500H395_LVS505020LVS505020-2R2-2.2uH-2.8ALP500_500H395
L3L-HEI252010A-1R5M-Q8_LP160_200HHEI252012A-2R2M-PAU-2ALP160_200H100
L6L-L0603_L0603_8.2UH8.2uHL0603
L7L-L0603_L0603_8.2UH8.2uHL0603
L10LCS-4C_0_LP4_320_450H300_ACT45BACT45BLP4_320_450H300
L88L-LVS505040-6R8-N_LP680_730H280HPPC06030B-6R8M-5.5ALP680_730H280
L90L-HEI252010A-1R5M-Q8_LP160_200HHEI252012A-2R2M-PAU-2ALP160_200H100
L91L-L2520_LP200_250H100_2.2UH-1A2.2uH-1ALP200_250H100
L92L-L2520_LP200_250H100_2.2UH-1A2.2uH-1ALP200_250H100
LED1LED-0603-R_LED0603_LED-0603-RLED-0603-RLED0603
LED2LED-0603-R_LED0603_LED-0603-RLED-0603-RLED0603
LED3LED_0_LED0805_POWERPOWERLED0805
LL3L-L2520_LP200_250H100_10UH-1A10uH-1ALP200_250H100
LW1INDUCTOR_L0805_NCNCL0805
MIC1MIC-DGHSEM6050_MIC_600X270_MICPMicphoneMIC_600X270
OSC1OSC_X4B250_320H120_SMD_NC/27MHZNC/27MHz/3225/20ppmX4B250_320H120_SMD
Q6NMOS-BSN20_SOT3P95B130_290H103_BSN20SOT3P95B130_290H103
Q9NMOS-2N7002_SOT3P95B130_290H103BSN20SOT3P95B130_290H103
Q10NMOS-2N7002_SOT3P95B130_290H103BSN20SOT3P95B130_290H103
Q16NMOS-BSN20_SOT3P95B130_290H103_BSN20SOT3P95B130_290H103
Q18BSN20_SOT3P95B130_290H103_NC/BSNC/BSN20SOT3P95B130_290H103
Q37NPN-MMBT3904_0_SOT3P95B130_290HMMBT3904SOT3P95B130_290H103
Q38BSN20_SOT3P95B130_290H103_NC/BSNC/BSN20SOT3P95B130_290H103
Q39BSN20_SOT3P95B130_290H103_NC/BSNC/BSN20SOT3P95B130_290H103
Q41FDS4953_1_SOT3P95B130_290H103_SSG20P2SOT3P95B130_290H103
U4SY8088_0_SOT5P95B160_290H145_SYSY8088SOT5P95B160_290H145
U5SY8089A_0_SOT5P95B160_290H145_SSY8089SOT5P95B160_290H145
U6SGM2028_SOT5P95B160_290H145_SGMSGM2028-ADJSOT5P95B160_290H145
U7SY8088_0_SOT5P95B160_290H145__1SY8089SOT5P95B160_290H145
U11F133-ELQFP128-NEW_0_QFP129P40B1T113-S3-eLQFP128-newQFP129P40B1600_1600H160
U12SGM803/809_SOT3P95B130_290H103_NC/SGM803/809SOT3P95B130_290H103
U13SPI-NAND+NOR_SOP9P127B600_800-C25Q64SOP9P127B600_800-COMPLEX_NOR
U14EMMC5.0-BGA169_BGA169P50B1200_1EMMC5.0-BGA169BGA169P50B1200_1600H100
U15RT9293B_SOT6P95B160_290H145_RT9RT9293BSOT6P95B160_290H145
U19LY8006_MSOP8_LY8006LY8006MSOP8
U20LY8006_MSOP8_LY8006LY8006MSOP8
U21SY6280_SOT5P95B160_300H130_SY62SY6280SOT5P95B160_300H130
U22SY6280_SOT5P95B160_300H130_SY62SY6280SOT5P95B160_300H130
U25VIDEO-JACK-1_0_VIDEO_JACK_JACK1JACK1IN1VIDEO_JACK
U26VIDEO-JACK-1_0_VIDEO_JACK_JACK1JACK1IN1VIDEO_JACK
U27VIDEO-JACK-1_0_VIDEO_JACK_JACK1JACK1IN1VIDEO_JACK
U38RAPTOR3_0_QFN55P35B550_550H55_NN5_54HUQFNQFN55P35B550_550H55
U39GD5F4GQ4UAYIG_2_SOP9P127B600_80128MBSOP9P127B600_800-COMPLEX_NOR
U43PCF8563_SOP8P127B390_490H175_ATAT8563SOP8P127B390_490H175
U44LMR14030_0_SOP9P127B390_490H170SYQA303SOP9P127B390_490H170
U45PCF8563_2_SOP8P127B390_490H175_TJA1051/3SOP8P127B390_490H175
U46MAX3237CAI_1_SOP16P65B440_500H1SP3232EEY-L/TLSOP16P65B440_500H120
U47M2016_0_SOP8P127B390_490H175_SPSP3485EN-L/TLSOP8P127B390_490H175
U48SY8088_0_SOT5P95B160_290H145__1SY8089SOT5P95B160_290H145
U49SY8088_0_SOT5P95B160_290H145_SYSY8088SOT5P95B160_290H145
U50XC6228_SOT5P95B160_290H145_ME62ME6211C18M5G-NSOT5P95B160_290H145
UN1IP101GR_0_QFN33P0_4B4X4_IP101GRIP101GRQFN33P0_4B4X4
UN2J_0_SOP16P1_27B6_86X12_70H6_0_PPM44-11BPSOP16P1_27B6_86X12_70H6_0
UW1AW1732-NOSOCKET_0_QFN41P40B500_XR829QFN41P40B500_500H75
UW2AW859A_3_SUB_WIFI44B1200_1200H1NC/AW859ASUB_WIFI44B1200_1200H150
Y1CRY-32.768KHZ-2X6-DIP_0_X3B190_NC/32.768K-12.5pF-20ppmX3B190_600H190
Y2CRY-24MHZ-3225-SMD_0_X4B250_32024M-16pF-10ppmX4B250_320H120_SMD
Y4CRY-25MHZ-SMD_X2B150_320H75_SMD32.768KHzX2B150_320H75_SMD
YN1XD-49US-A_CRY2P10B12X5_NC/25MHZNC/25MHzCRY2P10B12X5
YW1CRYSTAL-4_0_X4B250_320H120_SMD_24M-20pF-10PPMX4B250_320H120_SMD
PCB文件。回复可见下载
**** Hidden Message *****
谢谢好资料的分享 谢谢分享,,,,, 这是个好资料,下载来学习:victory: :) 学习一下,感谢分享 强强强强
