armclub 发表于 2024-11-5 15:52
BeagleY-AI 14层PCB文件 AM67A AI 视觉处理器TUSB8041RGCR+DP83867CRRGZR+IT66122FN
D1DIODETVS BI-DIR_D0402_TPD1E1B04DPYRTPD1E1B04DPYRD0402
D2DIODETVS BI-DIR_D0402_TPD1E1B04DPYRTPD1E1B04DPYRD0402
D3DIODETVS BI-DIR_D0402_TPD1E1B04DPYRTPD1E1B04DPYRD0402
D4DIODETVS BI-DIR_D0402_TPD1E1B04DPYRTPD1E1B04DPYRD0402
D5DIODETVS BI-DIR_D0402_TPD1E1B04DPYRTPD1E1B04DPYRD0402
D6DIODETVS BI-DIR_D0402_TPD1E1B04DPYRTPD1E1B04DPYRD0402
D7DIODETVS BI-DIR_D0402_TPD1E1B04DPYRTPD1E1B04DPYRD0402
D8D_SOD_523_LRB520S-30T1GLRB520S-30T1GSOD_523
D9DIODETVS BI-DIR_D0402_TPD1E1B04DPYRTPD1E1B04DPYRD0402
D10BZX84C6V8LT1G_SOT23_6.8V6.8VSOT23
D11DIODETVS BI-DIR_D0402_TPD1E10B06DPYRTPD1E10B06DPYRD0402
D12DIODETVS BI-DIR_D0402_TPD1E10B06DPYRTPD1E10B06DPYRD0402
D13DIODETVS BI-DIR_D0402_TPD1E0B04DPYRTPD1E0B04DPYRD0402
D14DIODETVS BI-DIR_D0402_TPD1E0B04DPYRTPD1E0B04DPYRD0402
D15D_SOD_523_LRB520S-30T1GLRB520S-30T1GSOD_523
D16D_SOD_523_LRB520S-30T1GLRB520S-30T1GSOD_523
D17DIODETVS BI-DIR_D0402_TPD1E10B06DPYRTPD1E10B06DPYRD0402
D18DIODETVS BI-DIR_D0402_TPD1E10B06DPYRTPD1E10B06DPYRD0402
D19DIODETVS BI-DIR_D0402_TPD1E10B06DPYRTPD1E10B06DPYRD0402
D20DIODETVS BI-DIR_D0402_TPD1E10B06DPYRTPD1E10B06DPYRD0402
D21DIODETVS BI-DIR_D0402_TPD1E10B06DPYRTPD1E10B06DPYRD0402
D22DIODETVS BI-DIR_D0402_TPD1E1B04DPYRTPD1E1B04DPYRD0402
D23DIODETVS BI-DIR_D0402_TPD1E1B04DPYRTPD1E1B04DPYRD0402
D24D_SOD_523_LRB520S-30T1GLRB520S-30T1GSOD_523
D37ESD122DMX_X2SON3_0D3_0_6X1X0_4MM_ESD122DMXRESD122DMXRX2SON3_0D3_0_6X1X0_4MM
F1FUSE_F0603_DISCRETE_100MA100mAF0603
FB37FB_L0603_120R120RL0603
FB38FB_L0603_120R120RL0603
J1MICROSDCARD_10+4P_SD-1040310811_10403108111040310811SD-1040310811
J2HEADER40+2P_FPC40_0D5_25_4X5_25X2MM_0.5K-DX-40PWB0.5K-DX-40PWBFPC40_0D5_25_4X5_25X2MM
J3HEADER2X5_1_CONNECT10_1D27_12_4X6_7MM_TC2050-IDCTC2050-IDCCONNECT10_1D27_12_4X6_7MM
J4HEADER2X5_1_CONNECT10_1D27_12_4X6_7MM_TC2050-IDCTC2050-IDCCONNECT10_1D27_12_4X6_7MM
J5RFANT 3P_U-FL3P-SMD-2_6X2_6X1_0MM_U.FL-R-SMT-1(10)U.FL-R-SMT-1(10)U-FL3P-SMD-2_6X2_6X1_0MM
J6RFANT 3P_U-FL3P-SMD-2_6X2_6X1_0MM_U.FL-R-SMT-1(10)U.FL-R-SMT-1(10)U-FL3P-SMD-2_6X2_6X1_0MM
J7FPC16+4P_FPC16_0D5_13_7X3_5X3_95MM_90D_MTFP65-816SWN-19A72MTFP65-816SWN-19A72FPC16_0D5_13_7X3_5X3_95MM_90D
J8USB2.0_TYPEC_16+6P#1_USB2_0_TYPE_C_USB2.0 TYPE CUSB2.0Type CUSB2_0_TYPE_C
J9JST_2+2P_JST2P_1D0_4_2X3X4_9MM_MTWF63-102SRN-01163MTWF63-102SRN-01163JST2P_1D0_4_2X3X4_9MM
J10HEADER1X2_HEADER2P_2D54_DIP_HEADER 1X2 2.54MMHeader1x2 2.54mmHEADER2P_2D54_DIP
J11HEADER1X2_HEADER2P_1D27_DIP_TOP_IO_HEADER 1X2 1.27MMHeader1x2 1.27mmHEADER2P_1D27_DIP_TOP
J12MICROHDMI_TYPE D_19P_HDMI19P_0D4_6_5X7_95X2_9MM_MTHD54-919000-02B23MTHD54-919000-02B23HDMI19P_0D4_6_5X7_95X2_9MM
J13JST_3+2P_JST3P_1D0_5_2X3X4_9MM_MTWF63-103SRN-01163MTWF63-103SRN-01163JST3P_1D0_5_2X3X4_9MM
J14HEADER2X20 OF RPI_HEADER2X20P_2D54_DIP_HEADER 2X20 2.54MMHeader2x20 2.54mmHEADER2X20P_2D54_DIP
J15FPC22+4P_FPC22_0D5_16_7X3_5X3_95MM_90D_MTFP65-822SWN-19A72MTFP65-822SWN-19A72FPC22_0D5_16_7X3_5X3_95MM_90D
J16FPC22+4P_FPC22_0D5_16_7X3_5X3_95MM_90D_MTFP65-822SWN-19A72MTFP65-822SWN-19A72FPC22_0D5_16_7X3_5X3_95MM_90D
J17HEADER2X2_HEADER2X2_2_54_HEADER 2X2 2.54MMHeader2x2 2.54mmHEADER2X2_2_54
J18JST_4+2P_JST4P_1D0_6_2X3X4_9MM_MTWF63-104SRN-01163MTWF63-104SRN-01163JST4P_1D0_6_2X3X4_9MM
J19RJ45_POE_LPJG0926HENL_RJ45_20P_LPJG0926HENL_SLOT_LPJG0926HENLS4RLPJG0926HENLS4RRJ45_20P_LPJG0926HENL_SLOT
J20USB3.0_DUALTYPE A_18+4P_USB3_0_2D0_17_5X13_78X15_49MM_SLOT_UBF30-D2112UBF30-D2112USB3_0_2D0_17_5X13_78X15_49MM_SLOT
J21USB3.0_DUALTYPE A_18+4P_USB3_0_2D0_17_5X13_78X15_49MM_SLOT_UBF30-D2112UBF30-D2112USB3_0_2D0_17_5X13_78X15_49MM_SLOT
L1L_L2P_4_2X4_2X1_9MM_DISCRETE_0.22UH0.22uHL2P_4_2X4_2X1_9MM
L2CL_L4P_0_85X0_65MM_90R90RL4P_0_85X0_65MM
L3CL_L4P_0_85X0_65MM_90R90RL4P_0_85X0_65MM
L4L_L0402_1.5NH1.5nHL0402
L5L_L0402_1.5NH1.5nHL0402
L6L_L0402_1.5NH1.5nHL0402
L7L_L0402_1.5NH1.5nHL0402
L8L_L1008_DISCRETE_0.47UH0.47uHL1008
L9CL_L2012_90R90RL2012
L10L_L2P_4_3X4_3X2MM_DISCRETE_110NH110nHL2P_4_3X4_3X2MM
L11L_L1008_DISCRETE_0.47UH0.47uHL1008
L12L_L1008_DISCRETE_0.47UH0.47uHL1008
L13CL_L4P_0_85X0_65MM_DISCRETE_90R90RL4P_0_85X0_65MM
L14CL_L4P_0_85X0_65MM_DISCRETE_90R90RL4P_0_85X0_65MM
L15CL_L4P_0_85X0_65MM_DISCRETE_90R90RL4P_0_85X0_65MM
L16CL_L4P_0_85X0_65MM_DISCRETE_90R90RL4P_0_85X0_65MM
L28CL_L2012_90R90RL2012
LED1LED_12GREED_34RED_LED4_3_2X1_5X1_0MM_XL-3210SURSYGCXL-3210SURSYGCLED4_3_2X1_5X1_0MM
OSC1OSC_4P_X4-SMD-2_5X2_0X1_0MM_32.768KHZ32.768kHzX4-SMD-2_5X2_0X1_0MM
Q1NMOS_123_SOT_523_CJ1012CJ1012SOT_523
Q2NMOS_123_SOT_523_CJ1012CJ1012SOT_523
Q3NMOS_123_SOT_523_CJ1012CJ1012SOT_523
SW1TACTILESWITCH_3+4P_SW3_4P_1D15_4_55X3_45X3_3MM_MTKG63-003A05-74333MTKG63-003A05-74333SW3_4P_1D15_4_55X3_45X3_3MM
U1TPS22918DBV_SOT23_6_TPS22918DBVRTPS22918DBVRSOT23_6
U2SN74LVC1G08DCKR_DCK5_2P15X1P4_SN74LVC1G08DCKRSN74LVC1G08DCKRDCK5_2P15X1P4
U3TPS62A06_SOT563_TPS62A06DRLRTPS62A06DRLRSOT563
U4LDO_5P_FB_EN_SOT23-5_TLV75512PDBVRTLV75512PDBVRSOT23-5
U5DS1340_SOP8_0D65_3X3X1_1MM_DS1340U-33+DS1340U-33+SOP8_0D65_3X3X1_1MM
U6SN74LVC1G08DCKR_DCK5_2P15X1P4_SN74LVC1G08DCKRSN74LVC1G08DCKRDCK5_2P15X1P4
U7TCA9801DGK_VSSOP8_0D65_3X3X1_1MM_TCA9801DGKRTCA9801DGKRVSSOP8_0D65_3X3X1_1MM
U8TPS74801DRCR_VSON10_0D5_3X3X1MM_TPS74801DRCRM3TPS74801DRCRM3VSON10_0D5_3X3X1MM
U9TMUX646_DSBGA36_0D4_2_45X2_45X0_5MM_TMUX646ZECRTMUX646ZECRDSBGA36_0D4_2_45X2_45X0_5MM
U10SN74LVC1T45YZPR_BGA6C50P2X3_89X139X50_SN74LVC1T45YZPRSN74LVC1T45YZPRBGA6C50P2X3_89X139X50
U11TPS2561_VSON10_0D5_3X3X1MM_TPS2561DRCRTPS2561DRCRVSON10_0D5_3X3X1MM
U12TVS0500DRVR_WSON6_0D65_2X2X0_8MM_TVS0500DRVRTVS0500DRVRWSON6_0D65_2X2X0_8MM
U13TPS62872_VQFN16_VQFN16_0D5_3_55X2_55X1MM_TPS62872QWRXSRQ1TPS62872QWRXSRQ1VQFN16_0D5_3_55X2_55X1MM
U14TPS65219_VQFN32_0D4_4X4X1MM_IC_TPS6521910RSMRTPS6521910RSMRVQFN32_0D4_4X4X1MM
U15SN74LVC1T45YZPR_BGA6C50P2X3_89X139X50_SN74LVC1T45YZPRSN74LVC1T45YZPRBGA6C50P2X3_89X139X50
U16WL1835MOD_E-13_4X13_3-N100_0_75-TOP_BM3301MODULE-1313BM3301Module-1313E-13_4X13_3-N100_0_75-TOP
U17MEM_24LC32_SOT23-5_SOT23-5_FT24C32A-ELRTFT24C32A-ELRTSOT23-5
U18TPS74801DRCR_VSON10_0D5_3X3X1MM_TPS74801DRCRM3TPS74801DRCRM3VSON10_0D5_3X3X1MM
U19TPD4E05U06DQAR_USON10_0D5_2D5X1X0D5MM_TPD4E05U06DQARTPD4E05U06DQARUSON10_0D5_2D5X1X0D5MM
U20IT66121_QFN64_QFN64_0D5_9X9MM_IC_IT66122FN/CXIT66122FN/CXQFN64_0D5_9X9MM
U21TPD4E05U06DQAR_USON10_0D5_2D5X1X0D5MM_TPD4E05U06DQARTPD4E05U06DQARUSON10_0D5_2D5X1X0D5MM
U22LPDDR4_X32_VFBGA200_BGA200_0D65_15X10X1MM_B3221PM3BDGUI-UB3221PM3BDGUI-UBGA200_0D65_15X10X1MM
U23SN74LVC1G08DCKR_DCK5_2P15X1P4_SN74LVC1G08DCKRSN74LVC1G08DCKRDCK5_2P15X1P4
U24TUSB8041_QFN64_0D5_9X9X1MM_TUSB8041RGCRTUSB8041RGCRQFN64_0D5_9X9X1MM
U25SN74LVC2G241_U_8_DCU_SN74LVC2G241DCURSN74LVC2G241DCURU_8_DCU
U26AM67X_AMW_FCBGA594_BGA594_0D65_18X18MM_XJ722S5AAMWXJ722S5AAMWBGA594_0D65_18X18MM
U27SN74LVC1G08DCKR_DCK5_2P15X1P4_SN74LVC1G08DCKRSN74LVC1G08DCKRDCK5_2P15X1P4
U28DP83867CRRGZ_QFN48_0D5_7X7MM_DP83867CRRGZRDP83867CRRGZRQFN48_0D5_7X7MM
U29TPD4E05U06DQAR_USON10_0D5_2D5X1X0D5MM_TPD4E05U06DQARTPD4E05U06DQARUSON10_0D5_2D5X1X0D5MM
U30TPD4E05U06DQAR_USON10_0D5_2D5X1X0D5MM_TPD4E05U06DQARTPD4E05U06DQARUSON10_0D5_2D5X1X0D5MM
U31PCA9306DQE_X2SON8_0D4_1_4X1X0_4MM_PCA9306DQERPCA9306DQERX2SON8_0D4_1_4X1X0_4MM
X1XTAL_2P_X2_SMD_3_2X1_5MM_32.768KHZ12.5PF32.768kHz12.5pFX2_SMD_3_2X1_5MM
X2XTAL_4P_X4-SMD-3_2X2_5X1_0MM_24MHZ18PF24MHz18pFX4-SMD-3_2X2_5X1_0MM
X3XTAL_2P_X2_SMD_3_2X1_5MM_32.768KHZ9PF32.768kHz9pFX2_SMD_3_2X1_5MM
X4XTAL_4P_X4_SMD_2_0X1_6MM_DISCRETE_25MHZ10PF25MHz10pFX4_SMD_2_0X1_6MM
X5XTAL_4P_X4_SMD_2_0X1_6MM_25MHZ18PF25MHz18pFX4_SMD_2_0X1_6MM
armclub 发表于 2024-11-5 15:54
PCB文件。回复可见下载
**** Hidden Message *****
lhr4373 发表于 2024-11-5 16:56
看看
fairy0212 发表于 2024-11-6 08:07
ZhenTing 发表于 2024-11-6 08:31
1234567890
io357 发表于 2024-11-6 08:44
yangjf 发表于 2024-11-6 08:46
谢谢资料分享!
richardz 发表于 2024-11-6 10:45
kingweison 发表于 2024-11-6 11:52
什么公司的方案啊?
lf2k2022 发表于 2024-11-6 13:21
页: [1] 2 3 4 5 6 7
查看完整版本: BeagleY-AI 14层PCB文件 AM67A AI 视觉处理器TUSB8041RGCR+DP83867CRRGZR+IT66122FN
