老吴 发表于 2024-11-26 17:42
NVIDIA 6层显卡PCB文件 142-14736-1000-A01
PCB文件。回复可见。
**** Hidden Message *****
BKT1BRACKET_BRKT_ATX_2TAB_1_HDMI_DPBRACKETBRKT_ATX_2TAB_1_HDMI_DP_2_HDMI_DP
BKT7BRACKET_TH3P2_T6P10_BRACKETBRACKETTH3P2_T6P10
CN1CON_PCI_EXPRESS_CON_FINGER_PEX_CON_PCI_EXPRESSCON_FINGER_PEX_164
D3D_SCHOTTKY#2_2_DIODE_SMD_SOD523D_SCHOTTKYDIODE_SMD_SOD523_B_AKP
D4D_3PIN_CC#1_SOT323_D_3PIN_CCD_3PIN_CCSOT323
D5D_3PIN_AA_SOT323_D_3PIN_AAD_3PIN_AASOT323
D7D_3PIN_AA_SOT323_D_3PIN_AAD_3PIN_AASOT323
D8D_3PIN_AA_SOT323_D_3PIN_AAD_3PIN_AASOT323
D9D_SCHOTTKY#2_3_DIODE_SMD_SOD523D_SCHOTTKYDIODE_SMD_SOD523_B_AKP
D13D#1_DIODE_SMD_SOD523_B_AKP_DDDIODE_SMD_SOD523_B_AKP
D14D_3PIN_CC_SOT323_D_3PIN_CCD_3PIN_CCSOT323
D17D_SCHOTTKY#2_0_DIODE_SMD_SOD523D_SCHOTTKYDIODE_SMD_SOD523_B
D1205D_SCHOTTKY#2_1_DIODE_SMD_SOD523D_SCHOTTKYDIODE_SMD_SOD523_B
D1207D_ESD_DIODE_SMD_010X060_D_ESDD_ESDDIODE_SMD_010X060
D1208D_ESD_DIODE_SMD_010X060_D_ESDD_ESDDIODE_SMD_010X060
D1209D_ESD_DIODE_SMD_010X060_D_ESDD_ESDDIODE_SMD_010X060
D1210D_ESD_DIODE_SMD_010X060_D_ESDD_ESDDIODE_SMD_010X060
D1213D_ESD_DIODE_SMD_010X060_D_ESDD_ESDDIODE_SMD_010X060
D1214D_ESD_DIODE_SMD_010X060_D_ESDD_ESDDIODE_SMD_010X060
D1215D_ESD_DIODE_SMD_010X060_D_ESDD_ESDDIODE_SMD_010X060
D1216D_ESD_DIODE_SMD_010X060_D_ESDD_ESDDIODE_SMD_010X060
F9605R#1_1206_1206FUSE_SMD1206P110T1206fuse_SMD1206P110TFT1206
G1U_GPU_GB5B_128_BGA_1358_P070_29U_GPU_GB5B_128BGA_1358_P070_290X290
J2CON_DISPLAYPORT#1_CON_DP_020_SMCON_DISPLAYPORTCON_DP_020_SMT_RA_F_B
J3CON_HDMI_CON_HDMI_019_SMT_RA_F_CON_HDMICON_HDMI_019_SMT_RA_F_P005_R
J4CON_HDMI_CON_HDMI_019_SMT_RA_F_CON_HDMICON_HDMI_019_SMT_RA_F_P005_R
J6CON_DISPLAYPORT#1_CON_DP_020_SMCON_DISPLAYPORTCON_DP_020_SMT_RA_F_B
J9HDR_3_CON_PWR_002X003_TH_RA_M_PHDR_2X3CON_PWR_002X003_TH_RA_M_P042_OP
J49HDR_0_DIP_POWERCON_8P_R_HDR_2X4HDR_2X4DIP_POWERCON_8P_R
J51HDR_1X4#1_CON_WAFER232_004_TH_SHDR_1X4CON_WAFER232_004_TH_ST_P020
L1L#1_IND_NONRKO_SMD_050X050_F_4.4.7uHIND_NONRKO_SMD_050X050_F
L5L_IND_NONRKO_SMD_118X081_0.22UH0.22uHIND_NONRKO_SMD_118X081
L1201L_IND_NONRKO_SMD_044X041_1UH_201uHIND_NONRKO_SMD_044X041
L1202L#1_IND_NONRKO_SMD_025X020_1UH_1uHIND_NONRKO_SMD_025X020
L1203L#1_IND_NONRKO_SMD_025X020_1UH_1uHIND_NONRKO_SMD_025X020
LB1L_IND_SMD_0402_600OHM_25%600ohmIND_SMD_0402
LB1208L_IND_SMD_0805_220OHM_25%220ohmIND_SMD_0805
M9U_MEM_SG_GDDR6#1_BGA_0180_P075_U_MEM_SG_GDDR6#1BGA_0180_P075_120X140
M10U_MEM_SG_GDDR6#2_BGA_0180_P075_U_MEM_SG_GDDR6#2BGA_0180_P075_120X140
M11U_MEM_SG_GDDR6_BGA_0180_P075_12U_MEM_SG_GDDR6BGA_0180_P075_120X140
M12U_MEM_SG_GDDR6#7_BGA_0180_P075_U_MEM_SG_GDDR6#7BGA_0180_P075_120X140
MEC2SOCKET_BGA_0_SKT_BGA_POGO_290X2SOCKET_BGASKT_BGA_POGO_290X290_P070_SMT
MEC3MOUNTING_HOLE_MECH_PEX_02122X01MOUNTING_HOLEMECH_PEX_02122X01112_SQ_TR_E4736_HOLES
Q1Q_NPN_SC70_6_Q_NPNQ_NPNSC70_6
Q2Q_FET_N_ENH_SC70_6_Q_FET_N_ENHQ_FET_N_ENHSC70_6
Q3Q_NPN#1_SOT323_D_Q_NPNQ_NPNSOT323_D
Q4Q_NPN#1_SOT323_D_Q_NPNQ_NPNSOT323_D
Q5Q_FET_N_ENH_SC70_6_Q_FET_N_ENHQ_FET_N_ENHSC70_6
Q6Q_NPN#1_SOT323_D_Q_NPNQ_NPNSOT323_D
Q7Q_NPN#1_SOT323_D_Q_NPNQ_NPNSOT323_D
Q23Q_FET_N_ENH#2_SOT323_Q_FET_N__1Q_FET_N_ENH_2N7002WSOT323
Q25Q_NPN#1_SOT23_Q_NPNQ_NPNSOT23
Q26Q_FET_N_ENH#2_SOT323_Q_FET_N_ENQ_FET_N_ENHSOT323
Q29Q_FET_N_ENH#2_SOT323_Q_FET_N_ENQ_FET_N_ENHSOT323
Q33Q_FET_N_ENH#2_SOT323_D_Q_FET_N_Q_FET_N_ENHSOT323_D
Q34Q_FET_N_ENH#1_SC70_6_Q_FET_N_ENQ_FET_N_ENHSC70_6
Q35Q_NPN#1_SOT323_D_Q_NPNQ_NPNSOT323_D
Q38Q_FET_N_ENH#2_SOT323_Q_FET_N_ENQ_FET_N_ENHSOT323
Q515Q_FET_N_ENH#2_SC70_6_Q_FET_N_ENQ_FET_N_ENHSC70_6
Q1210Q_NPN_SC70_6_Q_NPNQ_NPNSC70_6
Q1224Q_FET_N_ENH#2_SOT323_Q_FET_N_ENQ_FET_N_ENHSOT323
Q1225Q_FET_N_ENH#2_SOT323_Q_FET_N_ENQ_FET_N_ENHSOT323
Q1230Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
Q1231Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
Q1233Q_FET_N_ENH#2_SOT323_Q_FET_N_ENQ_FET_N_ENHSOT323
Q1234Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
Q1235Q_FET_N_ENH#2_SOT23_Q_FET_N_ENHQ_FET_N_ENHSOT23
Q1236Q_FET_N_ENH_SC70_6_Q_FET_N_ENHQ_FET_N_ENHSC70_6
Q1237Q_NPN#1_SOT323_D_Q_NPNQ_NPNSOT323_D
Q1238Q_FET_N_ENH_SC70_6_Q_FET_N_ENHQ_FET_N_ENHSC70_6
Q1239Q_FET_N_ENH_SC70_6_Q_FET_N_ENHQ_FET_N_ENHSC70_6
Q1240Q_FET_N_ENH#2_SOT323_D_Q_FET_N_Q_FET_N_ENHSOT323_D
Q1241Q_FET_N_ENH_SC70_6_Q_FET_N_ENHQ_FET_N_ENHSC70_6
Q1243Q_NPN#1_SOT323_D_Q_NPNQ_NPNSOT323_D
Q1244Q_FET_N_ENH#2_SOT323_D_Q_FET_N_Q_FET_N_ENHSOT323_D
Q1245Q_NPN#1_SOT323_D_Q_NPNQ_NPNSOT323_D
Q1246Q_FET_N_ENH_SC70_6_Q_FET_N_ENHQ_FET_N_ENHSC70_6
Q1247Q_FET_N_ENH_SC70_6_Q_FET_N_ENHQ_FET_N_ENHSC70_6
Q1248Q_NPN#1_SOT323_D_Q_NPNQ_NPNSOT323_D
Q1268Q_FET_N_ENH_SC70_6_Q_FET_N_ENH_Q_FET_N_ENH_PJT7828SC70_6
Q1272Q_FET_N_ENH_SC70_6_Q_FET_N_ENHQ_FET_N_ENHSC70_6
Q1273Q_FET_N_ENH_SC70_6_Q_FET_N_ENHQ_FET_N_ENHSC70_6
Q1274Q_FET_N_ENH_SC70_6_Q_FET_N_ENHQ_FET_N_ENHSC70_6
Q1275Q_FET_N_ENH_SC70_6_Q_FET_N_ENHQ_FET_N_ENHSC70_6
Q1276Q_FET_N_ENH_SC70_6_Q_FET_N_ENHQ_FET_N_ENHSC70_6
RS8R_SENSE#1_RES_04_SMD_064X032_RK0.005ohmRES_04_SMD_064X032_RKO
RS12R_SENSE#1_RES_04_SMD_064X032_RK0.005ohmRES_04_SMD_064X032_RKO
RS16R_SENSE#1_RES_04_SMD_064X032_RK0.005ohmRES_04_SMD_064X032_RKO
RS1260R_SENSE#1_RSENSE_VIRTUAL_04_SMD0OhmRSENSE_VIRTUAL_04_SMD_1206_B
RT1THERMISTOR#1_0402_100K_B25/50=4100k_B25/50=4250K402
RT2THERMISTOR#1_0603_100K_B25/85=4100k_B25/85=4550K603
RT3THERMISTOR_0402_1K_B25/100=0K_51k_B25/100=0K402
RT4THERMISTOR#1_0603_100K_B25/85=4100k_B25/85=4550K603
RT5THERMISTOR#1_0402_100K_B25/50_1100k_B25/50=4250K_NS402
RT10THERMISTOR_0402_150K_B25/50=450150k_B25/50=4500K402
RT11THERMISTOR_0402_150K_B25/50=450150k_B25/50=4500K402
TP1201LABTESTPOINT_LTPT071C125D_LABTELABTESTPOINTLTPT071C125D
U2U_PWR_SW_UL_SOT23_5_U_PWR_SW_ULU_PWR_SW_ULSOT23_5
U5U_BUCK_FET_1PH#1_SOT23_8_B_VIAS0.807V_MP1475DJ_GS7311SOT23_8_B_VIAS
U8U_DRMOS_QFN033Q_P050_0050_T036XU_DRMOSQFN033Q_P050_0050_T036X020_T017X011_T014X011
U9U_DRMOS_QFN033Q_P050_0050_T036XU_DRMOSQFN033Q_P050_0050_T036X020_T017X011_T014X011
U10U_DRMOS_QFN033Q_P050_0050_T036XU_DRMOSQFN033Q_P050_0050_T036X020_T017X011_T014X011
U11U_DRMOS_QFN033Q_P050_0050_T036XU_DRMOSQFN033Q_P050_0050_T036X020_T017X011_T014X011
U18U_DRMOS_QFN033Q_P050_0050_T036XU_DRMOSQFN033Q_P050_0050_T036X020_T017X011_T014X011
U20U_MEM_FL_SER_2MX8_SO08_048X038_U_MEM_FL_SER_2MX8SO08_048X038
U29U_DRMOS_QFN033Q_P050_0050_T036XU_DRMOSQFN033Q_P050_0050_T036X020_T017X011_T014X011
U34U_DRMOS_QFN033Q_P050_0050_T036XU_DRMOSQFN033Q_P050_0050_T036X020_T017X011_T014X011
U35U_DRMOS_QFN033Q_P050_0050_T036XU_DRMOSQFN033Q_P050_0050_T036X020_T017X011_T014X011
U37U_DRMOS_QFN033Q_P050_0050_T036XU_DRMOSQFN033Q_P050_0050_T036X020_T017X011_T014X011
U39U_DRMOS_QFN033Q_P050_0050_T036XU_DRMOSQFN033Q_P050_0050_T036X020_T017X011_T014X011
U58U_AND_2IN_SC70_5_U_AND_2INU_AND_2INSC70_5
U59U_PWR_SW_UL_SOT23_5_U_PWR_SW_ULU_PWR_SW_ULSOT23_5
U60U_AND_2IN_SC70_5_U_AND_2INU_AND_2INSC70_5
U61U_AND_2IN_SC70_5_U_AND_2INU_AND_2INSC70_5
U62U_AND_2IN_SC70_5_U_AND_2INU_AND_2INSC70_5
U64U_AND_2IN_SC70_5_U_AND_2INU_AND_2INSC70_5
U65U_AND_2IN_SC70_5_U_AND_2INU_AND_2INSC70_5
U68U_AND_2IN_SC70_5_U_AND_2INU_AND_2INSC70_5
U69U_AND_2IN_SC70_5_U_AND_2INU_AND_2INSC70_5
U70U_AND_2IN_SC70_5_U_AND_2INU_AND_2INSC70_5
U75U_OR_2IN_SC70_5_U_OR_2INU_OR_2INSC70_5
U76U_OR_2IN_SC70_5_U_OR_2INU_OR_2INSC70_5
U79U_SW_LOAD_SC70_6_U_SW_LOADU_SW_LOADSC70_6
U80U_AND_2IN_SC70_5_U_AND_2INU_AND_2INSC70_5
U81U_AND_2IN_SC70_5_U_AND_2INU_AND_2INSC70_5
U82U_LDO#1_DFN10_P050_030X030_T0240.8VDFN10_P050_030X030_T024X017_VIAS
U84U_AND_2IN_SC70_5_U_AND_2INU_AND_2INSC70_5
U87U_AND_2IN_SC70_5_U_AND_2INU_AND_2INSC70_5
U88U_PWRMTR_NCP4549_QFN032Q_P040_0U_PWRMTR_NCP4549QFN032Q_P040_0040_T027X027
U90U_AND_2IN_SC70_5_U_AND_2INU_AND_2INSC70_5
U91U_AND_2IN_SC70_5_U_AND_2INU_AND_2INSC70_5
U501U_AND_2IN_SC70_5_U_AND_2IN_M74VU_AND_2IN_M74VHC1GT08DFT2GSC70_5
U516U_AND_2IN_SC70_5_U_AND_2INU_AND_2INSC70_5
U518U_OPENVREG_TYPE4PLUS_QFN040Q_P02VQFN040Q_P040_0050_T035X035_VIAS
U610U_OPENVREG_TYPE3_QFN020Q_P040_02VQFN020Q_P040_035X035_T017X017_C
U1208U_VREG_APL5910_SO08_050X040_T030.8VSO08_050X040_T035X028
U1214U_PWR_SW_UL_SOT23_5_U_PWR_SW_ULU_PWR_SW_ULSOT23_5
U1218U_BUCK_FET_1PH_SOT23_6_0.6V_1%0.6VSOT23_6
U1219U_BUCK_FET_1PH_SOT23_6_0.6V_1%0.6VSOT23_6
U1220U_OPENVREG_TYPE3_QFN020Q_P040_02VQFN020Q_P040_035X035_T017X017_C
U1221U_AND_2IN_SC70_5_U_AND_2IN_M74VU_AND_2IN_M74VHC1GT08DFT2GSC70_5
Y1XTAL_4PIN_XTAL_SMD_4_032X025_2727MHzXTAL_SMD_4_032X025
为所欲为 发表于 2024-11-26 17:58
最新的,热乎
zspdeyc 发表于 2024-11-26 20:04
老吴吊爆了
微光 发表于 2024-11-26 22:17
学习学习
zheshiwo 发表于 2024-11-26 22:29
谢谢分享!
ilpuyi 发表于 2024-11-27 08:33
小小路人甲 发表于 2024-11-27 08:43
xg25 发表于 2024-11-27 08:46
学习,学习,顶
790 发表于 2024-11-27 09:01
谢谢分享,,,
io357 发表于 2024-11-27 09:01
谢谢分享!
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: NVIDIA 6层显卡PCB文件 142-14736-1000-A01
