74LVT16245
General DescriptionThe LVT16245 and LVTH16245 contain sixteen non-inverting bidirectional buffers with 3-STATE outputs and isintended for bus oriented applications. The device is bytecontrolled. Each byte has separate control inputs whichcan be shorted together for full 16-bit operation. The T/Rinputs determine the direction of data flow through thedevice. The OE inputs disable both the A and B ports byplacing them in a high impedance state.The LVTH16245 data inputs include bushold, eliminatingthe need for external pull-up resistors to hold unusedinputs.These non-inverting transceivers are designed for low-voltage (3.3V) VCC applications, but with the capability to provide a TTL interface to a 5V environment. The LVT16245and LVTH16245 are fabricated with an advanced BiCMOStechnology to achieve high speed operation similar to 5VABT while maintaining low power dissipation.
