老吴 发表于 2024-12-12 11:17
RK3368方案锐捷网络RG-SmartRain200V2_PAD_V100 智能云终端电脑PCB
CE6CAPE_CT7343_19_100UF 16V 7343100UF16V 7343 SMDCT7343_19
D1BAT54CLT1_SOT_23_BAT54CLT1_V-31BAT54CLT1SOT_23
D2SOD80_AP_SOD80_1N4148_V-31070001N4148SOD80
D3SOD80_AP_SOD80_1N4148_V-31070001N4148SOD80
D4BAT54CLT1_SOT_23_BAT54CLT1_V-31BAT54CLT1SOT_23
D5BAT54CLT1_SOT_23_BAT54CLT1_NC_VBAT54CLT1_NCSOT_23
D6ESD9B5VL_WBFBP_02C_ESD9B5VLESD9B5VLWBFBP_02C
D7ESD9B5VL_WBFBP_02C_ESD9B5VLESD9B5VLWBFBP_02C
D8ESD9B5VL_WBFBP_02C_ESD9B5VLESD9B5VLWBFBP_02C
D12SRV05_4TCT_SOT_23_6_SRV05_4TCT_SRV05_4TCTSOT_23_6
D13SRV05_4TCT_SOT_23_6_SRV05_4TCT_SRV05_4TCTSOT_23_6
D14DIODE_DO_214AA_N_P3100SB_V-3115P3100SBDO_214AA_N
D15DIODE_DO_214AC_B340A_V-31030009B340ADO_214AC
D16ESD9B5VL_WBFBP_02C_ESD9B5VLESD9B5VLWBFBP_02C
D17ESD9B5VL_WBFBP_02C_ESD9B5VLESD9B5VLWBFBP_02C
D18ESD9B5VL_WBFBP_02C_ESD9B5VLESD9B5VLWBFBP_02C
D19ESD9B5VL_WBFBP_02C_ESD9B5VLESD9B5VLWBFBP_02C
D20ESD9B5VL_WBFBP_02C_ESD9B5VLESD9B5VLWBFBP_02C
D27ESD9B5VL_WBFBP_02C_ESD9B5VLESD9B5VLWBFBP_02C
D28ESD9B5VL_WBFBP_02C_ESD9B5VLESD9B5VLWBFBP_02C
D29ESD9B5VL_WBFBP_02C_ESD9B5VLESD9B5VLWBFBP_02C
D38DIODE_DO_214AB_SMCJ12A_V-310900SMCJ12ADO_214AB
D39LED_SMT0603_AP_LED_SMT0603_LS_SLS_SP190YG84_5LED_SMT0603
D40ESD9B5VL_WBFBP_02C_ESD9B5VL_NCESD9B5VL_NCWBFBP_02C
ED1DIODEBI_DIR TRIG_ESD0402_AZ582AZ5825-01F_NCESD0402
F1SMD1812P150TF_FUSE1812_SMD1812PSMD1812P150TF_NCFUSE1812
HP_OUT1AZALIAJACK_5_AUDIO6_2SJS351_AUDAUDIOJACK GREENAUDIO6_2SJS351
J1DC_POWER_JACK_0_DC_JACK_SMT_DC_DC_POWER_JACKDC_JACK_SMT
JP1JP_3P_SIP_3P_SIP_3P_V-51130002-SIP_3PSIP_3P
JSPK1WAFER1X2_CON2_85204_WAFER1X21.WAFER1X21.25MM 85204-02001TCON2_85204
J_CTRL12*12PINP=2_1.0 LOCK DIP_HEADER2*12PINP=2.0 90D LOCK DIPHEADER2X12X2MM-H-90
L1L_7M2X6M5X3_AP_L_7M2X6M5X3_1.5U1.5uH/9AL_7M2X6M5X3
L2WSRPG0503_WSRPG0503_2.2UH/5.8A2.2uH/5.8AWSRPG0503
L3WSRPG0503_WSRPG0503_2.2UH/5.8A2.2uH/5.8AWSRPG0503
L4WSRPG0503_WSRPG0503_2.2UH/5.8A2.2uH/5.8AWSRPG0503
L5WSRPG0503_WSRPG0503_2.2UH/5.8A2.2uH/5.8AWSRPG0503
L6INDUCTOR_L0603_180R-100M180R-100ML0603
L7INDUCTOR_L0805_80/1.5A_V-25020080/1.5AL0805
L8INDUCTOR_L0805_80/1.5A_V-25020080/1.5AL0805
L9INDUCTOR_L0603_180R-100M180R-100ML0603
L10INDUCTOR_L0603_180R-100M180R-100ML0603
L11INDUCTOR_L0603_180R-100M180R-100ML0603
L12INDUCTOR_L0805_100/4A_V-2502000100/4AL0805
L13INDUCTOR_L0805_80/1.5A_V-25020080/1.5AL0805
L14INDUCTOR_L_0M80X2M50_2.2UH/1A_V2.2uH/1AL_0M80X2M50
L15INDUCTOR_L0805_100/4A_V-2502000100/4AL0805
L16INDUCTOR_L0603_180R-100M180R-100ML0603
L17INDUCTOR_L0603_180R-100M180R-100ML0603
L18L_7M2X6M5X3_AP_L_7M2X6M5X3_10UH10uH/3AL_7M2X6M5X3
L19L0805_L0805_X_L0805;L0805_APXL0805
L20L_7M2X6M5X3_AP_L_7M2X6M5X3_10UH10uH/3AL_7M2X6M5X3
L21INDUCTOR_L0805_80/1.5A_V-25020080/1.5AL0805
L22INDUCTOR_L0805_80/1.5A_V-25020080/1.5AL0805
L23INDUCTOR_L0805_80/1.5A_V-25020080/1.5AL0805
L24INDUCTOR_L0805_80/1.5A_V-25020080/1.5AL0805
L25INDUCTOR_L0805_80/1.5A_V-25020080/1.5AL0805
L26INDUCTOR_L0805_80/1.5A_V-25020080/1.5AL0805
L27INDUCTOR_L0805_80/1.5A_V-25020080/1.5AL0805
L28INDUCTOR_L0805_80/1.5A_V-25020080/1.5AL0805
L29INDUCTOR_L_0M80X2M50_2.2UH/1.5A2.2uH/1.5A_NCL_0M80X2M50
L30INDUCTOR_L0603_180R-100M180R-100ML0603
L31L0805_L0805_100/4A_V-25020009-0100/4AL0805
L32L0805_L0805_100/4A_V-25020009-0100/4AL0805
L33L0805_L0805_100/4A_V-25020009-0100/4AL0805
L34L0805_L0805_100/4A_V-25020009-0100/4AL0805
MIC_IN1AZALIAJACK_5_AUDIO6_2SJS351_A_1AUDIOJACK PINKAUDIO6_2SJS351
MIPI1H_7_CON39-0D3-FH35C_FPC39PIN 0FPC39pin 0.3mmCON39-0D3-FH35C
OSC1OSC_CRYSTAL_VMK3_32.768KHZ_V-4132.768KHZVMK3
OSC27M20000025_OSC_SMD3M2X2M5_0M65_24MHzOSC_SMD3M2X2M5_0M65
OSC37M20000025_OSC_SMD3M2X2M5_0M6_125.000625MHzOSC_SMD3M2X2M5_0M65
OSC47M20000025_OSC_SMD3M2X2M5_0M6_237.4MHz_NCOSC_SMD3M2X2M5_0M65
OSC57M20000025_OSC_SMD3M2X2M5_0M65_24MHzOSC_SMD3M2X2M5_0M65
PWR1TS7301VH_1_SW_CMOS_3531B_3531B-3531B-050SW_CMOS_3531B
Q1APM1105NUC_TRG_1_SOT_23_2N7002_2N7002SOT_23
Q2APM1105NUC_TRG_1_SOT_23_LP2301LLP2301LT1GSOT_23
Q3BCE_NPN_SOT_23_MMBT3904LT1G_V-3MMBT3904LT1GSOT_23
Q4APM1105NUC_TRG_1_SOT_23_LP230_1LP2301LT1G_NCSOT_23
Q5APM1105NUC_TRG_1_SOT_23_2N700_12N7002_NCSOT_23
Q6APM1105NUC_TRG_1_SOT_23_2N7002_2N7002SOT_23
Q7APM1105NUC_TRG_1_SOT_23_2N7002_2N7002SOT_23
Q8APM1105NUC_TRG_1_SOT_23_2N7002_2N7002SOT_23
Q9APM1105NUC_TRG_1_SOT_23_2N7002_2N7002SOT_23
Q10APM1105NUC_TRG_1_SOT_23_2N700_12N7002_NCSOT_23
Q11APM1105NUC_TRG_1_SOT_23_2N7002_2N7002SOT_23
Q12BCE_NPN_SOT_23_MMBT3904LT1G_V-3MMBT3904LT1GSOT_23
Q13BCE_NPN_SOT_23_MMBT3904LT1G_V-3MMBT3904LT1GSOT_23
Q14BCE_NPN_SOT_23_MMBT3904LT1G_V-3MMBT3904LT1GSOT_23
Q15BCE_NPN_SOT_23_MMBT3904LT1G_V-3MMBT3904LT1GSOT_23
Q16BCE_NPN_SOT_23_MMBT3904LT1G_V-3MMBT3904LT1GSOT_23
Q26APM1105NUC_TRG_1_SOT_23_2N7002_2N7002SOT_23
Q27BCE_NPN_SOT_23_MMBT3904LT1G_NC_MMBT3904LT1G_NCSOT_23
RTCBAT1WAFER1X2_CON2_85204_WAFER1X21.WAFER1X21.25MM 85204-02001TCON2_85204
TPD1TPCONN_0_FPC10PIN_UP2D0_A_FPC1FPC10Pin 0.5MM upperFPC10PIN_UP2D0_A
TP_WX1TP_WX1_TP_WX1_TP_WX1TP_WX1TP_WX1
U1SI4488DY_SOIC_8_AO4423_AO4423SOIC_8
U2TPS54227_SOP_8_EP2M90X2M00_TPS5TPS54527SOP_8_EP2M90X2M00
U3APL1117_33_SOT_223_APL1117_33_VAPL1117_33SOT_223
U4PMIC_RK808_QFN68-7X7_RK808-BRK808-BQFN68-7X7
U5DSP_RK3368_BGA453_19R00X19R00X1DSP_RK3368BGA453_19R00X19R00X1R40
U6DDR3_16BIT_FBGA_96_1M10_R14_128128x16bitFBGA_96_1M10_R14
U7DDR3_16BIT_FBGA_96_1M10_R14_128128x16bitFBGA_96_1M10_R14
U8DDR3_16BIT_FBGA_96_1M10_R14_128128x16bitFBGA_96_1M10_R14
U9DDR3_16BIT_FBGA_96_1M10_R14_128128x16bitFBGA_96_1M10_R14
U10TLV70025DDCR_SOT_23_5_N_TLV7001TLV70018DDCRSOT_23_5_N
U11KLMAG2GEAC_B001_FBGA_153_1M2_R1KLMAG2GEAC_B001FBGA_153_1M2_R10
U12TPS2042BD_SOIC_8_TPS2052BD_V-32TPS2052BDSOIC_8
U13USB2514B_AEZ_QFN_36_EP3M85_USB2USB2514B_AEZQFN_36_EP3M85
U14RTL8211F_QFN_40_EPAD3M60_RTL821RTL8211F-CGQFN_40_EPAD3M60
U15H5007_SOP24-40-280X160_TRANSFORTRANSFORMER1000M SMD24SOP24-40-280X160
U16RCLAMP0524P_QFN10_20_40X24_RCLARCLAMP0524PAQFN10QFN10_20_40X24
U17RCLAMP0524P_QFN10_20_40X24_RCLARCLAMP0524PAQFN10QFN10_20_40X24
U18RCLAMP0524P_QFN10_20_40X24_RCLARCLAMP0524PAQFN10QFN10_20_40X24
U19LEDDRIVE-BL_SOT23_6_1M10_MP148MP1488/UP6003AMT6SOT23_6_1M10
U2074LVC1GU04GW_TSSOP_5_NC//74LVC1NC//74LVC1GU04GWTSSOP_5
U21MP5610_QFN10-0D4-1D8X1D4X0D6_MPMP5610QFN10-0D4-1D8X1D4X0D6
U22ALC5651_QFN_40_5X5_ALC5651ALC5651QFN_40_5X5
U23LM4990_MSOP_8_PT5305PT5305MSOP_8
U24AP6335_QFN_44_AP6335_NCAP6335_NCQFN_44
U25MAX809SD_SOT_23_NC/MAX809RDNC/MAX809RDSOT_23
U26RCLAMP0524P_QFN10_20_40X24_RC_1RClamp0524PATCTQFN10QFN10_20_40X24
U27RCLAMP0524P_QFN10_20_40X24_RC_1RClamp0524PATCTQFN10QFN10_20_40X24
U28RCLAMP0524P_QFN10_20_40X24_RC_1RClamp0524PATCTQFN10QFN10_20_40X24
U29RCLAMP0524P_QFN10_20_40X24_RC_1RClamp0524PATCTQFN10QFN10_20_40X24
U30SN74CB3Q3384A_TSSOP_24_SN74CB3QSN74CB3Q3384A_NCTSSOP_24
U31RCLAMP0524P_QFN10_20_40X24_RC_1RClamp0524PATCTQFN10QFN10_20_40X24
U32RCLAMP0524P_QFN10_20_40X24_RC_1RClamp0524PATCTQFN10QFN10_20_40X24
USB1USB2X1_USB_WLUS225A_USBSINKINGUSBSINKING DIPUSB_WLUS225A
USB2USB2X1_USB_WLUS225A_USBSINKINGUSBSINKING DIPUSB_WLUS225A
USB3USB2X1_USB_WLUS225A_USBSINKINGUSBSINKING DIPUSB_WLUS225A
USB4USB2X1_USB_WLUS225A_USBSINKINGUSBSINKING DIPUSB_WLUS225A
VOL_DOWN1TS7301VH_SW_P2_TS7301_TS7301VHTS7301VHSW_P2_TS7301
VOL_UP1TS7301VH_SW_P2_TS7301_TS7301VHTS7301VHSW_P2_TS7301
WIFI_ANT1CON_IPEX_1_ANT-JACK_3PINANT JA3PinANT JACK_NCANT-JACK
老吴 发表于 2024-12-12 11:18
PCB文件。回复可见下载
**** Hidden Message *****
earth天王 发表于 2024-12-12 13:35
来学习学习
yjlinhai 发表于 2024-12-12 13:47
看看,学习学习,下载一下
bingshuihuo 发表于 2024-12-12 13:47
学习学习,下载一下
kenxjy 发表于 2024-12-12 13:52
谢谢分享!
yjlinhai 发表于 2024-12-12 14:07
要二级才能下载呢
yang96019 发表于 2024-12-12 15:12
:D:D:D:D:D:D:D:D:D:D
eagle1986 发表于 2024-12-12 16:57
:victory: 多谢老吴分享,学习学习
lf2k2022 发表于 2024-12-12 19:15
页: [1] 2 3 4 5 6 7
查看完整版本: RK3368方案锐捷网络RG-SmartRain200V2_PAD_V100 智能云终端电脑PCB
