16层PCB设计 XCVM1402_VFVC1596 +AFE58JD48ZBV+TX7516ZCX
REFDESCOMP_DEVICE_TYPESYM_NAME
BT1BUTTON-SKQGABE010,5100155,SKQGAFE010-SKQGAFE010SKQGAFE010
BUFFER_D3V3TP1-NCONPCB_1MM
D1BAT54C-5100298,BAT54C,SOT_3_3M1X1M5X1M3_0M95-SOT_3_3M1X1M5X1M3_0M95SOT_3_3M1X1M5X1M3_0M95
D2DIODE-S320,200VSMB
D3DIODE-S320,200VSMB
D6DIODE-MBR0580S1-7,80VSOD123
DS1LED-SS_0603E_GSC_Z_B3_H,5100158,LED0603-LED0603LED0603
DS14LED-SS_0603E_GSC_Z_B3_H,5100158,LED0603-LED0603LED0603
J1PIN_HEADER_25-DF9-25S-1VDF9-25S-1V
J2PIN_HEADER_6-DF14A-6P-1.25H(25)DF14A_6P_1_25H
J3SHEILD-5200494SHEILD_BASE
J4AIRMAX_POWER_4PIN-5200333,10028917-001LF,AIR_POWER_M-AIR_POWER_MAIR_POWER_M
J5SHEILD-5200494SHEILD_BASE
J6AIRMAX_POWER_4PIN-5200333,10028917-001LF,AIR_POWER_M-AIR_POWER_MAIR_POWER_M
J7AIRMAX_POWER_4PIN-5200333,10028917-001LF,AIR_POWER_M-AIR_POWER_MAIR_POWER_M
J8AIRMAX_GUIDE-3002631,TU-GUIDE-RT,AIRMAX_GUIDE_F-AIRMAX_GUIDE_FAIRMAX_GUIDE_F
J9INS-3200891,R11073-093,INS-INSINS
J10SHEILD-5200494SHEILD_BASE
J11SHEILD-5200494SHEILD_BASE
J12SHEILD-5200494SHEILD_BASE
J13INS-3200891,R11073-093,INS-INSINS
J14AIRMAX_GUIDE-3002631,TU-GUIDE-RT,AIRMAX_GUIDE_F-AIRMAX_GUIDE_FAIRMAX_GUIDE_F
J15SHEILD-5200494SHEILD_BASE
J16SHEILD-5200494SHEILD_BASE
J17SHEILD-5200494SHEILD_BASE
J18ROUND_ROLL-3200892,RRP-312RRP_312
J19ROUND_ROLL-3200892,RRP-312RRP_312
J20MPACS_125PIN-5200328,HM2R65PA5108N9LF,MPACS_125PIN-MPACS_125PINMPACS_125PIN
J21MPACS_125PIN-5200328,HM2R65PA5108N9LF,MPACS_125PIN-MPACS_125PINMPACS_125PIN
J22AIRMAX_VS2_54PIN-5200331,10122643-101LF,VS2_54PIN_F-VS2_54PIN_FVS2_54PIN_F
J23CON2-5200022,A2001WV_S_02PD01,A2001WV_S_02PD01-A2001WV_S_02PD01A2001WV_S_02PD01
J24PIN_HEADER_4-A2001WV_S_04PD01A2001WV_S_04PD01
J25SHEILD-5200494SHEILD_BASE
J26CONN_6PIN-5200172,A1250WV-S-6P,A1250WV-S-6P-A1250WV-S-6PA1250WV-S-6P
J27PCIE_X16-PCIE_164,PCIE-164-02-F-D-TH,5200381-PCIE_164PCIE_164
L1INDUCTOR-10UH_4300MA,4300MAL_2_10M3X10M3X4M5_8M
L3BEAD-BLM31PG121SN1L,3A3216
L4BEAD-BLM31PG121SN1L,3A3216
L8INDUCTOR-6.8UH,7.4AIHLP-3232DZ-01
L9BEAD-BLM31PG121SN1L,3A3216
L10BEAD-BLM31PG121SN1L,3A3216
M1MECHANICAL_HOLE-5300219,ISO3*6,SCREW-SCREWSCREW
M2MECHANICAL_HOLE-5300424,9774040151,VIA_PAD7_5R_3_7D-VIA_PAD7_5R_3_7DVIA_PAD7_5R_3_7D
M3MECHANICAL_HOLE-5300219,ISO3*6,SCREW-SCREWSCREW
M4MECHANICAL_HOLE-5300424,9774040151,VIA_PAD7_5R_3_7D-VIA_PAD7_5R_3_7DVIA_PAD7_5R_3_7D
M5MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M6MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M7MECHANICAL_HOLE-5300424,9774040151,VIA_PAD7_5R_3_7D-VIA_PAD7_5R_3_7DVIA_PAD7_5R_3_7D
M8MECHANICAL_HOLE-5300424,9774040151,VIA_PAD7_5R_3_7D-VIA_PAD7_5R_3_7DVIA_PAD7_5R_3_7D
M9MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M10MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M11MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M12MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M13MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M14MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M15MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M16MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M17MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M18MECHANICAL_HOLE-5300424,9774040151,VIA_PAD7_5R_3_7D-VIA_PAD7_5R_3_7DVIA_PAD7_5R_3_7D
M19MECHANICAL_HOLE-5300424,9774040151,VIA_PAD7_5R_3_7D-VIA_PAD7_5R_3_7DVIA_PAD7_5R_3_7D
M20MECHANICAL_HOLE-5300424,9774040151,VIA_PAD7_5R_3_7D-VIA_PAD7_5R_3_7DVIA_PAD7_5R_3_7D
M21MECHANICAL_HOLE-5300424,9774040151,VIA_PAD7_5R_3_7D-VIA_PAD7_5R_3_7DVIA_PAD7_5R_3_7D
M22MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M23MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M24MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M25MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M26MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M27MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M28MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M29MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M30MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M31MECHANICAL_HOLE-5300424,9774040151,VIA_PAD7_5R_3_7D-VIA_PAD7_5R_3_7DVIA_PAD7_5R_3_7D
M32MECHANICAL_HOLE-5300424,9774040151,VIA_PAD7_5R_3_7D-VIA_PAD7_5R_3_7DVIA_PAD7_5R_3_7D
M33MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M34MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M35MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M36MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M37MECHANICAL_HOLE-5300147,LD-B2039-C002T-01,M_5M5X1M5IN1M1-M_5M5X1M5IN1M1M_5M5X1M5IN1M1
M38MECHANICAL_HOLE-5300424,9774040151,VIA_PAD7_5R_3_7D-VIA_PAD7_5R_3_7DVIA_PAD7_5R_3_7D
M39MECHANICAL_HOLE-5300424,9774040151,VIA_PAD7_5R_3_7D-VIA_PAD7_5R_3_7DVIA_PAD7_5R_3_7D
Q1EL817S1_A__TU__F-EVERLIGHT,EL817S1(A)(TU)-F,5100178SOP254P1030X390-4N
Q3MOSFET-2SK1829,5100165,2SK1829-2SK18292SK1829
Q4MOSFET-2SK1829,5100165,2SK1829-2SK18292SK1829
Q5MOSFET-IRLML6402TRPBF,5100149,SOT23_3PIN-SOT23_3PINSOT23_3PIN
Q6MOSFET-2N7002,5100150,SOT23_3PIN-SOT23_3PINSOT23_3PIN
Q7MOSFET-2SK1829,5100165,2SK1829-2SK18292SK1829
Q8MOSFET-2SK1829,5100165,2SK1829-2SK18292SK1829
Q9MOSFET-2SK1829,5100165,2SK1829-2SK18292SK1829
U1SN65LVDS117DGG-SN65LVDS117DGG,5001177,DGG64,TI-DGG64DGG64
U2SN65LVDS117DGG-SN65LVDS117DGG,5001177,DGG64,TI-DGG64DGG64
U3CDCLVD1204-5000603,LMK1D1204,QFN4X4-QFN4X4QFN4X4
U4SG_8018CG-5001184OSC_3M2X2M5X0M8
U5XCVM1402_VFVC1596-VFVC1596VFVC1596
U6CDCLVD1204-5000603,LMK1D1204,QFN4X4-QFN4X4QFN4X4
U7CDCLVD1204-5000603,LMK1D1204,QFN4X4-QFN4X4QFN4X4
U8TPS7A33-5000167,TPS7A3301RGWT,QFN5X5-QFN5X5QFN5X5
U9ISL80102-ISL80102IRAJZ,5000100,DFN3MX3M-DFN3MX3MDFN3MX3M
U10TPS7A47-5000340,TPS7A4701RGWT,QFN5X5-QFN5X5QFN5X5
U11TPS7A33-5000167,TPS7A3301RGWT,QFN5X5-QFN5X5QFN5X5
U12ISL80102-ISL80102IRAJZ,5000100,DFN3MX3M-DFN3MX3MDFN3MX3M
U13TPS7A47-5000340,TPS7A4701RGWT,QFN5X5-QFN5X5QFN5X5
U14ADS7830-5000137,ADS7830IPWRTSSOP-16
U15OPA_DUAL-SOIC_8_4MX5MX1M75_1M27,TLC2272ACD,5000024-SOIC_8_4MX5MX1M75_1M27SOIC_8_4MX5MX1M75_1M27
U16AT24C02-5000098,AT24C02C_SSHM_T,SOIC_8PIN-SOIC_8PINSOIC_8PIN
U17TMP75-5000458,TMP75AIDGKT,MSOP8-MSOP8MSOP8
U18LMK1D1208-5000611,LMK1D1208RHA,VQFN29_5M0_5M0_1M0_0M5-VQFN29_5M0_5M0_1M0_0M5VQFN29_5M0_5M0_1M0_0M5
U19LMK1D1208-5000611,LMK1D1208RHA,VQFN29_5M0_5M0_1M0_0M5-VQFN29_5M0_5M0_1M0_0M5VQFN29_5M0_5M0_1M0_0M5
U20TPS62933FDRLR_SMD-TPS62933FDRLRSOT_33DRLR_TEX
U21ISL80102-ISL80102IRAJZ,5000100,DFN3MX3M-DFN3MX3MDFN3MX3M
U22LTM30AIY#PBF_SMD-LTM4630AIY#PBFBGA144_16X16_ADI
U23ISL80102-ISL80102IRAJZ,5000100,DFN3MX3M-DFN3MX3MDFN3MX3M
U24CRYSTAL-32.768KHZFC135327680KAA3
U25MT40A512M16-5000538,IS43QR16256B-083RBLI,FBGA96-FBGA96FBGA96
U26MT25QU-5000445,MT25QU01GBBB8ESF-0SIT,WSOIC_16PIN-WSOIC_16PINWSOIC_16PIN
U27LTM4644-BGA77_15P00X9P00X5P01_ADIBGA77_15P00X9P00X5P01_ADI
U28ISL80101-ISL80101IRAJZ,5000010,DFN3MX3M-DFN3MX3MDFN3MX3M
U29MT40A512M16-5000538,IS43QR16256B-083RBLI,FBGA96-FBGA96FBGA96
U30LTM4644-BGA77_15P00X9P00X5P01_ADIBGA77_15P00X9P00X5P01_ADI
U31CDCLVD1204-5000603,LMK1D1204,QFN4X4-QFN4X4QFN4X4
U32FXO_LC735-AK7DAF1-200.0000T2,200MHZ,5100846,OSC_6PIN-OSC_6PINOSC_6PIN
U33CDCLVD1204-5000603,LMK1D1204,QFN4X4-QFN4X4QFN4X4
U34LMK1D1208-5000611,LMK1D1208RHA,VQFN29_5M0_5M0_1M0_0M5-VQFN29_5M0_5M0_1M0_0M5VQFN29_5M0_5M0_1M0_0M5
U35ISL80102-ISL80102IRAJZ,5000100,DFN3MX3M-DFN3MX3MDFN3MX3M
U36LMK04800-5000134,LMK04803BISQE,QFN_65_9MX9MX1M_0M5_EP6M35-QFN_65_9MX9MX1M_0M5_EP6M35QFN_65_9MX9MX1M_0M5_EP6M35
U37ISL80102-ISL80102IRAJZ,5000100,DFN3MX3M-DFN3MX3MDFN3MX3M
U38ISL80102-ISL80102IRAJZ,5000100,DFN3MX3M-DFN3MX3MDFN3MX3M
U39ISL80102-ISL80102IRAJZ,5000100,DFN3MX3M-DFN3MX3MDFN3MX3M
U40CDCLVC1104-5000612,LMK1C1104PWR,TSSOP8-TSSOP8TSSOP8
U41TPS7A47-5000340,TPS7A4701RGWT,QFN5X5-QFN5X5QFN5X5
U42TPS7A47-5000340,TPS7A4701RGWT,QFN5X5-QFN5X5QFN5X5
U43TPS7A47-5000340,TPS7A4701RGWT,QFN5X5-QFN5X5QFN5X5
U44TPS7A47-5000340,TPS7A4701RGWT,QFN5X5-QFN5X5QFN5X5
U45ISL80102-ISL80102IRAJZ,5000100,DFN3MX3M-DFN3MX3MDFN3MX3M
U46ISL80102-ISL80102IRAJZ,5000100,DFN3MX3M-DFN3MX3MDFN3MX3M
U47ISL80102-ISL80102IRAJZ,5000100,DFN3MX3M-DFN3MX3MDFN3MX3M
U48TPS7A47-5000340,TPS7A4701RGWT,QFN5X5-QFN5X5QFN5X5
U49TPS7A47-5000340,TPS7A4701RGWT,QFN5X5-QFN5X5QFN5X5
U50ISL80102-ISL80102IRAJZ,5000100,DFN3MX3M-DFN3MX3MDFN3MX3M
U51TPS7A47-5000340,TPS7A4701RGWT,QFN5X5-QFN5X5QFN5X5
U52TPS7A47-5000340,TPS7A4701RGWT,QFN5X5-QFN5X5QFN5X5
U53CDCLVC1104-5000612,LMK1C1104PWR,TSSOP8-TSSOP8TSSOP8
U54TPS3808-5000253,TPS3808G01DBVT,SOT23_6PIN-SOT23_6PINSOT23_6PIN
U55LMK1D1208-5000611,LMK1D1208RHA,VQFN29_5M0_5M0_1M0_0M5-VQFN29_5M0_5M0_1M0_0M5VQFN29_5M0_5M0_1M0_0M5
U56LMK1D1208-5000611,LMK1D1208RHA,VQFN29_5M0_5M0_1M0_0M5-VQFN29_5M0_5M0_1M0_0M5VQFN29_5M0_5M0_1M0_0M5
U57REF5050-5000259,REF5025IDGKT,MSOP_8PIN-MSOP_8PINMSOP_8PIN
U58ISL80102-ISL80102IRAJZ,5000100,DFN3MX3M-DFN3MX3MDFN3MX3M
U59ISL80102-ISL80102IRAJZ,5000100,DFN3MX3M-DFN3MX3MDFN3MX3M
U60OPA_DUAL-SOIC_8_4MX5MX1M75_1M27,TLC2272ACD,5000024-SOIC_8_4MX5MX1M75_1M27SOIC_8_4MX5MX1M75_1M27
U61TVS-5100402SOT_23
U62DAC7811-5000128,DAC7811IDGS,MSOP10-MSOP10MSOP10
U63OPA_DUAL-SOIC_8_4MX5MX1M75_1M27,LMP7718MA,5000138-SOIC_8_4MX5MX1M75_1M27SOIC_8_4MX5MX1M75_1M27
U64THS4521IDGK-MSOP8,THS4131IDGK,5000250-MSOP8MSOP8
U65TPS7A33-5000167,TPS7A3301RGWT,QFN5X5-QFN5X5QFN5X5
U66TPS7A47-5000340,TPS7A4701RGWT,QFN5X5-QFN5X5QFN5X5
U68LTM4646-5000513BGA88_15X11M25-1M27P
U69SN74LV1T125-5000362,SN74LV1T125DBVR,SOT23_5PIN-SOT23_5PINSOT23_5PIN
U70SN74LV1T125-5000362,SN74LV1T125DBVR,SOT23_5PIN-SOT23_5PINSOT23_5PIN
U71TX7516-5000596,TX7516ZCX,NFBGA144_10X10-0M8P-NFBGA144_10X10-0M8PNFBGA144_10X10-0M8P
U72TX7516-5000596,TX7516ZCX,NFBGA144_10X10-0M8P-NFBGA144_10X10-0M8PNFBGA144_10X10-0M8P
U73TX7516-5000596,TX7516ZCX,NFBGA144_10X10-0M8P-NFBGA144_10X10-0M8PNFBGA144_10X10-0M8P
U74TX7516-5000596,TX7516ZCX,NFBGA144_10X10-0M8P-NFBGA144_10X10-0M8PNFBGA144_10X10-0M8P
U75TX7516-5000596,TX7516ZCX,NFBGA144_10X10-0M8P-NFBGA144_10X10-0M8PNFBGA144_10X10-0M8P
U76TX7516-5000596,TX7516ZCX,NFBGA144_10X10-0M8P-NFBGA144_10X10-0M8PNFBGA144_10X10-0M8P
U77TX7516-5000596,TX7516ZCX,NFBGA144_10X10-0M8P-NFBGA144_10X10-0M8PNFBGA144_10X10-0M8P
U78TX7516-5000596,TX7516ZCX,NFBGA144_10X10-0M8P-NFBGA144_10X10-0M8PNFBGA144_10X10-0M8P
U79TX7516-5000596,TX7516ZCX,NFBGA144_10X10-0M8P-NFBGA144_10X10-0M8PNFBGA144_10X10-0M8P
U80TX7516-5000596,TX7516ZCX,NFBGA144_10X10-0M8P-NFBGA144_10X10-0M8PNFBGA144_10X10-0M8P
U81TX7516-5000596,TX7516ZCX,NFBGA144_10X10-0M8P-NFBGA144_10X10-0M8PNFBGA144_10X10-0M8P
U82TX7516-5000596,TX7516ZCX,NFBGA144_10X10-0M8P-NFBGA144_10X10-0M8PNFBGA144_10X10-0M8P
U83TX7516-5000596,TX7516ZCX,NFBGA144_10X10-0M8P-NFBGA144_10X10-0M8PNFBGA144_10X10-0M8P
U84TX7516-5000596,TX7516ZCX,NFBGA144_10X10-0M8P-NFBGA144_10X10-0M8PNFBGA144_10X10-0M8P
U85TX7516-5000596,TX7516ZCX,NFBGA144_10X10-0M8P-NFBGA144_10X10-0M8PNFBGA144_10X10-0M8P
U86TX7516-5000596,TX7516ZCX,NFBGA144_10X10-0M8P-NFBGA144_10X10-0M8PNFBGA144_10X10-0M8P
U87AFE5848-5000481,AFE58JD48ZBV,BGAP289-BGAP289BGAP289
U88AFE5848-5000481,AFE58JD48ZBV,BGAP289-BGAP289BGAP289
U89AFE5848-5000481,AFE58JD48ZBV,BGAP289-BGAP289BGAP289
U90AFE5848-5000481,AFE58JD48ZBV,BGAP289-BGAP289BGAP289
U91AFE5848-5000481,AFE58JD48ZBV,BGAP289-BGAP289BGAP289
U92AFE5848-5000481,AFE58JD48ZBV,BGAP289-BGAP289BGAP289
U93AFE5848-5000481,AFE58JD48ZBV,BGAP289-BGAP289BGAP289
U94AFE5848-5000481,AFE58JD48ZBV,BGAP289-BGAP289BGAP289
U9574AVCH1T45DBVRE4_SMD-74AVCH1T45DBVRE4,,74AVCH1T45DBVRE4DBV0006A_N
U96TVS-5100402SOT_23
U9774AVCH4T245RGYRG4_SMD-74AVCH4T245RGYRG4RGY16_2P55X2P05
U98CDCLVC1104-5000612,LMK1C1104PWR,TSSOP8-TSSOP8TSSOP8
U9974AVCH4T245RGYRG4_SMD-74AVCH4T245RGYRG4RGY16_2P55X2P05
U10074AVCH4T245RGYRG4_SMD-74AVCH4T245RGYRG4RGY16_2P55X2P05
U10174AVCH1T45DBVRE4_SMD-74AVCH1T45DBVRE4,,74AVCH1T45DBVRE4DBV0006A_N
U102TCA6408ARSVR_SMD-TCA6408ARSVRRSV16
U10374AVCH4T245RGYRG4_SMD-74AVCH4T245RGYRG4RGY16_2P55X2P05
U10474AVCH4T245RGYRG4_SMD-74AVCH4T245RGYRG4RGY16_2P55X2P05
U10574AVCH4T245RGYRG4_SMD-74AVCH4T245RGYRG4RGY16_2P55X2P05
U10674AVCH1T45DBVRE4_SMD-74AVCH1T45DBVRE4,,74AVCH1T45DBVRE4DBV0006A_N
U10774AVCH1T45DBVRE4_SMD-74AVCH1T45DBVRE4,,74AVCH1T45DBVRE4DBV0006A_N
U10874AVCH4T245RGYRG4_SMD-74AVCH4T245RGYRG4RGY16_2P55X2P05
U10974AVCH4T245RGYRG4_SMD-74AVCH4T245RGYRG4RGY16_2P55X2P05
U11074AVCH1T45DBVRE4_SMD-74AVCH1T45DBVRE4,,74AVCH1T45DBVRE4DBV0006A_N
U11174AVCH1T45DBVRE4_SMD-74AVCH1T45DBVRE4,,74AVCH1T45DBVRE4DBV0006A_N
U11274AVCH4T245RGYRG4_SMD-74AVCH4T245RGYRG4RGY16_2P55X2P05
U11374AVCH1T45DBVRE4_SMD-74AVCH1T45DBVRE4,,74AVCH1T45DBVRE4DBV0006A_N
U11474AVCH1T45DBVRE4_SMD-74AVCH1T45DBVRE4,,74AVCH1T45DBVRE4DBV0006A_N
U11574AVCH1T45DBVRE4_SMD-74AVCH1T45DBVRE4,,74AVCH1T45DBVRE4DBV0006A_N
U116TPS51206DSQT_SMDDSQ0010A
U11774AVCH1T45DBVRE4_SMD-74AVCH1T45DBVRE4,,74AVCH1T45DBVRE4DBV0006A_N
U11874AVCH1T45DBVRE4_SMD-74AVCH1T45DBVRE4,,74AVCH1T45DBVRE4DBV0006A_N
U119TCA9617-5000366,TCA9617ADGKR,VSSOP_8PIN-VSSOP_8PINVSSOP_8PIN
U12074AVCH1T45DBVRE4_SMD-74AVCH1T45DBVRE4,,74AVCH1T45DBVRE4DBV0006A_N
U12174AVCH4T245RGYRG4_SMD-74AVCH4T245RGYRG4RGY16_2P55X2P05
U12274AVCH1T45DBVRE4_SMD-74AVCH1T45DBVRE4,,74AVCH1T45DBVRE4DBV0006A_N
U12374AVCH4T245RGYRG4_SMD-74AVCH4T245RGYRG4RGY16_2P55X2P05
U12474AVCH4T245RGYRG4_SMD-74AVCH4T245RGYRG4RGY16_2P55X2P05
U125TPS54331D-TPS54331DSOIC8_4MX5M-1M27P
PCB文件。回复可见下载
**** Hidden Message *****
好东西,学习一下 学习学习一下 新人报道,学习一下:lol 回复一下看看PCB 好东西,学习一下,谢谢分享!!! :D:D:D:D:(:( 谢谢分享,好好学习 谢谢分享
