pcb112233 发表于 2025-6-8 09:27
VITA STANDARDS LIST,VITA 最新标准清单大全下载_ansi vita
Designation                Title
VMEbus Handbook, 4th Edition
ANSI/VITA 1-1994 (S2021)        VME64
ANSI/VITA 1.1-1997 (S2021)        VME64 Extensions
ANSI/VITA 1.3-1997 (S2021)        VME64x 9U x 400mm Format
ANSI/VITA 1.5-2003 (S2014)        VME 2eSST
ANSI/VITA 1.6-2000 (S2021)        Keying for Conduction Cooled VME64x
ANSI/VITA 1.7-2003 (S2014)        Increased Current Level for 96 Pin &160 Pin DIN/IEC Connector
VITA 3-1995 (S2022)                Board Level Live Insertion for VMEbus
VITA 4-1995 (S2022)                IP Modules
VITA 4.1-1996 (S2022)        IP I/O Mapping to VME64x
VITA 5.1-1999 (S2022)        RACEway Interlink on VME
VITA 6-1994 (S2022)                Signal Computing System Architecture (SCSA) on VME
VITA 6.1-1996 (S2022)        Extensions to ANSI/VITA 6-1994 Signal Computing System Architecture
VITA 10-1995 (W2012)        SkyChannel Packet on VME P2
VITA 12-1997 (S2022)        M-Module
VITA 13-1995 (W2006)        VMEbus Pin Assignment Standard for ISO/IEC 14575 (IEEE Std. 1355-1995 (H.I.C.))
VITA 17-1998 (S2022)        Front Panel Data Port (FPDP)
ANSI/VITA 17.1-2015 (R2022)        Serial Front Panel Data Port
ANSI/VITA 17.3-2018        Serial Front Panel Data Port (sFPDP) Gen 3.0         Serial Front Panel Data Port (sFPDP) Gen 3.0
VITA 19.1-1998 (W2006)        BusNet Media Access Control (MAC) Standard
VITA 19.2-1998 (W2006)        BusNet Link Layer Control (LLC) Standard
ANSI/VITA 20-2005 (S2018)        Conduction Cooled PMC
VITA 23-1998 (S2022)        VME64 Extensions for Physics and Other Applications
VITA 25-1998 (W2006)        VISION (Versatile I/O Software Interface for Open-bus Networks)
VITA 26-1998 (S2022)        Myrinet-on-VME Protocol Standard
VITA 29-2001 (W2006)        PC*MIP
VITA 30-2000 (S2022)        2mm Equipment Practice for Eurocard Systems
VITA 30.1-2008 (S2022)        2mm Connector Practice on Conduction Cooled Euroboards
VITA 30.2-2001 (IEC)                Power Connector Equipment Practice
VITA 31.1-2003 (S2022)        Gigabit Ethernet on VME64x Backplanes
ANSI/VITA 32-2003 (S2014)        Processor PMC
ANSI/VITA 35-2000 (S2021)        PMC-P4 Pin Out Mapping to VME-P0 and VME64x-P2
VITA 38-2003 (S2022)        System Management on VME
VITA 39-2003 (S2022)        PCI-X for PMC and Processor PMC
ANSI/VITA 40-2020                Service and Status Indicator Standard         Service and Status Indicator Standard
VITA 41.0-2006 (S2022)        VXS VMEbus Switched Serial Standard
VITA 41.1-2006 (S2022)        VXS 4X InfiniBand ™Protocol Layer Standard
VITA 41.2-2006 (S2022)        VXS 4X Serial RapidIO Protocol Layer Standard
VITA 41.6-2009 (S2022)        VXS 1X Gigabit Ethernet Control Channel Layer Standard
ANSI/VITA 42.0-2021        XMC: Switched Mezzanine Card (XMC) Auxiliary Standard
VITA 42.1-2006 (S2022)        XMC Parallel RapidIO 8/16 LP-LVDS Protocol Layer Standard
ANSI/VITA 42.2-2006 (S2018)        XMC Serial RapidIO Protocol Layer Standard
ANSI/VITA 42.3-2020        XMC PCI Express Protocol Layer Standard
ANSI/VITA 42.6-2009 (S2024)        XMC 10 Gigabit Ethernet 4-Lane Protocol Layer Standard
ANSI/VITA 46.0-2023 +Errata        VPX Baseline Standard
ANSI/VITA 46.1-2007 (S2018)        VMEbus Signal Mapping on VPX
ANSI/VITA 46.3-2012 (S2024)        Serial RapidIO on VPX Fabric Connector
ANSI/VITA 46.4-2012 (S2025)        PCI Express ®on the VPX Fabric Connector
ANSI/VITA 46.6-2013 (S2025)        Gigabit Ethernet Control Plane on VPX
ANSI/VITA 46.7-2012 (S2024)        Ethernet on VPX Fabric Connector
ANSI/VITA 46.9-2018 (R2024)        PMC/XMC Rear I/O Fabric Signal Mapping on 3U and 6U VPX Modules Standard
ANSI/VITA 46.10-2009 (S2024)        Rear Transition Module for VPX
ANSI/VITA 46.11-2022        System Management on VPX
ANSI/VITA 46.30-2020        Higher Data Rate VPX
ANSI/VITA 46.31-2025        Higher Data Rate VPX - Solder Tail in Blind via
VITA 47 Bundle                VITA 47 Standards Package         Construction, Safety, and Quality for Plug-In Modules Standard
ANSI/VITA 47.0-2019        Construction, Safety, and Quality for Plug-In Modules Standard
ANSI/VITA 47.1-2025        Common Requirements for Environments, Design and Construction, Safety, and Quality Standard
ANSI/VITA 47.2-2019        Class 2 Requirements for Environments, Design and Construction, Safety, and Quality Standard
ANSI/VITA 47.3-2019        Class 3 Requirements for Environments, Design and Construction, Safety, and Quality Standard
ANSI/VITA 48.0-2022        Mechanical Standard for Microcomputers using Ruggedized Enhanced Design Implementation (REDI)
ANSI/VITA 48.1-2020        "Mechanical Standard for VPX REDI Air Cooling"
ANSI/VITA 48.2-2022        "Mechanical Standard for VPX REDI Conduction Cooling"
ANSI/VITA 48.4-2022        "Mechanical Standard for VPX REDI Liquid Flow Through Cooling"
ANSI/VITA 48.5-2010 (R2017)        "Mechanical Standard for VPX REDI Air Flow Through Cooling, 1.52 ""Pitch"
ANSI/VITA 48.7-2023        "Mechanical Standard for VPX REDI Air Flow-By ™Cooling"
ANSI/VITA 48.8-2022        "Mechanical Standard for VPX REDI Air Flow Through Cooling, 1.0 ""to 1.5 ""Pitches"
ANSI/VITA 49.0-2015 (R2021)        VITA Radio Transport (VRT) Standard
ANSI/VITA 49.1-2015 (R2021)        VITA Radio Link Layer (VRL) Standard
ANSI/VITA 49.2-2017 (R2024)        "VITA Radio Transport (VRT) Standard for Electromagnetic Spectrum: Signals and Applications"
ANSI/VITA 49A-2015 (R2021)        Spectrum Survey Interoperability Standard
ANSI/VITA 51.0-2012 (S2024)        Reliability Prediction
ANSI/VITA 51.1-2013 (S2025)        Reliability Prediction MIL-HDBK-217 Subsidiary
ANSI/VITA 51.2-2016 (R2025)        Physics of Failure Reliability Predictions
ANSI/VITA 51.3-2010 (S2024)        Qualification and Environmental Stress Screening in Support of Reliability Predictions
IEEE Std 2818-2024/VITA 51.4-2024        Reliability Component Stress Analysis and Derating
VITA 53.0-2010 (S2022)        Standard for Commercial Technology Market Surveillance
VITA 57 Bundle                VITA 57 FMC and FMC+ Bundle
ANSI/VITA 57.1-2019 + Errata        FPGA Mezzanine Card (FMC) Standard
ANSI/VITA 57.4-2018 + Errata        FPGA Mezzanine Card Plus (FMC+) Standard
VITA 58.0-2009 (S2022)        Line Replaceable Integrated Electronics Chassis Standard
VITA 58.1-2013 (S2022)        Line Replaceable Integrated Electronics Chassis Standard, Liquid Cooled Chassis
ANSI/VITA 60-2012 (R2018)        Alternative Connector for VPX
ANSI/VITA 61.0-2022        XMC 2.0
ANSI/VITA 62.0-2022        Modular Power Supply Standard
ANSI/VITA 62.1-2023        Three Phase High-Voltage Power Supply Front-End in a 3U Plug-In Module Standard
ANSI/VITA 62.2-2020        Modular Power Supply Standard for 270v Applications
ANSI/VITA 63.0-2015 (R2022)        Hyperboloid Alternative Connector for VPX VITA 65 Bundle        OpenVPX (VITA 65 and VITA 65.1) Bundle
ANSI/VITA 65.0-2023        OpenVPX System Standard
ANSI/VITA 65.1-2023        OpenVPX System Standard –Profile Tables
ANSI/VITA 66.0-2016 (R2025)        Optical Interconnect on VPX –Base VITA 66.1-2012        Optical Interconnect on VPX –MT Variant
ANSI/VITA 66.2-2013 (S2025)        Optical Interconnect On VPX –ARINC 801 Termini Variant
ANSI/VITA 66.3-2012 (R2018)        Optical Interconnect on VPX - Mini-Expanded Beam Variant
ANSI/VITA 66.4-2016 (R2025)        Optical Interconnect On VPX –Half Width MT Variant
ANSI/VITA 66.5-2022 +Errata        Optical Interconnect on VPX - Hybrid Variants
ANSI/VITA 67.0-2019        Coaxial Interconnect on VPX –Base Standard
ANSI/VITA 67.1-2019        Coaxial Interconnect on VPX, 4 Position SMPM Configuration         Coaxial Interconnect on VPX, 4 Position SMPM Configuration
ANSI/VITA 67.2-2020        Coaxial Interconnect on VPX, 8 Position SMPM Configuration
ANSI/VITA 67.3-2023        Coaxial Interconnect on VPX - Spring-Loaded Contact on Backplane
ANSI/VITA 68.0-2025        VPX Compliance Channel Standard
ANSI/VITA 68.1-2025        VPX Compliance Channel - Fixed Signal Integrity Budget Standard
ANSI/VITA 68.2-2021        VPX Standard S-Parameter Definition
VITA 68.3-2024-VDSTU        Reference SI Model Standard for Gen4 and Higher Speeds
ANSI/VITA 74.0-2022        Compliant System Small Form Factor Module (VNX) Base Standard
ANSI/VITA 76-2016 (R2021)        "High Performance Cable -Ruggedized 10 Gbaud Bulkhead Connector for Cu and AOC Cables"
ANSI/VITA 78.0-2022        SpaceVPX System Standard
ANSI/VITA 86-2025                High Voltage Input Sealed Connector Power Supply
ANSI/VITA 87.0-2024        High Density (HD) MT Circular Connector - Type 1
ANSI/VITA 88.0-2021        Switched Mezzanine Card Plus (XMC+) Standard
ANSI/VITA 91.0-2024        Connector for Higher Density VPX Applications
Download Contact:   1395833280@foxmail.com
                ipcstd@outlook.com
查看完整版本: VITA STANDARDS LIST,VITA 最新标准清单大全下载_ansi vita
