armclub 发表于 2025-6-14 10:20
ES8388+TPS63710+LM5001SDE+THAT1510S08 做的PCB文件
    REFDESCOMP_DEVICE_TYPESYM_NAME
CD4CAP_POL_CES8_0CES8
CON1PHONOJACKSTEREO-15_2_JK-S-5P-S3028_0JK-S-5P-S3028
CON2VH3.96-2P_AV-9D6-102_0AV-9D6-102
CON3ANYTAKE-6P-2_CN2X6-3D5MM_0CN2X6-3D5MM
CON4HEADER3_0_AV2X1_0AV2X1
CON5CONN_30PIN_D2MM_CN2X15-2D0-V-3_0CN2X15-2D0-V-3
CT1CAP_POL_CT-3216_0CT-3216
D1LM4040DIM_2_D-SMA-AK_0D-SMA-AK
D2LM4040DIM_2_D-SMA-AK_0D-SMA-AK
D3DIODEPIN_2_D-SMA-AK_0D-SMA-AK
D4LM4040DIM_2_D-SMA-AK_0D-SMA-AK
D5LM4040DIM_2_D-SMA-AK_0D-SMA-AK
D6DIODEPIN_2_D-SMA-AK_0D-SMA-AK
D7LM4040DIM_2_D-SMA-AK_0D-SMA-AK
D8LM4040DIM_2_D-SMA-AK_0D-SMA-AK
D9LM4040DIM_16_D-SMA-AK_0D-SMA-AK
D10DIODEPIN_2_D-SMA-AK_0D-SMA-AK
D11LM4040DIM_11_SOD-323_0SOD-323
D12LM4040DIM_11_SOD-323_0SOD-323
FB1INDUCTOR_SR0603_0SR0603
FB2INDUCTOR_SR0603_0SR0603
FB3INDUCTOR_SR0603_0SR0603
FB4INDUCTOR_SR0603_0SR0603
FB5INDUCTOR_SR0603_0SR0603
FB6INDUCTOR_SR0603_0SR0603
H1SIP1_0_HOLE7H3D5MM_SIP1HOLE7H3D5MM
H2SIP1_0_HOLE7H3D5MM_SIP1HOLE7H3D5MM
H3SIP1_0_HOLE7H3D5MM_SIP1HOLE7H3D5MM
H4SIP1_0_HOLE7H3D5MM_SIP1HOLE7H3D5MM
J1SIP1_0_SIP-1P_SIP1SIP-1P
J4SIP1_0_SIP-1P_SIP1SIP-1P
L1INDUCTOR_SPL0707G_0SPL0707G
L2INDUCTOR_LPS8045B-224MRB_0LPS8045B-224MRB
OSC125MHZ_0_HSX4_0302_0HSX4_0302
OSC225MHZ_0_HSX4_0302_0HSX4_0302
Q12N1069_2_SOT23_0SOT23
T1719VXA-N_2_EE13-NC_0EE13-NC
T2719VXA-N_2_EE13-NC_0EE13-NC
T3719VXA-N_2_EE13-NC_0EE13-NC
T4719VXA-N_2_EE13-NC_0EE13-NC
TP1TESTPOINT_0_PT40_24_0PT40_24
TP2TESTPOINT_0_PT40_24_0PT40_24
TP3TESTPOINT_0_PT40_24_0PT40_24
U1TPS63710_WSON12-050-0303_0WSON12-050-0303
U2THAT1510S08-U_0_SOP8-225-50_0SOP8-225-50
U3OPA137_0_SOT23-5P_0SOT23-5P
U4OPA137_0_SOT23-5P_0SOT23-5P
U5LM5001SDE/NOPB_WSON8_EP_0404_0WSON8_EP_0404
U6ES8388_2_QFN24-0303_0QFN24-0303
U7ES8388_2_QFN24-0303_0QFN24-0303
lf2k2022 发表于 2025-6-16 09:00
安好888 发表于 2025-7-9 17:03
0402 发表于 2026-8-27 08:38
学习学习
jielove2003 发表于 2026-8-27 08:40
感谢分享·········
hkw221 发表于 2026-8-27 09:00
很好,学习了
查看完整版本: ES8388+TPS63710+LM5001SDE+THAT1510S08 做的PCB文件
