CS8862A挂DDR4 做的高端路由器PCB 带POE功能 GDQ2BFAA-WJ+YT8821C/YT8821H YT8531C/YT8531H MP8009/TMI7332
PCB文件,4层设计。
D11N4148W_D1_0_D-SOD323-H1_2_1N4148W1N4148WD-SOD323-H1_2
D2BZX84C10/SOT_0_DO_214AA_TVS1_BEP4200SCBEP4200SCDO_214AA_TVS1
D4BZX84C10/SOT_0_DO_214AA_TVS1_BEP4200SCBEP4200SCDO_214AA_TVS1
D5BZX84C10/SOT_0_DO_214AA_TVS1_BEP4200SCBEP4200SCDO_214AA_TVS1
D6BZX84C10/SOT_0_DO_214AA_TVS1_BEP4200SCBEP4200SCDO_214AA_TVS1
D7BZX84C10/SOT_0_DO_214AA_TVS1_BEP4200SCBEP4200SCDO_214AA_TVS1
D8BZX84C10/SOT_0_DO_214AA_TVS1_BEP4200SCBEP4200SCDO_214AA_TVS1
D9BZX84C10/SOT_0_DO_214AA_TVS1_BEP4200SCBEP4200SCDO_214AA_TVS1
D10BZX84C10/SOT_0_DO_214AA_TVS1_BEP4200SCBEP4200SCDO_214AA_TVS1
D11BZX84C10/SOT_0_DO_214AA_TVS1_BEP4200SCBEP4200SCDO_214AA_TVS1
D121_2.5KE100A_R0402__ESD-KLXES15AAA1-0402ESD-KLXES15AAA1-0402R0402
D131_2.5KE100A_R0402__ESD-KLXES15AAA1-0402ESD-KLXES15AAA1-0402R0402
D141_2.5KE100A_R0402__ESD-KLXES15AAA1-0402ESD-KLXES15AAA1-0402R0402
D631_2.5KE100A_R0402__ESD-KLXES15AAA1-0402ESD-KLXES15AAA1-0402R0402
D641_2.5KE100A_R0402__ESD-KLXES15AAA1-0402ESD-KLXES15AAA1-0402R0402
D651_2.5KE100A_R0402__ESD-KLXES15AAA1-0402ESD-KLXES15AAA1-0402R0402
D661_2.5KE100A_R0402__ESD-KLXES15AAA1-0402ESD-KLXES15AAA1-0402R0402
D72BZX84C10/SOT_0_DO_214AA_TVS1_BEP4200SCBEP4200SCDO_214AA_TVS1
D75BZX84C10/SOT_0_DO_214AA_TVS1_BEP4200SCBEP4200SCDO_214AA_TVS1
D79DIODE_D_214AA_SS310SS310D_214AA
D81DIODE_D_214AA_SS310SS310D_214AA
EC1CAP/0805_ECAP-SMD-6_5_220UF/25V220uF/25VECAP-SMD-6_5
EC4CAP/0805_ECAP-SMD-6_5_220UF/25V220uF/25VECAP-SMD-6_5
EC7CAP/0805_ECAP-SMD-6_5_220UF/25V220uF/25VECAP-SMD-6_5
EC22CAP/0805_ECAP-SMD-6_5_220UF/25V220uF/25VECAP-SMD-6_5
EC23CAP/0805_ECAP-SMD-6_5_220UF/25V220uF/25VECAP-SMD-6_5
FB1FERRITEBEAD_2P0402R_UPZ1005D121-1R3TFUPZ1005D121-1R3TF2P0402R
FB2L_1_R0805_0R0RR0805
FB3L_1_R0805_0R0RR0805
FB4L_1_R0805_0R0RR0805
FB5L_1_R0805_0R0RR0805
FB6L_0_R0603_SBY100505T-121Y-(500MA)SBY100505T-121Y-(500mA)R0603
FB7L_1_R0603_SBY100505T-121Y-(500MA)SBY100505T-121Y-(500mA)R0603
FB8L_1_R0805_0R0RR0805
FB9L_1_R0805_0R0RR0805
FB11L_1_R0805_0R0RR0805
FB12L_1_R0805_0R0RR0805
FB34L_1_R0805_0R0RR0805
FE2LFB186G13CTCF094_FIL-1_6X0_8-3P-RF-A_BF1608-R6R1NACBF1608-R6R1NACFIL-1_6X0_8-3P-RF-A
FE4LFB186G13CTCF094_FIL-1_6X0_8-3P-RF-A_BF1608-R6R1NACBF1608-R6R1NACFIL-1_6X0_8-3P-RF-A
FL1FIL_LFB212G45CN1E205_3_FIL-SMD-85X53-5PIN_2450MHZ2450MHzFIL-SMD-85X53-5PIN
FL2FIL_LFB212G45CN1E205_3_FIL-SMD-85X53-5PIN_2450MHZ2450MHzFIL-SMD-85X53-5PIN
FR12R_2P0201R_0R0R2P0201R
FR13R_2P0201R_NCNC2P0201R
FR14R_2P0201R_0R0R2P0201R
FR15R_2P0201R_NCNC2P0201R
FR16R_2P0201R_0R0R2P0201R
FR17R_2P0201R_NCNC2P0201R
H1MH-8VIA_2_HOLE6D3_5MM_4-40X3/4IN-SCREW4-40X3/4in-SCREWHOLE6D3_5MM
H2MH-8VIA_2_HOLE6D3_5MM_4-40X3/4IN-SCREW4-40X3/4in-SCREWHOLE6D3_5MM
H3MH-8VIA_2_HOLE6D3_5MM_4-40X3/4IN-SCREW4-40X3/4in-SCREWHOLE6D3_5MM
H4MH-8VIA_2_HOLE6D3_5MM_4-40X3/4IN-SCREW4-40X3/4in-SCREWHOLE6D3_5MM
J1CONN_JACK_3P_V1_N1N3N2_0_POWERJACK-22600000099_CONN_JACK_3P_V1_N1N3N2_482-03524-0005CONN_JACK_3P_V1_N1N3N2POWERJACK-22600000099
J2CONETHER 1PORT_2_RJ45_LED-ZHENG_CON JACK SINGLE PORTCONJACK SINGLE PORTRJ45_LED-ZHENG
J3CONN_4_CONN_S_1_POE_DIP_CONN_4_CONN_S_4PIN_CONN_4_CONN_S_4PINPOE_DIP
J5CONETHER 1PORT_2_RJ45_LED-ZHENG_CON JACK SINGLE PORTCONJACK SINGLE PORTRJ45_LED-ZHENG
J6CON2_SIP2_CON2CON2SIP2
J7IPEX1B39721B8838P810IPEX-1S
J8IPEX1B39721B8838P810IPEX-1S
J9IPEX1B39721B8838P810IPEX-1S
J10IPEX1B39721B8838P810IPEX-1S
J11CONN_4_CONN_S_1_J4X1_CONN_4_CONN_S_4PIN_CONN_4_CONN_S_4PINJ4X1
L1BEAD_R0805_0R0RR0805
L2BEAD_2P0402R_UPZ1005D121-1R3TFUPZ1005D121-1R3TF2P0402R
L3BEAD_2P0805R_0R0R2P0805R
L4BEAD_R0805_0R0RR0805
L5BEAD_2P0402R_UPZ1005D121-1R3TFUPZ1005D121-1R3TF2P0402R
L6BEAD_2P0402R_UPZ1005D121-1R3TFUPZ1005D121-1R3TF2P0402R
L7BEAD_2P0402R_UPZ1005D121-1R3TFUPZ1005D121-1R3TF2P0402R
L8BEAD_2P0402R_UPZ1005D121-1R3TFUPZ1005D121-1R3TF2P0402R
L9BEAD_2P0402R_UPZ1005D121-1R3TFUPZ1005D121-1R3TF2P0402R
L10BEAD_R0201_UPZ0603U330-1R5TFUPZ0603U330-1R5TFR0201
L11BEAD_2P0402R_UPZ1005D121-1R3TFUPZ1005D121-1R3TF2P0402R
L12BEAD_R0201_UPZ0603U330-1R5TFUPZ0603U330-1R5TFR0201
L13BEAD_2P0402R_UPZ1005D121-1R3TFUPZ1005D121-1R3TF2P0402R
L14BEAD_R0201_UPZ0603U330-1R5TFUPZ0603U330-1R5TFR0201
L15BEAD_2P0402R_UPZ1005D121-1R3TFUPZ1005D121-1R3TF2P0402R
L16BEAD_2P0402R_0R0R2P0402R
L17BEAD_2P0402R_UPZ1005D121-1R3TFUPZ1005D121-1R3TF2P0402R
L18BEAD_2P0603R_UPZ1608E121-3R0TFUPZ1608E121-3R0TF2P0603R
L19INDUCTORIRON_0_L-2_5X2_0-H1_2_2.2UH/1A2.2uH/1AL-2_5X2_0-H1_2
L36BEAD_2P0603R_0R0R2P0603R
L37BEAD_2P0805R_0R0R2P0805R
L38BEAD_R0201_UPZ0603U330-1R5TFUPZ0603U330-1R5TFR0201
L39BEAD_2P0402R_0R0R2P0402R
L40BEAD_R0603_UPZ1005D121-1R3TFUPZ1005D121-1R3TFR0603
L41BEAD_R0603_UPZ1005D121-1R3TFUPZ1005D121-1R3TFR0603
L42BEAD_FB0603_YI160808U601-2R0TYI160808U601-2R0TFB0603
L48BEAD_2P0402R_UPZ1005D121-1R3TFUPZ1005D121-1R3TF2P0402R
L59L_0_2P0201R_NCNC2P0201R
L60L_0_2P0201R_NCNC2P0201R
L62BEAD_2P0603R_UPZ1608E121-3R0TFUPZ1608E121-3R0TF2P0603R
L63BEAD_2P0603R_UPZ1608E121-3R0TFUPZ1608E121-3R0TF2P0603R
L65L_0_2P0201R_NCNC2P0201R
L66L_0_2P0201R_NCNC2P0201R
L68L_0_2P0201R_0.2PF0.2pF2P0201R
L69L_0_2P0201R_0.2PF0.2pF2P0201R
L70BEAD_2P0603R_UPZ1608E121-3R0TFUPZ1608E121-3R0TF2P0603R
L71BEAD_2P0603R_UPZ1608E121-3R0TFUPZ1608E121-3R0TF2P0603R
L72L_0_2P0201R_0.2PF0.2pF2P0201R
L73L_0_2P0201R_0.2PF0.2pF2P0201R
L81L_0_2P0201R_NCNC2P0201R
L82L_0_2P0201R_NCNC2P0201R
L83L_0_2P0201R_NCNC2P0201R
L84L_0_2P0201R_NCNC2P0201R
L88BEAD_2P0603R_UPZ1608E121-3R0TFUPZ1608E121-3R0TF2P0603R
L90BEAD_FB0603_NCNCFB0603
L91XAL5030-332MEB_INA_8X8_1UH1uHINA_8X8
L92IND_MAG_HIND_MAG_2PIN_INA_8X8_2.2UH/4A_2.2UH/4AINA_8X8
L93INDUCTOR_L4018_1.0UH1.0uHL4018
L94INDUCTOR_L4018_1.0UH1.0uHL4018
L95INDUCTOR_L4018_1.0UH1.0uHL4018
L98BEAD_R0603_UPZ1005D121-1R3TFUPZ1005D121-1R3TFR0603
L99BEAD_R0603_UPZ1005D121-1R3TFUPZ1005D121-1R3TFR0603
L100BEAD_R0603_UPZ1005D121-1R3TFUPZ1005D121-1R3TFR0603
L102BEAD_R0603_UPZ1005D121-1R3TFUPZ1005D121-1R3TFR0603
L105L_0_2P0201R_NCNC2P0201R
L108L_0_2P0201R_NCNC2P0201R
L117IND_MAG_HIND_MAG_2PIN_INA_8X8_2.2UH/4A_2.2UH/4AINA_8X8
L120IND_MAG_HIND_MAG_2PIN_INA_8X8_2.2UH/4A_2.2UH/4AINA_8X8
LA1FERRITEBEAD_2P0402R_UPZ1005D121-1R3TFUPZ1005D121-1R3TF2P0402R
LEDLED-ANODE1_0_RGB_0805_LED_TZ-P4-1615RGBTCA1-0.55TLED_TZ-P4-1615RGBTCA1-0.55TRGB_0805
PD1SBM540-13-F_0_POWERDI5_SBR8U60P5SBR8U60P5POWERDI5
PD3BZX84C10/SOT_0_D_214AA_SMAJ58ASMAJ58AD_214AA
PD24DIODE_SOD-123_1N4148/NC1N4148/NCSOD-123
PD87TB8S_0_MBS__TB8STB8SMBS
PD89TB8S_0_MBS__TB8STB8SMBS
PD90DIODE_SOD-123_BAV21WBAV21WSOD-123
PD91DIODE_SOD-123_BAV21WBAV21WSOD-123
PEC2CAP/0805_SMD8_47UF/63V47uF/63VSMD8
PEC3CAP/0805_ECAP-SMD-6_5_220UF/25V220uF/25VECAP-SMD-6_5
PL60L/GDR1012_0_INA_8X8_10UH10uHINA_8X8
PL61INDUCTOR_1_L4-8_5MM-9X7MM_NCNCL4-8_5MM-9X7MM
PL62L/GDR1012_0_INA_8X8_1UH1uHINA_8X8
PQ6SI7430DP-T1-E3_0_SOP8-150_CEM0415CEM0415SOP8-150
PR175RES/0402_17_R0603_100R100RR0603
PR204RES/0402_17_R0603_4.7K/5%4.7K/5%R0603
PR208RES/0402_17_R1206_0.12R/1%0.12R/1%R1206
PR209RES/0402_17_R1206_0.12R/1%0.12R/1%R1206
PR218RES/0402_17_R0402_6.8K6.8KR0402
PR219RES/0402_17_R0402_2NC2NCR0402
PR220RES/0402_17_R0402_10K/5%10K/5%R0402
PR231RES/0402_17_R0603_10R10RR0603
PR233RES/0402_17_R0603_28.7R28.7RR0603
PR254RES/0402_16_R0402_24.9K/1%24.9K/1%R0402
PR336RES/0402_17_R0603_10R10RR0603
PR429RES/0402_17_R0603_4.7K/5%4.7K/5%R0603
PR430RES/0402_17_R0603_20R20RR0603
PR431RES/0402_17_R0402_8.2K/1%8.2K/1%R0402
PR432RES/0402_17_R0402_24.9K/1%24.9K/1%R0402
PR9593R_R1206_0R/5%0R/5%R1206
PR9600R_R1206_0R/5%0R/5%R1206
PR9605RES/0402_17_R0402_0R0RR0402
PR9606RES/0402_17_R0402_NCNCR0402
PT1TSE539_5_TOEP13-0399SG_TOEP13P-0588SGSPEC X0/TEP1313-C508TOEP13P-0588SGSPEC X0/TEP1313-C508TOEP13-0399SG
PU24PD70201_2_QFN-4X5-29P-0_5A_MP8009/TMI7332MP8009/TMI7332QFN-4X5-29P-0_5A
Q19013_SOT-23-3PS1_MMBT3904LT1GMMBT3904LT1GSOT-23-3PS1
Q39013_SOT-23-3PS1_MMBT3904LT1GMMBT3904LT1GSOT-23-3PS1
Q59013_SOT-23-3PS1_MMBT3904LT1GMMBT3904LT1GSOT-23-3PS1
S1TACT_SW-PUSH-6X7MM_TACTTACTSW-PUSH-6X7MM
SHFD1_2TESTPOINT-SM_PO1D0X2D0H0D5X1D5_H_SHF_NC_H_SHF_NCPO1D0X2D0H0D5X1D5
SHFD1_3TESTPOINT-SM_PO1D0X2D0H0D5X1D5_H_SHF_NC_H_SHF_NCPO1D0X2D0H0D5X1D5
SHFD1_5TESTPOINT-SM_PO1D0X2D0H0D5X1D5_H_SHF_NC_H_SHF_NCPO1D0X2D0H0D5X1D5
SHFD1_8TESTPOINT-SM_PO1D0X2D0H0D5X1D5_H_SHF_NC_H_SHF_NCPO1D0X2D0H0D5X1D5
SHFD1_9TESTPOINT-SM_PO1D0X2D0H0D5X1D5_H_SHF_NC_H_SHF_NCPO1D0X2D0H0D5X1D5
SHFD1_11TESTPOINT-SM_PO1D0X2D0H0D5X1D5_H_SHF_NC_H_SHF_NCPO1D0X2D0H0D5X1D5
T1XFMR-FM-1178-1LLF_TR24_15_24_1_27_G2401CGG2401CGTR24_15_24_1_27
T2XFMR-FM-1178-1LLF_TR24_15_24_1_27_G2401CGG2401CGTR24_15_24_1_27
TP1TP-SMD_STP40_TP-SMDTP-SMDSTP40
TP2TP-SMD_STP40_TP-SMDTP-SMDSTP40
TP3TP-SMD_STP40_CON1CON1STP40
TP4PAD_0R5MM_SMT_0_TPC40_35MIL35milTPC40
TP5TPOINT F_PAD_HOLE_5_5X3_5_M2_5MMM2_5MMPAD_HOLE_5_5X3_5
TP6TPOINT F_PAD_HOLE_5_5X3_5_M2_5MMM2_5MMPAD_HOLE_5_5X3_5
TP7TPOINT F_PAD_HOLE_5_5X3_5_M2_5MMM2_5MMPAD_HOLE_5_5X3_5
TP8TPOINT F_PAD_HOLE_5_5X3_5_M2_5MMM2_5MMPAD_HOLE_5_5X3_5
TP14TPOINT F_MARK_MARKMARKMARK
TP15TPOINT F_MARK_MARKMARKMARK
TP16TPOINT F_MARK_MARKMARKMARK
TP21TPOINT F_MARK_MARKMARKMARK
TVS1ESD5344D-10TR_DFN9P_0_IC-ESD10-1_1X2_65-H0_63_WS05-4R2PWS05-4R2PIC-ESD10-1_1X2_65-H0_63
TVS2ESD5344D-10TR_DFN9P_0_IC-ESD10-1_1X2_65-H0_63_WS05-4R2PWS05-4R2PIC-ESD10-1_1X2_65-H0_63
TVS3ESD5344D-10TR_DFN9P_0_IC-ESD10-1_1X2_65-H0_63_WS05-4R2PWS05-4R2PIC-ESD10-1_1X2_65-H0_63
TVS4ESD5344D-10TR_DFN9P_0_IC-ESD10-1_1X2_65-H0_63_WS05-4R2PWS05-4R2PIC-ESD10-1_1X2_65-H0_63
U1SOC_20231206_BGA576C65P24X24_1600X1600X66__CS8862ACS8862ABGA576C65P24X24_1600X1600X66
U2MT40A256M16GE-083EITB_FBGA96_9X14_MRN_GDQ2BFAA-WJGDQ2BFAA-WJFBGA96_9X14_MRN
U3IS25LQ040B_3_IC-WSON8-8X6-P1D27-H1D0_GD5F1GM7UEYIGGD5F1GM7UEYIGIC-WSON8-8X6-P1D27-H1D0
U4RCLAMP0542T_IC-SLP1610P4T_6-P0_5-H0_4_CESD1610LC5VUCESD1610LC5VUIC-SLP1610P4T_6-P0_5-H0_4
U5RCLAMP0542T_IC-SLP1610P4T_6-P0_5-H0_4_CESD1610LC5VUCESD1610LC5VUIC-SLP1610P4T_6-P0_5-H0_4
U6RTL8211F_IC-QFN40-5X5-P0_4-H0_8_YT8531C/YT8531HYT8531C/YT8531HIC-QFN40-5X5-P0_4-H0_8
U7RCLAMP0542T_0_USB-C_USB-A-90USB-A-90USB-C
U8CIU98_A_U1_0_QFN32_P04_4X4MMB_CIU98_ACIU98_AQFN32_P04_4X4MMB
U9SN74AVCH4T245RGYR_QFN17P_0_QFN-1_8X1_4-10P-0_4_SN74AVC2T245RSWR(TI)SN74AVC2T245RSWR(TI)QFN-1_8X1_4-10P-0_4
U12TMI6050_SOT-23-5P-RF_RT9078NRT9078NSOT-23-5P-RF
U14RTL8226B_0_IC-QFN48-6X6-P0_4-H1_0_YT8821C/YT8821HYT8821C/YT8821HIC-QFN48-6X6-P0_4-H1_0
U16SKY85333-11_0_IC-QFN16-3X3-P0_5-H0_9_KCT8270HEKCT8270HEIC-QFN16-3X3-P0_5-H0_9
U17SKY85333-11_0_IC-QFN16-3X3-P0_5-H0_9_KCT8270HEKCT8270HEIC-QFN16-3X3-P0_5-H0_9
U18SKY85333-11_0_IC-QFN16-3X3-P0_5-H0_9_KCT8570HEKCT8570HEIC-QFN16-3X3-P0_5-H0_9
U19SKY85333-11_0_IC-QFN16-3X3-P0_5-H0_9_KCT8570HEKCT8570HEIC-QFN16-3X3-P0_5-H0_9
U22MP1601GTF_0_TSOT23-6_TMI3255SFTMI3255SFTSOT23-6
U23RT6252BHGJ6F_0_6PSM67X51F197V5_MP1653GTF/LA1213SMP1653GTF/LA1213S6PSM67X51F197V5
U24MP1601GTF_6PSM67X51F197V5_MP1605/LA1122SMP1605/LA1122S6PSM67X51F197V5
U25MP1601GTF_6PSM67X51F197V5_MP1605/LA1122SMP1605/LA1122S6PSM67X51F197V5
U26MP1601GTF_6PSM67X51F197V5_MP1605/LA1122SMP1605/LA1122S6PSM67X51F197V5
U28SFP1X1_0_SFP-C_SFP_CAGE_1X1SFP_CAGE_1x1SFP-C
U29RT6252BHGJ6F_0_6PSM67X51F197V5_MP1653GTF/LA1213SMP1653GTF/LA1213S6PSM67X51F197V5
U32RT6252BHGJ6F_0_6PSM67X51F197V5_MP1653GTF/LA1213SMP1653GTF/LA1213S6PSM67X51F197V5
X1E1SB50E00000DE_XTAL-4P-3D2X2D5_25MHZ-Q22FA1280038825MHz-Q22FA12800388XTAL-4P-3D2X2D5
XA1CRYSTAL_XTAL-4P-3D2X2D5_25MHZ_+/-50PPM25MHz_+/-50PPMXTAL-4P-3D2X2D5
Y2X503248MSB4SI_0_XTAL-2_0X1_6-H0_6_E1SB40E000007EE1SB40E000007EXTAL-2_0X1_6-H0_6
大佬有原理图嘛,看PCB学不到东西:dizzy: 有原理图嘛,看PCB学不到东西啊 好资料,学习学习! 只能看看PCB有用 :lol 太贵了 啊 :):):):) 感谢分享
