一个开发板底板PCB ALC5672 +TCA9539+CP2102N
REFDESCOMP_DEVICE_TYPESYM_NAME
D1D_ESD_DIFFPAIR_DUAL-LRC8804LFVLDT1G,160-1023,2DIFFPAIR,UNI-DIRECTIONAL,5V,3A,5.5V,10V,0.35PFTSLP10_P050_025X010
D2D_ESD_DIFFPAIR_DUAL-LRC8804LFVLDT1G,160-1023,2DIFFPAIR,UNI-DIRECTIONAL,5V,3A,5.5V,10V,0.35PFTSLP10_P050_025X010
D3D_ESD_NORM-BDFN2C051RF,160-1017,1LINE,BI-DIRECTIONAL,5V,4A,6V,17V,0.3PFDIODE_SMD_010X060
D4D_ESD_NORM-BDFN2C051RF,160-1017,1LINE,BI-DIRECTIONAL,5V,4A,6V,17V,0.3PFDIODE_SMD_010X060
D5D_ESD_NORM-BDFN2C051S,160-1024,1LINE,BI-DIRECTIONAL,5V,1UA,6V,13V@5A,8PFDIODE_SMD_010X060
D6D_ESD_NORM-BDFN2C051S,160-1024,1LINE,BI-DIRECTIONAL,5V,1UA,6V,13V@5A,8PFDIODE_SMD_010X060
D7D_ESD_NORM-BDFN2C051S,160-1024,1LINE,BI-DIRECTIONAL,5V,1UA,6V,13V@5A,8PFDIODE_SMD_010X060
D8D_ESD_DIFFPAIR_DUAL-LRC8804LFVLDT1G,160-1023,2DIFFPAIR,UNI-DIRECTIONAL,5V,3A,5.5V,10V,0.35PFTSLP10_P050_025X010
D9D_ESD_NORM-BDFN2C051S,160-1024,1LINE,BI-DIRECTIONAL,5V,1UA,6V,13V@5A,8PFDIODE_SMD_010X060
D10D_ESD_NORM-BDFN2C051RF,160-1017,1LINE,BI-DIRECTIONAL,5V,4A,6V,17V,0.3PFDIODE_SMD_010X060
D11D_ESD_NORM-BDFN2C051RF,160-1017,1LINE,BI-DIRECTIONAL,5V,4A,6V,17V,0.3PFDIODE_SMD_010X060
D12D_ESD_NORM-BDFN2C051S,160-1024,1LINE,BI-DIRECTIONAL,5V,1UA,6V,13V@5A,8PFDIODE_SMD_010X060
D13D_SCHOTTKY_SOD523_AK-LBAT54XV2T1G,160-1025,SINGLE,0.32V@1MA25DEG,0.2A,30V,0.6ADIODE_SMD_SOD523_B_AKP
D14D_SCHOTTKY_SOD323-LMBR140ET1G,160-1026,SINGLE,0.55V@1A,1A,40V,22ADIODE_SMD_SOD323_B
D15D_SCHOTTKY_SOD523_AK-LBAT54XV2T1G,160-1025,SINGLE,0.32V@1MA25DEG,0.2A,30V,0.6ADIODE_SMD_SOD523_B_AKP
D16D_ESD_NORM-BDFN2C051RF,160-1017,1LINE,BI-DIRECTIONAL,5V,4A,6V,17V,0.3PFDIODE_SMD_010X060
D17D_SCHOTTKY_SOD523_AK-LBAT54XV2T1G,160-1025,SINGLE,0.32V@1MA25DEG,0.2A,30V,0.6ADIODE_SMD_SOD523_B_AKP
D18D_ESD_NORM-BDFN2C051RF,160-1017,1LINE,BI-DIRECTIONAL,5V,4A,6V,17V,0.3PFDIODE_SMD_010X060
D19D_ESD_NORM-BDFN2C051RF,160-1017,1LINE,BI-DIRECTIONAL,5V,4A,6V,17V,0.3PFDIODE_SMD_010X060
D20D_SCHOTTKY_SOD323-LMBR140ET1G,160-1026,SINGLE,0.55V@1A,1A,40V,22ADIODE_SMD_SOD323_B
D21D_ESD_NORM-BDFN2C051RF,160-1017,1LINE,BI-DIRECTIONAL,5V,4A,6V,17V,0.3PFDIODE_SMD_010X060
D22D_SCHOTTKY_SOD323-LMBR140ET1G,160-1026,SINGLE,0.55V@1A,1A,40V,22ADIODE_SMD_SOD323_B
D23D_SCHOTTKY_SOD323-LMBR140ET1G,160-1026,SINGLE,0.55V@1A,1A,40V,22ADIODE_SMD_SOD323_B
D24D_SCHOTTKY_SOD323-LMBR140ET1G,160-1026,SINGLE,0.55V@1A,1A,40V,22ADIODE_SMD_SOD323_B
D25D_SCHOTTKY_SOD323-LMBR140ET1G,160-1026,SINGLE,0.55V@1A,1A,40V,22ADIODE_SMD_SOD323_B
D26D_SCHOTTKY_SOD523_AK-LBAT54XV2T1G,160-1025,SINGLE,0.32V@1MA25DEG,0.2A,30V,0.6ADIODE_SMD_SOD523_B_AKP
D27D_SCHOTTKY_SOD323-LMBR140ET1G,160-1026,SINGLE,0.55V@1A,1A,40V,22ADIODE_SMD_SOD323_B
D28D_SCHOTTKY_SOD523_AK-LBAT54XV2T1G,160-1025,SINGLE,0.32V@1MA25DEG,0.2A,30V,0.6ADIODE_SMD_SOD523_B_AKP
D29D_SCHOTTKY_SOD523_AK-LBAT54XV2T1G,160-1025,SINGLE,0.32V@1MA25DEG,0.2A,30V,0.6ADIODE_SMD_SOD523_B_AKP
D31D_ESD_DIFFPAIR_DUAL-LRC8804LFVLDT1G,160-1023,2DIFFPAIR,UNI-DIRECTIONAL,5V,3A,5.5V,10V,0.35PFTSLP10_P050_025X010
D32D_ESD_NORM-BDFN2C051S,160-1024,1LINE,BI-DIRECTIONAL,5V,1UA,6V,13V@5A,8PFDIODE_SMD_010X060
D33D_ESD_NORM-BDFN2C051S,160-1024,1LINE,BI-DIRECTIONAL,5V,1UA,6V,13V@5A,8PFDIODE_SMD_010X060
D34D_ESD_NORM-BDFN2C051S,160-1024,1LINE,BI-DIRECTIONAL,5V,1UA,6V,13V@5A,8PFDIODE_SMD_010X060
D35D_ESD_NORM-BDFN2C051S,160-1024,1LINE,BI-DIRECTIONAL,5V,1UA,6V,13V@5A,8PFDIODE_SMD_010X060
D36D_SCHOTTKY_SOD523_AK-LBAT54XV2T1G,160-1025,SINGLE,0.32V@1MA25DEG,0.2A,30V,0.6ADIODE_SMD_SOD523_B_AKP
D37D_ESD_NORM-BDFN2C051S,160-1024,1LINE,BI-DIRECTIONAL,5V,1UA,6V,13V@5A,8PFDIODE_SMD_010X060
D38D_SCHOTTKY_SOD523_AK-LBAT54XV2T1G,160-1025,SINGLE,0.32V@1MA25DEG,0.2A,30V,0.6ADIODE_SMD_SOD523_B_AKP
D39D_SCHOTTKY_SOD523_AK-LBAT54XV2T1G,160-1025,SINGLE,0.32V@1MA25DEG,0.2A,30V,0.6ADIODE_SMD_SOD523_B_AKP
D40D_ESD_NORM-BDFN2C051RF,160-1017,1LINE,BI-DIRECTIONAL,5V,4A,6V,17V,0.3PFDIODE_SMD_010X060
D41D_ESD_NORM-BDFN2C051RF,160-1017,1LINE,BI-DIRECTIONAL,5V,4A,6V,17V,0.3PFDIODE_SMD_010X060
D42D_ESD_NORM-BDFN2C051RF,160-1017,1LINE,BI-DIRECTIONAL,5V,4A,6V,17V,0.3PFDIODE_SMD_010X060
D43D_ESD_NORM-BDFN2C051RF,160-1017,1LINE,BI-DIRECTIONAL,5V,4A,6V,17V,0.3PFDIODE_SMD_010X060
D83D_ESD_NORM-BDFN2C051S,160-1024,1LINE,BI-DIRECTIONAL,5V,1UA,6V,13V@5A,8PFDIODE_SMD_010X060
DS1LED_0603-LED_SMD_0603,160-0007,2.3V,20MA,5V,40MALED_SMD_0603_ST
DS2LED_0603-LED_SMD_0603,160-0007,2.3V,20MA,5V,40MALED_SMD_0603_ST
DS3LED_0603-LED_SMD_0603,160-0007,2.3V,20MA,5V,40MALED_SMD_0603_ST
DS4LED_0603-LED_SMD_0603,160-0007,2.3V,20MA,5V,40MALED_SMD_0603_ST
DS5LED_0603-LED_SMD_0603,160-0007,2.3V,20MA,5V,40MALED_SMD_0603_ST
J1CON_USB3_RJ45_TH_DUALUSB3_A_RJ45_2-72133W9-328Y-0ATM1,180-0138,FEMALE,0.45MM,90,YES,YES,YES,YES,YES,30V,1.8ACON_RJ45_USB_DUAL_032_TH_RA_2LED
J2CON_USB3_TYPEC_30PIN_B-W-UTP-CH158-024,180-0135,FEMALE,0.5MM,90,YES,N/A,N/A,N/A,YES,20V,5ACON_USB_024_SMT_RA_F_089X082
J3CON_USB3_RJ45_TH_DUALUSB3_A_RJ45_2-72133W9-328Y-0ATM1,180-0138,FEMALE,0.45MM,90,YES,YES,YES,YES,YES,30V,1.8ACON_RJ45_USB_DUAL_032_TH_RA_2LED
J4CON_ATX24P_ATX_24P-34202W00-2X12P-NHF,180-0125,FEMALE,4.2MM,180,YES,YES,YES,N/A,N/A,N/A,N/ACON_HDR_002X012_TH_ST_F_P042
J5CON_DISPLAYPORT_NORM_4GND-21019180012,180-0107,RECEPTACLE,0.5MM,90,YES,YES,YES,YES,YES,N/A,N/ACON_DP_020_SMT_RA_F_D
J6CON_DISPLAYPORT_NORM_4GND-21019180012,180-0107,RECEPTACLE,0.5MM,90,YES,YES,YES,YES,YES,N/A,N/ACON_DP_020_SMT_RA_F_D
J7CON_M2_PCI_EXP_SMD77_KEYM-562136-001H011R,180-0103,FEMALE,0.5MM,90,YES,NO,NO,NO,NO,N/A,N/ACON_EDGE_MINIPEX_067_SMT_RA_KEYM
J8CON_PCI_EXPRESS_PHY-X16-SMD-PIE164-3500-001-0H,180-0112,FEMALE,1.0MM,0,YES,YES,NO,NO,NO,[],[]CON_PEX_164_SMT_ST_P010_B
J9HDR_2X5_KEY9_MB-PH2.54*2.54-2*5P(N10P)-180DIP-PA5.0-PC3.5-6T,180-3028,MALE,2.54MM,180,NO,NO,NO,NO,NO,1000V,3ACON_HDR_009_002X005_TH_ST_M_P025
J10CON_USB3_TYPEC_30PIN_B-W-UTP-CH158-024,180-0135,FEMALE,0.5MM,90,YES,N/A,N/A,N/A,YES,20V,5ACON_USB_024_SMT_RA_F_089X082
J11CON_AUDIO_JACK_SW_TH_8PIN-5706B4-051R1000R,180-0104,FEMALE,N/A,90,YES,NO,NO,NO,NO,30V,0.5ACON_AUDIO_008_TH_RA_F_150X093
J12HDR_2X4_CPU_PWR8P-34202W00-2X4P-NHF,180-0124,FEMALE,4.2MM,180,YES,YES,YES,N/A,N/A,N/A,32ACON_HDR_002X004_TH_ST_M_P042
J13CON_DISPLAYPORT_NORM_4GND-21019180012,180-0107,RECEPTACLE,0.5MM,90,YES,YES,YES,YES,YES,N/A,N/ACON_DP_020_SMT_RA_F_D
J14CON_DISPLAYPORT_NORM_4GND-21019180012,180-0107,RECEPTACLE,0.5MM,90,YES,YES,YES,YES,YES,N/A,N/ACON_DP_020_SMT_RA_F_D
J15CON_MXM3_PHY_SEPARATE_EPIN-569H02-001H,180-0119,FEMALE,0.5MM,0,YES,YES,NO,NO,NO,[],0.5ACON_MXM3_314_P005_SMD_RA_C820X600
J16CON_M2_PCI_EXP_SMD77_KEYE_MID-562135-001H011R,180-0102,FEMALE,0.5MM,90,YES,NO,NO,NO,NO,N/A,N/ACON_EDGE_MINIPEX_067_SMT_RA_KEYE
J17CON_PWR_JACK_CON_5PIN-70018W9-004A-5AS50,180-0127,FEMALE,4.4MM,90,YES,YES,NO,NO,YES,500V,20ACON_PWR_005_TH_RA_M_DCJACK_C
J18HDR_1X4_NORM-12543W00-4PS-3E-R-A6,180-0141,MALE,2.54MM,90,YES,NO,NO,750V,3ACON_WAFTER_004_TH_ST_P025
J19CON_BATTERY_SMD-BAB13-VS200014-P,180-0126,FEMALE,9.45MM,0,YES,YES,YES,NO,NO,500V,1.5ACON_BATTERY_002_SMD_ST_F_154X142
J20HDR_1X4_NORM-12543W00-4PS-3E-R-A6,180-0141,MALE,2.54MM,90,YES,NO,NO,750V,3ACON_WAFTER_004_TH_ST_P025
J21HDR_1X4_NORMAL_KEY3-PH254020L-14200,180-3029,MALE,2.54MM,0,NO,N/A,NO,500VAC,3ACON_HDR_003_001X004_TH_ST_M_P025_F
J23HDR_2X3_NORM-PH2.54*2.54-2*3P-PA6.0-PC3.0-6T,180-0035,MALE,2.54MM,0,NO,NO,NO,500V,3ACON_HDR_002X003_TH_ST_M_P025
J24HDR_1X2_NORM-PH2.54*2.54-1*2P-PA6.0-PC3.0-6T,180-0031,MALE,2.54MM,0,NO,NO,NO,500V,3ACON_HDR_001X002_TH_ST_M_P025
J26HDR_2X10_SHR_JTAG1-2.54DC3-2*10P-180CDIP-L11.5-PC3.2-6T,180-0037,MALE,2.54MM,0,N/A,YES,NO,500V,3ACON_HDR_002X010_TH_ST_M_P025_SHR
J27HDR_2X10_SHR_JTAG1-2.54DC3-2*10P-180CDIP-L11.5-PC3.2-6T,180-0037,MALE,2.54MM,0,N/A,YES,NO,500V,3ACON_HDR_002X010_TH_ST_M_P025_SHR
J28HDR_2X10_SHR_JTAG1-2.54DC3-2*10P-180CDIP-L11.5-PC3.2-6T,180-0037,MALE,2.54MM,0,N/A,YES,NO,500V,3ACON_HDR_002X010_TH_ST_M_P025_SHR
J46HDR_1X4_NORM-5753104-T0006D-H,180-0045,MALE,2.0MM,0,NO,YES,YES,800V,2ACON_WAFER232_004_TH_ST_P020
J56HDR_1X4_NORM-5753104-T0006D-H,180-0045,MALE,2.0MM,0,NO,YES,YES,800V,2ACON_WAFER232_004_TH_ST_P020
L1L_7_6X7_6-2.2UH,155-2007,METALDUST,20%,10A,14A,0.0115OHM,[ ],N/AIND_NONRKO_SMD_069X065_B
L2L_7_6X7_6-2.2UH,155-2007,METALDUST,20%,10A,14A,0.0115OHM,[ ],N/AIND_NONRKO_SMD_069X065_B
L3L_2520-3.3UH,155-2077,METALDUST,20%,1.8A,2.5A,0.125OHM,[],[]IND_NONRKO_SMD_025X020
L18L_7_6X7_6-2.2UH,155-2007,METALDUST,20%,10A,14A,0.0115OHM,[ ],N/AIND_NONRKO_SMD_069X065_B
MEC1MEC_STANDOFF_SMD-STANDOFF_M3_H3.2,180-0117,N/A,N/A,90,YES,N/A,N/A,N/A,N/A,N/A,N/AMEC_STANDOFF_PTH_650C_B530430P
MEC2MEC_STANDOFF_SMD-NUT_M2X4X2.8+1,180-0139,N/A,N/A,90,YES,N/A,N/A,N/A,N/A,N/A,N/AMEC_STANDOFF_PTH_600C_300P
MEC3MEC_STANDOFF_SMD-NUT_M2X4X2.8+1,180-0139,N/A,N/A,90,YES,N/A,N/A,N/A,N/A,N/A,N/AMEC_STANDOFF_PTH_600C_300P
MEC4MEC_STANDOFF_SMD-STANDOFF_M3_H3.2,180-0117,N/A,N/A,90,YES,N/A,N/A,N/A,N/A,N/A,N/AMEC_STANDOFF_PTH_650C_B530430P
MEC5MEC_STANDOFF_SMD-STANDOFF_M3_H3.2,180-0117,N/A,N/A,90,YES,N/A,N/A,N/A,N/A,N/A,N/AMEC_STANDOFF_PTH_650C_B530430P
MEC6MEC_STANDOFF_SMD-STANDOFF_M3_H3.2,180-0117,N/A,N/A,90,YES,N/A,N/A,N/A,N/A,N/A,N/AMEC_STANDOFF_PTH_650C_B530430P
MEC7MOUNTING_HOLE_X1-MEC_HOLE_PTH_800C_400PMEC_HOLE_PTH_800C_400P
MEC8MOUNTING_HOLE_X1-MEC_HOLE_PTH_800C_400PMEC_HOLE_PTH_800C_400P
MEC9MOUNTING_HOLE_X1-MEC_HOLE_PTH_700C_310PMEC_HOLE_PTH_700C_310P
MEC10MOUNTING_HOLE_X1-MEC_HOLE_PTH_800C_400PMEC_HOLE_PTH_800C_400P
MEC11MOUNTING_HOLE_X1-MEC_HOLE_PTH_800C_400PMEC_HOLE_PTH_800C_400P
MEC12MEC_STANDOFF_SMD-STANDOFF_M3_H3.2,180-0117,N/A,N/A,90,YES,N/A,N/A,N/A,N/A,N/A,N/AMEC_STANDOFF_PTH_650C_B530430P
MEC13MOUNTING_HOLE_X1-MEC_HOLE_PTH_800C_400PMEC_HOLE_PTH_800C_400P
MEC14MOUNTING_HOLE_X1-MEC_HOLE_PTH_700C_310PMEC_HOLE_PTH_700C_310P
MEC19MOUNTING_HOLE_X1-MEC_HOLE_PTH_800C_400PMEC_HOLE_PTH_800C_400P
MIC1MIC_DIGITAL_DFN08-MSM261DHP006,175-0082,DMICMICROPHONE_08_SMD_030X040
MIC2MIC_DIGITAL_DFN08-MSM261DHP006,175-0082,DMICMICROPHONE_08_SMD_030X040
MIC3MIC_DIGITAL_DFN08-MSM261DHP006,175-0082,DMICMICROPHONE_08_SMD_030X040
MIC4MIC_DIGITAL_DFN08-MSM261DHP006,175-0082,DMICMICROPHONE_08_SMD_030X040
Q1Q_FET_N_ENH_SOT363-LBSS260DW1T1G,160-5024,2OHM@4.5V,0.1A/3OHM@1.8V,0.01A,0.2A,60V,0.8A,20V,0.38W,1V,[]SC70_6
Q2Q_FET_N_ENH_LFPAK-SM4522NHKP,160-5009,2.65MOHM@10V/ 4.3MOHM@4.5V / [ ]@2.5V,74A,30V,92A,20V,2.08W,[ ],30NC@10V / 14NC@4.5V / []@2.5VMULTI_SMD_SOT669_LFPAK_B
Q3Q_FET_N_ENH_SOT363-LBSS260DW1T1G,160-5024,2OHM@4.5V,0.1A/3OHM@1.8V,0.01A,0.2A,60V,0.8A,20V,0.38W,1V,[]SC70_6
Q4Q_FET_N_ENH_SOT363-LBSS260DW1T1G,160-5024,2OHM@4.5V,0.1A/3OHM@1.8V,0.01A,0.2A,60V,0.8A,20V,0.38W,1V,[]SC70_6
Q5Q_FET_N_ENH_SOT363-LBSS260DW1T1G,160-5024,2OHM@4.5V,0.1A/3OHM@1.8V,0.01A,0.2A,60V,0.8A,20V,0.38W,1V,[]SC70_6
Q6Q_FET_N_ENH_SOT363-LBSS260DW1T1G,160-5024,2OHM@4.5V,0.1A/3OHM@1.8V,0.01A,0.2A,60V,0.8A,20V,0.38W,1V,[]SC70_6
Q7Q_FET_N_ENH_SOT363-LBSS260DW1T1G,160-5024,2OHM@4.5V,0.1A/3OHM@1.8V,0.01A,0.2A,60V,0.8A,20V,0.38W,1V,[]SC70_6
Q8Q_FET_N_ENH_SOT363-LBSS260DW1T1G,160-5024,2OHM@4.5V,0.1A/3OHM@1.8V,0.01A,0.2A,60V,0.8A,20V,0.38W,1V,[]SC70_6
Q9Q_FET_N_ENH_SOT363-LBSS260DW1T1G,160-5024,2OHM@4.5V,0.1A/3OHM@1.8V,0.01A,0.2A,60V,0.8A,20V,0.38W,1V,[]SC70_6
Q10Q_FET_P_ENH_DFN3X3-SM3453PAQA-TRG,160-5025,14MOHM@-4.5V/7.9MOHM@-10V,-32A,-30,-128A,25V,21W,-2.3V,75NC@-10VDFET_SMD_032X033
Q11Q_FET_P_ENH_DFN3X3-SM3453PAQA-TRG,160-5025,14MOHM@-4.5V/7.9MOHM@-10V,-32A,-30,-128A,25V,21W,-2.3V,75NC@-10VDFET_SMD_032X033
Q12Q_FET_P_ENH_DFN3X3-SM3453PAQA-TRG,160-5025,14MOHM@-4.5V/7.9MOHM@-10V,-32A,-30,-128A,25V,21W,-2.3V,75NC@-10VDFET_SMD_032X033
Q13Q_FET_N_ENH_SOT363-LBSS260DW1T1G,160-5024,2OHM@4.5V,0.1A/3OHM@1.8V,0.01A,0.2A,60V,0.8A,20V,0.38W,1V,[]SC70_6
Q14Q_FET_N_ENH_SOT363-LBSS260DW1T1G,160-5024,2OHM@4.5V,0.1A/3OHM@1.8V,0.01A,0.2A,60V,0.8A,20V,0.38W,1V,[]SC70_6
Q15Q_FET_N_ENH_SOT363-LBSS260DW1T1G,160-5024,2OHM@4.5V,0.1A/3OHM@1.8V,0.01A,0.2A,60V,0.8A,20V,0.38W,1V,[]SC70_6
Q16Q_FET_N_ENH_SOT363-LBSS260DW1T1G,160-5024,2OHM@4.5V,0.1A/3OHM@1.8V,0.01A,0.2A,60V,0.8A,20V,0.38W,1V,[]SC70_6
Q17Q_FET_N_ENH_SOT363-LBSS260DW1T1G,160-5024,2OHM@4.5V,0.1A/3OHM@1.8V,0.01A,0.2A,60V,0.8A,20V,0.38W,1V,[]SC70_6
Q18Q_FET_N_ENH_LFPAK-SM4377NSKP,160-5010,7MOHM@10V/ 9.6MOHM@4.5V / [ ]@2.5V,35A,30V,85A,20V,1.73W,[ ],20NC@10V / 10NC@4.5V / []@2.5VMULTI_SMD_SOT669_LFPAK_B
Q19Q_FET_N_ENH_LFPAK-SM4522NHKP,160-5009,2.65MOHM@10V/ 4.3MOHM@4.5V / [ ]@2.5V,74A,30V,92A,20V,2.08W,[ ],30NC@10V / 14NC@4.5V / []@2.5VMULTI_SMD_SOT669_LFPAK_B
Q20Q_FET_N_ENH_SOT363-LBSS260DW1T1G,160-5024,2OHM@4.5V,0.1A/3OHM@1.8V,0.01A,0.2A,60V,0.8A,20V,0.38W,1V,[]SC70_6
Q21Q_FET_N_ENH_SOT363-LBSS260DW1T1G,160-5024,2OHM@4.5V,0.1A/3OHM@1.8V,0.01A,0.2A,60V,0.8A,20V,0.38W,1V,[]SC70_6
Q22Q_FET_P_ENH_DFN3X3-SM3453PAQA-TRG,160-5025,14MOHM@-4.5V/7.9MOHM@-10V,-32A,-30,-128A,25V,21W,-2.3V,75NC@-10VDFET_SMD_032X033
Q23Q_FET_N_ENH_SOT363-LBSS260DW1T1G,160-5024,2OHM@4.5V,0.1A/3OHM@1.8V,0.01A,0.2A,60V,0.8A,20V,0.38W,1V,[]SC70_6
Q24Q_FET_N_ENH_SOT363-LBSS260DW1T1G,160-5024,2OHM@4.5V,0.1A/3OHM@1.8V,0.01A,0.2A,60V,0.8A,20V,0.38W,1V,[]SC70_6
Q25Q_FET_N_ENH_SOT363-LBSS260DW1T1G,160-5024,2OHM@4.5V,0.1A/3OHM@1.8V,0.01A,0.2A,60V,0.8A,20V,0.38W,1V,[]SC70_6
Q26Q_FET_N_ENH_SOT363-LBSS260DW1T1G,160-5024,2OHM@4.5V,0.1A/3OHM@1.8V,0.01A,0.2A,60V,0.8A,20V,0.38W,1V,[]SC70_6
Q27Q_FET_N_ENH_SOT363-LBSS260DW1T1G,160-5024,2OHM@4.5V,0.1A/3OHM@1.8V,0.01A,0.2A,60V,0.8A,20V,0.38W,1V,[]SC70_6
Q28Q_FET_N_ENH_SOT363-LBSS260DW1T1G,160-5024,2OHM@4.5V,0.1A/3OHM@1.8V,0.01A,0.2A,60V,0.8A,20V,0.38W,1V,[]SC70_6
Q36Q_NPN_SOT363-LMBT3904DW1T1G,160-3003,0.2V@IC=10MA,IB=1MA,0.2A,40V,[],[],0.15WSC70_6
RS5R_SENSE_4PIN_R_SENSE_4PIN-0.001OHM,100-1505,1%,1W,150PPMRES_04_SMD_015X032
S1SW_SPST_PB_SMD_4P-DTSL-61N-V-T/R,180-0113,[],[],0,YES,[],[],12V,50MASW_04_SMD_ST_1XONOFF_065X060
S2SW_SPST_PB_SMD_4P-DTSL-61N-V-T/R,180-0113,[],[],0,YES,[],[],12V,50MASW_04_SMD_ST_1XONOFF_065X060
S3SW_SPST_PB_SMD_4P-DTSL-61N-V-T/R,180-0113,[],[],0,YES,[],[],12V,50MASW_04_SMD_ST_1XONOFF_065X060
U1U_NAND_2IN_SC70-5-SGM7SZ00YC5G/TR,175-0101,IC_GATESC70_5
U2U_PWR_SW_UL_SOT23_5_DP-GS7615STDE-R,172-0042,SWITCH,2.5V..5.5V,2.5V..5.5V,0.95ASOT23_5
U3U_MCU_FT60E01_SOP8-FT60E011A-RB,175-0106,MCUXSOP08_P127_050X040
U4U_PWR_SW_UL_SOT23_5_DP-GS7615STDE-R,172-0042,SWITCH,2.5V..5.5V,2.5V..5.5V,0.95ASOT23_5
U5U_BUCK_FET_1PH_SOT23_6_A-0.6V,GS7316CST-R,172-0007,1%,BUCK,1PH,1MHZ,NONE,0.6V..4.4V,5.5V,3A,13.2WSOT23_6
U6U_BUCK_FET_1PH_QFN23_PIR-0.6V,GS9227ATQ-R,172-0062,1%,BUCK,1PH,600KHZ,NONE,2.25V..5.5V,26V,16A,3.546WQFN023Q_P050_0040_T028X011_T028X014
U7U_PWR_SW_UL_SOT23_5_DP-GS7615STDB-R,172-0005,SWITCH,2.5V..5.5V,2.5V..5.5V,0.72ASOT23_5
U8U_NAND_2IN_SC70-5-SGM7SZ00YC5G/TR,175-0101,IC_GATESC70_5
U9U_MEM_EMMC_FBGA153_V5_1-YMEC7B0TE1A2C3,175-0091,5NS,2.7V..3.6VBGA_0153_P050_115X130
U10U_USB_CP2102N_QFN24_QFN24-CP2102N-A02-GQFN24R,175-0004,USBQFN024Q_P050_0045_T028X028
U11U_I2C_EXP_TCA9539_QFN24-TPT29555A-QF8R,175-0113,IO_EXPQFN024Q_P050_0040_T026X026
U12U_SHNTREG_TL431_SOT23_C-2.5V,TPR431B-S3TR,172-0083,0.5%,LOWDROP OUT,1.5V@[ ],2.5V..36V,36V,80MA,0.2WSOT23
U13U_BUCK_FET_1PH_QFN23_PIR-0.6V,GS9227ATQ-R,172-0062,1%,BUCK,1PH,600KHZ,NONE,2.25V..5.5V,26V,16A,3.546WQFN023Q_P050_0040_T028X011_T028X014
U14U_PWR_SW_UL_SOT23_5_DP-GS7615STDE-R,172-0042,SWITCH,2.5V..5.5V,2.5V..5.5V,0.95ASOT23_5
U15U_PWR_SW_UL_SOT23_5_DP-GS7615STDE-R,172-0042,SWITCH,2.5V..5.5V,2.5V..5.5V,0.95ASOT23_5
U16U_LDO_TDFN10_NOVR-0.8V,GS7155NVTD-R,172-0044,2%,LOWDROP OUT,0.38V@3A,0.8V..5V,5.5V,3A,2WDFN10_P050_030X030_T024X017
U21U_HOTSWAP_MSOP10-SGM25701A,175-0078,HOTSWAP CONTROLLER ICXSOP10_P050_030X030
U30U_CODEC_ALC5672_QFN48-ALC5672-VB-CGT,175-0085,CODECQFN048Q_P040_0060_T045X045
U46U_BUCK_FET_1PH_QFN23_PIR-0.6V,GS9227ATQ-R,172-0062,1%,BUCK,1PH,600KHZ,NONE,2.25V..5.5V,26V,16A,3.546WQFN023Q_P050_0040_T028X011_T028X014
U51U_LDO_TDFN10_NOVR-0.8V,GS7155NVTD-R,172-0044,2%,LOWDROP OUT,0.38V@3A,0.8V..5V,5.5V,3A,2WDFN10_P050_030X030_T024X017
U52U_PWR_SW_UL_SOT23_5_DP-GS7615STDB-R,172-0005,SWITCH,2.5V..5.5V,2.5V..5.5V,0.72ASOT23_5
U54U_PWR_SW_UL_SOT23_5_DP-GS7615STDE-R,172-0042,SWITCH,2.5V..5.5V,2.5V..5.5V,0.95ASOT23_5
U55U_PWR_SW_UL_SOT23_5_DP-GS7615STDE-R,172-0042,SWITCH,2.5V..5.5V,2.5V..5.5V,0.95ASOT23_5
U60U_LDO_TDFN10_NOVR-0.8V,GS7155NVTD-R,172-0044,2%,LOWDROP OUT,0.38V@3A,0.8V..5V,5.5V,3A,2WDFN10_P050_030X030_T024X017
U79U_PWR_SW_UL_SOT23_5_DP-GS7615STDE-R,172-0042,SWITCH,2.5V..5.5V,2.5V..5.5V,0.95ASOT23_5
U80U_PWR_SW_UL_SOT23_5_DP-GS7615STDE-R,172-0042,SWITCH,2.5V..5.5V,2.5V..5.5V,0.95ASOT23_5
Y6OSC_4PIN_2520-24MHZ,SCO77A24.0000WTS,165-5018,25PPM,3PPM,25PPM,15PF,N/AXTAL_SMD_4_025X020
谢谢分享:):) 谢谢分享 谢谢分享 赞,6666666 :):):):):):):):):) 谢谢分享 谢谢分享
