ntpcb017 发表于 2025-12-2 10:47
米尔 全志T113 邮票孔底板PCB 和原理图文件
D1GENERALDIODE_DO-214AB_SMCJ15CASMCJ15CADO-214AB
D16TVSDIODE_DO-214AA_SMBJ6.0CASMBJ6.0CADO-214AA
D36TVSDIODE_D0402_DNPDNPD0402
D37BAT54C_SOT-23_LBAT54CLT1GLBAT54CLT1GSOT-23
D38LED-19-217/R6C-AL1M2VY/3T_LED06RedLED0603
D39LED-19-217/BHC-ZL1M2RY/3T_LED06BlueLED0603
D40TVSDIODE_D0402_B72590D50H160B72590D50H160D0402
D41TVSDIODE_D0402_B72590D50H160B72590D50H160D0402
D42TVSDIODE_DO-214AA_SMBJ6.0CASMBJ6.0CADO-214AA
D43TVSDIODE_D0402_B72590D50H160B72590D50H160D0402
D44TVSDIODE_D0402_B72590D50H160B72590D50H160D0402
D45TVSDIODE_D0402_B72590D50H160B72590D50H160D0402
D46TVSDIODE_D0402_B72590D50H160B72590D50H160D0402
D47LED-204-10SURD/S530-A3-L_LED060GreenLED0603
D48TVSDIODE_D0402_B72590D50H160B72590D50H160D0402
D49TVSDIODE_D0402_B72590D50H160B72590D50H160D0402
F1FUSE_F1206_4A/72V4A/72VF1206
F2FUSE_F1206_0.75A0.75AF1206
F3FUSE_F1206_0.75A0.75AF1206
FB1FERRITEBEAD_FB0603_220R/1.5A220R/1.5AFB0603
FB2FERRITEBEAD_FB0603_220R/1.5A220R/1.5AFB0603
FB3FERRITEBEAD_FB0603_220R/1.5A220R/1.5AFB0603
FB4FERRITEBEAD_FB0603_220R/1.5A220R/1.5AFB0603
FB5FERRITEBEAD_FB0603_220R/1.5A220R/1.5AFB0603
FB6FERRITEBEAD_FB0603_220R/1.5A220R/1.5AFB0603
FB7FERRITEBEAD_FB0603_220R/1.5A220R/1.5AFB0603
FB8FERRITEBEAD_FB0603_220R/1.5A220R/1.5AFB0603
FB9FERRITEBEAD_FB0603_220R/1.5A220R/1.5AFB0603
FB10FERRITEBEAD_FB0603_220R/1.5A220R/1.5AFB0603
FB11FERRITEBEAD_FB0603_220R/1.5A220R/1.5AFB0603
FB12FERRITEBEAD_FB0603_220R/1.5A220R/1.5AFB0603
J1JPD441-N5215-7H_JPD441-N5215-7HJPD441-N5215-7HJPD441-N5215-7H
J22X20PIN_CONN2X20-2_54-DIP-MA_1212251220CNG1S115001CONN2X20-2_54-DIP-MA
J31X4PIN_CONN-B4B-PH-K-S_B4B-PH-KB4B-PH-K-SCONN-B4B-PH-K-S
J41X3PIN_CONN1X3-2_54-DIP_1125-111125-1103G0S116C001CONN1X3-2_54-DIP
J5WQ21801-B2180-7F_WQ21801-B2180-WQ21801-B2180-7FWQ21801-B2180-7F
J6FPC40_FPC40-0_5-H_FPC05040-1720FPC05040-17205FPC40-0_5-H
J72X15PIN_CONN2X15-2_00-SMD_1320113201215CNG4M80T01CONN2X15-2_00-SMD
J91X6PIN_CONN-B6B-PH-K-S_B6B-PH-KB6B-PH-K-SCONN-B6B-PH-K-S
J10UT12111-B1609-7F_UT12111-B1609-UT12111-B1609-7FUT12111-B1609-7F
J11UB11121-8FDE-4F_UB11121-8FDE-4FUB11121-8FDE-4FUB11121-8FDE-4F
J12S11-ZZ-0319_S11-ZZ-0319_S11-ZZ-S11-ZZ-0319S11-ZZ-0319
J15PCIEXP_CONN67P_KEY_B_CONN-21992APCI0105-P001ACONN-2199230-3
J16SIM-SI62C_SIM-SI62C-01200_SI62CSI62C-01200SIM-SI62C-01200
J17SIM-SI62C_SIM-SI62C-01200_SI62CSI62C-01200SIM-SI62C-01200
J201X2PIN_CONN1X2-1_25-DIP_5304702530470210CONN1X2-1_25-DIP
J21B6B-PH-K-S_CONN-B6B-PH-K-S_B6B-B6B-PH-K-SCONN-B6B-PH-K-S
J25UT12111-B1609-7F_UT12111-B1609-UT12111-B1609-7FUT12111-B1609-7F
J281X2PIN_1_AN3216_AN3216AN3216AN3216
JP21X3PIN_CONN1X3-2_54-DIP_1125-111125-1103G0S116C001CONN1X3-2_54-DIP
JP31X3PIN_CONN1X3-2_54-DIP_1125-111125-1103G0S116C001CONN1X3-2_54-DIP
L1COMMON_CHOKE_1_INDCM-ACM7060_10100MHz/80V/5AINDCM-ACM7060
L2INDUCTOR_L5_2X5_5_2.2UH/35MR/5.2.2uH/35mR/5.5AL5_2X5_5
L3INDUCTOR_L5_2X5_5_2.2UH/35MR/5.2.2uH/35mR/5.5AL5_2X5_5
L4INDUCTOR_L5_2X5_5_2.2UH/35MR/5.2.2uH/35mR/5.5AL5_2X5_5
L5COMMONCHOKE_INDCM-SDCW2012_90O90ohm/280mAINDCM-SDCW2012
L6INDUCTOR_L3X3_2.2UH2.2uHL3X3
L7INDUCTOR_L5_2X5_5_2.2UH/35MR/5.2.2uH/35mR/5.5AL5_2X5_5
L8COMMONCHOKE_INDCM-SDCW2012_90O90ohm/280mAINDCM-SDCW2012
M1TP_ID-BOARD_MARKPIONTMarkPiontID-BOARD
M2TP_ID-BOARD_MARKPIONTMarkPiontID-BOARD
M3TP_ID-BOARD_MARKPIONTMarkPiontID-BOARD
M4TP_ID-BOARD_MARKPIONTMarkPiontID-BOARD
M5TP_ID-BOARD_MARKPIONTMarkPiontID-BOARD
M6TP_ID-BOARD_MARKPIONTMarkPiontID-BOARD
MTG1MHOLE_3_HOLE3_2P-8_MHOLEMHOLEHOLE3_2P-8
MTG3MHOLE_3_HOLE3_2P-8_MHOLEMHOLEHOLE3_2P-8
MTG4MHOLE_3_HOLE3_2P-8_MHOLEMHOLEHOLE3_2P-8
MTG5MOUNTING_HOLE_1P_MH236-125T_IC_MH236-125TMH236-125T
MTG6MOUNTING_HOLE_1P_MH236-125T_IC_MH236-125TMH236-125T
MTG7MOUNTING_HOLE_1P_MH236-125T_IC_MH236-125TMH236-125T
MTG8MOUNTING_HOLE_1P_MH236-125T_IC_MH236-125TMH236-125T
MTG9MOUNTING_HOLE_1P_GNDPOINT256_ICMH236-125TGNDPOINT256
MTG10MOUNTING_HOLE_1P_GNDPOINT256_ICMH236-125TGNDPOINT256
Q1P-MOSFET_SOT-23_YJL2305AYJL2305ASOT-23
Q2N-MOSFET_SOT-23_LBSS139LT1GLBSS139LT1GSOT-23
Q3N-MOSFET_SOT-23_LBSS139LT1GLBSS139LT1GSOT-23
Q4N-MOSFET_SOT-23_LBSS139LT1GLBSS139LT1GSOT-23
Q5N-MOSFET_SOT-23_LBSS139LT1GLBSS139LT1GSOT-23
Q6N-MOSFET_SOT-23_LBSS139LT1GLBSS139LT1GSOT-23
S1SKRAAME010_SKRAAME010_SKRAAME01SKRAAME010SKRAAME010
S2SKRAAME010_SKRAAME010_SKRAAME01SKRAAME010SKRAAME010
SW1SS-12D10-L9-B_SW-SS-12D10-L9-B_SS-12D10-L9-BSW-SS-12D10-L9-B
TEMPLATE1TEMPLATE-A2_TEMPLATE-A2_TEMPLATTEMPLATE_A2TEMPLATE-A2
U1SM8103ADC_SOT23-6_SM8103ADCSM8103ADCSOT23-6
U2SM8103ADC_SOT23-6_SM8103ADCSM8103ADCSOT23-6
U3SM8103ADC_SOT23-6_SM8103ADCSM8103ADCSOT23-6
U4AT9555PW_TSSOP24_NCA9555NCA9555TSSOP24
U5CS8121SM_SOIC8_CS8121SCS8121SSOIC8
U6CS8121SM_SOIC8_CS8121SCS8121SSOIC8
U7PCMF2USB3S_WLCSP10_IC_PCMF2USB3PCMF2USB3SWLCSP10
U8PCMF3USB3S_WLCSP15_IC_PCMF3USB3PCMF3USB3S/CZWLCSP15
U9PCMF2USB3S_WLCSP10_IC_PCMF2USB3PCMF2USB3SWLCSP10
U10PCMF3USB3S_WLCSP15_IC_PCMF3USB3PCMF3USB3S/CZWLCSP15
U11PTN5150AHXMP_X2QFN12_IC_PTN5150PTN5150AHXMPX2QFN12
U12NX5P3090UKZ_WLCSP12_IC_NX5P3090NX5P3090UKZWLCSP12
U13AQFP48AT_LQFP48_FE1.1-AQFP48ATFE1.1-AQFP48ATLQFP48
U14YT8521SH_QFN48-0_4_YT8531SHYT8531SHQFN48-0_4
U15TPD4E1U06_SOT23-6_SR05-04ASR05-04ASOT23-6
U16TPD4E1U06_SOT23-6_SR05-04ASR05-04ASOT23-6
U17SM8103ADC_SOT23-6_SM8103ADCSM8103ADCSOT23-6
U18FG6188EUFX-05_MODILE-FG6188EUFXFG6131EUXX-00MODILE-FG6188EUFX-05
U19RX-8025T_SOP14_RX-8025T/UCRX-8025T/UCSOP14
U20CH342F_QFN24-0_5_CH342FCH342FQFN24-0_5
U21AM335X_QFN_4_YOUPK37X39_1_00-SMMYC-YT11S3YOUPK37X39_1_00-SMD-148
Y1CRYSTAL_4P_3225_IC_12MHZ12MHz3225
Y2CRYSTAL_4P_3225_25MHZ25MHz3225
yinxiangpeng 发表于 2025-12-2 11:07
有核心板吗,广地板设计没啥用
hltj123 发表于 2025-12-2 11:37
cy30404 发表于 2025-12-2 13:37
谢谢分享!:handshake
higowee 发表于 2025-12-2 15:00
谢谢分享
tellme 发表于 2025-12-2 21:28
:):)厉害
AIY 发表于 2025-12-2 22:30
好东西,谢谢分享
yfchen1003 发表于 2025-12-3 08:25
谢谢分享!
页: [1] 2 3 4 5 6
查看完整版本: 米尔 全志T113 邮票孔底板PCB 和原理图文件
