armclub 发表于 2026-6-15 10:23
MAX481CSA 做的一个485 板PCB原理图
eagle格式。可以用AD 打开。
   TERMBLK_3PINNOSILK485, POWERTERMBLK_3PIN_90_NOSILKTERMBLK_3PIN_90_NOSILK
REDBATT, RTCB, SDBLED-0603LED-0603
104C10603-CAP0603-CAP
YLWEPW, SDWLED-0603LED-0603
WIZ820IO_THINETH1WIZ820IO_THINWIZ820IO_THIN
FRAME1DUMMYDUMMY
MAX481CSAIC1SO08SO08
TEENSY_31_OUTER_THINJP1TEENSY-3.1_OUTER_THINTEENSY-3.1_OUTER_THIN
LED1, LED2LED-0603LED-0603
GRNPWRLED-0603LED-0603
MOSFET-N2N7002Q1, Q2, Q3SOT23-3SOT23-3
680R1, R2, R3, R4, R50603-RES0603-RES
1KR6, R11, R120603-RES0603-RES
510R7, R80603-RES0603-RES
10KR9, R100603-RES0603-RES
120R130603-RES0603-RES
270R140603-RES0603-RES
33KR150603-RES0603-RES
DPDT_DIP_SMDS1DPDT_DIP_SMDDPDT_DIP_SMD
DIP_SWITCH_SPDT_NS2SINGLE_DIP_SW_NEUTSINGLE_DIP_SW_NEUT
U$1WIZ820_SHLD_OVERLAYWIZ820_SHLD_OVERLAY
BATT_2POS_VERTU$2BATTCONN_20MM_VERTBATTCONN_20MM_VERT
U$4UPENN_SHIELD_3_SILKUPENN_SHIELD_3_SILK
R-78-E5.0VR2R-78-EXXR-78-EXX
beiniya 发表于 2026-6-15 11:12
看看,学习学习
junkyoung 发表于 2026-7-11 18:41
好好地学习。。。
查看完整版本: MAX481CSA 做的一个485 板PCB原理图
