挂32条内存条的大型服务器电脑主板PCB文件
AD格式。但是看起来是转换过来的。需要的下载。
DIODE-SS33,FAIRCHILD,SS33,YD00-00163-100,YES_YD1, D2, D10, D11, D12D-SD-2-7_2-FC-MBRS3405
TPD1E05U06DPYR-TI,TPD1E05U06DPYR,TPD1E05U06DPYR,YFE0-00032-000,YES_YD3, D4, D5, D6, D8, D21ESD-2-1_0-100X60X456
DIODE-BAT46W-7-F,DIODES,BAT46W-7-F,YD00-00235-000,YES_YD7, D9SD-2-3_15-265X155X1452
DIODE-SMDJ15A,LITTELFUSE,SMDJ15A,YFE0-00016-000,YES_YD13, D14, D15, PD1, PD2D-SD-2-6_6-LITTELFUSE-SMDJ5
DIODE-LMBR0530T1G,LRC,LMBR0530T1G,YD00-00264-000,YES_YD16SD-2-3_27-270X160X1351
DIODE-FSV530AF,ONSEMICONDUCTOR,FSV530AF,YD00-00225-000,YES_YD17, D18, D19, D20SMAFL-2-4_08-380X250X1104
74LVC1G07GW-NXP,74LVC1G07GW,74LVC1G07GW,YUB1-00031-100,YES_YEU1, U6, U24, U40, U41U-TSSOP-5-0_65-NXP-74LVC1G085
TPS62135RGXR-TI,TPS62135RGXR,YUI0-01146-000,YES_Y,TPS62135RGXREU2VQFN-11-0_5-200X300X1001
MP2183GTL_Z-MP2183GTL-Z,MPS,MP2183GTL-Z,YUI0-01102-000,YES_YEU3SOT583-8-0_5-210X120X601
PXE1110CDM_G003-PXE1110CDM-G003,INFINEON,PXE1110CDM-G003,YU00-00930-000,YES_YEU4, EU17U-QFN-40-0_4-INFINEON-PX812
TPS74801-TPS74801DRCR,TI,TPS74801DRCR,YU00-00067-000,YES_YEU5U-SON-10-0_5-TEXAS-TPS747011
SN74LVC07ARGYR-SN74LVC07ARGYR,TI,SN74LVC07ARGYR,YUI0-01107-100,YES_YEU6, EU7, U55QFN-14-0_5-350X350X1003
TDA21590_ES-TDA21590_ES,INFINEON,TDA21590_ES,YUI0-01144-000,YES_YEU8, PQFN-41-0_45-500X600X11030
TDA21535_ES-TDA21535_ES,INFINEON,TDA21535_ES,YUI0-01193-100,YES_YEU11, U45PQFN-27-0_5-400X500X1102
MPQ8633AGLEZ-MPQ8633AGLE-Z,MPS,MPQ8633AGLE-Z,YUI0-00204-000,YES_YEU13, EU14, EU32, EU33U-QFN-21-0_4-MPS-MP8733AGL4
BEAD-SUNLORD,UPZ2012U300-6R0TF,UPZ2012U300-6R0TF,YB00-00020-100,YES_YFB1SFB0805A1
BEAD-CHILISIN,PBY160808T-600Y-N,PBY160808T-600Y-N,YB00-00009-100,YES_YFB2SFB0603A1
BEAD-MURATA,BLM21PG331SN1,BLM21PG331SN1,YB00-00022-100,YES_YFB3SFB0805A1
BEAD-MURATA,BLM18AG601SN1D,BLM18AG601SN1D,YB00-00052-100,YES_YFB4SFB0603A1
BEAD-TDK,MMZ1608R301ATA00,MMZ1608R301ATA00,YB00-00087-000,YES_YFB5, FB6, FB13, FB14SFB0603A4
BEAD-TDK,MMZ1608F470BT,MMZ1608F470BT,YB00-00048-100,YES_YFB7SFB0603A1
BEAD-MURATA,BLM18PG121SN1D,BLM18PG121SN1D,YB00-00063-100,YES_YFB8, FB12SFB0603A2
BEAD-TAIYOYUDEN,BK2125HS601-T,BK2125HS601-T,YB00-00134-000,NO_NFB9, FB10, FB11SFB0805D3
SCON168_ME10168334B2A01-ME10168334B2A01,AMPHENOL,ME10168334B2A01,YAC6-00377-100,YES_YJ1, J2STR-168-0_6-7315X1600X5492
SCON56_ME10056334B1A01_SPLIT2-ME10056334B1A01,AMPHENOL,ME10056334B1A01,YAC6-00378-100,YES_YJ3SCON-56-0_6-2916X1600X543_81
SCON168_ME10168334B2A01_1-ME10168334B2A01,AMPHENOL,ME10168334B2A01,YAC6-00377-100,YES_YJ4STR-168-0_6-7315X1600X5491
CONN1X3_5P1_221A4_18E00_103-5P1.221A4-18E00.103,ARC,5P1.221A4-18E00.103,YAC0-00656-100,YES_YJ5, J6, J7, J8, J9, J10, J11, J12, J13, J14, J15, J16, J18,J21, J26, J66, J77, J78J-CON-3-2_54-ARC-5P1221A4118
CONN2X5_HEADER-ARC,5P1.223A4-10D00.205,5P1.223A4-10D00.205,YAC0-00876-100,YES_YJ17J-SCON-2X5-2_54-ARC-D002051
CON56X4_ME3005602311041-ME3005602311041,AMPHENOL,ME3005602311041,YAC6-00389-100,YES_YJ19, J20CON-PF-56X4-1_1-5000X4430X2025_A2
SCONN64_QSH03001FDAKTR-QSH-030-01-F-D-A-K-TR,SAMTEC,QSH-030-01-F-D-A-K-TR,YAC0-00983-000,YES_YJ22J-SCON-60-0_5-SAMTEC-QSH01
SCONN2X10_5011902017-5011902017,MOLEX,5011902017,YAC0-00955-100,YES_YJ23J-SCONN-2X10-MOLEX-50119021
SCON140_23276773_SPLIT2-2327677-3,TE,2327677-3,YAC6-00280-000,YES_YJ24, J25SCON-140-0_6-5717X615X925H2
SCON288_ADR50007P003C34-ADR50007-P003C34,ADR50007-P003C34,YAC2-00074-000,LOTES,YES_YJ29, J31, J33, J35, J38, J40, J42, J44, J45, J47, J49, J51,J54, J56, J58, J60SDIMM-288-0_85-14200X650X213016
SCON288_ADR50007P009C34-ADR50007-P009C34,ADR50007-P009C34,YAC2-00073-000,LOTES,YES_YJ30, J32, J34, J36, J37, J39, J41, J43, J46, J48, J50, J52,J53, J55, J57, J59SDIMM-288-0_85-14200X650X213016
CONN4_HF2704EM1_VC-FOXCONN,HF2704E-M1,YAC8-00080-100,HF2704E-M1,YES_YJ61, J62J-CON-4-2_54-FOXCONN-H2704_AC2
MEP1_EG10W19142A-EG-10W19-142A,HANWIT,EG-10W19-142A,YMEP-00332-000,YES_YJ65MEP-1-1100X900_PM1
SCON84_G64V32312HR_SPLIT2-G64V32312HR,AMPHENOL,G64V32312HR,YAC6-00391-000,YES_YJ67, J68, J69, J70, J71, J72, J73, J74SCON-84-0_6-3560X874X9258
CONN4_0532530470-0532530470,MOLEX,0532530470,YAC0-00901-000,YES_YJ75J-CON-4-2-MOLEX-5325304701
CON72_10124756_101LF_SPLIT2-10124756-101LF,AMPHENOL,10124756-101LF,YAC6-00384-000,YES_YJ76CON-PF-72-1_4-1590X2580X11651
CON1X4_10127397_34N1000LF-10127397-34N1000LF,AMPHENOL,10127397-34N1000LF,YAC7-00394-100,YES_YJ79, J80, J81PWR-1X4-5-2400X2240X9853
CONN1_10045588_101LF-10045588-101LF,FCI,10045588-101LF,YAG0-00028-000,YES_YJ82, J83J-CON-PRE-3-5_13-FCI-455882
INDUCTOR-CYNTEC,CMME042T-1R0MS,YL10-00258-000,1UH,6.5A,YES_YL1, L2SL-2-3_7-CYNTEC-CMLE042T2R2
INDUCTOR-COOPER,HCP0805-1R0-R,YL10-00059-000,1UH,14.5A,YES_YL3SL-2-5_4-COOPER-0805-1R51
INDUCTOR-ITG,AH3740A-100K,YL10-00363-000,100NH@500KHZ,82A,YES_YL4, L7, L8, L12, L13, L16, L27, L28, L29, L30, L32, L37, L38,L39, L40SL-2-7_2-ITG-AH3740A-70K15
INDUCTOR-ITG,AH3740A-120K,YL10-00368-000,120NH@500KHZ,67A,YES_YL5, L15SL-2-7_2-ITG-AH3740A-70K2
INDUCTOR-DELTA,HCB444-101IN,YL10-00408-000,100NH@100KHZ,17A,YES_YL6, L9, L10, L11, L35, L36, L41, L42SL-2-2_6-COOPER-LD065UH8
INDUCTOR-EATON,MPI4015V2-R33-R,YL10-00351-000,0.33UH@100KHZ,9.5A,YES_YL14, L17SL-2-3_3-VISHAY-L1D5UH2
INDUCTOR-ITG,AH3740A-70K,YL10-00362-000,70NH@500KHZ,115A,YES_YL18, L19, L20, L21, L22, L23, L24, L25, L26, PL1, PL2, PL3,PL4, PL5, PL6, PL7SL-2-7_2-ITG-AH3740A-70K16
INDUCTOR-COOPER,HCM0503-1R0-R,YL10-00161-000,1U,10.1A,YES_YL31, L33SL-2-4_25-COOPER-HCM0503-12
INDUCTOR-EATON,FP1010R3-R100-R,YL10-00381-000,100NH@100KHZ,77A,YES_YL34SL-2-7_2-ITG-AH3740A-70K1
LED-YELLOWGREEN,L-C292KGC-A,PARA,L-C292KGC-A,YDL0-00152-100,YES_YLED1, LED2SLED-2-1_1-100X50X552
LED-ORANGE,L-C292KFC-A,PARA,L-C292KFC-A,YDL0-00150-100,YES_YLED3, LED4SLED-2-1_1-100X50X552
LED-RED,BL-HE136D-AV-TRB,BRTLED,BL-HE136D-AV-TRB,YDL0-00009-100,YES_YLED5, LED6, LED7, LED8, LED9, LED10, LED11, LED12D-SLED-2-1_45-ROHM-SML3108
MHG_H4_7_7TP12X18-YA01-00290MH1, MH4, MH5, MH6, MH7, MH8, MH9, MH10MHG-H4_7-7TP12X188
MHG_H4_5_7TP12X18-YA01-00289MH2, MH3MHG-H4_5-7TP12X182
RES_0402-1.43K,YAGEO,RC0402FR-071K43L,YES_Y,YR10-00285-100,1%PR302, PR342, R778SMR0402A3
MAX9634TEUKT-MAX9634TEUK+T,MAXIM,MAX9634TEUK+T,YUA0-00027-100,YES_YPU1, PU2, PU3, PU4U-SOT23-5-0_95-MAX-64204
MP5922GRT_0025_Z-MP5922GRT-0025-Z,MPS,MP5922GRT-0025-Z,YUPW-00079-100,YES_YPU5TQFN-32-0_4-400X400X1001
NPN-LMBT3904LT1G,LRC,LMBT3904LT1G,YT10-00052-000,YES_YQ1, Q39, Q40, Q46SOT23-3-1_9-290X130X1114
T2N7002AKLMT-T2N7002AK,LM/T,TOSHIBA,T2N7002AK,LM/T,YT20-00178-100,YES_YQ2, Q3, Q9, Q10, Q11, Q14, Q16, Q17, Q42, Q43, Q44, Q45, Q47,Q48, Q49, Q62, Q63, Q64SOT23-3-1_9-290X130X11018
PMV20XNE-PMV20XNE,NEXPERIA,PMV20XNE,YT20-00218-000,YES_YQ4, Q6, Q7, Q29, Q30, Q34, Q35, Q37, Q38, Q41, Q61SOT23-3-1_9-290X130X110_A11
NTJD4001NT1G-NTJD4001NT1G,ONSEMICONDUCTOR,NTJD4001NT1G,YT20-00131-100,YES_YQ5, Q20, Q23, Q24, Q50, Q51, Q52, Q53, Q54, Q55, Q56, Q57,Q58, Q59, Q60SOT363-6-0_65-200X125X11015
FDMC8878-FDMC8878,ON,FDMC8878,YT20-00242-100,YES_YQ8, Q12, Q13, Q18WDFN-8-0_65-330X330X804
IRLML6401TRPBF-INFINEON,IRLML6401TRPBF,IRLML6401TRPBF,YT20-00217-100,YES_YQ15, Q19, Q21, Q22, Q25, Q26, Q27, Q28SOT23-3-1_9-292X130X112A8
LMBT3904DW1T1G-LMBT3904DW1T1G,LRC,LMBT3904DW1T1G,YT10-00026-100,YES_YQ31, Q32, Q33, Q36SOT363-6-0_65-200X125X1104
SW4_DHN02FTVTR-DHN-02F-T-V-T/R,DIPTRONICS,DHN-02F-T-V-T/R,YAH2-00126-500,YES_YS1, S2, S3, S4SSW-4-1_27-377X450X1734
NC7SZ66P5X-NC7SZ66P5X,FAIRCHILD,NC7SZ66P5X,YU00-00826-100,YES_YS5U-SC70-5-0_65-FATRCHILD-NC1
TEST_POINT-A03-00001TP1, TP2, TP3, TP4, TP5, TP6, TP7, TP8TP_26MIL8
AZIFS035_P001C-AZIFS035-P001C,LOTES,AZIFS035-P001C,YAHS-00105-100,YES_YU1, U2BGA-4677-0_81-8200X6450X9742
SN74CBTLV3126PWR-SN74CBTLV3126PWR,TI,SN74CBTLV3126PWR,YUI0-00213-100,YES_YU3, U4, U10, U14, U42, U73U-TSSOP-14-0_65-TEXAS-TPS511176
SN74LVC2G07DCKR-TI,SN74LVC2G07DCKR,SN74LVC2G07DCKR,YUI0-00295-100,YES_YU5, U36U-SOT363-6-0_65-PHILIP-74L2G142
MP5023GV_0000_Z-MP5023GV-0000-Z,MPS,MP5023GV-0000-Z,YUI0-00315-000,YES_YU7, U16U-QFN-24-0_5-MPS-MP5023GVZ2
74HC2G125DP_125-74HC2G125DP,125,NXP,74HC2G125DP,125,YUI0-00392-000,YES_YU8U-TSSOP-8-0_65-NXP-74LVC2G1
INA219AIDCNR-INA219AIDCNR,TI,INA219AIDCNR,YU00-00670-100,YES_YU9, U28, U39U-SOT23-8-0_65-MAXIM-MAX633
ADC128D818CIMTX_NOPB-ADC128D818CIMTX/NOPB,TI,ADC128D818CIMTX/NOPB,YUI0-00424-100,YES_YU11U-TSSOP-16-0_65-PERICOM-PI6C5571
EMC1413_A_AIZL_TR-EMC1413-A-AIZL-TR,MICROCHIP,EMC1413-A-AIZL-TR,YUS0-00024-100,YES_YU12, U72U-MSOP-10-0_5-MICROCHIP-TR2
GTL2014PW-GTL2014PW,NXP,GTL2014PW,YU00-00526-100,YES_YU13, U21, U25, U31, U32, U33U-TSSOP-14-0_65-TEXAS-TPS511176
PCA9545APWR-PCA9545APWR,TI,PCA9545APWR,YUI0-00585-100,YES_YU15, U43, U56, U64U-TSSOP-20-0_65-TI-SN74LVC4
MPQ8633BGLE_Z-MPQ8633BGLE-Z,MPS,MPQ8633BGLE-Z,YUI0-00200-000,YES_YU17U-QFN-21-0_4-MPS-MP8733AGL1
9SQ440NQQI8-9SQ440NQQI8,RENESAS,9SQ440NQQI8,YUI0-01232-100,YES_YU18QFN-100-0_5-800X800X651
M24256_BRMN6TP-M24256-BRMN6TP,ST,M24256-BRMN6TP,YUMD-00043-100,YES_YU19U-SO-8-1_27-ST-LM1931
9DML0451AKILFT-9DML0451AKILFT,IDT,9DML0451AKILFT,YUI0-00527-100,YES_YU20U-QFN-24-0_5-SILICONLABS-S1
74LVC07AD-74LVC07AD,NXP,74LVC07AD,YUB1-00010-100,YES_YU22, U27U-SO-14-1_27-PHILIPS-74LVC14AD2
10M50DAF484C8G-10M50DAF484C8G,INTEL,10M50DAF484C8G,YUCT-00002-100,YES_YU23FBGA-484-1-2300X2300X2001
SN74LVC244APWR-SN74LVC244APWR,TI,SN74LVC244APWR,YUB2-00013-100,YES_YU26, U37U-TSSOP-20-0_65-TI-SN74LVC2
TPS3700DDCR-TPS3700DDCR,TI,TPS3700DDCR,YUI0-00153-000,YES_YU29, U30U-SOT23-6-0_95-TI-TPS2553D2
9ZXL0853EKILFT-9ZXL0853EKILFT,RENESAS,9ZXL0853EKILFT,YUB1-00118-000,YES_YU34, U35, U68, U69VFQFPN-48-0_4-600X600X1004
XDPE152C4A_ES-XDPE152C4A_ES,INFINEON,YUI0-01143-000,XDPE152C4A_ES,YES_YU38, U44, U63, U65QFN-48-0_4-600X600X90_A4
SN74CB3Q3257DBQR-SN74CB3Q3257DBQR,TI,SN74CB3Q3257DBQR,YUI0-00529-100,YES_YU46, U74U-SSOP-16-0_635-BB-ADS7843E2
PCA9617ADPJ-PCA9617ADPJ,NXP,PCA9617ADPJ,YU00-00600-100,YES_YU47, U48U-TSSOP-8-0_65-NXP-PCA9511ADP2
MP5991GLUZ_ES-MP5991GLU-Z_ES,MPS,MP5991GLU-Z_ES,YUI0-01175-000,YES_YU57, U58, U59, U60, U61, U62LGA-32-0_5-500X500X1006
AD8130ARMZ_REEL7-AD8130ARMZ-REEL7,ADI,AD8130ARMZ-REEL7,YUA0-00046-000,YES_YU66, U67TSSOP-8-0_65-300X300X1102
PCA9555BS118-PCA9555BS,118,NXP,PCA9555BS,118,YUI0-00907-000,YES_YU70, U71HVQFN-24-0_5-400X400X1002
7M25070034-7M25070034,TXC,7M25070034,YX10-00109-000,YES_YY1SY-4-2_2-320X250X801
那个CPU的? niu!牛!!! 路过,学习下 这个画的真不错,学习了。 谢谢分享 挂32条内存条的大型服务器电脑主板PCB文件 我嘞个豆看着头大
