FE1.1s +CH482D+HYM8563TS 做的一个底板PCB和原理图 radxa-cm3-io
NamePart TypePCB DecalValue
BAT1BATTERY_1SMD-3P-1.25LI_3.7V
CN14A1SD_SOCKET_0TF-CKT01-009DTF_SD_SOCKET
CON1CN_0DIP40PIN_2D54MM2X20-F-2MM
D1DIODESOD_323B5819WS
D2DIODESOD_123SMF5.0CA
D39DIODE_BI_DIR_TRIG_0ESD0402_1XD5BTR04G02
D40DIODE_BI_DIR_TRIG_0ESD0402_1XD5BTR04G02
D41DIODE_BI_DIR_TRIG_0ESD0402_1XD5BTR04G02
D42DIODESOD_323B5819WS
D43DIODE_DOUBLESOT_23BAT54C
D44DIODESOD323NC
D45DIODEDO_214ACSS54
D46DIODEDO_214ACSS54
D47DIODE_ZENER1SOD_123SMFJ18A
D48DIODE_BI_DIR_TRIG_0ESD0402_1XD5BTR04G02
D49DIODE_BI_DIR_TRIG_0ESD0402_1XD5BTR04G02
D50DIODEDO214ACSS34
ED1DIODE_BI_DIR_TRIG_0ESD0402_1XD5BTR04G02
H107HOLEHOLE_R6_2D7MMHOLE
J1HDMI_AHDMIA19SHDMI_A
J2CON15_1FPC_15PIN_1MMFPC_15PIN_1MM
J3HR911130C_1RJ45_HRK1HR911130C
J4CON4A_0DIP4PIN-2_54MM-2X2CON4A
J5CON15_2FPC_15PIN_1MMFPC_15PIN_1MM
J6PCIE_4X_CON_1PCIEX1_36PIN_DIPPCIEX1_36PIN_DIP
J7SATA_DIP_1SMD_SATA_7P_50_180SATA30_7P_V_DIP
J8PHONEJACK_STEREO_SW_0PJ-327APHONEJACK
J9CON2DIP2PIN-2P54MMSPK
J10CON2DIP2PIN-2P54MMMIC
J11CON40_120455-040E-TOPCON40
J12CON6_1FPC6-0.5MM-2660HCON6
J16USB20_MICROMICRO_USB_NJ2USB20_micro
J17CON4_0USB_DUALDouble-USB-HOST
J18CON4_0DIP_10PIN-2_54MMDIP_10PIN-2_54MM
J20SATA_DIP_1SMD_SATA_7P_50_180SATA30_7P_V_DIP
J24CN_7DF40C_100DSconnector3
L1INDUCTORS_OF_FERRITEIND-50204.7uH
L2INDUCTORS_OF_FERRITEIND-4X4SWPA4020S4R7MT/2A
L3CHOKE_RFR0402FB120R
L4CHOKE_RFL0402FB120R
L5INDUCTOR_COMRP2_0405BCMF122P900H
L6INDUCTOR_COMRP2_0405BCMF122P900H
L7INDUCTOR_COMRP2_0405BCMF122P900H
L8INDUCTOR_COMRP2_0405BCMF122P900H
L10INDUCTOR_COMRP2_0405BCMF122P900H
L11INDUCTOR_COMRP2_0405BCMF122P900H
L12INDUCTORS_OF_FERRITEIND-5020SPM5020T-2R2M-LR
L13INDUCTORS_OF_FERRITEIND-50204.7uH
L14INDUCTORS_OF_FERRITEIND-4X4SWPA4020S4R7MT/2A
L15INDUCTOR_COMRP2_0405BCMF122P900H
LCD1HQ101WX001FH35C_31P_0_6SHW_LCDFH35C_31P_0_6SHW
LED3LEDLED0603LED_RED
LED4LEDLED0603LED_GREEN
M1MARKMARKMARK
M2MARKMARKMARK
M3MARKMARKMARK
M4MARKMARKMARK
M5MARKMARKMARK
P1TESTPOINT1TP_0R70TEST
P2TESTPOINT1TP_0R70TEST
P3TESTPOINT1TP_0R70TEST
P4TESTPOINT1TP_0R70TEST
P5TESTPOINT1TP_0R70TEST
P6TESTPOINT1TP_0R70TEST
Q1MOSFET_PSOT23NC/WPM2301
Q2MOSFET_PSOT23WPM2301
Q3NPNSOT23S8050
Q4MOSFET_PSOT_23WPM2015-3/TR
Q5NPN4SOT23S8050
Q6MOSFET_PSOT_23WPM2015-3/TR
Q7MOSFET_PSOT23WPM2015-3/TR
Q8NPNSOT23S8050
Q9N-MOSFETS0T-23WNM2021-3/TR
Q10P-MOSFETS0T-23NC/AO3401
Q11N-MOSFETS0T-23NC/WNM2021-3/TR
Q12MOSFET_NSOT23AO3416
Q13MOSFET_PSOT23WPM2015-3/TR
Q14NPNSOT23S8050
Q17P-MOSFETS0T-23WPM2341-3/TR
U1ESD_ESD5304DSON10_2R50X1R00X0R50ESD5344D
U2ESD_ESD5304DSON10_2R50X1R00X0R50ESD5344D
U3CON3_6SMD_1D25X2PIN_90SMD_1D25X2PIN_90
U5ESD_ESD5304DSON10_2R50X1R00X0R50ESD5344D
U6ESD_ESD5304DSON10_2R50X1R00X0R50ESD5344D
U7DCDC_SY8113SOT_23_6SY8113B
U8CH482XQFN20-2D5X4D5CH482D
U9SWITCH_SY6280SOT_23_5SY6280AAC
U10MP3202-QFN8_1DFN10P_3X3SY7203
U11LDO_PT5108SOT25PT5108E23E-18
U13OSC_4PIN_1CRY4_3R20X2R50X0R80NC/SOC_27MHz
U17FE1_1S_B_QFN24_2QFN24FE1.1s_QFN
U18SWITCH_SY6280SOT_23_5SY6280AAC
U19SWITCH_SY6280SOT_23_5SY6280AAC
U20SWITCH_SY6280SOT_23_5SY6280AAC
U22CH482XQFN20-2D5X4D5CH482D
U23CON_BATTERY-20MM_0BAT_CR1220CR1220-3V
U24RTC_HYM8563MSOP8HYM8563TS
U27DCDC_NB679QFN12_2R00X3R00X1R00NB679GD
U28CON3_2XIAO_4PIN_2D54DIP_2D54MM_4PIN_90
U29DCDC_SY8113SOT_23_6SY8113B/SM8103ADC
U30CON3_0DIP_14PIN-2_54MMDIP_2D54MM_14PIN_180
U31CON3_1DIP3_1X2P54DIP_2.54MM_3PIN_180
U32CON3_1DIP3_1X2P54DIP_2.54MM_3PIN_180
U33HETER_4DF40C-200DS-D4-OKconnector_1
U34MP3202-QFN8_1DFN10P_3X3SY7203
U35LDO_PT5108SOT25PT5108E23E-18
U36CON3_5DIP4_1X2P54DIP4_1X2P54
U37CON3_7DC-044ADC-044A
U90074LCD39P_03LCD39PIN-OKLCD39P_03
USB6USB30_TYPE_AUSB30-L1USB30_A
Y1CRYSTAL_4PCRY4_3R20X2R50X0R8012MHz_20PF
Y2CRYSTAL_2P_0CRY-321532.768KHz
学习一下。这个芯片挺经典的 感谢分享 感谢分享 学习学习 谢谢分享 :):):):) 主控是配什么? 谢谢分享 23333333333:lol
