sii9000 发表于 2026-7-22 23:28
STM32F415RGT6 +LSF0204 +TLV320AIC31XX+PCA9685 +LM3549+BQ25703A 做的GPA ROBOTICS PCB和原理图
      TPD4E05U06D1, D2, D3, D11, D12, D13, D14,D15, D16TI_PSON50P100X55-10Ntpd4e05u069
BAS40-5D4, D5DCC_SOT95P235X110-3Ndiode_dual_cc2
603D6, D7, D8LEDC1608X06Ndiode_led3
ZenerD9DCA_SOT95P235X110-3Ndiode_dual_ca_zener1
P6SMB12AD10SMA_DIOM5226X22Ndiode_tvs_unidirectional1
2506036007Y3FB1, FB5, FB11, FB12, FB13, FB14, FB15, FB16, FB17, FB18, FB19FBC1608X07Nferrite_bead11
Ferrite beadFB2, FB3, FB4, FB6, FB7, FB8, FB9, FB10FBC1005X06Nferrite_bead8
Ferrite beadFB21, FB25FBC1608X07Nferrite_bead2
SEAM-50-02.0-XX-08-X-AJ1SEAM-50-02.0-XX-08-X-ASEAM-50-02.0-XX-08-X-A1
1x6J2HDR_100MIL_1X6header_1x61
FTSH-105-01-XXX-DV-KJ3, J6_SR1, J6_SR2, J7_SR1, J7_SR2, J17, J18, J19FTSH-105-01-XXX-DV-KFTSH-105-01-XXX-DV-K8
ffc_1x15J4, J5fci_ffc_1mm_1x15ffc_1x152
61082-06xx0xxxxJ8fci_mezzanine_61082mezzanine_2x301
molex_usdJ9molex_usdmolex_usd1
ARJE-025J10abraconn_rj45_arje0025geth_wmagnetics1
6.85119E+11J11wurth_hdmi_minihdmi_mini_c1
43045-0600J12molex_microfit_2x6_90degmicrofit_2x31
PJ-082BHJ13CUI_DC_5.5MM_PJ028dc_jack_shielded1
usb3_aJ14usb3_ausb3_a1
usb3_micro_abJ15usb3_micro_abusb3_micro_ab1
1x4J16, J20molex_picoblade_1x4header_1x42
ASPI-0630LR-XXXM-T15L1, L2, L4BOURNS_SRN6045TA-XXXind3
ASPI-0630LR-XXXM-T15L3, L6YUDEN_NRS4018T-XXXMDGJind2
ASPI-0630LR-XXXM-T15L5VISHAY_IHLM2525CZERXXXM01ind1
M3MH1, MH2, MH3, MH4, MH7, MH8, MH9, MH10m3_pan_tight_roundmounting_hole8
M2MH5m2_pan_tight_roundmounting_hole1
NTR4003NQ1, Q2, Q3, Q4, Q5, Q6, Q7, Q8, Q9, Q10, Q12, Q13, Q14, Q15,Q25, Q26NCH_SOT95P237X110-3Nnch_mosfet16
FDMC6679AZQ11, Q16, Q19NCH_SON65P330X80_HS-9Npch_mosfet_diode3
CSD17551Q17, Q18, Q20, Q21NCH_SON65P330X80_HS-9Nnch_mosfet_diode4
DMG2301LQ22NCH_SOT95P237X110-3Npch_mosfet1
MMBT3904Q23NPN_SOT95P230X110-3Nnpn_bipolar1
PHPT610030PKQ24NXP_LFPAK56D127P610X105-8Npnp_bipolar_dual1
PWRS1SW_6MM_TACTbtn1
RSTS2SW_6MM_TACTbtn1
RECS3SW_6MM_TACTbtn1
SLPS4SW_6MM_TACTbtn1
AS01808AO-SC-WP-RSPK1pui_audio_speakerspeaker1
STM32F415RGT6U1STM-LQFP64_NSTM32F415RGT61
LSF0204U2, U4, U7, U9TI_TSOP65P640X120-14Nlsf02044
TCA9548AU3TI_TSOP65P640X120-24Ntca9548a1
AT24C02DU5AT_TSOP65P640X120-8Nat24c02d1
PCA9685U6_SR1, U6_SR2NXP_QFN65P600X600X100_HS-29Mpca96852
TPS2065CU8, U13, U14TI_SOT95P280X145-5Ntps2065c3
tps65261U10TI_QFN50P500X500X100_HS-33Mtps652611
tps56120xU11TI_SOT95P280X110-6Ntps56120x1
BQ25703AU12TI_QFN40P400X400X80_HS-33Mbq25703a1
TLV320AIC31XXU15TI_QFN50P500X500X100_HS-33Mtlv320aic31001
LM3549U16TI_QFN50P400X400X80_HS-25Mlm35491
MPU6000U17INVSENSE_QFN50P400X400X95_HS-25Minvsense_mpu60001
crystal_shieldedX1FA-238crystal_shielded1
吾乃 发表于 2026-7-22 23:55
看看:loveliness:
吾乃 发表于 2026-7-22 23:56
看看:loveliness:
junkyoung 发表于 2026-7-23 06:41
好好地学习。。。
杰克黄 发表于 2026-7-23 06:49
感谢分享
江波波 发表于 2026-7-23 07:17
谢谢分享
飞扬11 发表于 2026-7-23 08:04
感谢分享
ymq0225 发表于 2026-7-23 08:27
:loveliness:
单枪舞九州 发表于 2026-7-23 09:11
谢谢分享支持楼主
zqt32 发表于 2026-7-23 09:11
查看完整版本: STM32F415RGT6 +LSF0204 +TLV320AIC31XX+PCA9685 +LM3549+BQ25703A 做的GPA ROBOTICS PCB和原理图
