sii9000 发表于 2026-7-23 15:46
AMC1311 + IR2111 + 6N136+IRFP150N 做的Synchrouns_Buck_Converter_48V_12V 电路PCB和原理图
      330uf/100VC1, C2, C4, C5, C7, C8, C10,C11, C65, C66, C67, C68CAPACITOR 330UFCap 330uf12
C0603C3, C9, C12C0603C06033
330uf/100VC6C0603C06031
10ufC13, C17, C19, C23, C25, C29,C31, C35C1206Cap 12068
220nfC14, C18, C20, C24, C26, C30,C32, C36C1206Cap 12068
2.2ufC15, C16, C21, C22, C27, C28,C33, C34C1206Cap 12068
100nf/50VC37, C39, C43, C45, C49, C51,C55, C57, C61, C63, C69, C70, C71, C72, C78, C80C0603C060316
1uf/60vC38, C40, C44, C46, C50, C52,C56, C58Film Polyester Capacitor 5mmpitchFilm Polyester Capacitor8
330pf/50VC41, C47, C53, C59C1206Cap 12064
100pf/50VC42, C48, C54, C60C1206Cap 12064
330nF/50VC62, C79C1206Cap 12062
10uF25VC64, C81C1206Cap 12062
100nfC73C0603C06031
1uF/50VC74, C77C1206Cap 12062
10nF/50VC75, C76C1206Cap 12062
1N4148WSD1, D2, D3, D4, D5, D6, D7, D8SOD3231N4148WS8
RS1DD9DIOM4330X250NRS1D1
Pinheaders4 pinsJSAMTEC_TSW-104-24-G-SPinheaders 4 pins1
TerminalsJ1, J2, J3, J4, J5, J6Barrier Terminal Block 2 PinBarrier Terminal Block 2 Pin,Barrier Terminal Block 2 Pin_1_For_Power6
CustmizedPower InductorL1, L2, L3, L4, L5Power InductorPower Inductor5
10uHL6, L7inductor 0805Inductor 08052
LED1206LED1, LED2, LED3, LED4, LED5LED 1206LED 12065
IRFP150NQ1, Q2, Q3, Q4, Q5, Q6, Q7, Q8TO-247ACIRFP150N8
7805Q9, Q11TO-22078052
LD1117AV33Q10, Q12TO-220LD1117AV332
3K3R1R0603RES1
1KR2, R3, R4, R5R0603RES4
330R6, R12, R18, R24R0603RES4
4K7R7, R13, R19, R25R1206_4K7Res 4K7 .25W4
22R8, R9, R14, R15, R20, R21, R26,R27R1206Res 12068
10KR10, R11, R16, R17, R22, R23,R28, R29, R45, R46R1206Res 120610
300K/1%R30, R31, R33, R34, R36, R37,R39, R40R1206Res 12068
10K/1%R32, R35, R38, R41R1206Res 12064
3386P-1-101TR42TRIM_3386P-1-101T3386P-1-101T1
Res1206R43, R44R1206Res 12062
MomentaryTactile Tact Push Button Switch 4 PinSW1Momentary Tactile Tact PushButtonMomentary Tactile Tact PushButton Switch 4 Pin1
4.18117E+11SW?DIP_SW_2PDIP_SW_2P1
6N136U1, U4, U7, U108-Pin DIP 鈥?Land Pattern6N1364
IR2111U2, U5, U8, U118-Lead PDIPIR21114
B1515SU3, U6, U9, U12B1515SB1515S4
AMC1311U13, U14, U15, U16SOIC - 2.8 mm max heightAMC13114
LM2596HVSU17TO263LM2596HVS1
STM32F103C8T6U18QFP50P900X900X160-48NSTM32F103C8T61
AIY 发表于 2026-7-23 19:23
感谢。好资料
祈祷 发表于 2026-10-19 08:51
看看,学习学习
gfshao 发表于 2026-10-19 08:54
谢谢分享
查看完整版本: AMC1311 + IR2111 + 6N136+IRFP150N 做的Synchrouns_Buck_Converter_48V_12V 电路PCB和原理图
