sii9000 发表于 2026-7-24 11:14
MK60DN512VLQ10 +88E6071-xx-NNC2I000 做的控制板PCB和原理图 HY_MWYT_3S24_V20A.BRD
D1DIODE13_7_SOD-123_1N4148W-TP1N4148W-TPSOD-123
D2DIODE13_7_SOD-123_1N4148W-TP1N4148W-TPSOD-123
D3LED_4_LED0805_LED_GREEN/NILED_GREEN/NILED0805
D4LED_4_LED0805_LED_GREENLED_GREENLED0805
D5LED_4_LED0805_LED_GREENLED_GREENLED0805
D6LED_4_LED0805_LED_GREENLED_GREENLED0805
D7LED_4_LED0805_LED_GREEN/NILED_GREEN/NILED0805
D8LED_4_LED0805_LED_GREENLED_GREENLED0805
D9LED_4_LED0805_LED_YELLOW/NILED_YELLOW/NILED0805
D10LED_4_LED0805_LED_YELLOWLED_YELLOWLED0805
D11LED_4_LED0805_LED_YELLOWLED_YELLOWLED0805
D12LED_4_LED0805_LED_YELLOWLED_YELLOWLED0805
D13LED_4_LED0805_LED_YELLOW/NILED_YELLOW/NILED0805
D14LED_4_LED0805_LED_YELLOWLED_YELLOWLED0805
D15DIODE13_7_SOD-123_1N4148W-TP1N4148W-TPSOD-123
D16DIODE13_7_SOD-123_1N4148W-TP1N4148W-TPSOD-123
D17DIODE13_7_SOD-123_1N4148W-TP1N4148W-TPSOD-123
D18DIODE13_7_SOD-123_1N4148W-TP1N4148W-TPSOD-123
D21DIODE13_6_TO-227A_V10P10V10P10TO-227A
D22LED_4_LED0805_LED_GREENLED_GREENLED0805
F1FUSE_FUSE1812_MSMD200-16VmSMD200-16VFUSE1812
F2FUSE_FUSE1812_MSMD200-16VmSMD200-16VFUSE1812
FB1FB_L1812_FBMH4532HM132-T/NIFBMH4532HM132-T/NIL1812
GDT1BA301N_SMD4532_4532-091-LF4532-091-LFSMD4532
GDT2BA301N_SMD4532_4532-091-LF4532-091-LFSMD4532
GDT3BA301N_SMD4532_4532-091-LF4532-091-LFSMD4532
GDT4BA301N_SMD4532_4532-091-LF4532-091-LFSMD4532
GDT5BA301N_SMD4532_4532-091-LF4532-091-LFSMD4532
GDT6BA301N_SMD4532_4532-091-LF4532-091-LFSMD4532
GDT7BA301N_SMD4532_4532-091-LF4532-091-LFSMD4532
GDT8BA301N_SMD4532_4532-091-LF4532-091-LFSMD4532
J1CONNRCPT 4_HEADER4X1_2R54_HEADHEADER4X1_2R54/NIHEADER4X1_2R54
J2CON20_0_HEADER10X2_2R54_HEADER1HEADER10X2_2R54HEADER10X2_2R54
J3CONNRCPT 2_XHB-2AW_XHB-2AWXHB-2AWXHB-2AW
J4CONNRCPT 4_XHB-4AW_XHB-4AWXHB-4AWXHB-4AW
J5CONNRCPT 3_XHB-3AW_XHB-3AWXHB-3AWXHB-3AW
J6CONNRCPT 3_XHB-3AW_XHB-3AWXHB-3AWXHB-3AW
J7CONNRCPT 3_XHB-3AW_XHB-3AWXHB-3AWXHB-3AW
J8HDR_1_HEADER2X1_2R54_HEADER2X1_HEADER2X1_2R54HEADER2X1_2R54
J9CONNRCPT 6_XHB-6AW_XHB-6AWXHB-6AWXHB-6AW
J12CONNRCPT 6_XHB-6AW_XHB-6AWXHB-6AWXHB-6AW
J13CONNRCPT 6_XHB-6AW_XHB-6AWXHB-6AWXHB-6AW
J1443650-0801_43650-0800_43650-08043650-080043650-0800
J1543650-0801_43650-0800_43650-08043650-080043650-0800
J16CONNRCPT 6_XHB-6AW_XHB-6AWXHB-6AWXHB-6AW
J17CONNRCPT 4_XHB-4AW_XHB-4AWXHB-4AWXHB-4AW
J18CONNRCPT 4_XHB-4AW_XHB-4AWXHB-4AWXHB-4AW
J19CONNRCPT 4_XHB-4AW_XHB-4AWXHB-4AWXHB-4AW
L1IND_BEAD_0805_600OHM_1_L0805_BLBLM21PG600L0805
L2IND_BEAD_0805_600OHM_1_L0805_BLBLM21PG600L0805
L3IND_BEAD_0805_600OHM_1_L0805_BLBLM21PG600L0805
L6IND_BEAD_0805_600OHM_1_L0805_BLBLM21PG600L0805
L7IND_BEAD_0805_600OHM_1_L0805_BLBLM21PG600L0805
L8IND_BEAD_0805_600OHM_200MA_L080BLM21PG600L0805
L9IND_BEAD_0805_600OHM_200MA_L080BLM21PG600L0805
MH1HOLD_1_HOLD6R35X3R10_HOLD-M3/NIHold-M3/NIHOLD6R35X3R10
MH2HOLD_1_HOLD6R35X3R10_HOLD-M3/NIHold-M3/NIHOLD6R35X3R10
MH3HOLD_1_HOLD6R35X3R10_HOLD-M3/NIHold-M3/NIHOLD6R35X3R10
MH4HOLD_1_HOLD6R35X3R10_HOLD-M3/NIHold-M3/NIHOLD6R35X3R10
MH5HOLD_1_HOLD6R35X3R10_HOLD-M3/NIHold-M3/NIHOLD6R35X3R10
MH6HOLD_1_HOLD6R35X3R10_HOLD-M3/NIHold-M3/NIHOLD6R35X3R10
Q1SI4497DY-T1-GE3_SOIC8_IRF9321TRIRF9321TRPbFSOIC8
Q2MOS-P_0_SOT23-3_2N70022N7002SOT23-3
Q3SI4497DY-T1-GE3_SOIC8_IRF9321TRIRF9321TRPbFSOIC8
Q4SI4497DY-T1-GE3_SOIC8_IRF9321TRIRF9321TRPbFSOIC8
Q5MOS-P_0_SOT23-3_2N70022N7002SOT23-3
Q6MOS-P_0_SOT23-3_2N70022N7002SOT23-3
Q7MOS-P_0_SOT23_GSD_SI2347DS-T1-GSI2347DS-T1-GE3SOT23_GSD
Q8MOS-P_0_SOT23_GSD_SI2347DS-T1-GSI2347DS-T1-GE3SOT23_GSD
Q11MOS-P_0_SOT23-3_2N70022N7002SOT23-3
Q12SI4497DY-T1-GE3_SOIC8_IRF9321TRIRF9321TRPbFSOIC8
Q13MOS-P_0_SOT23-3_2N70022N7002SOT23-3
Q14MOS-P_0_SOT23-3_2N70022N7002SOT23-3
Q24MOS-P_0_SOT23-3_2N70022N7002SOT23-3
S1SWPUSHBUTTON_0_KEY_SMD_2_KEYKEYKEY_SMD_2
SW1SWDIP-4_1_DM-08-V_DM-08-VDM-08-VDM-08-V
SW2SWDIP-4_0_DM-04-V_DM-04-VDM-04-VDM-04-V
T1H1102_0_MAG-100M-1_HR661655EHR661655EMAG-100M-1
T2H1102_0_MAG-100M-1_HR661655EHR661655EMAG-100M-1
T3H1102_0_MAG-100M-1_HR661655EHR661655EMAG-100M-1
U1TXB0108PWR_1_TSSOP20_TXB0108PWRTXB0108PWRTSSOP20
U2K60_0_LQFP-144_MK60DN512VLQ10MK60DN512VLQ10LQFP-144
U3TXB0108PWR_1_TSSOP20_TXB0108PWRTXB0108PWRTSSOP20
U4DAC7311IDCKT_2_R-PDSO-G6_DAC731DAC7311IDCKTR-PDSO-G6
U5DAC7311IDCKT_2_R-PDSO-G6_DAC731DAC7311IDCKTR-PDSO-G6
U7CEIT_C5000_0_SOIC-8_208_W25Q128W25Q128FVSIGSOIC-8_208
U8MAX3485ESA_SOIC8_MAX3485ESAMAX3485ESASOIC8
U9MAX3485ESA_0_SOIC8_MAX3488EESAMAX3488EESASOIC8
U10MB85RC64PNF-G-JNERE1_SOIC8_MB85MB85RC64PNF-G-JNERE1SOIC8
U11TMP75AIDR_0_SOIC8_TMP75AIDRTMP75AIDRSOIC8
U12SP706T_1_SOIC8_SP706RENSP706RENSOIC8
U13SN74AUP1G32YZPR_1_SOT363_74LVC274LVC2G14GWSOT363
U14SN74LVC14APW_TSSOP14_SN74LVC14ASN74LVC14APWTSSOP14
U1588E6071-XX-NNC2I000_QFN-64_88E688E6071-xx-NNC2I000QFN-64
U16TPD4E1U06DBVR_SOT363_TPD4E1U06DTPD4E1U06DCKRSOT363
U17TPD4E1U06DBVR_SOT363_TPD4E1U06DTPD4E1U06DCKRSOT363
U18TPD4E1U06DBVR_SOT363_TPD4E1U06DTPD4E1U06DCKRSOT363
U19L6235D_1_SOIC24_L6235DL6235DSOIC24
U20SN74LVC14APW_TSSOP14_SN74LVC14ASN74LVC14APWTSSOP14
U21L6235D_1_SOIC24_L6235DL6235DSOIC24
U22SN74LVC14APW_TSSOP14_SN74LVC14ASN74LVC14APWTSSOP14
U2374AHC1G08_1_SOT23-5_INA195AIDBVINA195AIDBVTSOT23-5
U25PTN78020H_0_PTN78020H_HPSD12V5AHPSD12V5APTN78020H
U26PTH05000_1_PTH05000WAH_HPSD1233HPSD1233I2APTH05000WAH
U27SPX3819M5-L-1-2_SOT23-5_SPX3819SPX3819M5-L-3-3/TRSOT23-5
U28SPX3819M5-L-1-2_SOT23-5_SPX38_1SPX3819M5-L-5/TRSOT23-5
U45MAX3485ESA_SOIC8_MAX3485ESAMAX3485ESASOIC8
U47MAX809_0_SOT23_123_MAX809SN293DMAX809SN293D3T1GSOT23_123
U48PTH05000_1_PTH05000WAH_HPSD1233HPSD1233I2APTH05000WAH
U54AS5048A-HTSP_TSSOP14_AS5047DAS5047DTSSOP14
U55AS5048A-HTSP_TSSOP14_AS5047DAS5047DTSSOP14
U56TPD4E1U06DBVR_SOT363_TPD4E1U06DTPD4E1U06DCKRSOT363
U57TPD4E1U06DBVR_SOT363_TPD4E1U06DTPD4E1U06DCKRSOT363
X1TSX-3225_X-4P-3R2X2R5-SMD_X3225X322525MSB4SIX-4P-3R2X2R5-SMD
Mr_Harold 发表于 2026-7-24 15:25
学习学习
飞扬11 发表于 2026-7-25 09:02
感谢分享
竹青 发表于 2026-7-25 09:04
感谢分享
east_genie 发表于 2026-7-25 12:00
感谢分享
wwhfxz 发表于 2026-7-25 22:34
谢谢分享!
wangbin88 发表于 2026-7-26 07:18
感谢分享
吾乃 发表于 2026-7-26 12:27
:loveliness::loveliness:
单枪舞九州 发表于 2026-7-27 08:51
谢谢分享支持楼主
查看完整版本: MK60DN512VLQ10 +88E6071-xx-NNC2I000 做的控制板PCB和原理图 HY_MWYT_3S24_V20A.BRD
