sii9000 发表于 2026-7-24 11:42
飞思卡尔MK60DN512VLQ10开发板PCB和原理图
B1BEEP_HC12085P_HC12085P_BEEP_HC1BEEP_HC12085PHC12085P
BEAD1FB_L1812_FBMH4532HM132-TFBMH4532HM132-TL1812
D1LED_4_LED0805_LED_REDLED_REDLED0805
D2LED_4_LED0805_LED_REDLED_REDLED0805
D3LED_4_LED0805_LED_REDLED_REDLED0805
D4LED_4_LED0805_LED_REDLED_REDLED0805
D5DIODE13_0_SOD123_MBR0520_SOD123MBR0520_SOD123SOD123
D6DIODE13_0_SOD123_MBR0520_SOD123MBR0520_SOD123SOD123
D7LED_4_LED0805_LED_REDLED_REDLED0805
D8LED_4_LED0805_LED_GREENLED_GREENLED0805
D9DSCHOTTKY_SOD123_MBR0520_SOD12MBR0520_SOD123SOD123
D10DSCHOTTKY_SOD123_MBR0520_SOD12MBR0520_SOD123SOD123
D11LED_4_LED0805_LED_GREENLED_GREENLED0805
D12LED_4_LED0805_LED_GREENLED_GREENLED0805
D13DSCHOTTKY_SOD123_MBR0520_SOD12MBR0520_SOD123SOD123
J1CONNRCPT 32X2_HEADER32X2_CONNCONNRCPT 32x2HEADER32X2
J2CONNRCPT 17X2_1_TFTLCD_3R5_TFTTFTLCDTFTLCD_3R5
J3CON20_3_HEADER10X2_DIP2/10/2.54DIP2/10/2.54MMHEADER10X2
J4CONNRCPT 11X2_HEADER11X2_CONNCONNRCPT 11x2HEADER11X2
J5CONNRCPT 9X2_OV2640_OV7620OV7620OV2640
J6CONNRCPT 7X2_HEADER7X2_CONN RCCONNRCPT 7x2HEADER7X2
J7CONNRCPT 7X2_HEADER7X2_CONN RCCONNRCPT 7x2HEADER7X2
J8CONNRCPT 6X2_HEADER6X2_CONN RCCONNRCPT 6X2HEADER6X2
J9HR911105A_HR911105A_HR911105AHR911105AHR911105A
J10CONNRCPT 3_POWER3A_CONN RCPT 3CONNRCPT 3POWER3A
J11CONNPLUG 2_0_POWER2A_CANCANPOWER2A
J12CONNPLUG 2_0_POWER2A_RS485RS485POWER2A
L1IND_BEAD_0805_600OHM_200MA_LC08BEAD_BLM21PG600LC0805
L2IND_BEAD_0805_600OHM_200MA_LC08BEAD_BLM21PG600LC0805
L3IND_BEAD_0805_600OHM_200MA_LC_1BEAD_BLM18PG600_0805LC0805
MH1HOLD_1_HOLD250D134_HOLDHoldHOLD250D134
MH2HOLD_1_HOLD250D134_HOLDHoldHOLD250D134
MH3HOLD_1_HOLD250D134_HOLDHoldHOLD250D134
MH4HOLD_1_HOLD250D134_HOLDHoldHOLD250D134
MP1MARKPOINT_MARKPOINT_R3_MARKPOINMarkPointMARKPOINT_R3
MP2MARKPOINT_MARKPOINT_R3_MARKPOINMarkPointMARKPOINT_R3
Q1L14G1/TO_1_SOT23_123_S8050_SOT2S8050_SOT23_NPNSOT23_123
Q2L14G1/TO_1_SOT23_123_S8050_SOT2S8050_SOT23_NPNSOT23_123
RP1RESISTORVAR_0_VISHAY_RES_VAR_610KVISHAY_RES_VAR_64W
SW1SWITCH-SPST-4P_SW-6X6X6-L_KEY1KEY1SW-6X6X6-L
SW2SWITCH-SPST-4P_SW-6X6X6-L_RESETRESETSW-6X6X6-L
SW3SWITCH-SPST-4P_SW-6X6X6-L_KEY2KEY2SW-6X6X6-L
SW4SWITCH-SPST-4P_SW-6X6X6-L_KEY3KEY3SW-6X6X6-L
SW5SWITCH_3P_SWITCH_3P_SWITCH_3PSWITCH_3PSWITCH_3P
T1TOUCHPAD_TOUCHPAD_TOUCHPADTouchPadTOUCHPAD
T2TOUCHPAD_TOUCHPAD_TOUCHPADTouchPadTOUCHPAD
T3TOUCHPAD_TOUCHPAD_TOUCHPADTouchPadTOUCHPAD
T4TOUCHPAD_TOUCHPAD_TOUCHPADTouchPadTOUCHPAD
TP1TESTPOINT_0_TP-0R75_TESTPOINTTestPointTP-0R75
U1IS61LV25626_0_TSOP-44_IS62WV512IS62WV51216TSOP-44
U2K60_LQFP144_MK60DN512VLQ10MK60DN512VLQ10LQFP144
U3SP706T_0_SOIC8_SP706RENSP706RENSOIC8
U4BATTERY_CR1220_BATTERYBATTERYCR1220
U5KSZ8041NL_MLF-32_KSZ8041NLKSZ8041NLMLF-32
U6ADXL345_1_LGA-14_ADXL345ADXL345LGA-14
U7AT24C512_0_SOIC8_AT24C512AT24C512SOIC8
U8NRF24L01PACK_NRF24L01PACK_NRF24NRF24L01PACKNRF24L01PACK
U9LM2904QDR_SOIC8_LM2904QDRLM2904QDRSOIC8
U10W25Q64_0_SOIC16W_W25Q128FVFGW25Q128FVFGSOIC16W
U11TFCARD_1_TFCARD_TFCARDTFCARDTFCARD
U12TJA1050_SOIC8_TJA1050T/CMTJA1050T/CMSOIC8
U13MAX3485ESA_0_SOIC8_MAX3485ESAMAX3485ESASOIC8
U14CP2102_QFN-28_CP2102CP2102QFN-28
U15TPS7133_0_SOIC8_TPS76833QTPS76833QSOIC8
USB1USB-MICRO_USB-MICRO_USB-MICROUSB-MICROUSB-MICRO
USB2USB-MICRO_USB-MICRO_USB-MICROUSB-MICROUSB-MICRO
USB3USB-A_0_USB-A_USB-AUSB-AUSB-A
X1XTAL_5032_0_X-2P-3R2X1R5-SMD_XTXTAL_32768Hz_3215X-2P-3R2X1R5-SMD
Y1SMD_OSC_3_OSC7X5_SG7050CAN-50M-SG7050CAN-50M-TJGAOSC7X5
换成简单的 发表于 2026-7-24 14:17
233333333:)
bidinghong 发表于 2026-7-24 15:05
Mr_Harold 发表于 2026-7-24 15:25
这个可以
Mr_Jiyang 发表于 2026-7-24 18:29
感谢分享
November1227 发表于 2026-7-24 19:41
感谢分享
AIY 发表于 2026-7-24 20:54
谢谢分享
江波波 发表于 2026-7-25 07:30
谢谢分享
junkyoung 发表于 2026-7-25 07:34
好好地学习。。。
电路PCB爱好者 发表于 2026-7-25 07:39
感谢分享
页: [1] 2 3 4 5 6
查看完整版本: 飞思卡尔MK60DN512VLQ10开发板PCB和原理图
