sii9000 发表于 2026-8-2 16:23
AT32F403AVGT7+MS2375(AM26LS33) +PCA82C251 做的控制板PCB文件
   NamePart TypePCB DecalValue
D1SS56LDO-214AASS56L
D2GBJ3510A6KBJGBJ2510
D3YBSM4010YBS3YBSM4010
D4RND_SMBJ43ADO-214AASMBJ43A
D5B560CDO-214ABB560C-13-F
D6SS56LDO-214AASS56L
D7SS56LDO-214AASS56L
D8RND_SMBJ43ADO-214AASMBJ13A
D9LEDSMDLEDSMD15-21SYGC/S530-E2/3T
D10LEDSMDLEDSMD15-21SYGC/S530-E2/3T
D11LEDSMDLEDSMD15-21SYGC/S530-E2/3T
D12LEDSMDLEDSMD15-21SYGC/S530-E2/3T
D13LEDSMDLEDSMD15-21SYGC/S530-E2/3T
D14LEDSMDLEDSMD15-21SYGC/S530-E2/3T
D15LEDSMDLEDSMD15-21SYGC/S530-E2/3T
D16LEDSMDLEDSMD15-21SYGC/S530-E2/3T
D17LEDSMDLEDSMD15-21SYGC/S530-E2/3T
D18LEDSMDLEDSMD15-21SYGC/S530-E2/3T
D19LEDSMDLEDSMD15-21SYGC/S530-E2/3T
D20LEDSMDLEDSMD15-21SYGC/S530-E2/3T
D21LEDSMDLEDSMD15-21SURC/S530-A3/3T
D22LEDSMDLEDSMD15-21UYC/S530-A2/3T
D23ES2BDO-214AAES3DB
D24LEDSMDLEDSMD15-21SURC/S530-A3/3T
D25ES2BDO-214AAES3DB
D26LEDSMDLEDSMD15-21SURC/S530-A3/3T
D27ES2BDO-214AAES3DB
D28LEDSMDLEDSMD15-21SURC/S530-A3/3T
D29ES2BDO-214AAES3DB
D30LEDSMDLEDSMD15-21SURC/S530-A3/3T
D31ES2BDO-214AAES3DB
D32LEDSMDLEDSMD15-21SURC/S530-A3/3T
D33ES2BDO-214AAES3DB
D34LEDSMDLEDSMD15-21SURC/S530-A3/3T
D35ES2BDO-214AAES3DB
D36LEDSMDLEDSMD15-21SURC/S530-A3/3T
D37ES2BDO-214AAES3DB
D38LEDSMDLEDSMD15-21SURC/S530-A3/3T
D39BAV756SSOT363BAV756S
D40LEDSMDLEDSMD15-21SURC/S530-A3/3T
D41BZV55C15MLL34---
D42BAS16LT1SOT23BAS16LT1G
D43BAS16LT1SOT23BAS16LT1G
D44BAS16LT1SOT23BAS16LT1G
D45BAS16LT1SOT23BAS16LT1G
D46BAS16LT1SOT23BAS16LT1G
D47SS56LDO-214AASS56L
D48RND_SMBJ43ADO-214AASMBJ18A
F1FUSE_FL1FUSE_MINI_FL1XF-150
F2FUSE_2410FUSE-2410_OMNI-BLOK2410保险丝座+3A保险丝
J1MTL2S7772-6-00A-202TAG6.2_2A7921WVA-2P-0A-B
J2MTL2S7774-6-00A-404TAG6.3MM_4_NA7921WVA-4P-0A-B
J3HDR-P2.54-2X5HDR-P2.54-2X5
J4HDR-P2.54-1X4HDR-P2.54-1X4HDR2.54-1x4
J5MODULAR_4_4MODULAR_4_45301-4P4C
J6MODULAR_4_4MODULAR_4_45301-4P4C
J7MODULAR_4_4MODULAR_4_45301-4P4C
J8MODULAR_4_4MODULAR_4_45301-4P4C
J9MODULAR_4_4MODULAR_4_45301-4P4C
J10MODULAR_4_4MODULAR_4_45301-4P4C
J11MODULAR_4_4MODULAR_4_45301-4P4C
J12MODULAR_4_4MODULAR_4_45301-4P4C
J13MODULAR_4_4MODULAR_4_45301-4P4C
J14MODULAR_4_4MODULAR_4_45301-4P4C
J15MODULAR_4_4MODULAR_4_45301-4P4C
J16MODULAR_4_4MODULAR_4_45301-4P4C
J17MODULAR_4_4MODULAR_4_45301-4P4C
J18MTL2S7772-6-00A-202TAG6.2_2A7921WVA-2P-0A-B
J19MTL2S7772-6-00A-202TAG6.2_2A7921WVA-2P-0A-B
J20MTL2S7772-6-00A-202TAG6.2_2A7921WVA-2P-0A-B
J21MTL2S7772-6-00A-202TAG6.2_2A7921WVA-2P-0A-B
J22MTL2S7772-6-00A-202TAG6.2_2A7921WVA-2P-0A-B
J23MTL2S7772-6-00A-202TAG6.2_2A7921WVA-2P-0A-B
J24MTL2S7772-6-00A-202TAG6.2_2A7921WVA-2P-0A-B
J25MTL2S7772-6-00A-202TAG6.2_2A7921WVA-2P-0A-B
J26RJ45_2LEDAMPHENOL_RJ45_08X_LED_SHRJHSE-5381
J27RJ45_2LEDAMPHENOL_RJ45_08X_LED_SHRJHSE-5381
J28RJ45_2LEDAMPHENOL_RJ45_08X_LED_SHRJHSE-5381
J29MTL2S7772-6-00A-202TAG6.2_2A7921WVA-2P-0A-B
J31HDR-P2.54-2X10HDR-P2.54-2X10
L1SMS0865-101MTSMD_9.0X8.1MMSMS0865-680MT
L2SMS0865-101MTSMD_9.0X8.1MMSMS0865-680MT
L3IND-MOLDED8040MPIT8040-220M-LF
L4IND-MOLDED603600R@100Mhz/200mA
L5IND-MOLDED603600R@100Mhz/200mA
L6BEAD_ARRAYARC241BLA31AG121SN4D
L7BEAD_ARRAYARC241BLA31AG121SN4D
L8BEAD_ARRAYARC241BLA31AG121SN4D
L9BEAD_ARRAYARC241BLA31AG121SN4D
L10BEAD_ARRAYARC241BLA31AG121SN4D
L11BEAD_ARRAYARC241BLA31AG121SN4D
L12BEAD_ARRAYARC241BLA31AG121SN4D
L13BEAD1206BLM31PG500SN1L
L14BEAD1206BLM31PG500SN1L
L15BEAD1206BLM31PG500SN1L
L16BEAD1206BLM31PG500SN1L
L17BEAD1206BLM31PG500SN1L
L18BEAD1206BLM31PG500SN1L
L19BEAD1206BLM31PG500SN1L
L20BEAD1206BLM31PG500SN1L
L21BEAD1206BLM31PG500SN1L
L22BEAD1206BLM31PG500SN1L
L23CHOKES_DOUBLEIND0163-AB82793S0513N201
L24CHOKES_DOUBLEIND0163-AB82793S0513N201
Q1MOS-N-SOT223SOT223PHT8N06LT-VB
Q2MOS-N-SOT223SOT223PHT8N06LT-VB
Q3MOS-N-SOT223SOT223PHT8N06LT-VB
Q4MOS-N-SOT223SOT223PHT8N06LT-VB
Q5MOS-N-SOT223SOT223PHT8N06LT-VB
Q6MOS-N-SOT223SOT223PHT8N06LT-VB
Q7MOS-N-SOT223SOT223PHT8N06LT-VB
Q8MOS-N-SOT223SOT223PHT8N06LT-VB
Q9MOS-N-SOT223SOT223PHT8N06LT-VB
Q10MOS-N-SOT223SOT223PHT8N06LT-VB
Q11BC847ALT1SOT23BC847ALT1G
Q12MOSSMDTO-263NCE0157A2D
Q13MOSSMDTO-263NCE0157A2D
Q14BC847ALT1SOT23BC847ALT1G
Q15QM3003JSOT-89QM3003J-TP
U1XL2596HVSTO-263-5XL2596HVS-ADJE1
U2XL2596HVP-ADJE1SOIC-8-PADXL2596HVP-ADJE1
U3SGM61410SOT23-6SGM61410XN6G-JSM
U4LD1117-3.3SOT223LD1117-3.3
U5CJ7812TO-252CJ7812
U6AT32F407VGT7LQFP100-14X14MMAT32F403AVGT7
U7MCP9700ATSOT23MCP9700AT
U8AM26LS33SO16M1MS2375
U9AM26LS33SO16M1MS2375
U10AM26LS33SO16M1MS2375
U11MAX483EESASO8M1SN65176BDR
U12LM358BAIDRSO8M1LM358BAIDR
U13PCA82C251SO8M1PCA82C251
U14ISO7721DRSO8M1ISO7721DR
U15PCA82C251SO8M1PCA82C251
U16ISO7721DRSO8M1ISO7721DR
U17XJNG2103SO8M1IRS2007STRPBF
U18LM358BAIDRSO8M1LM358BAIDR
X1YSX531SL-8MHZSMD5032-4PYSX531SL-8MHz
Z13PESD1CANSOT23SM712
Z14PESD1CANSOT23PESD1CAN
Z15PESD1CANSOT23PESD1CAN
maogege-chen 发表于 2026-8-2 17:56
a6682100 发表于 2026-8-2 19:39
hufuju 发表于 2026-8-2 19:43
谢谢分享,AT32F403AVGT7+MS2375(AM26LS33) +PCA82C251 做的控制板PCB文件 。
liulinno3 发表于 2026-8-2 20:45
楼主好人,感谢楼主贡献【 AT】的资料,解决了我一直想找的内容。
bidezhi7777 发表于 2026-8-2 20:52
林枫1314 发表于 2026-8-2 20:56
牛!
飞扬11 发表于 2026-8-3 00:41
感谢分享
kanxue_nmg 发表于 2026-8-3 06:33
qixurulin01 发表于 2026-8-3 07:22
大佬,楼主的【 AT】内容很详实,我先mark一下,等会仔细消化。 好帖。
页: [1] 2 3 4 5 6
查看完整版本: AT32F403AVGT7+MS2375(AM26LS33) +PCA82C251 做的控制板PCB文件
