armclub 发表于 2026-8-5 12:43
STM32H743VIT6 开发板PCB文件和原理图和源码
PCB 原理图 源码一起打包
FQ-014BZ1BUZ FQ-013BZ_FQ-0141
DC_JackCN2CON DC-JackCON_DC-Jack1
353120560CN3CON 0353120560 (MOLEX)CON_03531205601
3220-10-0100-00CN4CON 3220-10-0100-00 (Hand_Solder)CON_IDC_3220-10-0100-001
MC-311SCN7CON USB-Type-C (16P)CON_USB-Type-C1
353120960CN8CON 0353120960 (MOLEX)CON_03531209601
SS34D1DIO DO-214AC (SMA)DIO_SS341
M7D2, D3DIO DO-214AC (SMA)DIO_M72
330uF/35V/10Øx10EC1CAP ALSMD 10.3MM H10.5MM LEADSPANMAX12MMCAP_EC 330uF/35V/10Øx101
100uF/35V/6.3Øx7.7EC2CAP ALSMD 6.6MM H7.7MMCAP_EC 100uF/35V/6.3Øx7.71
01550900MFH1FUSE 01550900M_SMD(Hand_Solder)FUSE_01550900M-SMD1
NTH-3MMH1, H2, H3, H4HOLE NTH-3MMHOLE_NTH-3MM4
NT-804AN-BWKEYPAD1KEYPAD_NT-804AN-BWKEYPAD_NT-804AN-BW1
Character_LCD(1602)LCD1LCD_CHARACTOR-1602LCD_Character-16021
BLUE/2012LED1, LED2, LED4, LED7, LED8, LED9LED MHT170RGBCT (BLUE)LED_MHT170RGBCT(BLUE)6
RED/2012LED3LED MHT170RGBCT (RED)LED_MHT170RGBCT(RED)1
RGB/2012LED5, LED6LED MHT170RGBCTLED_RGB_MHT170RGBCT2
MMBT3904Q1SOT 23-3 (DIODES INCORPORATED)BJT_NPN_MMBT39041
SBSB1, SB2, SB3, SB4, SB5, SB6SB (Solder-Bridge)SB_Solder-Bridge6
LTOP-ML38ATHSEN1SEN_IR-LTOP-ML38ATHSEN_IR_LTOP-ML38ATH1
YSS-1201S(2mm)_2PSW1SW YSS-1201S-2mmSW_YSS-1201S(2mm)_2P1
TACT_SWSW2, SW3, SW4SW K2-1102SP-C4SC-04SW_K2-1102SP-C4SC-04(2P)3
TFT-32ATFT1LCD_TFT-32ALCD_TFT-32A1
TP_HOLE(1MM)TP1, TP2TP_HOLE(1MM)TP_HOLE(1MM)2
AMS1117-3.3U1SOT 223-3 (DIODES INCORPORATED)IC_REG_AMS1117-3.31
LTM8074IY#PBFU2IC_BGA-25IC_REG_LTM8074IY#PBF1
STM32H743VIT6U3LQFP-100_14x14MM (ST)IC_MCU_STM32H743VIT61
AT24C16U4TSSOP-8_PW (TI)IC_EEPROM_AT24C161
MCP4725A1T-E/CHU5SOT-23-6 (TI DBV PACKAGE)IC_DAC_MCP4725A1T-E/CH1
ADS1100A0IDBVRU6SOT-23-6 (TI DBV PACKAGE)IC_ADC_ADS1100A0IDBVR1
LM75ADU7SOIC-8 150mil Wide (MICRO CHIP)IC_TEMP-SEN_LM75AD1
CP2102-GMRU8QFN-28 (5x5mm)IC_USB_CP21021
3362P-1-103LFVR1VR_3362P-1-103LFVR_3362P-1-103LF1
S2D12.000000B20F30T(12MHz)X1OSC SMD_2.5x2.0 (SCTF)OSC_S2D12.000000B20F30T(12MHz)1
S2D32.768KB20F30T(32.768kHz)X2OSC SMD_2.5x2.0 (SCTF)OSC_S2D32.768KB20F30T(32.768kHz)1
SMAJ24AZD1DIO DO-214AC (SMA)DIO_SMAJ24A1
xrn12 发表于 2026-8-5 12:45
qq1988 发表于 2026-8-5 16:33
666666666666666
o桃花岛主o 发表于 2026-8-5 16:48
bidezhi7777 发表于 2026-8-5 20:12
io357 发表于 2026-8-6 08:17
谢谢分享
hkw221 发表于 2026-8-6 08:42
好好地学习,天天都向上。
地球很危险 发表于 2026-8-6 09:15
谢谢分享
hans112 发表于 2026-8-6 10:19
林枫1314 发表于 2026-8-6 11:42
谢谢分享支持
查看完整版本: STM32H743VIT6 开发板PCB文件和原理图和源码
