EEG Measurement 脑电图测量(脑电波)测量板PCB和原理图
10uF/25V/1608C300, C308CAP 1608 (0603_INCH)CAP_10uF/25V/16082
100nF/50V/1608C301, C309, C310, C318, C319,C403, C404, C405, C406, C419, C420, C421, C430, C431, C432, C433, C434, C435,C436CAP 1608 (0603_INCH)CAP_100nF/50V/160819
10uF/50V/2012C302, C307, C311, C316CAP 2012 (0805_INCH)CAP_10uF/50V/20124
2.2uF/50V/2012C303, C306, C312, C315CAP 2012 (0805_INCH)CAP_2.2uF/50V/20124
100nF/50V/2012C304, C305, C313, C314, C411,C429CAP 2012 (0805_INCH)CAP_100nF/50V/20126
10uF/10V/1608C317, C320CAP 1608 (0603_INCH)CAP_10uF/10V/16082
470nF/50V/2012C400, C401, C410CAP 2012 (0805_INCH)CAP_470nF/50V/20123
1nF/50V/1608C402, C409, C414, C415, C418,C424CAP 1608 (0603_INCH)CAP_1nF/50V/16086
1uF/50V/1608C407, C408, C412, C413, C416,C417, C422, C423, C425, C426, C427, C428CAP 1608 (0603_INCH)CAP_1uF/50V/160812
SMW250-02CN300CON_SMW250-02CON_SMW250-021
DC_JackCN400, CN401, CN402CON DC-JackCON_DC-Jack3
PH_3PCN403CON PIN_HEADER-3PIN(2.54MM)CON_PIN_HEADER_SINGLE-3PIN(2.54MM)1
10144518-041802LFCN500, CN501CON_BergStak-Lite(0.8mm)_PLUG-40P(10144518-041802LF)CON_BergStak-Lite(0.8mm)_PLUG-40P(10144518-041802LF)2
100uF/35V/6.3Øx7.7EC300, EC301CAP ALSMD 6.6MM H7.7MMCAP_EC 100uF/35V/6.3Øx7.72
GREEN/2012LED300LED MHT170RGBCT (GREEN)LED_MHT170RGBCT(GREEN)1
10K/2012R300, R304, R432RES 2012 (0805_inch)RES_10K/2012/0.125W3
2K/2012R301RES 2012 (0805_inch)RES_2K/2012/0.125W1
150R/2012R302, R303RES 2012 (0805_inch)RES_150R/2012/0.125W2
100R/2012R305, R407, R408, R425, R443RES 2012 (0805_inch)RES_100R/2012/0.125W5
0R/2012R306, R307, R309, R311, R313,R400, R401, R402, R403, R404, R405, R411, R415, R422, R423, R424RES 2012 (0805_inch)RES_0R/2012/0.125W16
4.7K/2012R308RES 2012 (0805_inch)RES_4.7K/2012/0.125W1
220R/2012R310, R417, R426RES 2012 (0805_inch)RES_220R/2012/0.125W3
820R/2012R312RES 2012 (0805_inch)RES_820R/2012/0.125W1
1M/2012R406RES 2012 (0805_inch)RES_1M/2012/0.125W1
2M/2012R409, R410, R427RES 2012 (0805_inch)RES_2M/2012/0.125W3
1K/2012R412RES 2012 (0805_inch)RES_1K/2012/0.125W1
3.9M/1608R413, R429RES 1608 (0603_inch)RES_3.9M/1608/0.1W2
39.2K/1608R414, R430RES 1608 (0603_inch)RES_39.2K/1608/0.1W2
2.2K/2012R416, R428RES 2012 (0805_inch)RES_2.2K/2012/0.125W2
3.9K/2012R418, R419, R420, R421, R433,R434, R435, R436, R437, R438, R439, R440RES 2012 (0805_inch)RES_3.9K/2012/0.125W12
200K/1608R431RES 1608 (0603_inch)RES_200K/1608/0.1W1
20R/2012R441RES 2012 (0805_inch)RES_20R/2012/0.125W1
330R/2012R442, R444RES 2012 (0805_inch)RES_330R/2012/0.125W2
SBSB300, SB301, SB400, SB401,SB500SB (Solder-Bridge)SB_Solder-Bridge5
TP_HOLE(1MM)TP400, TP401, TP402, TP403,TP404, TP405, TP406, TP407, TP408, TP409, TP410, TP411, TP412, TP413, TP414,TP415, TP416TP_HOLE(1MM)TP_HOLE(1MM)17
TP_CIRCLETP500, TP501, TP502, TP503TP CircleTP_CIRCLE4
LM317AG-TN3-RU300, U302IC_TO-252-2(DPAK)IC_REG_LM317AG-TN3-R2
TLV171IDBVRU301, U400, U401, U402, U404,U405, U406, U408, U409, U410, U411, U412SOT-23-5 (TI DBV PACKAGE)IC_OPAMP_TLV171IDBVR12
AMS1117-3.3U303SOT 223-3 (DIODES INCORPORATED)IC_REG_AMS1117-3.31
INA826AIDRU403, U407IC_SOIC-8 (4.90x3.90mm)IC_INST-AMP_INA826AIDR2
BU79100G-LATRU413IC_SOT-23-6IC_ADC_BU79100G-LATR1
:lol:lol:lol:lol:lol:lol 666666666666 好好地学习,,, 谢谢分享 :$:$:$:$:$:$:$:$:$:$ 感谢老板分享
