sii9000 发表于 2026-8-10 17:55
SigmaStar SS524V100挂两个DDR4 + MS7200做的TVBOX PCB文件
D1D_A_0_DO_214AC_SS34SS34DO_214AC
D2DZ3_SD1710A_DZ3dz3SD1710A
D31N4148_2_SOD-123_1N41481N4148SOD-123
D5D_A_1_HSOD323A_D_AD_AHSOD323A
D6DZ_L_HSC0402B_DZ_Ldz_lHSC0402B
D7DZ_L_HSC0402B_DZ_Ldz_lHSC0402B
D8DZ_L_HSC0402B_DZ_Ldz_lHSC0402B
D9RCLAMP0524P_MLF10-050-0301L_RCLrclamp0524pMLF10-050-0301L
D10RCLAMP0524P_MLF10-050-0301L_RCLrclamp0524pMLF10-050-0301L
D11DZ_L_HSOD882_DZ_Ldz_lHSOD882
D20D3-2_SD0402K_D3-2d3-2SD0402K
D22RCLAMP0524P_0_MLF10-050-0301L_RRClamp0524PMLF10-050-0301L
D23RCLAMP0524P_0_MLF10-050-0301L_RRClamp0524PMLF10-050-0301L
D24DIODE-SCHOTTKY_1_DO_214AC_1N5811N5819DO_214AC
D25D_A_0_DO_214AC_SS34SS34DO_214AC
D51SMAJ5.0CA_DO_214AC_SMAJ6.8CASMAJ6.8CADO_214AC
D85SMAJ5.0CA_DO_214AC_SMAJ6.8CASMAJ6.8CADO_214AC
D102SMAJ5_0.0CA_DO_214AC_SMBJ15CASMBJ15CADO_214AC
D5008DZ_L_HSC0402B_DZ_Ldz_lHSC0402B
D5018DZ_L_HSC0402B_DZ_Ldz_lHSC0402B
D5019D_A_2_HSOD323A_D_AD_AHSOD323A
F1FUSE2_SF6127_FUSE2fuse2SF6127
FB1FB_L0603_90R-100MHZ90R-100MHzL0603
FB2FB_L0603_90R-100MHZ90R-100MHzL0603
ID1ID-BOARD_MARK_NCNCMARK
ID2ID-BOARD_MARK_NCNCMARK
ID3ID-BOARD_MARK_NCNCMARK
ID4ID-BOARD_MARK_NCNCMARK
J1PWC3_A_PWC0103-M-N_PWC3_Apwc3_aPWC0103-M-N
J4IDC20_A_2_DIP3_5-6P2_DIP3_5-6PDIP3_5-6PDIP3_5-6P2
J5HDMI_HDMIA19_HDMI_01A_HDMI-AHDMI-AHDMIA19_HDMI_01A
J6RCA3M2_1_PJ-325_RCA3M2rca3m2PJ-325
J7RCA3M2_1_PJ-325_RCA3M2rca3m2PJ-325
J8HDMI_HDMIA19_HDMI_01A_HDMI-AHDMI-AHDMIA19_HDMI_01A
J9J-F-RJ45-LED-H-DIP-LS_0_RJ45-LERJ45RJ45-LED
J10CON8_0_AG9605-SIM_CONN-2X4PIN-2CONN-2X4PIN-2.54MAG9605-SIM
J11IDC20_A_2_DIP3_5-6P2_DIP3_5-6PDIP3_5-6PDIP3_5-6P2
J37CON4_0_2_54X3P_CN4M_2R54_VCN4M_2R54_V2_54X3P
J55TOUCH_SCREEN_3_FPC8P_05MM_OLEDOLEDFPC8P_05MM
JP14-PIN/2MM_0_2_54X4P_4P-2_54MM4P-2_54MM2_54X4P
L1INDUCTORSOF FERRITE_L0520_4.7U4.7uHL0520
L2INDUCTORSOF FERRITE_L0420_1UH1uHL0420
L3INDUCTORSOF FERRITE_L0520_4.2U4.2uHL0520
L4INDUCTORSOF FERRITE_L0420_1.5U1.5uHL0420
L5INDUCTORSOF FERRITE_L0520_4.2U4.2uHL0520
L6INDUCTORSOF FERRITE_L0420_1.8U1.8uHL0420
L7L_B_SL4-1210-AAA_NINISL4-1210-AAA
L8L_B_SL4-1210-AAA_NINISL4-1210-AAA
L9L_B_SL4-1210-AAA_NINISL4-1210-AAA
L10INDUCTORSOF FERRITE_L0420_2.2U2.2uHL0420
L11FB_SL0805_120/100MHZ120/100MHzSL0805
L12FB_SL0805_120/100MHZ120/100MHzSL0805
LB1LB_SL0402_LBlbSL0402
LB2LB_SL0402_LBlbSL0402
LB3LB_SL0402_LBlbSL0402
LB4LB_SL0402_LBlbSL0402
LB5LB_SL0402_LBlbSL0402
LB6LB_SL0402_LBlbSL0402
LB7LB_SL0402_LBlbSL0402
LB8LB_SL0805_LBlbSL0805
LB9LB_SL0402_LBlbSL0402
LB10LB_SL0402_LBlbSL0402
LB11LB_SL0402_LBlbSL0402
LB12LB_SL0402_LBlbSL0402
LED1CON3_1_DIP-2P_LED-RLED-RDIP-2P
LED2CON3_1_DIP-2P_LED-GLED-GDIP-2P
LED3CON3_1_DIP-2P_LED-GLED-GDIP-2P
LED4CON3_1_DIP-2P_LED-OLED-ODIP-2P
M5HOLE_HOLE_**HOLE
M6HOLE_HOLE_**HOLE
M6005HOLE_MTH_C6MMD3P2MM_HOLEholeMTH_C6MMD3P2MM
M6006HOLE_MTH_C6MMD3P2MM_HOLEholeMTH_C6MMD3P2MM
Q2NPN_SOT_23_S8050S8050SOT_23
Q9BCENTQ_SOT_23_80508050SOT_23
Q2401MOSFETN_SOT_323_2SK30182SK3018SOT_323
Q2402MOSFETN_SOT_323_2SK30182SK3018SOT_323
Q2403MOSFETN_SOT_323_2SK30182SK3018SOT_323
Q2404MOSFETN_SOT_323_2SK30182SK3018SOT_323
Q2405MOSFETN_SOT_323_2SK30182SK3018SOT_323
Q4904NPN_SOT_23_S8050S8050SOT_23
REL1RELAY1_DIP-4P_W11-1A2STLE-DV12VW11-1A2STLE-DV12V-10ADIP-4P
RN4RN-4_2_0402X4_33R*4-5%33R*4-5%0402X4
RN5RN-4_2_0402X4_33R*4-5%33R*4-5%0402X4
RN6RN-4_2_0402X4_33R*4-5%33R*4-5%0402X4
RN7RN-4_2_0402X4_33R*4-5%33R*4-5%0402X4
S1PSW3_B_3_SW-2P_SWSWSW-2P
S2MSW4_SSW-PUSH_MSW4msw4SSW-PUSH
T1H5007_G24P02S_G24P02SG24P02SG24P02S
TP1TESTPOINT_TP_0R70_TESTPOINTtestpointTP_0R70
TP2TESTPOINT_TP_0R70_TESTPOINTtestpointTP_0R70
TP3TESTPOINT_TP_0R70_TESTPOINTtestpointTP_0R70
TP4TESTPOINT_TP_0R70_TESTPOINTtestpointTP_0R70
TP5TESTPOINT_TP_0R70_TESTPOINTtestpointTP_0R70
TP6TESTPOINT_TP_0R70_TESTPOINTtestpointTP_0R70
TP7TESTPOINT_TP_0R70_TESTPOINTtestpointTP_0R70
TP11TESTPOINT_TP_0R70_TESTPOINTtestpointTP_0R70
TP12TESTPOINT_TP_0R70_TESTPOINTtestpointTP_0R70
TP13TESTPOINT_TP_0R70_TESTPOINTtestpointTP_0R70
TP14TESTPOINT_TP_0R70_TESTPOINTtestpointTP_0R70
U1SS524V100_DDRC_0_BGA424-32-2323ss524v100_ddrcBGA424-32-2323
U2MP8759_0_TSOT23-8_MP2315MP2315TSOT23-8
U3MP8759_1_SOT23-5_SY8089AACSY8089AACSOT23-5
U4MP8759_0_TSOT23-8_MP2315MP2315TSOT23-8
U5MP8759_2_SOT23-5_SY8089AACSY8089AACSOT23-5
U6MP8759_0_TSOT23-8_MP2315MP2315TSOT23-8
U7AMS1117-ADJ_0_SOT_23_ME6211A25MME6211A25M3G_NSOT_23
U8MP8759_0_TSOT23-8_MP2315MP2315TSOT23-8
U9K4A4G165WD_BGA96-32-1609I_K4A4Gk4a4g165wdBGA96-32-1609I
U10K4A4G165WD_BGA96-32-1609I_K4A4Gk4a4g165wdBGA96-32-1609I
U11PWR1-2_SBAT2-13A_PWR1-2pwr1-2SBAT2-13A
U12SPI_NAND_FLASH_8PIN_WSON8-MX25LSPI_NAND_FLASH_8PINWSON8-MX25L12835ZN-AAA
U13N25Q512A11GSF40G_0_SOP16-50-300NC*SOP16-50-300A
U15IDC20_A_1_SOP-14_74LS0874LS08SOP-14
U16SN74LVC1G125Q-Q1_0_HSOT-SC70-DCsn74lvc1g125q-q1HSOT-SC70-DCK
U17ADM706SAR_0_SOP8-50-150_ADM706Sadm706sarSOP8-50-150
U18AMS1117-ADJ_1_SOT_23_ME6211A18MME6211A18M3G_NSOT_23
U19ES8388_MLF28A-045-0404L_ES8388es8388MLF28A-045-0404L
U20SY6287CDEC_MLF6-065-0202L_SY628sy6287cdecMLF6-065-0202L
U21SY6287CDEC_MLF6-065-0202L_SY628sy6287cdecMLF6-065-0202L
U22SY6287CDEC_MLF6-065-0202L_SY628sy6287cdecMLF6-065-0202L
U23MS7200_0_QFN76-9X9X04P_MS7200MS7200QFN76-9X9X04P
U24ETHERNET_RTL8211F_0_QFN40_5R00XRTL8211F-CGQFN40_5R00X5R00X0R90_T
U30SP485_SOP-8_SP485RENSP485RENSOP-8
U100GD32E113R8T6_LQFP64-10X10X05P_GGD32F303RBT6LQFP64-10X10X05P
U138HS0038B_IR-3P-2_54_HS0038BHS0038BIR-3P-2_54
U3501MAX3232E_SOP16-26-208-255_MAX32max3232eSOP16-26-208-255
U6708AMS1117-ADJ_0_SOT_23_TMI6030C-2TMI6030C-28SOT_23
U6709MP8759_4_SOT23-5_LN1178B120MRLN1178B120MRSOT23-5
USB1USB-4S4_0_USBA_USB-4S4usb-4s4USBA
USB2USB-4S4_1_USB-B_USB-4S4usb-4s4USB-B
USB3USB-4S4_0_USBA_USB-4S4usb-4s4USBA
X1X_B_HSX4-0302_24MHZ24MHZHSX4-0302
X2X_HSX2-0302_32.768KHZ32.768KHZHSX2-0302
X3CRYSTAL_1_CRY4_3R20X2R50X0R80_227MHzCRY4_3R20X2R50X0R80
Y1CRYSTAL_0_CRY4_3R20X2R50X0R80_225MHzCRY4_3R20X2R50X0R80
Y2XTAL_0_CRY4_3R20X2R50X0R80_8MHZ8MHZ30PPMCRY4_3R20X2R50X0R80
qazyxb 发表于 2026-8-10 18:58
谢谢分享
bidezhi7777 发表于 2026-8-10 20:13
790 发表于 2026-8-10 21:38
ymq0225 发表于 2026-8-10 23:48
:loveliness:
ymq0225 发表于 2026-8-10 23:55
:loveliness:
kanxue_nmg 发表于 2026-8-11 03:14
junkyoung 发表于 2026-8-11 06:40
好好地学习。。。
江波波 发表于 2026-8-11 07:16
学习学习
鼹鼠先生 发表于 2026-8-11 08:12
这个资料很不错,来学习学习,谢谢分享
页: [1] 2 3 4 5 6
查看完整版本: SigmaStar SS524V100挂两个DDR4 + MS7200做的TVBOX PCB文件
